[Testing Updates] 2025-08-26 - Kernels, ZFS, Deepin, Python, Haskell
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • some Kernels got updated
  • zfs 2.3.4
  • Updates to Deepin
  • Python and Haskell updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.296
  • linux510 5.10.240
  • linux515 5.15.189
  • linux61 6.1.148
  • linux66 6.6.102
  • linux612 6.12.43
  • linux615 6.15.11 [EOL]
  • linux616 6.16.3
  • linux617 6.17.0-rc3
  • linux61-rt 6.1.146_rt53
  • linux66-rt 6.6.101_rt59
  • linux612-rt 6.12.43_rt12
  • linux615-rt 6.15.0_rt2
  • linux616-rt 6.16.0_rt3
Package Changes (Tue Aug 26 21:23:03 CEST 2025)
  • testing core x86_64: 2 new and 2 removed package(s)
  • testing extra x86_64: 1201 new and 1199 removed package(s)
  • testing multilib x86_64: 6 new and 6 removed package(s)
Overlay Changes
  • testing core x86_64: 4 new and 4 removed package(s)
  • testing extra x86_64: 47 new and 47 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-08-26
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
2025-06-19
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduce a possible breaking change if you have custom scripts relying on the mirrors data file.
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
2025-06-14
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
Previous testing threads:
How should I understand this? Does this mean that I can now select ZFS as a file system during installation?
We only support zfs as an external module and also don’t have adjusted the Calamares installer to utilize it yet. You can read more about ZFS on the Arch Wiki and how it may be usable on an Install media.
thanks @philm
Thanks for (so quickly!) releasing a kernel with the commit reverted that prevented suspend/resume on my machine :+1:
Updating after a month (not sure if related) but I am getting
unable to satisfy dependency 'nvidia-utils=580.76.05' required by lib32-nvidia-utils
Was 580.xx added and then removed since I can’t find them in package manager?
Think so.
I did run the update 2 days ago, I believe since yesterday evening this message comes up:
Warnung: libxnvctrl: Lokale Version (580.76.05-1) ist neuer als extra (575.64.05-1)
Warnung: linux612-nvidia-open: Lokale Version (580.76.05-3) ist neuer als extra (575.64.05-5)
Warnung: linux616-nvidia-open: Lokale Version (580.76.05-9) ist neuer als extra (575.64.05-6)
Warnung: linux66-nvidia-open: Lokale Version (580.76.05-2) ist neuer als extra (575.64.05-6)
Warnung: mhwd-nvidia: Lokale Version (580.76.05-2) ist neuer als extra (575.64.05-1)
Warnung: nvidia-settings: Lokale Version (580.76.05-2) ist neuer als extra (575.64.05-1)
Warnung: nvidia-utils: Lokale Version (580.76.05-2) ist neuer als extra (575.64.05-1)
Warnung: opencl-nvidia: Lokale Version (580.76.05-2) ist neuer als extra (575.64.05-1)
right, I forgot to downgrade lib32 as well
What is the background? As everything seems to work with my 2070mobile … and Kernel 6.12
there are still some regressions in the 580 driver series: 580 release feedback & discussion - #174 by tda06261 - Linux - NVIDIA Developer Forums
thanks for the clarification!
