Manjaro 25.0 Zetar released
Manjaro 25.0
Since we released Yonada in December 2024 we worked hard to get the next release of Manjaro out there. We call it Zetar.
The GNOME edition has received several updates to Gnome 48 series. This includes a lot of fixes and polish when Gnome 48 originally was released in March 2025. You can find find release dates of each upcoming point-release here: Release Calendar. Weekly updates around GNOME can be found here.
Highlights of 48 release series are:
GNOME 48 introduces stacking to the notification list. Notifications from the same app are grouped into stacks, each of which can be expanded to reveal individual messages. Stacking keeps the notification list organized and makes it easier to navigate. It also prevents the notification list from becoming too long.
GNOME 48 includes a number of notable performance improvements. The most significant of these is the introduction of dynamic triple buffering. This change has undergone significant review and testing over a period of five years and improves the perceived smoothness of changes on screen, with fewer skipped frames and more fluid animations. This has been achieved by enhancing the concurrency capabilities of Mutter, the GNOME display manager, and is particularly effective at handling sudden bursts of activity.
GNOME 48 includes a new option which enhances the lifespan of the device’s battery. When enabled, battery charge is limited to 80% while the device is plugged in. Maintaining the battery charge level at this reduced level keeps the battery working better for longer.
GNOME 48 is an important milestone for HDR support in GNOME, with the initial introduction of system level HDR support. This means that, if you have an HDR display, it is now possible to have HDR output shown from apps which support it. Currently the number of apps which support HDR is limited. However, work to extend HDR support is ongoing, and the availability of this feature is expected to increase in the future.
The Plasma edition comes with the latest Plasma 6.3 series, Frameworks 6.12 and KDE Gear 24.12. It brings exciting new improvements to your desktop.
One year on Plasma’s developers have worked on fine-tuning, squashing bugs and adding features to Plasma 6 — turning it into the best desktop environment for everyone!
The most important news regarding graphics is a huge overhaul of how fractional scaling works. In Plasma 6.3, KWin makes a stronger effort to snap things to the screen’s pixel grid, greatly reducing blurriness and visual gaps everywhere and producing sharper and crisper images. In the color department, screen colors are more accurate when using the Night Light feature both with and without ICC profiles, and KWin offers the option to choose screen color accuracy — although this can sometimes affect system performance.
System Monitor monitors CPU usage more accurately, and consumes vastly fewer CPU resources while doing it! Info Center also provides more information, exposing data about all of your GPUs as well as your batteries’ cycle counts. Monitoring printers is equally easy, as each printer’s print queue is shown directly in the widget. The widget also shows a little spinner on any printers that are currently printing, so you can see at a glance which ones are in use. Plasma 6.3 makes things easy without ditching flexibility. If you prefer using a mouse with your laptop, you can now configure its built-in touchpad to switch off automatically, so it doesn’t interfere with your typing. Also, if you set up your machine as a network hotspot, Plasma generates a random password for the network so you don’t have to think one up.
Finally, what would Plasma be without customization? Panels can now be cloned! You can also use scripting to change your panels’ opacity levels and what screen they appear on.
With our XFCE edition, we have now Xfce 4.18. Here some highlights: A new file highlighting feature (accessed from the file properties dialog) in Thunar file manager lets you set a custom colour background and a custom foreground text colour – an effective way to call attention to specific file(s) in a directory laden with similar-looking mime types. On the subject of finding files, Thunar includes recursive search.
The panel picks up a pair of new preferences. First, panel length is now configured in pixels rather than percentages, as before. Second, there’s a new “keep panel above windows” option. This allows maximised app windows to fill the area behind the panel rather than maximise its bottom or top edge to sit flush against it.
Control Centre groups all of the desktop’s various modules for managing the system into one easy-to-use window. New options are present in many of these. For example you can disable header bars in dialogs from the Appearance module; show or hide a ‘delete’ option in file context menus from Desktop; and pick a default multi-monitor behaviour before you attach an additional screen – dead handy, that.
