[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.296
  • linux510 5.10.240
  • linux515 5.15.189
  • linux61 6.1.146
  • linux66 6.6.99
  • linux612 6.12.39
  • linux615 6.15.7
  • linux616 6.16.0-rc6
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.94_rt56
  • linux612-rt 6.12.28_rt10
  • linux615-rt 6.15.0_rt2
Package Changes (Sat Jul 19 08:50:01 CEST 2025)
  • testing core x86_64: 15 new and 15 removed package(s)
  • testing extra x86_64: 1752 new and 1744 removed package(s)
  • testing multilib x86_64: 22 new and 22 removed package(s)
Overlay Changes
  • testing core x86_64: 19 new and 20 removed package(s)
  • testing extra x86_64: 124 new and 126 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-07-19
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
2025-06-19
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduce a possible breaking change if you have custom scripts relying on the mirrors data file.
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
2025-06-14
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
Previous testing threads:
Updated, but it wasn’t smooth. The Grub update was problematic. Needed a recovery USB to repair it - based on that experience I’d strongly recommend anyone yet to update to make sure you’ve got a recovery USB to hand! Despite all that, grateful for the update, thank you!
Anything from logs might be able to help others? Update went smooth on my desktop and another laptop. I’ve only had to do that recently after updating the BIOS and having to reinstall GRUB
upgrade was mostly fine. I updated the last 3-4 weeks of testing releases in one batch.
Only issue I have seen so far was mhwd looking for an old libhd.so file. I reinstalled using pacman but that didn’t fix it. I then added a symlink /usr/lib/libhd.so.24 -> /usr/lib/libhd.so.25.0, which appears to have resolved it for now. May be an issue with my setup but figured I’d post here in case others run into the same problem.
mhwd version: v0.6.6-4
hwinfo version: 25.0-1
Exact error was:
mhwd: error while loading shared libraries: libhd.so.24: cannot open shared object file: No such file or directory
Be more specific what had happen with your update and why you had to repair …
The actual error that greeted me at boot was “grub is using legacy shim lock protocol not found”. I’ve been through the logs and can see Grub was definitely updating the EFI partition. It created grubx64.efi just fine, no errors at that point. Reinstalled it after chrooting in and it’s now fine.
Any chance you had install-grub installed? Install-grub: a new way to keep your EFI/MBR in-sync with grub package. Normally grub needs to be installed manually as just updating the package grub doesn’t do anything … Arch Linux - News: Grub bootloader upgrade and configuration incompatibilities
I do, yes. You wouldn’t recommend it?
The shim lock protocol is usually only used by grub when Secure Boot is enabled. Or you have a buggy UEFI firmware. In the latter case I would recommend to install grub with --disable-shim-lock option.
If you have an off-standard boot situation better not use the ìnstall-grub script.
I dont have updates yet. Maybe un some hours they appear.
It is a tool which may work 98% on most default UEFI systems. Since your system seems to be problematic I suggest to maintain grub on your end manually. Arch and Manjaro normally don’t maintain grub at all. So the grub version you install via the install media is the one installed to your UEFI or MBR. Read my post again to get the needed background what we tried to achieve with this script: Install-grub: a new way to keep your EFI/MBR in-sync with grub package
new version of mhwd was added so I don’t think anyone else should run into this issue with missing libhd.so.24. Thanks for the quick fix, yall!
Oh thank god, I’m back up and running.
Same! At this point my default assumption is that if I’m going to update a manjaro system, it will bork the grub. Every time. But YMMV I guess.
Everyone should ideally always make sure to have such, no matter what. But yes. A life saver.
Something I’ve noticed tho, and multiple times over the past 3 years of running manjaro, pamac-manager has a habit of closing the GUI randomly in the midst of the update. Update still happens in the BG but you just can’t keep any track of it.
Best you can do is relaunch pamac-manager, press update again and see it complain about another instance already running… until it stops complaining about that and then assume that it’s done…
…except you often restart before it’s had a chance to update grub I guess.
Honestly a rather terrible experience. I don’t think pamac should just randomly close itself like that in the middle of an update. Something is definitely wrong with that.
Please post the output of:
pacman -Qs pamac-gtk
local/pamac-gtk 11.7.3-3
    A Package Manager based on libalpm with AUR and Appstream support (GTK4)
Try switching to pamac-gtk3, which seems to be more suited to Plasma than the Gnome/Adwaita-focused pamac-gtk:
sudo pacman -Syu pamac-gtk3
This might help to prevent that :
Yes - that can happen - especially on stable branch.
Large branch syncs usually affect nearly everything - the GUI is explicitly vulnerable - see the explanation mentioned above.
My own preference is smaller chunks; even those can cause an incident for an experienced member.
[Unstable Update] July 2025 - #31 by linux-aarhus
This is what happened for me on Juli 21. when I started my system in the morning.
I had updated my system the day before but none of the updates required restart and I didn’t notice grub was updated.
The issue is caused when the EFI firmware is pointing to the fallback /EFI/boot/bootx64.efi which is not updated automagically.
When it happens the efi-stub /EFI/Manjaro/grubx64.efi must be copied to /EFI/boot/ as bootx64.efi and this is what the install-grub script is designed for.
Booting from a live ISO - however - in my case the script didn’t work - running install-grub in chroot I was greeted by
WARNING: EFI directory not found! Grub couldn't be installed.
I verified my mounts and $esp was present and I checked the /sys/firmware/efi/efivars.
I used efibootmgr to create an efi entry pointing to the efi-stub in /EFI/Manjaro/grubx64.efi and manually generated grub.cfg using grub-mkconfig.
After booting the system using the systems boot override to select the Manjaro entry - the install-grub script did a successful run.
As a sidenote, on KDE, the update went smoothly, but I’ve noticed a large number of systemd-coredump log entries related to kclock and to spectacle.
I haven’t noticed any outright crashes in these apps, so I’m a little surprised to see so many log entries. Here’s an excerpt :
output : journalctl --reverse --grep=nvidia --boot=-0
Jul 22 20:15:19 REDACTED systemd-coredump[148026]: Process 146405 (kclock) of user 1000 dumped core.
                                                      Stack trace of thread 146405:
                                                      #0  0x00007fbd5ecc3415 _ZN20QQmlComponentPrivate21prepareLoadFromModuleE14QAnyStringViewS0_N14QQmlTypeLoader4ModeE (libQt6Qml.so.6 + 0x2c3415)
                                                      #1  0x00007fbd5ecc34ea _ZN13QQmlComponent14loadFromModuleE14QAnyStringViewS0_NS_15CompilationModeE (libQt6Qml.so.6 + 0x2c34ea)
                                                      #2  0x00007fbd4bfafee4 n/a (libKirigamiLayouts.so.6 + 0x16ee4)
                                                      #3  0x00007fbd4bfb044d n/a (libKirigamiLayouts.so.6 + 0x1744d)
                                                      #4  0x00007fbd4bfb49ce n/a (libKirigamiLayouts.so.6 + 0x1b9ce)
                                                      #5  0x00007fbd4bfb5655 n/a (libKirigamiLayouts.so.6 + 0x1c655)
                                                      #6  0x00007fbd5e3d37ef n/a (libQt6Core.so.6 + 0x1d37ef)
                                                      #7  0x00007fbd5d1ad8cf _ZN17QQuickItemPrivate24setEffectiveVisibleRecurEb (libQt6Quick.so.6 + 0x1ad8cf)
                                                      #8  0x00007fbd5d1ad971 _ZN17QQuickItemPrivate10setVisibleEb (libQt6Quick.so.6 + 0x1ad971)
                                                      #9  0x00007fbd4bfb2f96 n/a (libKirigamiLayouts.so.6 + 0x19f96)
                                                      #10 0x00007fbd4bfb81c9 n/a (libKirigamiLayouts.so.6 + 0x1f1c9)
                                                      #11 0x00007fbd5d1a9974 _ZN17QQuickItemPrivate10itemChangeEN10QQuickItem10ItemChangeERKNS0_14ItemChangeDataE (libQt6Quick.so.6 + 0x1a9974)
                                                      #12 0x00007fbd5d1a14b0 _ZN17QQuickItemPrivate11removeChildEP10QQuickItem (libQt6Quick.so.6 + 0x1a14b0)
                                                      #13 0x00007fbd5d1a1d21 _ZN10QQuickItem13setParentItemEPS_ (libQt6Quick.so.6 + 0x1a1d21)
                                                      #14 0x00007fbd5d1d8554 n/a (libQt6Quick.so.6 + 0x1d8554)
                                                      #15 0x00007fbd5d466907 n/a (libQt6Quick.so.6 + 0x466907)
                                                      #16 0x00007fbd5e3b8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #17 0x00007fbd5e3bfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #18 0x00007fbd5d97f286 n/a (libQt6QuickTemplates2.so.6 + 0x17f286)
                                                      #19 0x00007fbd5e3c0d3c _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c0d3c)
