[Testing Update] 2025-05-15 - KDE Gear, KDE Frameworks, Firefox, GStreamer, LibreOffice
Hello community, here we have another set of package updates. Since I’m still recovering from my move back to Europe from Asia, I might be less responsive on the forum. So lets test these packages thoroughly so we can do another stable branch snap.
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: See current promotion
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.293
  • linux510 5.10.237
  • linux515 5.15.182
  • linux61 6.1.138
  • linux66 6.6.90
  • linux612 6.12.28
  • linux613 6.13.12 [EOL]
  • linux614 6.14.6
  • linux615 6.15-rc5
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.87_rt54
  • linux612-rt 6.12.16_rt9
  • linux613-rt 6.13_rt5
  • linux614-rt 6.14.0_rt3
Package Changes (Thu May 15 09:37:03 CEST 2025)
  • testing core x86_64: 22 new and 22 removed package(s)
  • testing extra x86_64: 1903 new and 1879 removed package(s)
  • testing multilib x86_64: 15 new and 15 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-05-15
2025-03-20
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
2025-03-05
[community] repo removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
Previous testing threads:
There’s a problem with the KDE Frameworks update for me. Chromium is consistently taking 25 seconds to load, normally instant. I can solve it by running Chromium with:
env XDG_CURRENT_DESKTOP=chromium chromium
journalctl -f give any clues? Chromium launches instantly for me.
Yes, it’s KWallet causing it.
Is it disabled?
You’re right, the update has disabled it, re-enabling does solve the issue. Thanks for your help in further diagnosing it.
Known issue with kwallet and chromium: Please consider applying patch c9a9252d34a6 (KDE bug 504014) (#1) · Issues · Arch Linux / Packaging / Packages / kwallet · GitLab
The issue with Kwallet should be fixed with 6.14.0-2.
Not sure about that. It asked me for a password when I started kmail. It normally never does that.
I’ve edited my above reply to link the upstream issue.
It seems what you’re referring to is not related to that issue / fix. Either way, Phil already linked to the Arch packaging issue that links to the same upstream issue.
Can confirm this new issue on manjaro stable with latest kwallet 6.14.0-2.
Now kwallet asks for my password on login, which never was the case before.
Edit: @Yochanan: It also dumped core, this is definitely related to recent updates from yesterday afternoon. The kwallet version distributed 2025-05-14 with all the other latest stable packages didn’t have this specific issue.
?!? Kwallet normaly got only updated in unstable branch for now.
I’ve now removed the forwarded kwallet from the branches. We will push it with a regular branch snap as needed. Users on stable branch should perform a downgrade to the working 6.13.0 version of kwallet via: sudo pacman -Syuu.
