[Tutorial] Working with additional 'drives'
Difficulty: ★★☆☆☆
1. INTRODUCTION
Microsoft Windows started its life as a graphical user interface on top of MS-DOS, a 16-bit single-user, single-tasking operating system that in turn originated as 86DOS, an unauthorized 16-bit rewrite (by Tim Paterson of Seattle Computer) of Digital Research’s originally 8-bit CP/M operating system. Both CP/M and MS-DOS were at the time developed for computers that did not support any other storage media than floppy disks.
Considering this legacy, Microsoft Windows still uses the concept of “drives” and “drive letters”, but this concept does not exist in GNU/Linux, because GNU/Linux is a UNIX-family operating system, and UNIX itself was designed as a multitasking, multi-user platform that was modeled after the Multics mainframe operating system, which used a single, unified directory hierarchy where everything can always be found at the same location in the tree of directories ─ or “folders” in Windows-speak ─ regardless of what physical medium it is stored on.
Now, given that the vast majority of our members are (or have until recently been) Windows users, many of them have data stored across various different physical storage media, whether they be external and removable media such as (for instance) USB sticks, or whether they be additional partitions on their internal or external SSDs or HDDs. As such, a question that we get all too often here at the forum is “How can I access the data on my other partition/drive?”
It is these members that this particular tutorial is intended for, as an intermediary step in transitioning away from the Microsoft Windows paradigm and onto the UNIX paradigm, because these two platforms are indeed radically different, and one can never expect to reach a high level of productivity and comfort in GNU/Linux by clinging onto the paradigm of Microsoft Logic™.
2. AUTODETECTION
Manjaro, being based upon Arch, uses systemd as a system daemon, started as the very first userspace process after the kernel has finished booting and loading its driver modules.
systemd is not a single program, but a whole framework of different modules that all work together in a tightly integrated manner. Among other things, it takes care of loading additional driver modules, setting up the login consoles, starting and managing other system daemons ─ i.e. background services ─ and detecting additional hardware as it is plugged into the system.
Therefore, in most cases, systemd will automatically detect any additional partitions and storage media you have, and it will then make those available by way of a mountpoint ─ i.e. a directory ('folder") ─ under the /run directory. However, there are two caveats here…:
  • systemd will automatically assign a default set of permissions to the new mountpoint, depending on which type of filesystem is mounted on it, which sometimes leads to permissions issues.
  • Considering that /run is itself a tmpfs ─ i.e. a temporary filesystem that only exists in virtual memory and will thus cease to exist when the machine is shut down ─ manually changing the permissions on the mountpoint for the new filesystem will not persist across reboots.
3. SETTING UP A STATIC MOUNTPOINT
Considering the potential for permissions issues, the better solution for mounting additional filesystems into the directory tree is therefore to set them up with a static mountpoint and permanent permissions. You do this by adding an entry for the additional filesystem in /etc/fstab.
/etc/fstab is a simple text file, in which each line is regarded as a record that describes a filesystem, and each record is divided into six fields, separated by whitespace ─ i.e. spaces or tabs.
A typical filesystem entry might for instance look like this… :arrow_down:
# Anything starting with a "#" is a comment.
#    -1 -             -2-         -3-         -4-      -5-    -6-
#  STORAGE       | MOUNTPOINT | FILESYSTEM | MOUNT   | DUMP | PASS
#  DEVICE        |            | TYPE       | OPTIONS |
UUID=some-string   /home        ext4         defaults   0      0
In the example above, you can clearly see the six fields, and their function should be clear enough by now. However, I will offer some further clarification on account of the 4th, 5th and 6th fields.
  • Mount Options: You can specify multiple mount options there, but they must be separated by commas and may not contain any spaces, because spaces are used as the field separator that distinguishes between the different fields of the record. A valid entry would for instance be defaults,auto,ssd,noatime,nodev.
