Paccache command not found
@linux-aarhus
Thank you very much
But i got an ERROR here
sudo paccache -ruk0
bash: $: command not found
paccache is included with pacman - so :man_shrugging:
@Firas2023 I suspect you copied and pasted a command with the $ in front of it and that is, indeed, a non-existing command.
@Mirdarthos
I did not copy $ but u never know with me :slight_smile:
but it’s working now that you mention it
Thank you so much
sudo paccache -ruk0
[sudo] password for
==> finished: 48 packages removed (disk space saved: 106.79 MiB)
That is an error by bash complaining that the $ command you provided does not exist. So if you don’t see it, you’ve got 1 of two problems:
  1. Serious magic; or
  2. failing eyes.
:stuck_out_tongue_winking_eye:
I am terrible @ multitasking :v:
