[HowTo] Find system information
Difficulty: ★☆☆☆☆
Rather than providing the commercial reference of a computer or piece of hardware, it is usually better to directly ask the system to describe itself. On top of saving time to everyone, this also often provides more details, including something specific to the running system.
Below is a (not exhaustive) list of commands for retrieving system information.
:star: If you don’t know how to use those commands, or how to provide them to support, see: [HowTo] Use the terminal / TTY
:star: If you can’t access your system like usual, see: [HowTo] Reach a minimal system
:warning: Remember to use formatting when providing the result in the forum!
Global information
:star2: This is the main source of information to provide for support.
inxi -zv8
Specific information
The commands below provide detailed information for specific cases.
CPU
LANG=C lscpu
Drivers
mhwd -li
Kernels
mhwd-kernel -li
Manjaro Version
lsb_release -sirc
Package content
pacman -Ql <package_name>
Package owner
pacman -Qo <file_path_or_software_command>
Partitioning
lsblk -fa
LANG=C sudo parted -l
PCI Devices
lspci -k
RAM
free -h
Software locations
echo $PATH
which <software_command>
Sound Devices
aplay -L
Storage usage
LANG=C df -h
System Monitoring
htop
Can't install AMD or nvidia support, can't use discord either
Wifi options available on Windows, not Linux
TP-LINK TL-WN821N - Can’t connect to any network
Help a noob: fan speed control and pwmconfig woes
Firefox 99 hard crashes my computer
XFCE manjaro with no sound at all
System slow even after a restart, but not after a shutdown/power on
A whole drive volume is missing in manjaro (it's not listed dolphin)
Is it possible to undo an upgrade?
Cannot get to GUI
For me manjaro became unuseble
Gnome 46 stops switching to new connected audio device
Mouse stops, computer freezes
Graphical glitches after installing
Recent stable update broke HDMI audio on Steam Deck
Strange Graphics Corruption after Update
Broadcom 4321 [14e4:4328] rev03
Virtscreen error
Laptop display detected but not working
Black screen when logging in due to changing screen refresh rate
Lock screen not recognising password Other have same problem!
Black Bars at top and bottom of screen
One user account disappear after reboot
Screen freeze in videos
Install Brother MFC-L2820DW Printer Driver
Cannot update: invalid or corrupted database
Joystick and touchpad are randomly stop working
Inkscape only start as root
[BUG] gnome shell doesn't work
Microphone Volumes are terribly low
Mouse cursor doesn't move diagonally and stops over buttons
Code-OSS, Vs-Code does not appear on my screen
After updating kernel to 5.18.3, system fails to start
Steam games won't launch
System won’t launch
[Stable Update] 2024-05-13 - Kernels, Plasma 6, Gnome 46, LxQT 2.0, Nvidia, Pacman
Invalid or corrupted package (PGP signature) --- Why
Just Tried Installing and Did NOT Work!
Games crashing a few seconds in/instantly
PC hard frozen with no responce
Gry nie uruchamiają się
3/4 of the screen goes black for a few seconds when i run a pygame window
No connection with BCM4360 Wi-Fi card (TP-link T6E)
Vulkan Radeon performance issues
Thunderbird [unhandlable oom] Failed to mmap
Unable to enable G-SYNC on Viotek GFV24C monitor
No sound on Manjaro on asus laptop
Cannot connect to 5G WIFI!
Chromium libva error
Wi-Fi stopped working after updating drivers and rebooting system
Is Intel Z590 supported?
Bluetooth problem after upgrading to Uranos 23.0.0
Qt-based applications stopped working on Manjaro-Gnome
Wayland workspaces
In a Manjaro dual booted with Windows why is grub not displaying at startup?
No desktop fresh install
Code Oss is no longer opening... Failed to run "code-oss.desktop"
USB-C Display stopped working
2.4Ghz Wireless 6d gaming mouse does not work
Borked my system trying to add nvidia hdmi output (optimus hybrid stuff)
Make command not found
Manjaro is slow no matter what i am doing
Failed to start Terminate Plymouth Boot Screen
Wi-fi update for linux 63
Glitches in screen while scrolling or dragging
Freeze on Launch Install
WiFi disabled after disconnected power
How do i get my gpu fans spinning?
