[HowTo] Find error logs
Difficulty: ★☆☆☆☆
The first step for troubleshooting an issue is to find an error log: a trace produced by an application when failing/crashing, and providing the first trail a user/developer can follow to fix it.
1. Reach a usable system
Obviously, it will be impossible to acquire those logs if you can’t have access to a usable system.
See: [HowTo] Reach a minimal system
2. Find the faulty application
If you don’t know which application failed – this is usually the case on a system or graphical failure – a good place to search the culprit is in the system journal.
Supposing the failure occurred in the previous boot:
journalctl --boot=-1 --priority=3 --catalog --no-pager
3. Find error traces
Depending on the faulty application, there are several means to obtain an error log:
- Launch the application from a terminal
Most applications will write messages and errors in the terminal or TTY they are launched from.
If you don’t know what command to use, one should be available in its launcher properties.
- Open user log files
Some applications, when launched by a user, trace logs in a dedicated file within ~/.local/share/.
- Open system log files
Some applications, when launched by the system or as a service, trace logs in a dedicate file within /var/log/.
- Search the system journal
Service traces are usually logged into the system journal.
journalctl --boot=-1 --unit=<service_name> --no-pager
- Search the kernel ring buffer
Low level failures can prevent journals from logging the associated errors. In that case, those logs may nonetheless be present in the ring buffer used by the kernel.
sudo dmesg
4. Share the logs with us
Now that you found the error message, you can use it to diagnose and fix your issue.
But if you can’t make heads and tails of it, you can ask for support in the forum.
:star: For tips on extracting and sharing results from the terminal, see: [HowTo] Use the terminal / TTY
:star2: You can retrieve and upload graphically some of those logs through the manjaro-log-helper utility.
:warning: When posting those logs in the forum, it is recommended to format them to make them more readable.
:warning: It is recommended, in order to allow as many people as possible to help you, to provide logs in English. If your system uses another language, and the application thus produces non-English messages, you can run it in English with:
LANG=C <command>
More details available in the following guides:
[HowTo] Troubleshoot anything
Manjaro KDE Stuck At Login Screen
Continual Issues with PC Freezing during usage
I have this freeze with every KDE distros
[HowTo] Find system information
Cannot get to GUI
Why does my system automatically reboots itself. How can I fix it?
Pamac authorization error
Problem in the update system
Migrating Manjaro to new drive (old drive is sata, new is nvme)
For me manjaro became unuseble
Gnome 46 stops switching to new connected audio device
Total system hang while playing via proton
Welcome and introduce yourself - 2022
Mouse stops, computer freezes
System freezes randomly while browsing
Recent stable update broke HDMI audio on Steam Deck
Strange Graphics Corruption after Update
Pamac shows there is an update, but does not update it
Black Bars at top and bottom of screen
Internal hard drive VERY slow read speed
After last update X wont start
Sometimes i cant login after boot
Install Brother MFC-L2820DW Printer Driver
DELL 14 Plus: GNOME Camera display playback mess up
Joystick and touchpad are randomly stop working
[Stable Update] 2022-03-14 - Kernels, KDE, LibreOffice, Kodi, Qt5, Mozilla, NetworkManager, Pipewire
No GUI after update
Fan runs on high as soon as boot up?
Cant start Manjaro
Black screen when playing Garry's Mod
Cant install NVIDIA drivers
Debug_shell not working
"Oh no" Error screen and no access to TTY
"If playback doesn't begin shortly, try restarting your device."
Invalid or corrupted package (PGP signature) --- Why
Keyboard Causes GUI Crash & Coredump
After kernel update 5.13 -> 5.15 system wont boot
Screen turn black and only mouse cursor
I can't launch any Feral games since the Feb 27th Manjaro update
One of cores at around 90% load
Corrupt package or non valid
Firefox frequently freezes, requiring browser restart
Usb ports , maybe drivers
High memory usage
Issues after replacing a Nvidia GTX 960 gpu with an AMD radeon 6600 gpu
Discord seems to freeze when in background
System does not work after latest update
Problemas con aplicaciones de PDF
Crash & reset - windows 10 & linux
System error after update
Gry nie uruchamiają się
No graphical display with an Nvidia card
No connection with BCM4360 Wi-Fi card (TP-link T6E)
Pulse Audio right pane missing in System Settings
Stuck in Emergency Mode after update
Steam + Left 4 Dead 2 - KDE Session Closes
Cannot connect to 5G WIFI!
