[Stable Update] 2025-08-11 - Kernels, Mesa, KDE Frameworks, Systemd
Hello community, here we have another set of package updates. We are also happy to tell you about our latest Gaming Notebook from Slimbook.
Slimbook MANJARO III Specs
CPU: AMD Ryzen 7 8845HS
Graphics: Nvidia RTX 4070 8GB
Display: 15.3" WQHD 2560*1600p 120 Hz
Keyboard: RGB
Material: aluminum
Ports: 3x USB 3.2, 1x USB-C 3.2, HDMI 2.1, MiniDP
Connectivity: RJ45, Wifi 6, Bluetooth 5.2
RAM memory: up to 96GB DDR5
Storage: 2x SSD NVMe PCIe 4.0 M.2 up to 8TB
Keyboard: multiple languages
Operating System: Manjaro Gaming Plasma 6
More details
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • Most Kernels got updated
    • linux-firmware 20250808
    • this includes an initial release of 6.16 and first candidate of 6.17 kernel series
    • toolchain updates with gcc security fixes and glibc 2.42
  • Grub got updated. If you have issues, please read the troubleshoot notes in our second post.
  • Some Updates to GNOME
  • Blender 4.5.1
  • Mesa 25.1.7
  • Ollama 0.10.1
  • QEMU 10.0.3
  • Firefox 141.0.3 & 142.0b9
  • Tuxedo Drivers 4.14.4
  • Slimbook Service 0.8.5
  • GStreamer 1.26.5
  • KDE Frameworks 6.17.0
  • Systemd 257.8
  • Heroic Games Launcher 2.18.1
  • InputPlumber 0.62.0
  • OpenGamepadUI 0.41.0
  • Updates to Python and Haskell
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.296
  • linux510 5.10.240
  • linux515 5.15.189
  • linux61 6.1.147
  • linux66 6.6.101
  • linux612 6.12.41
  • linux615 6.15.9
  • linux616 6.16.0
  • linux617 6.17.0-rc1
  • linux61-rt 6.1.146_rt53
  • linux66-rt 6.6.99_rt58
  • linux612-rt 6.12.39_rt11
  • linux615-rt 6.15.0_rt2
Package Changes (Thu Aug 7 19:55:16 CEST 2025)
  • stable core x86_64: 99 new and 98 removed package(s)
  • stable extra x86_64: 3259 new and 3320 removed package(s)
  • stable multilib x86_64: 46 new and 45 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-08-11
Wrong default action removing phonon-qt6-vlc
I did my update as usual with pacman from the command line. Pacman usually provides pretty sane default answers and the user can just hit Enter, but today i noticed the following:
:: phonon-qt6-vlc-0.12.0-5 and phonon-qt5-vlc-0.12.0-3 are in conflict. Remove phonon-qt5-vlc? [y/N] y
The default is No, which will leave the old and deprecated package. This is obviously not what we want, so answer Y here.
Grub gained security fixes. Updating it may be risky
When Manjaro updates the grub package the actual installed binaries in master boot record (MBR) or UEFI won’t get updated. This is however needed to apply recent security fixes added to grub. Therefore we created Install-grub: a new way to keep your EFI/MBR in-sync with grub package to make it easier.
A more manual approach can be found here: [root tip] [How To] Primer on handling a grub package update
We also have it documented in our wiki on how to manually install grub when a disaster happens: GRUB/Restore the GRUB Bootloader - Manjaro. So if you are not experienced with it you can either ignore that extra step or have an install media at hand to recover as needed.
See also on how to create a boot media to install Manjaro fresh: Burn an ISO File - Manjaro. Those who want to get install medias having this update included may look for 25.0 ISOs when released or here: Releases · manjaro/release-review · GitHub
Remember, update-grub only updates the boot menu and install-grub is a script helper to install or reinstall grub on most case automatically via grub-install. All grub installations can be with a risk when not done properly as the user will change low level system parts and can easily break their systems.
Note: most likely grub was initially installed by an installer and therefore the user doesn’t know how grub got installed. So if you are unsure simply skip a reinstallation of grub.
Additional information can be found here.