Network Issue since couple of days
Brother DS-640 scanner
Unable to get games working on Steam
External Display Not Working With NVIDIA/AMD Hybrid Drivers
[HowTo] Request support
Unable to log into Gnome desktop after system update
How to activate ray tracing support on Manjaro?
[HowTo] Provide System Information
My browser drops a bunch of frames while playing YouTube videos
Lost Right Click Bring Up Menu Context On External Mouse
Virt-Manager / Gnome-Boxes: No screen found
Razer blade 18 2023 sound doesn’t work
Keyboard isn't working in Wayland session
Help wanted installing Nvidia drivers!
Issues with OpenCL Detection on NVIDIA GeForce GTX 660 After Installing DaVinci Resolve via AUR
Steam - disk read error
Recent update seemed to have installed a separate instance of Manjaro
Minisforum reports 120 TiB but over 450 GB of space available
Can't run games on manjaro
Manjaro crash and dont start
Reinstall amdgpu (or switch to amdgpu-pro)
New user having trouble updating Manjaro GNOME
Random trash files appearing in /home directory, why and how to delete effectively?
Tablet-Mode on 2-in-1 Convertible
Cant use second monitor
External monitor resolution not compatible with laptop resolution
Repeated keys in activity overview
Evolution crashing after latest update
Beta Minecraft only shows white screen
Sometimes losing files when I move them to another drive
System does not shutdown after update
GeForce GTX 760 Intel HD3000 , manjaro live manjaro-kde-22.0-221224-linux61
OBS-Studio not working after last update
Error: config 'video-nvidia-470xx' conflicts with config(s): video-nvidia
Gnome 43 - Dark Theme
Questions about manjaro screen turning black and the impact of shutting down pressing power button
How to change NVIDIA drivers?
High cpu usage while browsing!
PANic ! im shaking, need help with last few steps in LIVE root context
Can I remove all partitions?
Some applications do not follow Gnome dark/light theme
Gaming FPS inconsistency
How to increase free disk space at root partition?
Kernel > linux60
Bluetooth connectivity issues
340 nvidia driver installation problem
Manjaro install with replace partition option deleted my home folder
The session is closed with any random movement
How to enable hibernation in manjaro-xfce?
Can't change display resolution
Chromium based browser glitching in latest update
Anbox in manjaro
OLED Brightness Issues
Graphical glitches on the right side of the screen
Booting stuck indefinitely on Plymouth loading screen
Apps are closing
Driver Nvidia 390 can't be installed with Geforce 820m
Xorg failed to create screen resources after enabling nvidia_drm.modeset
Since last updatre, system regularly freezes with network manager
NVIDIA Drivers - RTX 3060 -
Can’t adjust screen brightness
Video apps issues and sluggish performance
After using my login credentials manjaro doesn't boot to desktop
Nvidia Driver Update Problem
Broken Nvidia Hybrid mode after envycontrol installation
No me parece el grud de selección del sistema dual
2 GPUs, only one works
Vscode.db can't be downloaded
Missing Setting to set battery charge limit
Manjaro maintenance
Xfce4-panel update broke border radius
Manjaro OS keeps restarting after logging in
Borked dual boot Manjaro
Cannot turn on Bluetooth in GNOME anymore
When gaming in lutris, sudden black screen on both monitors requires restarting pc after a few minutes in game
Chromium startet nicht mehr (Vulkan Support)
My Manjaro system is lagging
Unable to install DKMS modules due to the absence of the Manjaro kernel modules tree
NVIDIA X Server Settings has missing options
RX Vega 64 only supports MPEG2
The ability to sort images by their resolution in dpi
Dark theme (style) not working properly after update
Pamac GUI is not working after enabling flatpak
Cannot suspend to RAM or hibernate
Pamac keeps crashing with every update
Issues with WiFi Speed on manjaro-kde (Realtek 8821CE & TP-Link TL-WN822N)
Keras tensorflow package version mismatch and pipenv gpu problem
Set to 100mb/s by default/auto
Boot time taking to long to boot
[Stable Update] 2023-11-06 - Kernels, Gnome 45.1, Plasma 5.27.9, Firefox, Thunderbird, Pipewire
Disk encryption won't work at first boot if user inputs a passphrase with non-ascii characters
No secrets were provided when connecting to WIFI/VPN
Error : Failed to mount Windows Volume
Black screen after switching gpu
Problems resizing windows
Blackscreen after update all packages and install pulseaudio
TexStudio crash since update
Sound card not found after upgrade
Video artifacts and reboot by the pc
Error en cambio de sesión y ejecución de programas
WIFI on Manjaro
Pamac throws an error during installation
Trouble booting later versions of Manjaro on PinePhone v1.2
[Stable Update] 2023-12-15 - Kernels, Blender, Thunderbird, Xorg-Server, Xwayland, Warzone2100
Systems hangs after update on Plymouth boot screen
Package build fails in GUI but succeeds on CLI
Login to X11 session broken after last major update
I can’t open my terminal
'Add / Remove software' app fails to load after update
Frozen system install
El wifi no esta funcionando
OBS Studio won't run
Bloqueo en apagado. KDE Plasma en Asus ROG
Helldivers Crashes and freezes entire computer. Has happened in other games
How to disable transparent application window top bars?