Kernel 6.12 is used for this release, such as the latest drivers available to date. With 6.6 LTS and 6.1 LTS we offer additional support for older hardware as needed.
We hope you enjoy this release and let us know what you think of Zetar.
Zetar 25.0.10 (2025-10-13)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-251013-linux612.iso
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-251013-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-251013-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-251013-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-251013-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-251013-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux612.iso
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux66.iso
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux61.iso
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.10/manjaro-xfce-25.0.10-minimal-251013-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-251013-linux612.iso
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-251013-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-251013-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-251013-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-251013-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-251013-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux612.iso
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux66.iso
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux61.iso
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.10/manjaro-gnome-25.0.10-minimal-251013-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-251013-linux612.iso
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-251013-linux612.iso.sig
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-251013-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-251013-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-251013-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-251013-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux612.iso
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux612.iso.sig
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux66.iso
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux66.iso.sig
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux61.iso
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux61.iso.sig
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.10/manjaro-kde-25.0.10-minimal-251013-linux61.iso.pkgs
Zetar 25.0.9 (2025-10-03)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-251003-linux612.iso
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-251003-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-251003-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-251003-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-251003-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-251003-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux612.iso
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux66.iso
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux61.iso
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.9/manjaro-xfce-25.0.9-minimal-251003-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-251003-linux612.iso
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-251003-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-251003-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-251003-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-251003-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-251003-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux612.iso
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux66.iso
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux61.iso
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.9/manjaro-gnome-25.0.9-minimal-251003-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-251003-linux612.iso
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-251003-linux612.iso.sig
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-251003-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-251003-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-251003-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-251003-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux612.iso
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux612.iso.sig
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux66.iso
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux66.iso.sig
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux61.iso
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux61.iso.sig
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.9/manjaro-kde-25.0.9-minimal-251003-linux61.iso.pkgs
Zetar 25.0.8 (2025-09-02)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-250902-linux612.iso
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-250902-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-250902-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-250902-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-250902-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-250902-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux612.iso
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux66.iso
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux61.iso
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.8/manjaro-xfce-25.0.8-minimal-250902-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-250902-linux612.iso
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-250902-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-250902-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-250902-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-250902-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-250902-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux612.iso
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux66.iso
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux61.iso
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.8/manjaro-gnome-25.0.8-minimal-250902-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-250902-linux612.iso
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-250902-linux612.iso.sig
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-250902-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-250902-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-250902-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-250902-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux612.iso
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux612.iso.sig
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux66.iso
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux66.iso.sig
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux61.iso
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux61.iso.sig
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.8/manjaro-kde-25.0.8-minimal-250902-linux61.iso.pkgs
Zetar 25.0.7 (2025-08-12)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-250812-linux612.iso
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-250812-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-250812-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-250812-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-250812-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-250812-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux612.iso
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux66.iso
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux61.iso
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.7/manjaro-xfce-25.0.7-minimal-250812-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-250812-linux612.iso
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-250812-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-250812-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-250812-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-250812-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-250812-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux612.iso
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux66.iso
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux61.iso
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.7/manjaro-gnome-25.0.7-minimal-250812-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-250812-linux612.iso
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-250812-linux612.iso.sig
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-250812-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-250812-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-250812-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-250812-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux612.iso
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux612.iso.sig
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux66.iso
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux66.iso.sig
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux61.iso
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux61.iso.sig
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.7/manjaro-kde-25.0.7-minimal-250812-linux61.iso.pkgs
Zetar 25.0.6 (2025-07-30)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-250730-linux612.iso
