[root tip] Update Manjaro the smart way
Manjaro updates
Either when you use your system or shortly after login - a message appears - telling you there is updates available. When you click the message Pamac opens with the updates pane listing 100’s of packages ready to download/install on your system. Almost per instinct you click the update now - provide your password and the flow begin. Suddenly your screen goes blank - you wait - nothing happens. You press CtrlAltF4 - nothing happens - you wait - nothing happens. You hold the power button until the system powers off and press it again to power on your system - and now you are having a black screen maybe a message …
What now? Could the situation have been avoided?
While - of course - there is no guarantee - the following headlines may help you understand what goes on behind the scenes.
  1. Know your system
  2. What happens when you update
  3. What happens and why when an update stalls
  4. Updating the smart way
  5. Conclusion
Know your system
There is a few packages - which when updated most likely will require a restart. A short list of important system packages which probably requires restart
  • ucode
  • cryptsetup
  • linux
  • nvidia
  • mesa
  • systemd
  • wayland
  • xf86-video
  • xorg
Another part of knowing your system is which foreign packages you have installed. Foreign packages is defined as everything not in the official repository so keeping a list of packages installed by an AUR helper or using makepkg -i will be of help when you update your system.
Before you update - you can query pacman for the list - pipe it to a text file for later referral
$ pacman -Qm > ~/aur-pkglist.txt && xdg-open aur-pkglist.txt
package download
The way pacman works - using the alpm library - is to download the packages and verify by signatures - and when a package validation fail - the transaction will be not committed.
This ensures no updates are written to the system if the internet connects is severed as the update will be cancelled unless all packages required is available in the local package cache.
pacman hooks
A part of knowing your system is to understand how the alpm library applies the updates.
Many packages - especially system packages - makes use of hooks to process changes during an update.
If a package update is not fully completed - eg. your system loses power during update - the post-update hooks are not executed - and bad things can happen - what actually happens depends on the package and the hooks implemented.
What happens on update?
Most of us has been using Windows and we know from Windows that system files may be locked so the system must be restarted so the file can be replaced with the updated versions.
Due to the modularity of Linux only needed parts of an application is loaded into memory and the rest is loaded on as-needed-basis - and this includes kernel, kernel modules and drivers.
Custom packages
When you build a custom package using an AUR helper, the package is built using the - at build time - available system libraries. When you update your system - you may be replacing those dependencies with new libraries - and such replacement may cause instability or outright failure of your custom package - especially when your custom packages depends on a specific kernel release.
When you reboot your system after an update the system will use new modules and any application or device relying on a custom kernel module will fail because the module has not been rebuilt.
Only after a successful update and a successful restart you can begin to update your custom modules.
What happens when an update stalls?
The following is a simplified description - of what may happen.
When you run huge updates within the graphical environment - whether you use a terminal or a gui package manager - the system may end in a state where it needs to load a specific library at a specific memory address pointing at a specific routine in the library - but due to updates - the library is no longer existing - it has been updated to a never version - and your update stalls.
Updating the smart way includes knowing which packages may pose a problem if the update is run with the GUI. I showed you a list of packages which by a lot of users experience often requires special attention.
When Pamac shows you a huge list of update - it can be hard to get a clear view and you could miss one.
You can use a small utility script simplifying the task of evaluating a huge list of updates.
When you have evaluated the list and found this update to have the potential to stall - the smart way is to update using the console. Logout of your GUI and switch to TTY.
Don’t ever interrupt the process
Don’t ever interrupt the process - intentionally or unintentionally.
Ensure you are not doing your update when your area are known to power spike, or during stormy weather which can cause interruptions to the power grid - if your system loses power you will probably have a problem getting it back up and runnning.
Ensure mirror is up-to-date
Before syncronizing your system optionally ensure your primary mirror is up-to-date
$ pacman-mirrors
Pacman-mirrors version 4.16.4
Local mirror status for unstable branch
Mirror #1   OK  00:31   Denmark  https://www.uex.dk/public/manjaro/
Ensure enough diskspace
If you don’t regularly clean up you system - now is a good time
Remove old entries from the journal (reduce the size to 50M)
$ sudo journalctl --vacuum-size=50M
Cleanup your pacman cache (this will remove uninstalled packages and reduce pkg versions to the installed version)
$ sudo paccache -ruk0
Updating
Logout of your GUI and switch to TTY- CtrlAltF4 and run the update. Depending on the result you may proceed to update the system
$ sudo pacman -Syu
If you need to rebuild your mirror list - you will need to use below variation of the update command - forcing your system package database to equal your primary mirror’s databases and as pointed to by @cscs Pamac has a timer - rebuilding your mirror list on a regular base - in which case the this command should be favored.
$ sudo pacman -Syyu
When you reboot after a successful update - first thing to do is rebuilding your foreign packages and drivers. This can be done from a terminal in the GUI session - but if you want to ensure you get no problems - TTY is recommended CtrlAltF4.
Depending on your environment, you switch back to GUI using CtrlAltF7 or if your displaymanager is SDDM CtrlAltF1
Rebuilding all your AUR packages using a single command e.g.
$ pamac upgrade -a
Conclusion
Following a few basic rules will help you keep your system healthy and hopefully you will avoid problems from a stalled update.
Is Manjaro really big risk for beginner?
Update breaks the Manjaro OS
Update only when installing new software
[Stable Update] 2020-10-19 - Kernels, Nvidia 455, Browsers,
How to avoid rebooting after nVidia driver update?