  • Dump: This field is only there anymore for compatibility reasons, although it is still functional. It denotes whether or not a particular filesystem is eligible for backing up when the dump utility is used. dump is an old UNIX backup utility that is still supported on ext3/ext4 filesystems ─ other filesystems may provide for a more customized alternative in their respective toolkit ─ but these days, much better backup solutions exist, such as TimeShift or BackInTime.
  • Pass: This field specifies whether the filesystem must be checked at system boot. A value of “0” denotes that the filesystem must not be checked, while the values of “1” and “2” determine the priority of checking.
4. THINGS TO CONSIDER
Now, how exactly you should set up a mountpoint and an /etc/fstab record for your additional filesystem depends on a couple of different things…:
  • Is the filesystem a partition on an internal storage medium, or does it reside on a removable drive?
  • Does the filesystem support POSIX file ownership and permissions ─ or otherwise put: is it a Linux-native filesystem ─ or is it a DOS or Windows filesystem?
  • Is the content of the filesystem to be shared among all user accounts on the system, or is it data belonging to one user only?
If the filesystem in question resides on a removable drive, then chances are that this device isn’t always connected, and then if the device is indeed not connected when the machine boots, the boot will stall. This is why you should always include the mount options noauto,nofail to the /etc/fstab entry for such a filesystem.
If the filesystem is not POSIX-compatible ─ e.g. it is an NTFS partition ─ then it cannot store any information about file ownership and permissions. However, being a POSIX operating system, GNU/Linux requires every file to have an owner, a group and a permissions mask.
Therefore, when a non-POSIX filesystem is mounted into the virtual filesystem layer of the kernel, the kernel will emulate a mask of fake ownership and permisions to the whole mounted filesystem. Considering that this ownership and these permissions are emulated and set for the whole device at mount time, they cannot be altered for individual files and directories (“folders”) on the filesystem, nor can they be altered for the whole filesystem without remounting the filesystem.
If you want to know what mount options exist for setting the compatibility options for non-POSIX filesystems, then please Read The Fine Manual™ (“RTFM” :stuck_out_tongue:) for the mount command. :arrow_down:
man mount
Lastly, there is the choice of where to create the mountpoint. In a UNIX system, the root directory is read-only to unprivileged users ─ only the root account can write to /.
Therefore, if the device contains files that are only pertinent to one particular user, then it is best to ─ as the user ─ create a mountpoint inside the user’s home directory. That way, the mountpoint will be owned by and writable to the user by default ─ you would simply create a directory (“folder”) inside your ${HOME} and use that as the mountpoint.
Do however keep in mind that the permissions on the content of the filesystem will be dictated by what type of filesystem it is… :arrow_down:
  • If it is a non-POSIX filesystem, then the permissions on the individual files are emulated, and they will depend upon the mount options for the filesystem as specified in /etc/fstab, as explained higher up already.
  • If it is a POSIX filesystem and it already contains files, then the permissions and ownership that were already in place will still apply. So if the filesystem contains root-owned files, then this will not change, and those files will still be root-owned.
Now, if the POSIX filesystem contains files owned by a user account that doesn’t exist on your system, then the owner and group will be represented as a number ─ the UID (“user ID”) of the user who owned those files on the system that it came from.
This UID may or may not correspond to your own UID. If it does, then great ─ then your own user name will be listed as the owner. If however it doesn’t correspond to your own UID, then you must change either the ownership or the permissions on those files, and on the directories that contain them. See… :arrow_down:
man chown
… and… :arrow_down:
man chmod
Now, if the filesystem contains files that are to be shared among multiple user accounts, then there are two possible other locations where you can set up a mountpoint, i.e.:
  • a directory under /srv for filesystems on non-removable media; or
  • a directory under /media for filesystems on removable media.
The directory /media may not necessarily exist on your system, but it is trivial to create it. You will however need elevated permissions to do so, because unlike in Microsoft Windows, an unprivileged user account has no write access to anything outside of their home directory, /tmp and /var/tmp.