Grub - “Error: grub_is_using_legacy_shim_lock_protocol not found"
The issue Error: grub_is_using_legacy_shim_lock_protocol not found is caused when the EFI firmware is pointing to the fallback /EFI/boot/bootx64.efi which is not updated automatically.
When it happens the efi-stub /EFI/Manjaro/grubx64.efi must be copied to /EFI/boot/ as bootx64.efi and this is what the install-grub script is designed for: Install-grub: a new way to keep your EFI/MBR in-sync with grub package
Booting from a live ISO running install-grub in chroot I may result in
WARNING: EFI directory not found! Grub couldn't be installed.
You can verified your mounts for $esp and check the /sys/firmware/efi/efivars.
efibootmgr can be used to create an efi entry pointing to the efi-stub in /EFI/Manjaro/grubx64.efi and manually generated grub.cfg using grub-mkconfig.
Example run of install-grub
[manjaro user]# install-grub
[D] GRUB 2 EFI-x64 found
[D] Checking EFI-Directory: /boot/efi
[D] Found EFI Bootloader: /boot/efi/EFI/Manjaro/grubx64.efi
[D] Found EFI Fallback: /boot/efi/EFI/boot/bootx64.efi
Install command will be: grub-install --no-nvram --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --recheck --force
Do you want to proceed? (yes/no) yes
ok, we will proceed
Grub will be installed on: EFI
Installing for x86_64-efi platform.
Installation finished. No error reported.
Update Grub Menu
ok, we will proceed
Found linux image: /boot/vmlinuz-6.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.15-x86_64.img
Found initrd fallback image: /boot/initramfs-6.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Warning: GRUB bootloader at /boot/efi/EFI/Manjaro was updated,
but it seems like you are not using it by default.
Please check your EFI boot priorities!
Example
[manjaro user]# efibootmgr
BootCurrent: 000A
Timeout: 1 seconds
BootOrder: 000A,0001,0003,0008,0009,0002,0004,0000,0007,0006,0005
Boot0000  Lenovo Cloud  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)/Uri(https://download.lenovo.com/pccbbs/cdeploy/efi/boot.efi)
Boot0001* UEFI OS       HD(1,GPT,519fa53d-c862-4efb-948b-eee1a5d9c584,0x1000,0x96000)/\EFI\BOOT\BOOTX64.EFI0000424f
Boot0002  UEFI: HTTP IPv4 Marvell AQtion 10Gbit Network Adapter PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)/Uri()0000424f
Boot0003* UEFI: PXE IPv4 Marvell AQtion 10Gbit Network Adapter  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)0000424f
Boot0004  UEFI: HTTP IPv6 Marvell AQtion 10Gbit Network Adapter PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv6([::],0,Static,[::],[::],64)/Uri()0000424f
Boot0005* Generic Usb Device    VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0006* CD/DVD Device VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0007  Win VDI Boot  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv4(0.0.0.0,0,DHCP,0.0.0.0,0.0.0.0,0.0.0.0)/Uri(https://download.lenovo.com/pccbbs/cdeploy/vdiboot/efi/vdi.efi)
Boot0008* UEFI: PXE IPv6 Marvell AQtion 10Gbit Network Adapter  PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/MAC(047bcba9026a,0)/IPv6([::],0,Static,[::],[::],64)0000424f
Boot0009* UEFI: KingstonDataTraveler 3.0PMAP, Partition 2       PciRoot(0x0)/Pci(0x3,0x1)/Pci(0x0,0x0)/Pci(0x8,0x0)/Pci(0x0,0x1)/USB(7,0)/HD(2,GPT,9bea21dc-4f71-6934-996a-cdea67030e7b,0x6f6ffd8,0x10000)0000424f
Boot000A* Manjaro Linux HD(1,GPT,519fa53d-c862-4efb-948b-eee1a5d9c584,0x1000,0x96000)/\EFI\MANJARO\GRUBX64.EFI
Set boot order (example)
[manjaro user]# efibootmgr --bootorder 000A,0001,0000
BootCurrent: 000A
Timeout: 1 seconds
BootOrder: 000A,0001,0000
Potential issues with toolchain update due to glibc 2.42
Whenever the toolchain gets updated, your system more or less switches to new versions of low level basic system package, which can soft-brick your system when not updated properly.