How much longer can I keep gnome 3.36.x? (need it for gaming)
[Stable Update] 2021-06-14 - Kernels, Browsers, Mesa, Deepin, Systemd, Gnome Apps 40.2, Pipewire, Haskell
Berryboot manjaro image 19.06 isn't upgradeable, pacman-mirrors disappeared
How does one configure Manjaro in such a way that EACH & EVERY piece of software offered for upgrade is a stable version (not bleeding edge)?
Please use kernel-modules-hook instead of kernel-alive!
==> ERROR: Missing 5.17.9-1-MANJARO kernel headers for module v4l2loopback/0.12.5
What are the advantages or disadvantages to using Manjaro instead of Ubuntu-based distros?
[Stable Update] 2021-11-19 - Kernels, Gnome 41.1, Plasma 5.23.3, Frameworks 5.88, LxQt 1.0, Xorg-Server 21.1, Mesa
Creating video tutorials, can I use the Manjaro logo?
Mkvtoolnix-gui: error while loading shared libraries: libcmark.so.0.29.0: cannot open shared object file: No such file or directory
What to do after installing Manjaro?
Does updating system with pacman updates AUR packages as well?
Install a package using pamac vs pacman -S
Kernel upgrades from `pacman -Syu` fails. Presets aren't being created in `/etc/mkinitcpio.d/`
Cannot repair after update
Problem with my password
Should I install these updates from discover or are they potentially unstable?
Having a problem in installing codelite
While Upgrading, encountered errors from AUR python2 packages
Download updates in bits and pieces
Stability Problems with Manjaro-ARM-gnome-rpi4-22.04
System instability
Black screen after latest update on linux 515
Some applications take more than half a minute to open
Need to rebuild megasync after recent testing update
Welcome and introduce yourself - 2022
Few questions for first time Linux user
Boot issues every update
How long do you use Arch based/Manjaro distro without crashes after update?
How do I set the fastest mirror?
Updates after 4 months of not using a computer
Difference between pamac install and pamac build
How does Manjaro behave on the long term?
My machine just froze
Having a ton of upgrades - how to handle?
Welcome and introduce yourself - 2021
Any Firefox Updates past 88.1 Freezes The Whole System
Best practices to safeguard our system against unforeseen interruptions during updates and installations
Expectations from a stable release : an user's perspective
Linux Update Interrupted And Now Linux Broken
For anyone like me, who is yet planning to move away from Windows, this is super useful. Thank you for this tip!
Unless mirrors have changed, such as if you have pamac-mirrorlist.timer running :wink:
(in which case 2 ys)
I have some project with some friend to put your OS on some company machine’s and we would like to know is it’s possible to do only security update has in Debian?
In my opinion I would go with full update but my friend are a bit … well they fear it will crash to often. (I have been using manjaro for the past cople of year’s with almost no issue in that regard but I have to convince them :slight_smile: )
No.
Arch/Manjaro comes with the following requisite:
Partial Upgrades are Not Supported.
You could probably hold off on updates for some time … but I wouldnt suggest for long.
And … if you need to install another package - its full update time.
You can check a box in pamac to install a package without updating under preferences.
So if you needed a program on the day of updates and you didn’t want to update until others had updated first, in order to avoid problems you could do so.
Also in Preferences you can set a program not to be updated. That might be useful if you need a program to work a certain way. Although it might be better to use a flatpak in that situation.
Well … yeah … I could set my kernel and more to the “IgnorePkg” line … but its still not supported and still a bad idea.
https://wiki.archlinux.org/index.php/System_maintenance#Partial_upgrades_are_unsupported
… are you sure?
At least for the longest time that was impossible, and I certainly cant find such an option.
pamac was built with just these kinds of mistakes in mind. And thus defaulted to refreshing dbs and downloading updates whenever there is a package transaction.
pacman on the other hand you could fire away using -S and it wouldnt update.
But again … that is the incorrect way to install a package, and considered a partial upgrade. (see above)
Under Preferences/Advanced/ Do not check for updates when installing.
While I’m at it, two little thing’s that bug me with update’s.
I know that I can do some automatic update but is there a way to set it up with pamac or I do have to create a service with a cron job that run every day?
Also, is there a way to make the power manager or the screen manager to keep my computer alive while it is updating? i had some issues with this before, If I try to update and forget to remove the auto-lock and sleep, my computer would go to sleep while updating creating a huge mess!!
Thank’s! That’s what I tough but you never know :slight_smile:
I think I will go with snap or flatpack instead for most of the software part and maintain the system separately
Ah. I do see it now. Wonder when that got added.
I am not totally against it.
But … theres a reason its under Advanced.
Couldnt tell you for sure as … I wouldnt use such a thing.
But … it looks like pamac can handle it … though it will still prompt (not just do it without asking).
Eh … you could do any number of things, like in plasma set to ‘presentation mode’, make an alias so that updates always keep the session active, etc etc …
I think I actually wrote a script for someone like this somewhere … if I find it I will post.
If you do that, I’d suggest the routine includes at least these two things:
  • Checking available disk space (the cache(s) can accumulate a LOT of previously-installed packages over time if not kept an eye on)
  • Verifying that the system isn’t running on battery before doing updates.
This is indeed good advise!
A post was split to a new topic: Update KDE the smart way
A post was split to a new topic: Using pamac to upgrade AUR packages