After stable update 2024-03-13 system fails to shutdown
Baby New Linux/Manjaro user has no sound
After wake up from sleep there is no password input or anything else just the lock image background and mouse
Libva error: /usr/lib/dri/i965_drv_video.so init failed
Manjaro hanging from boot
Extremly slow ethernet Intel I219-V
Speakers not working on Laptop HP Envy x360 2-in-1 Laptop 15-fe0xxx
Diablo II: Resurrected - Failed to initialize graphics device. Please ensure your PC meets the minimum system requirements and your drivers are up to date
GTA IV Complete Edition crashes when I try to open it
Black screen after update aur (yay)
Error while unzipping a file. "failed to make - directory"
"pamac-manager" received signal SIGSEGV, Segmentation fault
Rimworld does not load after 'Initialization'
Extremely slow boot times due to run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount
"data leaks possible via Spectre v2 BHB attacks" and some other things in red in journalctl -b
Vivaldi fails to start
Poor graphics performance in games
/boot/initramfs-linux.img not found after update
When closing the lid, the laptop does not turn off after switching from plasma 5.24 to 5.25 (now already 5.27)
Browsing very slow in comparison to old Macbook
Second monitor max refresh rate 60Hz Hybrid GPU
Unable to shutdown with AMD Radeon 7800XT
Manjaro stuck on dell logo after update
Problems with Nvidia card
I installed kernel version 5.17 but Huawei Matebook d15 sound card is not recognized
No audio devices found on newly installed manjaro
Trouble with DisplayLink Hub (Targus DOCK191)
"The current theme cannot be loaded due to the errors below"
Can't boot Manjaro after resetting BIOS
Unable to edit file in second drive
So is it actually possible to get VRR working with multiple monitors on Linux?
Headphones have no application output, only system audio
Help with Espeak
Need advice on how to lower CPU heat when gaming
Laptop battery draining faster
Virt-manager (KVM) black screens
Removing nvidia-390xx-utils breaks dependency 'nvidia-utils=390.157' required by nvidia-390xx-dkms
Install Manjaro using gnome-boxes
Mouse speed changed by itself(since 2016 till nowadays) on amd cpu and amd videocard
"sudo: /sbin/vboxconfig: command not found" Error while trying to start virtual machine
Installing pacman (6.1.0-3) breaks dependency
Need to reboot after start
Booting into blank screen after switching to unstable
Multiseat or multihead for multiple desktops?
Soundblaster Z se heavy bass
Installed manjaro yesterday and there is no sound
Power Management working incorrectly
How to start Manjaro KDE?