                                                      #20 0x00007fbd5fd01c70 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x101c70)
                                                      #21 0x00007fbd5e368118 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x168118)
                                                      #22 0x00007fbd5e3684fb _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x1684fb)
                                                      #23 0x00007fbd5e63fcf8 n/a (libQt6Core.so.6 + 0x43fcf8)
                                                      #24 0x00007fbd5e10887d n/a (libglib-2.0.so.0 + 0x5e87d)
                                                      #25 0x00007fbd5e109cd7 n/a (libglib-2.0.so.0 + 0x5fcd7)
                                                      #26 0x00007fbd5e109ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                      #27 0x00007fbd5e63c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                      #28 0x00007fbd5e3744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                      #29 0x00007fbd5e36c7c1 _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x16c7c1)
                                                      #30 0x000055a6634d05cc n/a (/usr/bin/kclock + 0xd5cc)
                                                      #31 0x00007fbd5dc376b5 n/a (libc.so.6 + 0x276b5)
                                                      #32 0x00007fbd5dc37769 __libc_start_main (libc.so.6 + 0x27769)
                                                      #33 0x000055a6634d0b25 n/a (/usr/bin/kclock + 0xdb25)
                                                      Stack trace of thread 146416:
                                                      #0  0x00007fbd5dcade22 n/a (libc.so.6 + 0x9de22)
                                                      #1  0x00007fbd5dca1fda n/a (libc.so.6 + 0x91fda)
                                                      #2  0x00007fbd5dca264c n/a (libc.so.6 + 0x9264c)
                                                      #3  0x00007fbd5dca4d1e pthread_cond_wait (libc.so.6 + 0x94d1e)
                                                      #4  0x00007fbd518bc188 n/a (libEGL_nvidia.so.0 + 0xbc188)
                                                      #5  0x00007fbd5188afe1 n/a (libEGL_nvidia.so.0 + 0x8afe1)
                                                      #6  0x00007fbd518c1bae n/a (libEGL_nvidia.so.0 + 0xc1bae)
                                                      #7  0x00007fbd5dca57eb n/a (libc.so.6 + 0x957eb)
                                                      #8  0x00007fbd5dd2918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 146410:
                                                      #2  0x00007fbd5dca2024 n/a (libc.so.6 + 0x92024)
                                                      #3  0x00007fbd5dd1c5a6 ppoll (libc.so.6 + 0x10c5a6)
                                                      #4  0x00007fbd5e109e04 n/a (libglib-2.0.so.0 + 0x5fe04)
                                                      #5  0x00007fbd5e109ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                      #6  0x00007fbd5e63c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                      #7  0x00007fbd5e3744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                      #8  0x00007fbd5e48e054 _ZN7QThread3runEv (libQt6Core.so.6 + 0x28e054)
                                                      #9  0x00007fbd5e51ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #10 0x00007fbd5dca57eb n/a (libc.so.6 + 0x957eb)
                                                      #11 0x00007fbd5dd2918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 146408:
                                                      #3  0x00007fbd5dd1c05e __poll (libc.so.6 + 0x10c05e)
                                                      #4  0x00007fbd593d64a3 n/a (libQt6WaylandClient.so.6 + 0x654a3)
                                                      #5  0x00007fbd5e51ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #6  0x00007fbd5dca57eb n/a (libc.so.6 + 0x957eb)
                                                      #7  0x00007fbd5dd2918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 146407:
                                                      Stack trace of thread 146406:
                                                      #8  0x00007fbd5e4873c6 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2873c6)
                                                      #9  0x00007fbd5f17adae n/a (libQt6DBus.so.6 + 0x37dae)
                                                      #10 0x00007fbd5e51ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #11 0x00007fbd5dca57eb n/a (libc.so.6 + 0x957eb)
                                                      #12 0x00007fbd5dd2918c n/a (libc.so.6 + 0x11918c)
Jul 22 20:01:30 REDACTED systemd-coredump[146419]: Process 142667 (kclock) of user 1000 dumped core.