If you decide to share the contents of the additional filesystem with the other user accounts on your system, then there are various options to choose from on account of what permissions and ownership to set for the files on said filesystem ─ provided of course that it is a POSIX-compatible filesystem. I am therefore going to include links below to two other tutorials I’ve written. The first one deals with POSIX file ownership and permissions ─ which allow for far more flexibility than you’re probably expecting ─ and the second one deals with the repurposing of an empty extra partition in the event that your root filesystem is getting full.
I hope this tutorial was useful to you, but if you have any questions, then please post them below on this thread; do not send me any PMs about it, because that would not benefit anyone here on the forum. :wink:
How do I configuring a new storage SSD?
Automount second internal hdd
What is the most efficient way to share files across manjaro and windows?
Can't mount secondary HDD
Welcome and introduce yourself - 2022
[How to] Help a new forum member solve problems
My Manjaro Installation aborted when I tried to create home director and separate bootloader
Acceso a Partición de Disco
Having SSD as boot and game disk and the HDD as storage
Mounting Windows Drive
Fresh install manjaro i3 and first update
Unable to paste files to Windows partition
Home folder put on second hard drive
Moving home to new drive subdirectory, I have some questions
Questions/Problems with my first HDD Setup
New issues after upgrade new 6.9kernel based manjaro os
Cant see the files on my External HDD
Mounting on startup
Dual boot and secondary hard drive ownership
I can't access my second partition
I can't disable write caching for removable drives
Wanted to make a download partition on my window drive?
Best practices for gaming PC?
Resizing root? Root needs a diet
How do I add a new hard drive to my system?
Unable to paste files into external hard drive
Installation question
Issue with fstab data drive mounting
I changed the mount point of my 2nd ssd and now i cannot boot
My all external hardrives is read only
I'm out of space on / issue
Can not copy files to second hard drive
How to see which drive a file is on
What file systems can I use for /home?
External SSD issue
Is this the correct Btrfs structure?
Error mount partion
Newbie learning Linux
My hard drive is read only and i can't write on it
Absolute beginner looking to get into linux
Unable to write to non-system drives
Secondary Hard Drive Auto Mount & Its On Read Only Mode
Problem mounting ntfs partition drive
Drive shown as empty after applying chmod
Checking fstab settings AND Automount options?
How Partition m.2 Drive for Timeshift to Direct to
Files missing during file transfer / renaming process
Help needed for editing fstab (new ext4 partition, encryption and adding as home)
Npm package installation error on other partition
How do I get my Plex media server running on startup?
No write permission for my non boot drive
Lost Dolphin “Comment” in Properties>Details
Mounting external drive to /mnt instead of /run/media
How to add drives to fstab on fresh install (switch from GNOME to XFCE)?
A whole drive volume is missing in manjaro (it's not listed dolphin)
Don't replace my Links!
I can't unmount and reformat a hard drive
Need Help With Two Issues On Boot Of Manjaro KDE
Installing Win10 in secondary disk corrupted my main (Manjaro) disk
Formatting an External Drive is Locking Me Out of Permission to Use It
Invalid File Permissions file could not be saved
I can not access my second drive (HDD)
Do I have to format other drives?
How to use my hdd from windows on linux without a format?
Cannot view files I own
Issues with secondary m.2 storage
Drive shows lock icon, even though permissions say read/write?
Add secondary drive in steam
Mount secondary SSD without loosing data?
Couldn't run npm run on ntfs partition
My computer doesn't boot up
How can I give read and write permissions to a partition on fstab?
Only 1 ssd drive visible
Change permissions of a USB hard drive
Trouble with an external HDD drive for Steam
Over 250GB available BUT not enough space error
My drive won't show up
Steam not creating folder on new selected drive
I can't mount external NFTS hard drive
Permission issues writing/deleting to ext4 formatted HDD
What’s the difference between bash and default terminal
How to install WhatsApp and Facebook Messenger?