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-250730-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-250730-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-250730-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-250730-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-250730-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux612.iso
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux66.iso
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux61.iso
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.6/manjaro-xfce-25.0.6-minimal-250730-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-250730-linux612.iso
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-250730-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-250730-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-250730-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-250730-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-250730-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux612.iso
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux66.iso
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux61.iso
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.6/manjaro-gnome-25.0.6-minimal-250730-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-250730-linux612.iso
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-250730-linux612.iso.sig
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-250730-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-250730-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-250730-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-250730-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux612.iso
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux612.iso.sig
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux66.iso
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux66.iso.sig
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux61.iso
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux61.iso.sig
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.6/manjaro-kde-25.0.6-minimal-250730-linux61.iso.pkgs
Zetar 25.0.5 (2025-07-13)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-250713-linux612.iso
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-250713-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-250713-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-250713-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-250713-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-250713-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux612.iso
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux66.iso
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux61.iso
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.5/manjaro-xfce-25.0.5-minimal-250713-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-250713-linux612.iso
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-250713-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-250713-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-250713-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-250713-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-250713-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux612.iso
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux66.iso
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux61.iso
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.5/manjaro-gnome-25.0.5-minimal-250713-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-250713-linux612.iso
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-250713-linux612.iso.sig
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-250713-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-250713-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-250713-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-250713-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux612.iso
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux612.iso.sig
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux66.iso
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux66.iso.sig
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux61.iso
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux61.iso.sig
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.5/manjaro-kde-25.0.5-minimal-250713-linux61.iso.pkgs
Zetar 25.0.4 (2025-06-23)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-250623-linux612.iso
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-250623-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-250623-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-250623-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-250623-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-250623-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux612.iso
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux66.iso
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux61.iso
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.4/manjaro-xfce-25.0.4-minimal-250623-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-250623-linux612.iso
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-250623-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-250623-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-250623-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-250623-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-250623-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux612.iso
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux66.iso
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux61.iso
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.4/manjaro-gnome-25.0.4-minimal-250623-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-250623-linux612.iso
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-250623-linux612.iso.sig
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-250623-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-250623-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-250623-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-250623-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux612.iso
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux612.iso.sig
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux66.iso
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux66.iso.sig
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux61.iso
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux61.iso.sig
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.4/manjaro-kde-25.0.4-minimal-250623-linux61.iso.pkgs
Zetar 25.0.3 (2025-05-26)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-250526-linux612.iso
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-250526-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-250526-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-250526-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-250526-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-250526-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux612.iso
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux66.iso
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux61.iso
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.3/manjaro-xfce-25.0.3-minimal-250526-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-250526-linux612.iso
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-250526-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-250526-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-250526-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-250526-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-250526-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux612.iso
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux66.iso
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux61.iso
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.3/manjaro-gnome-25.0.3-minimal-250526-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-250526-linux612.iso
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-250526-linux612.iso.sig
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-250526-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-250526-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-250526-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-250526-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux612.iso
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux612.iso.sig
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux66.iso
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux66.iso.sig
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux61.iso
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux61.iso.sig
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.3/manjaro-kde-25.0.3-minimal-250526-linux61.iso.pkgs
Zetar 25.0.2 (2025-05-16)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-250516-linux612.iso
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-250516-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-250516-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-250516-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-250516-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-250516-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux612.iso
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux66.iso