Manjaro can’t recognize any of my monitors
Speech Note and the Error: “translation engine initialization has failed”
File chooser/dialog (xdg-desktop-portal-gtk) single click
Black screen after monitor turns off
No text in window mode
Login loop (xfce)
Black screen after last release - KDE
Snapdragon x elite Lenovo
Issues with neo4j
Clean install latest manjaro KDE on redmibook 15 7840HS have black screen issue when shutting down system
Can't login, screen goes black on any keypress mouse and keyboard
Log in password changed itself
Adw-gtk-theme and adw-gtk3 are in conflict
The PC does not turn off via the start menu
Plasma 6.2 black screen when logging in for EndeavourOS
Black screen on boot and does not update the system due to 'adw-gtk3' 'adw-gtk-theme'
Dualboot with enabled secureboot
Session is randomly resetting
Enabling GeForce 720m
Firefox Chromium excessive heat due to extremely high CPU use
Davinci Resolve will not open (and I don't understand GPU drivers)
Bluetooth: hci0: Malformed MSFT vendor Event: 0x02
Suspend fails. System suspends and then immediately restarts
Unable to adjust brightness in Manjaro XFCE
Boot stuck at Failed to start D-Bus System Message Bus
Black boxes behind drop down menu in chromium based browsers (e.g. google-chrome)
System hangs up at least once a day
Manjaro clears the status bar
Some apps start with delay
Stuck on "enter passphrase for" screen
System freezes due to unknown reason
Anyone know how I can play android games in Manjaro Linux?
I accidentally locked my hard drive
Sudden freezes after Stable Update 2025.06.23
My headset connects and then immediately disconnects
Laptop screen suddenly had text, rebooted and TimeShift acted weird
I had wifi now i dont
Booted into emergency mode after update
Cant get past login but
Wifi not working, problem with driver?
Thinkbook Plus Gen3 - No sound
GNOME return to X11 from Wayland
Since major Update a few days ago: blackscreen after entering password
Fresh install stuck in boot
Most windows on the desktop constantly flashing after updates
Unable to chroot into system after failed update
Infinite folder loop with dolphin embedded terminal when using manjaro-zsh-config
I messed up my bootsystem
Sd cards and flash drives not showing in Thunar
Problem with Installing 24.0.2 Manjaro on VMware workstation 17.6.0
Installer won't load on Asus ZenBook Flip
Installed Realtek r8168 driver and can't connect to the network anymore
Manjaro graphics issue during video playback
Unknown devices in hardware detection tool
KDE connect never stays connected to android phone for very long
Cannot connect to my workplace VPN
Steam Client: Could not connect to Steam Network... error
Lenovo Legion 7 - NVidia drivers not working properly with external display
Dash to dock, workspaces and alt+tab
How Do I Change Default Action When Connecting an Additional Monitor?
Install replacing previous Linux installation: what partition to choose
Blocking all sites, allowing only specific
3 in 1 out HDMI - Nothing on my screen
Kde Plasma Black screen
Dell Inspiron 5720 works with kernel 5.13 only
Manjaro slow after doing dual boot
I added some more.
Thanks.
I’d rather keep commands about logs outside though, since those are more relevant to finding errors than the system itself.
Specific information about the CPU:
lscpu
Also: Under “Software locations” you might want to add something like:
which echo # or whatever other app or tool you want to find in stead of echo
Please add lspci -k - to list all PIC kernel modules. This is what provided me with information for a realtek WiFi, in order to find the driver for it.
Thanks for that great collection! Do you think some input device info like xinput list or libinput list-devices could enrich it?
df -h
Check avail. partition size.
btrfs device usage and btrfs device stats (unallocated space and errors).
neofetch also provides basic information
Which is rarely useful beyond theme, desktop, kernel, and C/GPU?.. which it may not even get right … so entirely inferior, and frustrating when people try to use it as if it is somehow a replacement for a more serious tool like inxi.
Please dont open a troubleshooting thread and include neofetch.
Too basic, most likely. Try not to suggest that.
This is much more detailed:
sudo inxi -v7azy
along with other variations of the command. There’s a guide for it somewhere.
Hmm, I didn’t notice the date of the last post, at first. Maybe I’m typing to ghosts.
This is every more detailed:
sudo inxi -v8azy
:wink:
Just a heads up from inxi creator here
We should be using
inxi -zv8
which will give the same detailed information and is shorter to type as the other options are redundant inxi options.
Another two commands that may e.g. help to find out which ports are USB 3, which are USB 2, and available bandwidths:
lsusb
lsusb -t
To find out which device name the USB storage got that was just attached, you may look up the console messages log right after attaching it to USB:
sudo dmesg
sudo dmesg | grep -ie "usb\|sd"
sudo dmesg | grep sd | tail
And this shows where actually the swap is (if any) and how much of it is in use:
swapon
Add -v to get more details, including usb device:vendor IDs.
I was likely too… 7azy… to increment.