[Stable Update] 2024-01-13 - Kernels, Systemd, Qt5, Mesa, Dbus, Firefox, Thunderbird
Partition two different drives as /home
Can't Create Folder and Copy File in External Drive
Cannot paste file into a partition directory
Error symbol 'grub_debug_malloc' not found. Entering rescue mode... grub rescue>
I want to install Manjaro OS on SSD and the programs on HDD
Trying to get the Original MYST game running on lutris?
New to Linux and trying to get ownership on NTFS drives on dual boot system
How can I mount a folder in /home that points to the hdd?
Quick Question on partitioning
Mounting storage disk
Syncthing and fstab mounts
Disk usage analyzer shows different values inside and outside of partition
Please help me properly install my new SSD storage drive
Cannot access files on ext-4 usb drive
Porque no puedo ejecutar los binarios desde mi usb pero desde mi /home/ si
Mounting an exfat partition on boot and giving everyone rw access
External drives are on root permissions
Plasma workspace installation problem
NTFS partitions are gone from dolphin
Help how to make drive usable for non root
Usb disk not writable
Permissions issue in OnlyOffice when trying to write to an exFAT partition
Error Mounting NTFS drive in Dolphin [KDE]
Update removes symlink
Unable to mount fat or ntfs drives after updating
Gnome file places
Editing fstab to include 2 extra drives
Can't delete/modify files in specific disks
Need to put in pasword to open drive now, why? (drive is in system)
How "should" i deal with a shared NTFS drive?
External HD can't be found in /etc/fstab and I can't mount
USB device will not mount
NVMe storage (not boot) drive is being recognized as an external drive?
Can't create folders on hard drives
File names in Cyrillic are not displayed from the external HDD NTFS
My 2nd HDD is nowhere to find
HDD is failed to be mounted in Dolphin
Problem installing manjaro with f2fs format
How to move Steam games to external hard drive?
Distributing applications on different hard drives
How to install linux packages into a separate drive?
Mounting second device wihtout pasword
Read-only Hard Disk
Help needed with setting restoration
Noob question: what's the deal with my connected drives not being accessible?
Unable to save files on an external / flash drive
USB Floppy Drive sometimes mounted as root
Portable USB drive permission denied
How to mount partitions as my user?
What Theme/Desktop is this? and How to Change
Home directory after reinstalling manjaro
KDE Partition Manager mount point edit
Can not mount drive
Looking for someone to proofread fstab (new ssd)
Mounting external devices
Manjaro fails to mount, fix or identify my F drive of my HDD
Will xfs_repair -L option remove metadata to access all that has been stored ever on HDD?
Issues with Shutdown
Problem adding a second SSD
New linux user : manjaro doesn't recognize my partitions for installing
Understanding all the tutorials here, but cannot add 2 drives to fstab
Error messages pop up
Unsure which options to check during partitioning
Stale file handle - can't delete file even with rm -f
Steam refuses to add internal ssd’s
Sudo popup pasword requested for mounting a btrfs disk?
Need guidance about update and problems after. (picom, polkit, replace kernel?)
Install manjaro plasma and use other hard disk to files
Randomly entering Emergency Mode due to failed mount
Configure external thunderbolt storage for user mount?
New Steam library folder myst be on filesystem mounted with exucute permissions
Sudo for all my commands for me
Cannot access partition as a user
Userspace loading time takes a long time
How can I set my SSD as my boot drive and my HDD as my storage drive?
Restoring file system
Setting up a SD card as /home(?)
Extracting information from a separate windows drive
Strange Dolphin issue
I have been using Linux for some time, although mostly on servers, and considered myself intermediate to proficient, by no means an expert. In Other Words, I was quite comfortable with it.
Yet, this was VERY insightful and I learned something, if not a lot. Thank you!