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux61.iso
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.2/manjaro-xfce-25.0.2-minimal-250516-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-250516-linux612.iso
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-250516-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-250516-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-250516-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-250516-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-250516-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux612.iso
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux66.iso
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux61.iso
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.2/manjaro-gnome-25.0.2-minimal-250516-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-250516-linux612.iso
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-250516-linux612.iso.sig
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-250516-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-250516-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-250516-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-250516-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux612.iso
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux612.iso.sig
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux66.iso
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux66.iso.sig
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux61.iso
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux61.iso.sig
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.2/manjaro-kde-25.0.2-minimal-250516-linux61.iso.pkgs
Zetar 25.0.1 (2025-05-08)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-250508-linux612.iso
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-250508-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-250508-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-250508-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-250508-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-250508-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux612.iso
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux66.iso
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux61.iso
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.1/manjaro-xfce-25.0.1-minimal-250508-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-250508-linux612.iso
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-250508-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-250508-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-250508-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-250508-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-250508-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux612.iso
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux66.iso
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux61.iso
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.1/manjaro-gnome-25.0.1-minimal-250508-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-250508-linux612.iso
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-250508-linux612.iso.sig
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-250508-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-250508-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-250508-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-250508-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux612.iso
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux612.iso.sig
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux66.iso
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux66.iso.sig
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux61.iso
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux61.iso.sig
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.1/manjaro-kde-25.0.1-minimal-250508-linux61.iso.pkgs
Zetar 25.0.0 (2025-04-14)
Download XFCE
Full
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-250414-linux612.iso
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-250414-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-250414-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-250414-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-250414-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-250414-linux612.iso.pkgs
Minimal
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux612.iso
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux612.iso.sig
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux612.iso.sha1
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux612.iso.sha256
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux612.iso.torrent
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux66.iso
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux66.iso.sig
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux66.iso.sha1
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux66.iso.sha256
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux66.iso.torrent
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux61.iso
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux61.iso.sig
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux61.iso.sha1
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux61.iso.sha256
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux61.iso.torrent
https://download.manjaro.org/xfce/25.0.0/manjaro-xfce-25.0.0-minimal-250414-linux61.iso.pkgs
Download GNOME
Full
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-250414-linux612.iso
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-250414-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-250414-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-250414-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-250414-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-250414-linux612.iso.pkgs
Minimal
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux612.iso
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux612.iso.sig
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux612.iso.sha1
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux612.iso.sha256
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux612.iso.torrent
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux66.iso
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux66.iso.sig
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux66.iso.sha1
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux66.iso.sha256
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux66.iso.torrent
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux61.iso
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux61.iso.sig
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux61.iso.sha1
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux61.iso.sha256
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux61.iso.torrent
https://download.manjaro.org/gnome/25.0.0/manjaro-gnome-25.0.0-minimal-250414-linux61.iso.pkgs
Download KDE
Full
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-250414-linux612.iso
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-250414-linux612.iso.sig
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-250414-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-250414-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-250414-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-250414-linux612.iso.pkgs
Minimal
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux612.iso
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux612.iso.sig
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux612.iso.sha1
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux612.iso.sha256
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux612.iso.torrent
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux612.iso.pkgs
Minimal (linux66)
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux66.iso
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux66.iso.sig
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux66.iso.sha1
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux66.iso.sha256
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux66.iso.torrent
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux66.iso.pkgs
Minimal (linux61)
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux61.iso
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux61.iso.sig
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux61.iso.sha1
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux61.iso.sha256
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux61.iso.torrent
https://download.manjaro.org/kde/25.0.0/manjaro-kde-25.0.0-minimal-250414-linux61.iso.pkgs
Manjaro 25.0 Zetar Release Review
[Stable Update] 2025-05-04 - Kernels, GNOME 48.1, NVIDIA, KDE Gear, KDE Frameworks, LXQt
Manjaro 24.2 Yonada released
[Stable Update] 2025-05-14 - Kernels, Firefox, Thunderbird, Mesa, Plasma, LibreOffice, QEMU
[Testing Update] 2025-04-27 - Kernels, LXQt 2.2, Thunderbird 137.0.2, COSMIC Alpha 7
[Stable Update] 2025-12-22 - Kernels, Cinnamon, KDE Frameworks, Pacman
[Testing Update] 2025-10-20 - Kernels, Systemd, GNOME, Certbot, Deepin, Firefox
[Testing Update] 2025-10-07 - Kernels, Firefox, Nvidia, Wine, Erlang
What kernel does Manjaro use?
[Testing Update] 2025-10-13 - Kernels, Qt 6.10, KDE Frameworks & Gear
[Testing Update] 2025-04-21 - Kernels, GNOME 48.1, NVIDIA 570.144, KDE Gear 25.04, Mesa
[Testing Update] 2025-05-20 - Kernels, Firefox, NVIDIA
[Testing Updates] 2025-06-05 - Kernels, VirtualBox, Bluez, PipeWire, Qt6, Mesa, Thunderbird
[Stable Update] 2025-07-12 - Kernels, Systemd, GNOME, NVIDIA, Plasma, Firefox, VLC splits
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan
[Testing Update] 2025-11-19 - Plasma 6.5.3, KDE Frameworks 6.20.0, Firefox 145.0.1
Xfdesktop core dump
[Testing Update] 2026-01-01 - Wireplumber, NVIDIA Driver Assistant, ALSA
[Testing Update] 2025-08-07 - Systemd, Heroic Games Launcher, OpenGamepadUI
[Testing Update] 2025-08-10 - Linux-Firmware, Gstreamer, KDE Framework
[Testing Update] 2025-07-10 - Kernels, Thunderbird, Firefox, OpenSearch, QEMU, VLC splits
[Testing Update] 2025-10-03 - Kernels, Mesa, Firefox, Deepin
[Testing Update] 2025-12-29 - Mesa, NVIDIA 590xx, Firefox, LibreOffice, Gstreamer
[Testing Update] 2025-06-01 - Kernels, Firefox, Thunderbird, NVIDIA, Mesa, PipeWire
[Testing Update] 2025-11-06 - Kernels, Mesa, Grub, Nvidia, Plasma 6.5, LibreOffice
[Stable Update] 2025-05-19 - Firefox, Thunderbird, KDE Gear, KDE Frameworks
[Testing Update] 2025-11-14 - Kernels, GStreamer, Firefox, Mesa, LibreOffice, Vivaldi
[Testing Update] 2025-09-10 - Kernels, Systemd, LibreOffice, Thunderbird, Deepin
[Testing Update] 2025-09-18 - Kernels, NVIDIA, PipeWire, KDE Gear & Frameworks
[Testing Update] 2025-11-10 - Kernels, Systemd, Mkinitcpio, KDE Gear, Plasma
[Testing Update] 2025-09-20 - Kernels, Mesa, Firefox, Deepin, Gstreamer
[Stable Update] 2025-09-26 - Kernels, NVIDIA, Systemd, LibreOffice, KDE Software
[Testing Update] 2025-09-27 - Kernels, Plasma 6.4.5, GNOME 49.0, Cosmic 1.0b1
[Testing Update] 2025-07-24 - Kernels, Firefox, Nvidia, 0ad
[Stable Update] 2025-08-30 - Kernels, ROCm, Firefox, Steam, PHP
[Testing Update] 2025-09-02 - Kernels, Wine, Haskell, Python
Last update broke my system
[Testing Update] 2025-09-03 - Qemu, Nvidia, Deepin, Ollama, Virtualbox
[Testing Update] 2025-08-31 - Mesa, LibreOffice, Qt 6.9.2, ROCm
HDMI audio output does not turn off automatically after disconnecting until suspend or reboot
[Testing Update] 2025-08-29 - Kernels, Nvidia, Firefox, php, rocM, Steam
[Stable Update] 2025-08-29 - Kernels, Toolchain, Virtualbox, Mesa, Wine, ZFS
[Testing Updates] 2025-08-26 - Kernels, ZFS, Deepin, Python, Haskell
[Testing Update] 2025-09-29 - Kernel 6.17, Deepin, Yoshimi, Haskell, Python
[Testing Update] 2025-08-24 - Kernels, Firefox, Mesa, LibreOffice
[Testing Update] 2025-11-24 - Kernels, COSMIC Beta 7, GRUB, NVIDIA, Blender, LXQt
[Testing Update] 2025-10-21 - Mesa, Firefox-Beta, Rebuilds
[Testing Update] 2025-08-16 - KDE Gear, Wine, Xfce, Python, Haskell
[Testing Updates] 2025-08-15 - Kernels, NVIDIA, VirtualBox, GCC, InputPlumber
[Stable Update] 2025-08-11 - Kernels, Mesa, KDE Frameworks, Systemd
[Testing Update] 2025-08-04 - Kernels, Toolchain, Blender, Mesa, Ollama
[Testing Update] 2025-07-06 - Kernels, KDE Gear, Mesa
[Testing Update] 2025-07-03 - Kernels, Linux-Firmware, Systemd, NVIDIA, Firefox, GStreamer
Wayland Lag on Wake and Login After latest update
[Testing Update] 2025-07-30 - QEmu, Firefox Beta, Tuxedo Drivers, Slimbook Service
[Stable Update] 2025-06-23 - Kernels, KDE, NVIDIA, Pamac, Wine, VirtualBox, PipeWire, Qt6
[Testing Update] 2025-06-20 - Kernels, Mesa, Steam, OpenGamepadUI, ZFS
[Testing Update] 2025-06-19 - KDE Frameworks, Nvidia, Pamac, Xorg, Wine
[Testing Update] 2025-05-17 - Kernel 6.15-rc6, Gitlab, Thunderbird
[Testing Update] 2025-06-14 - Firefox, Thunderbird, Login_NG, Erlang, Yoshimi
[Testing Update] 2025-11-27 - Firmware, GNOME, Xorg, Firefox, Qt, ROCm
[Testing Updates] 2025-06-11 - Kernels, Mesa, KDE Gear, LibreOffice, AMD ROCm
[Testing Update] 2025-05-15 - KDE Gear, KDE Frameworks, Firefox, GStreamer, LibreOffice
[Stable Update] 2025-07-18 - Kernels, UMU, KDE Frameworks, NetworkManager
[Testing Update] 2025-12-02 - Kernels, Pamac, COSMIC, GStreamer, Python
[Stable Update] 2025-12-08 - 25.1 Anh-Linh Preview
[Testing Update] 2025-12-07 - Kernels, COSMIC, Mesa, ROCm, Gambas
[Testing Update] 2025-12-09 - Plasma 6.5.4, Firefox, Deepin, Python, Haskell
[Stable Update] 2026-01-04 - Manjaro 26.0, Mesa, Firefox, LibreOffice, COSMIC
[Stable Update] 2025-12-15 - Kernels, NVIDIA, Plasma, Cosmic, Firefox
[Testing Update] 2025-12-13 - KDE Gear, Cosmic 1, NVIDIA
[Testing Update] 2025-05-09 - Kernels, Plasma 6.3.5, Grub, Qemu 10.0
[Testing Update] 2025-12-18 - Kernels, Systemd, Cinnamon, Pacman, Vulkan-SDK
[Testing Update] 2025-07-15 - Kernels, KDE Frameworks, NetworkManager, Poppler, UMU
[Stable Update] 2025-07-20 - Kernels, Mesa, Thunderbird, LibreOffice, Perl, Vulkan
[Testing Update] 2025-11-17 - Kernel 6.18-rc6, Thunderbird 145.0, COSMIC Beta 6
[Testing Update] 2026-01-03 - COSMIC 1.0.1, Budgie, NVIDIA-Driver-Assistant
Switch between Nvidia drivers without driver removal possible?
[Testing Update] 2025-05-06 - Kernels, Firefox, Thunderbird, Mesa, Pamac, GTK, Wine
[Testing Update] 2025-07-26 - Portmaster, Plymouth, Pipewire, Thunderbird
I finally reloaded with this version. I am happy with btrfs too which was the primary reason to reload my old laptop. I turned 2 x 240GB drives into a single (JBOD) with 453GB available to the system. This will give a little extra life to this old machine.
Load went smoothly. Just working out all the apps now. This is a good release.
Desktop… Yeah, that will have to wait. That is a Big job.
Edit: Here is a good little article if anyone else wants to do the same as me:
The It’s FOSS News article also mentions the release of Manjaro Summit Public Alpha (formerly known as Manjaro Immutable).
Hi,
Manjaro 25.0 Zetar Gnome Review (available on English)
About the YouTuber => System administrator by profession, Linux trainer in schools and training centers.
Video Review
https://www.youtube.com/watch?v=KiskRejdRkQ
Just wanted to mention.
