Difficulty: ★★☆☆☆
A few things you need to know about backups:
- One copy does not constitute a good backup!
- Backing up is not about the backup itself, it’s all about the easy and fast restore!
- Backup files should be stored on an external disk that gets connected to the system only during a backup or restore cycle so that RansomWare cannot encrypt your backup when it stumbles into your system through wine ¹
- Alternatively, you can use a NAS directory that is protected by a password and that gets only mounted during a backup (or restore) cycle!
- A Cold System Backup can also protect your dual/triple boot system (backing up all OSes including other Linux systems and even Windows)!
- If you encrypt your backup in the backup program itself, use an algorithmic password depending on date and don’t forget the password!
Make a Cold System Backup
Download CloneZilla live
Save the ISO in
/opt/
Edit the
/etc/grub.d/40_custom
file and add at the end:menuentry "CloneZilla ISO" { # The string between " and " below is the actual name of the ISO file you just downloaded # and copied to the /opt directory (where optional software resides) and is the current # version as of the last edit to this [HowTo]. set ISOFile="/opt/clonezilla-live-2.7.0-10-amd64.iso" loopback loop ($root)$ISOFile linux (loop)/live/vmlinuz boot=live components config findiso=$ISOFile ip=frommedia toram=filesystem.squashfs union=overlay initrd (loop)/live/initrd.img }
Where
is the exact file name of the version you downloaded. (E.G. If you downloadedclonezilla-live-20201102-groovy-amd64.iso
, use that instead! -
If you want to show the GRUB menu, open these instructions
If you want to ensure GRUB shows a menu for 5 seconds so you don’t have to press Shift when booting, ensure the following lines are present:
GRUB_TIMEOUT=5 GRUB_TIMEOUT_STYLE=menu
If you want GRUB to remember the last choice you made from the menu, ensure these lines are present:
GRUB_DEFAULT=saved GRUB_SAVEDEFAULT=true
Execute
update-grub
Reboot and choose
CloneZilla ISO
from the grub menu -
Follow the CloneZilla Disk to image instructions
This way:
- You have CloneZilla installed in a fully bootable read-only environment on your local disk so you don’t have to go hunt around for your CloneZilla USB stick to boot from.
- The CloneZilla live environment gets loaded into RAM to ensure this backup solution doesn’t touch your existing Manjaro system (including other OSes in a multi-boot environment) as it will only read them…
If you ever need to do a Cold System Restore, it will be of a non-running system exactly as it was at the time of backup!
(Remember: A backup system is all about the restore, not about the backup!) - You should connect/mount an external drive (or NAS mountpoint) during the backup / restore process but have it disconnected at any other time so even if anyone would ever design a RansomWare attack for Manjaro, should not be available during the attack so your backup cannot be impacted.
- Ensure big unimportant files:
- are symlinked to a drive/partition that is not a part of the Cold System Backup so that you still back up your
/home
's important configuration files and data files using CloneZilla. (or split/
and/home
and use CloneZilla only for/
and a data backup program for/home
) - Exclude unimportant files from your data backup too (See next section).
- Using this methodology allows you to easily back up your entire dual/triple boot environment while backing up your Manjaro environment if you want to! (Yeah, that includes Windows!)
Make a data backup
On top of the Cold System Backup above you should still take a data backup every day / every couple of days because:
A Cold System Backup is only needed in case of your system breaking and is a one-stop shop: everything gets restored and you cannot restore individual files!
A Data backup can be made to only back up modified files, so is blindingly fast compared to a Cold System Backup that backs up everything all of the time whether it’s changed or not!
There are a lot of backup programs out there:
- TimeShift package and TimeShift Manual
- BackInTime Package and BackInTime Manual
But I like Borg Backup best because Borg Backup is a de-duplicating, compressing, encrypting backup program
E.G. Using Borg Backup, If you would have the exact same document stored in 2 directories, (E.G. a copy of a picture) it will only be backed up once (deduplication), and still get compressed (and optionally encrypted) afterwards, resulting in much smaller backups that are much faster to execute without impacting restore time!
Borg Backup Installation instructions
You need to have the AUR activated in pamac
Install Borg:
pamac install borg
Create your first backup:
If you do not want encryption, change the
--encryption=repokey
below to--encryption=none
(whererepokey
is the password to your Borg repository) -
In the below example we’ll back up the current user’s
(=home directory) to/media/backup
(If you want another mount point, just change that to whatever you like, just ensure it exists before youinit
your backup!)
Ensure that this mount point does not automount! (We do not want RansomWare to be able to encrypt our backups!)
You can change the local repository to a remote server accessible by
ssh
by just replacing/media/backup
withuser@hostname:backup
--stats
is optional as it just creates a statistics page so if you don’t like stats for everything, you can drop that.# Initialise repository borg init --encryption=repokey /media/backup/ # Change to home directory so we can use relative paths cd # create backup borg create --stats --progress --compression lzma,9 \ --exclude ".cache/" \ --exclude ".local/share/" \ --exclude ".config/borg/" \ --exclude "snap" \ --exclude "jimbo" \ --exclude "Examples" \ --exclude "Downloads" \ --exclude "Videos/*.avi" \ --exclude "Videos/*.mp4" \ --exclude "Videos/*.mkv" \ /media/backup/{user}::{now:%Y-%m-%d} . 2>> /temp/"$USER"-bck.log
The above will create a backup of all the important files in your home directory, store them under your user name in the repository with today’s date.
As it uses today’s date as the unique backup identifier, the maximum amount of backups you can take is one per day!
If you want to go up to the nanosecond
change this:
{now:%Y-%m-%d}
to that:{now:%Y-%m-%dT%H:%M:%S.%f}
See the section “Full backup” below on why we exclude directories instead of including them.
If you want to do an efficient data backup and you’re not using Borg Backup you need to know about:
Full Backup
The very first time you take a backup, you’ll have to take a backup of all your files (for a reasonable definition of all ) and in this tutorial we do that by taking one single user’s home directory, excluding the directories that are not critical to this example user!
(If you want to take a backup of all users on your computer, ignore ~
(=home directory) and use /home
instead (=all of the user’s home directories).
Why use excludes instead of includes?
Well, you can easily:
- Re-install snaps
- Re-download anything in Downloads
- Can always reconvert your DVD collection of Star Trek, Star Gate and Babylon 5
and even your audio CD collection again! (no data loss as you still have the DVDs/CD you legally bought anyway.)
- but it would be much more work to get the subtitles back that you have been painstakingly editing after having them OCRed and it would be impossible to get your Documents / Pictures / … back.
so that’s why in the Borg example above we excluded snap
, Downloads
, Videos/*.mkv
and if you would create an additional directory like “Public” in your home directory that you decide to publish using samba, it will be automatically included in your backup without having to do anything unless you also manually exclude it!
Incremental Backup
In the case of Borg, an incremental backup does not exist, as any backup (except your very first one) is always differential (see next section), but I’ve added it here for completeness for other backup programs.
An incremental backup only backs up the files that changed since the last backup so that’s blindingly fast ² so this is what most people do:
- First Full backup
- keep on making incremental backups
until the day arrives they need to do a restore and then they find out they need to restore all of their backups !!!
So if your backup program only allows Full and Incremental, dump it and take another backup program because backing up is all about the restore!
Differential Backup
The crucial difference between an incremental and differential backup is that a differential backup backs up all files since the last full backup .
So you only have to worry about the space or time your differential backup is taking: if it starts taking up too much space or taking too much time, just make another full backup and restart the differentials.
This is the default in Borg because it’s a de-duplicating backup system, so you should prune
your backups once in a blue moon.
Backup schedules
The most important question you have to ask yourself is:
How much data can I afford to lose???
A day? A week?? A month???
Well that is your x
: backup every x
With other backup programs, a daily differential and a weekly full backup (or a weekly differential and a monthly full, again depending on your personal x
) will be fine.
Whenever you need to restore, just restore your last full backup and then restore your last differential.
With Borg this matters less: just backup every x
days and just keep an eye on the total space it takes and do a:
borg prune --stats --keep-last 10 /media/backup/
every couple of months to keep the last 10 backups and a restore will still be a one-step process. You’ll see with Borg that the difference between keeping the last 10 and 20 is not that big, so I generally keep the last 30 backups (and I back up every couple of days or after I’ve made important changes or before I leave on travel! )
How to do a restore?
Remember to test your restore before you actually need it! This forum is full of people that did take backups but could never do a restore because they encrypted the backup and forgot their password, excluded the wrong directories, did not include their ~/.config
So if you do something:
stupid , like deleting a file and deleting it from the Wastebin : just restore that file from your data backup:
# Restores entire archive and list files while processing $ borg extract --stats --list /media/Backup/{user}::{now:%Y-%m-%d}
really stupid , like breaking Manjaro: Just reboot, choose CloneZilla Live in your grub environment, restore the entire system from your last Cold System Backup (and restore the latest data backup if needed).
extraordinarily stupid , like screw up grub itself:
- If you used the CloneZilla Tutorial instead of this one, you can skip this step:
- Go to another machine and download CloneZilla live from there, burn it to a USB stick,
- Go back to your sick computer, boot from your CloneZilla USB stick, and restore the entire system from there (and restore the latest data backup afterwards if needed)
And if you’re just unlucky
and get the following error when restoring::
Failed to create initrd in the restored os
just:
switch to TTY2 by pressing Ctrl+Alt+F2
execute this:
sudo mkinitcpio --preset $(awk -F . '{print "linux"$1$2}' <<< "$(uname -r)")
If you are using wine,
make sure you setup a separate user account with minimal privileges and use this user just for running your wine applications. That way any Windows ransomware or other malicious software can only access the contents of that user’s home directory, and none of the other users.
Never run wine as your main user (or, heaven forbid, root).
Note 1: Original link not available any more. In a nutshell: if you install wine, you’re opening up your system to Windows malware that uses the Windows API only…
Note 2: For most people anyway and yes I know about large databases which do not fall into this category.