A more static release model of the likes of Debian or Ubuntu, only update the toolchain with major release updates. With Arch and Manjaro, this happens more often without a major release announcement.
Kernels and other system relevant parts need to been updated when that happens. glibc is used by more than 4955 packages.
To add a safety net to your system, you can install pacman-static:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/pacman-static-7.0.0.r6.gc685ae6-8-x86_64.pkg.tar.xz
… and maintain the system as usual via sudo pacman-static -Syu, even when the regular pacman might trow glibc errors: With update I see glibc errors
phonon-qt5 and phonon-qt5-gstreamer packages got dropped to AUR
Those packages used to be in the repo, but they were dropped to the AUR because they’re still qt5-based and no longer required by any of the official packages — with the exception perhaps that they might be a dependency of something installed from the AUR.
2025-07-12
SDDM may crash with Nvidia drivers
In some case Nvidia drivers need the following workaround in /etc/environment to launch SDDM properly:
MESA_LOADER_DRIVER_OVERRIDE=zink
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command in order to downgrade the installed package with the higher version to the version currently in the repository… :point_down:
 sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins.
 sudo pacman -S vlc-plugins-all
linux-firmware-meta replaces linux-fimware
With the linux-firmware-meta package, all of the firmware is now split up into individual packages, which are all installed as dependencies of linux-firmware-meta.
If you wish to uninstall the firmware packages that you don’t need — e.g. linux-firmware-nvidia — including the meta package itself, then be sure to mark the firmware packages you wish to keep as explicitly installed, or else pacman will regard them as orphans, which would be dangerous when cleaning out your real orphans.
 sudo pacman -D --asexplicit <name-of-package(s)>
2025-06-23
Breaking changes to wine and wine-staging
Transition to the new WoW64 wine and wine-staging
2025-06-16
We are transitioning the wine and wine-staging package to a pure wow64 build. This change removes the dependency on the multilib repository for wine and wine-staging.
The main reason for this is to align with upstream Wine development, which simplifies packaging and the dependency chain.
Potential Issues:
  • OpenGL Performance: A known limitation of the new WoW64 mode is reduced performance for 32-bit applications that use OpenGL directly
  • Breaking Changes: Existing 32-bit prefixes needs to be recreated
If you are facing issues with 32 bit prefixes, please recreate these and reinstall the application.
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduces a possible breaking change if you have custom scripts relying on the mirrors data file. If this is the case, then simply create a symlink from the new location under /var/lib back to the old location, i.e. /usr/share.
ln -s /var/lib/pacman-mirrors /usr/share/
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
avahi-discover python script may fail to discover services
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
2025-04-12
2025-03-24
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
No sound from PulseAudio after PipeWire update
If PulseAudio audio playback is suspended after PipeWire update, unload module-suspend-on-idle
pactl unload-module module-suspend-on-idle
If that works, create a custom default.pa configuration for PulseAudio in home folder
cp /etc/pulse/default.pa ~/.config/pulse/default.pa
and comment out module-suspend-on-idle in custom configuration
sed -i '/load-module module-suspend-on-idle/s/^/#/' ~/.config/pulse/default.pa
2025-03-05
[community] repository removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-05-02
community has been re-created as an empty repository so that systems where package manager configuration /etc/pacman.conf has not been updated can still be used to update packages from other repositories
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
2025-02-04
Kernel 4,19 and 6.11 are EOL, 6.11 and 4.19 got removed from repos
Kernel 6.11 and 4.19 got marked [EOL] on kernel.org
Linux 6.11 and 4.19 have been removed from the repositories.
Please ensure your system use a supported kernel mhwd-kernel -l
PostgreSQL users should consider to prepare the change of major version 16→17
More info here and here
Update libpamac before installing the 2025-02-04 updates
Run sudo pacman -Sy libpamac in a terminal to make sure pamac-manager doesn’t crash during the update.