Pamac freezes system while installing or removing packages
Pamac eats up my disk space while updating packages from the AUR
Disappearing Close (x) Button in Title Bar
No desktop fresh install
Blank screen after reboot
Lightdm failed to start again
Booting into Emergency Modus
I tried to boot from an old usb stick, now cannot boot Manjaro from my main HD
Experiencing Random Shutdowns
Manjaro is slow no matter what i am doing
No sound in my installation
Crashing to Black-Screen-Of-Indifference - Ryzen 3 System - Logs no help so far
WiFi disabled after disconnected power
Vlc 3.0.17.4 fails playing mpeg2 ts
Network Issue since couple of days
Video artifacts and reboot by the pc
[HowTo] Request support
My browser drops a bunch of frames while playing YouTube videos
Unable to boot to desktop after latest update
Virt-Manager / Gnome-Boxes: No screen found
Libre office no abre
Why does Manjaro freeze and Windows doesn't?
Issues with OpenCL Detection on NVIDIA GeForce GTX 660 After Installing DaVinci Resolve via AUR
Manjaro freezing at boot, even after reinstall
Reinstall amdgpu (or switch to amdgpu-pro)
Issue with monitor flashing wildly -- is there a log that might indicate the cause?
External monitor resolution not compatible with laptop resolution
Repeated keys in activity overview
Lightdm fails to start after Dec. 6 updates
Broken/Incomplete Gnome desktop
System does not shutdown after update
I can't lower my brightness on gnome
Questions about manjaro screen turning black and the impact of shutting down pressing power button
Some applications do not follow Gnome dark/light theme
Can I remove all partitions?
Update Manjaro and Material Shell
Bluetooth connectivity issues
Anbox in manjaro
VLC from Official Repositories Freezes System
Apps are closing
Borked dual boot Manjaro
Xfce4-panel update broke border radius
Sound card not found after upgrade
Regarding the inexplicable automatic restart problem
"sudo: /sbin/vboxconfig: command not found" Error while trying to start virtual machine
Suspend disabled, but not waking up after longer unused time
Disk encryption won't work at first boot if user inputs a passphrase with non-ascii characters
No secrets were provided when connecting to WIFI/VPN
Manjaro freezes when running backintime (rsync)
Blackscreen after update all packages and install pulseaudio
Error en cambio de sesión y ejecución de programas
WIFI on Manjaro
Cargas lentas en Nautilus
[Stable Update] 2023-12-15 - Kernels, Blender, Thunderbird, Xorg-Server, Xwayland, Warzone2100
Systems hangs after update on Plymouth boot screen
Package build fails in GUI but succeeds on CLI
Login to X11 session broken after last major update
HP laptop freezes at Grub or rEFind menu when a USB device is plugged into computer at boot
Bloqueo en apagado. KDE Plasma en Asus ROG
OBS Studio won't run
How to disable transparent application window top bars?
Baby New Linux/Manjaro user has no sound
After wake up from sleep there is no password input or anything else just the lock image background and mouse
Lost Right Click Bring Up Menu Context On External Mouse
Manjaro hanging from boot
Extremly slow ethernet Intel I219-V
Error while unzipping a file. "failed to make - directory"
Vivaldi fails to start
Poor graphics performance in games
/boot/initramfs-linux.img not found after update
When closing the lid, the laptop does not turn off after switching from plasma 5.24 to 5.25 (now already 5.27)
Second monitor max refresh rate 60Hz Hybrid GPU
"The current theme cannot be loaded due to the errors below"
After installation I can only see one partition and its a read only
How to troubleshoot why nftables.service doesn't work?
