[HowTo] Use the terminal / TTY
Difficulty: ★☆☆☆☆
When receiving support, or simply browsing documentation, you will see most (if not all) actions asked of you will take form of commands to use in a terminal.
About the terminal
The terminal emulator is an interface allowing a user to interact with a system through commands, as well as Command Line Interface and Text User Interface applications.
All desktop environments available on Linux ship with a terminal.
About TTY
The TeleTYpewritter is terminal interface connected directly to the standard input and output, and thus doesn’t require a dedicated graphical processor.
There are commonly 24 teletypes, accessible with Ctrl+Alt+Fx (for 1 to 12) and Ctrl+Alt+Shift+Fx (for 13 to 24). TTY7 is the one usually used for graphical sessions.
Why use a terminal ?
  • Stability
    Since CLI commands rarely require sophisticated graphical output, that is so much of code not needed to maintain. Thus, these commands are usually minimal in size and less prone to bugs.
  • Communication
    While GUI applications need instructions to guide a user toward a feature, CLI commands may only need relevant parameters. This is much straightforward to share with another user.
  • Security
    Some tasks may need to be done with superuser privileges. Running any application with those privileges involves a risk, but that risk reduces the fewer code needed to execute it. This is why commands are recommended over GUI applications for such cases.
How to execute a command in a terminal
:arrow_right: Simply type or paste the command, and tap Enter.
:star: For clarity sake, when you are asked to execute several commands – usually presented one per line – prefer executing one after the other, rather than the whole group at once. This way, you will know which result pertains to which command.
:star: It is not abnormal for a command not to produce any output. This is actually the normal behavior when a search command does not find anything, or when a process command succeeds.
Keyboard cheatsheet
  • Copy
    Ctrl+Shift+C
  • Paste
    Ctrl+Shift+V
  • Interrupt
    Ctrl+C
  • Reuse a previous command
    Up
Tips
  • Run with English output
    This is most useful for sharing debug and error information, while you have set your system to use another language.
LANG=C <command>
  • Paginate output
    Navigate with Up and Down
    Navigate pages with Page Up and Page Down
    Exit with Q
<command> | less
  • Write output to file
    The command output will be sent to the file, replacing its content, instead of the standard output.
    That file will be automatically created if missing, but its parent folder must already exist.
<command> > /path/to/file
  • Append output to file
    The command output will be sent to the file, added at its end, instead of the standard output.
<command> >> /path/to/file
  • Send output to an online pastebin
    The command output will be sent to the pastebin instead of the standard output.
    A link to the generated pastebin will be provided in the standard output.
<command> | curl -F 'clbin=<-' https://clbin.com
[HowTo] Reach a minimal system
[HowTo] Find system information
Manjaro not booting after new partitions
Swapping Kernels?
Microphone problem
Unable to boot after latest update
No right click and no close button on thunar or any tab
Sudden freezes after Stable Update 2025.06.23
Kernel Modules are failing after updating
Code Oss is no longer opening... Failed to run "code-oss.desktop"
Popping up whisker-menu with super key
Network Issue since couple of days
Video artifacts and reboot by the pc
[HowTo] Request support
Error en cambio de sesión y ejecución de programas
Can I remove all partitions?
Manjaro wont boot, says a problem has occurred and the system cant recover. Contact system administrator.m
Apps are closing
Xfce4-panel update broke border radius
Sound card not found after upgrade
WIFI on Manjaro
Cryptodisk access denied, entering grub rescue - any way to work around?
[Stable Update] 2023-12-15 - Kernels, Blender, Thunderbird, Xorg-Server, Xwayland, Warzone2100
Trouble installing any program at all
Multiseat or multihead for multiple desktops?
Black screen after last release - KDE
System hangs up at least once a day
Manjaro clears the status bar
Stuck on "enter passphrase for" screen
My headset connects and then immediately disconnects
Laptop screen suddenly had text, rebooted and TimeShift acted weird
I had wifi now i dont
Booted into emergency mode after update
Cant get past login but
I can't log in after installing lightdm
Thinkbook Plus Gen3 - No sound
GNOME return to X11 from Wayland
Since major Update a few days ago: blackscreen after entering password
Fresh install stuck in boot
Unable to chroot into system after failed update
Infinite folder loop with dolphin embedded terminal when using manjaro-zsh-config
Black screen after hp-uninstall
I messed up my bootsystem
Locking up not sure why
Installed Nvidia proprietary drivers and now can't boot into GUI
Stuck at clean, files, block at boot
Problem in the update system
[HowTo] Find error logs
I tried to install something from AUR that I shouldn’t have and it messed up GNOME
System error after update
System won't start after Manjaro update
@maycne.sonahoz one minor suggestion, could you include a description above the line
command | less
As you have described the next three examples, the new user might be confused if the bottom or the top example wasn’t explained.
For the rest this is top notch work.