XFCE 4.20 may blank display after 5 mins idle time regardless of power management settings
Most likely this: Disable screen blanking
Call xfce4-screensaver-preferences and disable the screensaver.
xfce4-screensaver - Usage [Xfce Docs]
Installed the core packages without any problems. When it finished, said a reboot was needed to complete the installation. I clicked OK and suddenly another window popped up asking me to install the phonon-qt5 and phonon-qt5-gstreamer packages from the AUR and that need to import the authors’ GPG keys. Can be legit, but seems a bit strange…
Those packages used to be in the repo, but they were dropped to the AUR because they’re still qt5-based and no longer required by any of the official packages — with the exception perhaps that they might be a dependency of something you’ve installed from the AUR.
A post was split to a new topic: With update I see glibc errors
phonon-qt5-vlc - circular dependency Fix
[SOLVED] phonon-qt5-vlc - circular dependency? / Pacman & Package Upgrade Issues / Arch Linux Forums
sudo pacman -Rcs phonon-qt5-vlc phonon-qt5
phonon-qt5-vlc requires an actual implementation of it. But phonon-qt5 is no longer in repos. phonon-qt6 is. Is this Arch or something else?
Keep your system up-to-date! Particularly if using a rolling-release distro like Arch.
As mentioned here, I had to remove dracut-hook for the install to work with an installed dracut.
Additionally, I am now unable to generate an initramfs with dracut. It failed with the following during the system upgrade:
Updating initramfs with dracut
--> Building initramfs for linux612 (6.12.41-1-MANJARO)
dracut[W]: If you need to use bluetooth, please include it explicitly.
dracut-install: ERROR: cannot mmap '/var/tmp/dracut.dqG7J4J/initramfs/usr/bin/fsck.overlay': Invalid argument
dracut[F]: Resolving executable dependencies failed
--> Building initramfs for linux615 (6.15.9-2-MANJARO)
dracut-install: ERROR: cannot mmap '/var/tmp/dracut.dIFpr8J/initramfs/usr/bin/fsck.overlay': Invalid argument
--> Building initramfs for linux616 (6.16.0-5-MANJARO)
dracut-install: ERROR: cannot mmap '/var/tmp/dracut.d4vDA0P/initramfs/usr/bin/fsck.overlay': Invalid argument
Additionally, if I run dracut manually, it now fails with:
> sudo dracut --regenerate-all
dracut[I]: Executing: /usr/bin/dracut --kver=6.12.41-1-MANJARO
dracut[F]: Can't write to /boot/efi/1cb921454d6a481d8eae8063f4e3ec27/6.12.41-1-MANJARO: Directory /boot/efi/1cb921454d6a481d8eae8063f4e3ec27/6.12.41-1-MANJARO does not exist or is not accessible.
dracut[I]: Executing: /usr/bin/dracut --kver=6.15.9-2-MANJARO
dracut[F]: Can't write to /boot/efi/1cb921454d6a481d8eae8063f4e3ec27/6.15.9-2-MANJARO: Directory /boot/efi/1cb921454d6a481d8eae8063f4e3ec27/6.15.9-2-MANJARO does not exist or is not accessible.
dracut[I]: Executing: /usr/bin/dracut --kver=6.16.0-5-MANJARO
dracut[F]: Can't write to /boot/efi/1cb921454d6a481d8eae8063f4e3ec27/6.16.0-5-MANJARO: Directory /boot/efi/1cb921454d6a481d8eae8063f4e3ec27/6.16.0-5-MANJARO does not exist or is not accessible.
I installed mkinitcpio now as a workaround.
Also my partition layout in case it helps (I removed some output):
> lsblk -f
NAME                                          FSTYPE      FSVER LABEL MOUNTPOINTS
sda
├─sda1                                        vfat        FAT32       /boot/efi
├─sda2                                        ext4        1.0         /boot
└─sda3                                        crypto_LUKS 1
  └─luks-fbaf2308-0380-4355-a033-a64480e2ff45 btrfs                   /var/log
        /var/cache
        /home
sdb
└─sdb1                                        ext4        1.0
In my case upgrading kernel from 6.15.x to 6.16.0 caused constant stutters on desktop with intel iGPU. Reverting back to 6.15.x solves the problem for now
11 posts were split to a new topic: Get a black screen with “Error: grub_is_using_legacy_shim_lock_protocol not found"
So pacman -R phonon-qt5 phonon-qt5-gstreamer and problem solved. :axe: :grinning:
I still have 21 qt5 packages installed, I wonder if I all them can be uninstalled too…
Or simply remove your orphans. :point_down:
sudo pacman -Rns $(pacman -Qdtq)
:wink:
Probably not. I’ve still got a whole boatload of them as well, because some packages still depend on them. For instance, calligraplan and clipgrab still haven’t been ported to qt6 yet, and there are yet many others.