Headphones have no application output, only system audio
Need advice on how to lower CPU heat when gaming
Laptop battery draining faster
Virt-manager (KVM) black screens
Removing nvidia-390xx-utils breaks dependency 'nvidia-utils=390.157' required by nvidia-390xx-dkms
Enabling GeForce 720m
Install Manjaro using gnome-boxes
Mouse speed changed by itself(since 2016 till nowadays) on amd cpu and amd videocard
Installing pacman (6.1.0-3) breaks dependency
Need to reboot after start
Booting into blank screen after switching to unstable
Multiseat or multihead for multiple desktops?
Soundblaster Z se heavy bass
Installed manjaro yesterday and there is no sound
Power Management working incorrectly
How to start Manjaro KDE?
Manjaro can’t recognize any of my monitors
Speech Note and the Error: “translation engine initialization has failed”
File chooser/dialog (xdg-desktop-portal-gtk) single click
No text in window mode
Black screen after last release - KDE
Snapdragon x elite Lenovo
Adw-gtk-theme and adw-gtk3 are in conflict
Clean install latest manjaro KDE on redmibook 15 7840HS have black screen issue when shutting down system
Can't login, screen goes black on any keypress mouse and keyboard
Log in password changed itself
The PC does not turn off via the start menu
Plasma 6.2 black screen when logging in for EndeavourOS
Black screen on boot and does not update the system due to 'adw-gtk3' 'adw-gtk-theme'
Dualboot with enabled secureboot
Session is randomly resetting
Help with Espeak
Problem with Installing 24.0.2 Manjaro on VMware workstation 17.6.0
Davinci Resolve will not open (and I don't understand GPU drivers)
Bluetooth: hci0: Malformed MSFT vendor Event: 0x02
Boot stuck at Failed to start D-Bus System Message Bus
Black boxes behind drop down menu in chromium based browsers (e.g. google-chrome)
System hangs up at least once a day
System does not shutdown anymore
Manjaro crashing
Manjaro clears the status bar
Stuck on "enter passphrase for" screen
Black screen Post Update
Sudden freezes after Stable Update 2025.06.23
My headset connects and then immediately disconnects
Laptop screen suddenly had text, rebooted and TimeShift acted weird
I had wifi now i dont
Plasma-wayland freezing problem with 2nd monitor
Network connection causes large boot time
Booted into emergency mode after update
Manjaro Cinnamon boots into black screen
Cant get past login but
Since major Update a few days ago: blackscreen after entering password
Thinkbook Plus Gen3 - No sound
GNOME return to X11 from Wayland
Fresh install stuck in boot
Unable to chroot into system after failed update
Infinite folder loop with dolphin embedded terminal when using manjaro-zsh-config
I messed up my bootsystem
Manjaro won't boot after I booted into Windows
Live Manjaro GNOME - Application windows appear behind the wallpaper (Acer laptop)
No audio with WirePlumber 0.5.17 — downgrading to 0.5.14 fixed it for me
System freezes due to unknown reason
Installer won't load on Asus ZenBook Flip
Locking up not sure why
Wifi goes down after some time
KDE connect never stays connected to android phone for very long
PC crash when using controller
Cannot connect to my workplace VPN
Manjaro will not reboot after latest (1st of Feb 2022) update
Dash to dock, workspaces and alt+tab
Stuck at clean, files, block at boot
Blocking all sites, allowing only specific
Complete system crash when playing games
Kde Plasma Black screen
Chartnexus.jnlp
Keyboard and mouse freeze on login screen
Hello, nice tutorial.
Just wanted to say that in my case only if I press the left side Ctrl + Alt + … F2 trough F6 work for TTY. Why ??.. it beats me :man_shrugging:
Its a regular QWERTY 105 key, us layout keyboard.
So if someone presses the right side and it doesn’t work, the left will surely work :smiley:
Cheers…
Two things come to mind:
  • The right Alt key is replaced by AltGr on many keyboards. The layout for generic 105-key layout may have that replacement too.
  • One may need a compose key in order to input a character absent from the keyboard (usually diacritics).
    That key can be configured to use the right Alt or Ctrl key, in which case it cannot be used for key combinations.
2 posts were split to a new topic: How to access logs without booting the system?
@maycne.sonahoz @Stefano has a handy GUI in the repos you might want to mention here somewhere:
