Trying to use the above instructions.
The font on my laptop is so small I can’t read the screen.
It also boots to a point and stops with a message about reading the keyboard layout.
below is my system info:
[demo@manjaro Downloads]$ inxi -Fza
Kernel: 6.0.2-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet pci=nocrs
acpi=force "acpi_osi=Windows 2015"
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.28 date: 07/14/2022
ID-1: BAT0 charge: 67.3 Wh (100.0%) condition: 67.3/67.3 Wh (100.0%)
volts: 13.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 178
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 987 high: 2300 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 2300 6: 800 7: 800 8: 800 bogomips: 36812
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: N/A alternate: nouveau non-free: 515.xx+ status: current (as of
2022-10) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 3b:00.0 chip-ID: 10de:1d13
class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 model: AU Optronics 0x30eb built: 2017 res: 3840x2160
hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 3840x2160
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.2.1
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Sound API: ALSA v: k6.0.2-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Local Storage: total: 931.51 GiB used: 245.87 GiB (26.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 41.9 C scheme: GPT
ID-1: / raw-size: 239 GiB size: 234.94 GiB (98.30%) used: 41.07 GiB (17.5%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 68.8 MiB
(71.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 325.57 GiB size: 319.4 GiB (98.10%) used: 204.74
GiB (64.1%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 57.0 C pch: 54.0 C mobo: N/A
Processes: 254 Uptime: 15m wakeups: 825 Memory: 15.26 GiB used: 8.11 GiB
(53.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1601 pm: pacman pkgs: 1596
libs: 414 tools: pamac,yay pm: flatpak pkgs: 5 pm: snap pkgs: 0 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