My update got stuck at 20/37 Installing Grub to MBR/EFI
Warning: os-prober will be executed to detect other bootable partitions
It’s output will be used to detect bootable binaries on them and create new boot entries.
Got an other SSD with windows, no secureboot.
I’ve removed dracut-hook from the repos as it’s now obosolete:
The dracut and dracut-gitAUR packages include hooks for pacman to automatically generate new initramfs images upon each kernel upgrade.
– dracut - ArchWiki
I first performed the update on my test laptop and then ran sudo install-grub – everything worked fine. I then performed the update on my main computer WITHOUT running sudo install-grub afterwards – everything also worked fine (both times followed by a restart, of course). From what you say, I gather that the corresponding hook makes an additional install-grub obsolete (?).
Short answer is yes, but looking at the contents of the hook file provides the proof… note the Exec line
[Trigger]
Type = Package
Operation = Upgrade
Target = grub
[Action]
Description = Installing Grub to MBR/EFI
When = PostTransaction
Exec = /usr/bin/install-grub
I got
error: failed to commit transaction (conflicting files)
npm: /usr/lib/node_modules/npm/lib/utils/oidc.js exists in filesystem
Searched the net and ran this:
sudo pacman -S npm --overwrite ‘/usr/lib/node_modules/npm/*’
sudo pacman -Syyu
I don’t remember/have a clue what I installed that uses node.js. Haven’t noticed any problems.
You can check which package owns an installed file by using the pacman -Qo command:
pacman -Qo /usr/lib/node_modules/npm/lib/utils/oidc.js
/usr/lib/node_modules/npm/lib/utils/oidc.js is owned by npm 11.5.2-1
For less detailed output, add q to the command:
pacman -Qoq /usr/lib/node_modules/npm/lib/utils/oidc.js
npm
Of course, now that you have overwritten the conflicting file with the npm package, you may have to work out another way to find out which package previously installed the file (if you want to spend the time doing so).
had no issues except for some reason no Japanese Characters displayed correctly and instead horrendous escape sequences appeared when e.g. listing files with those characters in the filenames.
Also typing Japanese in the Console just yielded no characters typed.
I was able to trace it to just no locale being generated on the system.
Upon inspecting /etc/locale.gen, i confirmed all locales where commented out.
On un-commenting locales i wanted, and regenerating new ones with # locale-gen, a reboot fixed all my problems.
Maybe i missed something in one of the earlier updates?
Hmm, all the locale’s rem’d out sounds like what a pacnew file would contain… your post Manjaro calemares install will minimally have a section at the bottom that includes the install locale choice(s)…
# Locales enabled by Calamares
en_CA.UTF-8 UTF-8
en_US.UTF-8 UTF-8
so to me it sounds like you might have made an “error” when working through your pacnew’s and overwrote your locale file instead of selectively migrating across any required new lines from the pacnew while preserving your pre-existing config choices in the file.
Should I be worried about all of those warnings? Also I think I haven’t seen update of this size yet.
sudo pacman -Syu
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
warning: dependency cycle detected:
warning: nvidia-utils will be installed before its mesa dependency
warning: erlang-ssl will be installed before its erlang-inets dependency
warning: python-soupsieve will be installed before its python-beautifulsoup4 dependency
warning: mhwd-nvidia will be installed before its mhwd-db dependency
warning: phonon-qt6-vlc will be installed before its phonon-qt6 dependency
Packages (411) ...
Total Download Size:    5614,09 MiB
Total Installed Size:  16073,64 MiB
Net Upgrade Size:         59,21 MiB