Yesterday evening I switched my sff media box back from Manjaro. It previously ran Fedora Kinoite as a test for several months, but it’s FF/ffmpeg Flatpak video acceleration/decoding on Intel HD igpu has regressed/become bugged and the immutable nature was not helping resolve it.
Manjaro 25 was setup in 10 minutes and 5 minutes later my FF session/extension back-up was up and playing the episode’s I wanted to watch that evening.
Like a warm bath, back to normality.
Refreshed ISOs are now available. Grab 25.0.1!
Hi @philm
when 25.02 iso’s ? stable update to 25.02 without issues.
:grey_question:
@philm
Hi,
Just checked after update to 25.02 so conclusion the message from philm in the announcements is for a previous manjaro release.
2025-05-15_08-40
Right. Might need to update that section thrn …
As always Manjaro is good looking and very usable.
Remark. I believe that there is a flaw in the installation process. When installed as a second system on one disk drive, the installer seems to ignore that grub should be installed in the root directory / of the new installation. With update-grub the system can then be found by the first system. Manjaro seems to install however overwriting MBR and the first system’s boot information.
I thought this release was important enough to do a clean install on a new 1 tb ssd. Assome work everyone!!!
First of all: A big Thank You to the team - great work!
Secondly: A caveat for users with old nvidia cards - TLDR: get rid of that crap
Story Time:
As Xfce user I got nosy about wayland and btrfs that’s now the standard filesystem, so I chose to download Zetar 25.0.7 Gnome Edition and try it out on my Lenvo laptop with AMD Ryzen CPU and integrated graphics: All fine, no issues.
So I thought to also do a clean install on my main system (after doing a full backup, of course), which has an old nvidia card
  Device-1: NVIDIA GK208B [GeForce GT 710]
  • Installation with open source driver went fine
  • Toyed around with btrfs and got everything set up as I wanted it.
  • Installed Zoom, Audacity and OBS Studio, three programs I use very often and heavily - and from here it all went south.
Zoom on its own worked, but when I tried to set up OBS Studio to record my screen, it would simply freeze and crash
I remembered a similar problem a long while back and switched to the proprietary nvidia driver.
  • OBS Studio still would simply crash whenever I wanted to set up screen recording.
  • Zoom would work, but after a few minutes in a conference it would quietly crash.
  • Other programs like Thunar, Signal or Brave would simply disappear at random.
  • Audacity would crash randomly when updating the waveforms on the screen
  • Kdenlive would also crash during importing files into a project.
  • with journactl I discovered core dumps related to the nvidia drivers
My quick remediation: Downloaded Zetar 25.0.7 Xfce Edition (because no Wayland), did a clean install again, imported my btrfs subvolumes and I am now running Kernel 6.12.44-3 and inxi -G reports
  Device-1: NVIDIA GK208B [GeForce GT 710] driver: nvidia v: 470.256.02
  Device-2: Sunplus Innovation FHD Camera Microphone
    driver: snd-usb-audio,uvcvideo type: USB
  Display: x11 server: X.org v: 1.21.1.18 driver: X: loaded: N/A
    failed: nvidia gpu: nvidia,nvidia-nvswitch
    resolution: <missing: xdpyinfo/xrandr> resolution: 1: 1920x1080
    2: 1920x1080
  API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
    renderer: NVIDIA GeForce GT 710/PCIe/SSE2
    gpu: nvidia-settings,nvidia-smi x11: xprop
… and all problems are gone.
My longterm solution will be to get rid of the old nvidia card and replace my AMD Ryzen 7 5700X with an AMD Ryzen 7 5700G with integrated graphics.
Hallo everyone,
just a quick reminder: The iso manjaro-xfce-25.0.9-251003-linux612.iso is now too large to burn the iso to a DVD-RW for backup storage.
Best regards,
VV
buy a nvme put it in a small shellcase and ventoy it. Makes it easy for more bootable iso’s :slightly_smiling_face:
A post was split to a new topic: Sometimes the sddm-greeter-qt causes a core-dump
