[Testing Update] 2025-09-20 - Kernels, Mesa, Firefox, Deepin, Gstreamer
Hello community, here we have another set of package updates. This will be mostly the last update to our Zetar release cycle. Please test it thru and let us know if there are any issues left. Also I won’t be very responsive next week, but might catch up on the weekend with your feedbacks.
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.299
  • linux510 5.10.244
  • linux515 5.15.193
  • linux61 6.1.153
  • linux66 6.6.107
  • linux612 6.12.48
  • linux615 6.15.11 [EOL]
  • linux616 6.16.8
  • linux617 6.17.0-rc6
  • linux61-rt 6.1.151_rt54
  • linux66-rt 6.6.106_rt61
  • linux612-rt 6.12.43_rt12
  • linux615-rt 6.15.0_rt2
  • linux616-rt 6.16.0_rt3
Package Changes (Sat Sep 20 09:38:35 CEST 2025)
  • testing multilib x86_64: 15 new and 14 removed package(s)
  • testing extra x86_64: 1375 new and 1370 removed package(s)
Overlay Changes
  • testing core x86_64: 10 new and 10 removed package(s)
  • testing extra x86_64: 75 new and 76 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-09-02
  • pacman-mirrors version 5.1
    Deprecation of --geoip in favor of -tz/--timezone.
    This internal change make mirror-list generation use your system’s configured timezone - when applicable - without using an IP location provider.
    More privacy..
2025-08-24
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
It seems on older hardware the mesa 25.2.x update created some regressions which may result in black screens or flickering. Some older Nvidia cards with nouveau driver seem to be affected.
You can try to use the 25.1.x series of Mesa via this repo. Simply place it on top of [extra] in your /etc/pacman.conf file and use sudo pacman -Syuu to downgrade.
[mesa-251]
SigLevel = PackageRequired
Server = https://download.manjaro.org/pkgs/mesa
If you have no graphical session available you can access the bootloader by pressing ESC key during boot and select the bootloader entry. Press CTRL+E for edit and search for the words quiet and splash. Delete those and add 3 to the line. Then execute CTRL+x to start your session. You will land in a text console TTY. Login with your user.
Edit the /etc/pacman.conf with nano: sudo nano /etc/pacman.conf. Perform the downgrade and reboot.
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
Previous testing threads:
Maybe related to last update already, I got follwing error message during update:
Fehler: Konnte Datei 'linux-firmware-mediatek-20250917-2-any.pkg.tar.zst' nicht von ftp.gwdg.de übertragen : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
Update went OK, anyhow.
Looks like you had a bad connection to that mirror at the time of downloading.
That’s what I also thought, but after updating the mirrorlist, next update trial did not show any package…
The update went through without any problems on the XFCE setup. Kernel 6.16 seems stable so far and performance with Mesa improvements feels smoother on Vulkan-based applications.
This is a libalpm message.
The most common cause is when the mirror you are syncing from has been updated during your download or your mirrorlist has been changed either deliberately or by pamac-mirrorlist.timer.
The process is roughly
  • libalpm pulls metadata based on the HTTP-header Last-Modified for the given file - if the local file timestamp is never than or matches Last-Modified the file is not updated
  • libalpm generates a list of packages changed based on the structure in /var/lib/pacman/local
  • libalpm download the packages in the list including signature
  • libalpm verifies the downloaded packages using signature
  • libalpm runs transactions for the download packages
If the mirror syncs often - the package list may contain a package which was valid when the list was generated - but becomes invalid by the time you reach the changed package in the download list.
This will cause the server to try and download the file - which the server did in fact provide to another download process seconds ago - but now it is gone - the cache is invalid and connection times out.
It is a little complex to explain - it is a simplified explanation - but it is often best solved by executing a forced metadata refresh using -Syyu.
With this update everything is fine with the system now, everything looks good.
Just to confirm, The MEDIATEK MT7922 wireless is working again as it should @philm
This would explain why there was no package identified to be updated after forcing a refresh of the mirrorlist and again update using -Syyu.