                                                      Stack trace of thread 142667:
                                                      #0  0x00007fd1162c3415 _ZN20QQmlComponentPrivate21prepareLoadFromModuleE14QAnyStringViewS0_N14QQmlTypeLoader4ModeE (libQt6Qml.so.6 + 0x2c3415)
                                                      #1  0x00007fd1162c34ea _ZN13QQmlComponent14loadFromModuleE14QAnyStringViewS0_NS_15CompilationModeE (libQt6Qml.so.6 + 0x2c34ea)
                                                      #2  0x00007fd0ec34dee4 n/a (libKirigamiLayouts.so.6 + 0x16ee4)
                                                      #3  0x00007fd0ec34e44d n/a (libKirigamiLayouts.so.6 + 0x1744d)
                                                      #4  0x00007fd0ec3529ce n/a (libKirigamiLayouts.so.6 + 0x1b9ce)
                                                      #5  0x00007fd0ec353655 n/a (libKirigamiLayouts.so.6 + 0x1c655)
                                                      #6  0x00007fd1159d37ef n/a (libQt6Core.so.6 + 0x1d37ef)
                                                      #7  0x00007fd1147ad8cf _ZN17QQuickItemPrivate24setEffectiveVisibleRecurEb (libQt6Quick.so.6 + 0x1ad8cf)
                                                      #8  0x00007fd1147ad971 _ZN17QQuickItemPrivate10setVisibleEb (libQt6Quick.so.6 + 0x1ad971)
                                                      #9  0x00007fd0ec350f96 n/a (libKirigamiLayouts.so.6 + 0x19f96)
                                                      #10 0x00007fd0ec3561c9 n/a (libKirigamiLayouts.so.6 + 0x1f1c9)
                                                      #11 0x00007fd1147a9974 _ZN17QQuickItemPrivate10itemChangeEN10QQuickItem10ItemChangeERKNS0_14ItemChangeDataE (libQt6Quick.so.6 + 0x1a9974)
                                                      #12 0x00007fd1147a14b0 _ZN17QQuickItemPrivate11removeChildEP10QQuickItem (libQt6Quick.so.6 + 0x1a14b0)
                                                      #13 0x00007fd1147a1d21 _ZN10QQuickItem13setParentItemEPS_ (libQt6Quick.so.6 + 0x1a1d21)
                                                      #14 0x00007fd1147d8554 n/a (libQt6Quick.so.6 + 0x1d8554)
                                                      #15 0x00007fd114a66907 n/a (libQt6Quick.so.6 + 0x466907)
                                                      #16 0x00007fd1159b8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #17 0x00007fd1159bfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #18 0x00007fd114f7f286 n/a (libQt6QuickTemplates2.so.6 + 0x17f286)
                                                      #19 0x00007fd1159c0d3c _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c0d3c)
                                                      #20 0x00007fd117101c70 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x101c70)
                                                      #21 0x00007fd115968118 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x168118)
                                                      #22 0x00007fd1159684fb _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x1684fb)
                                                      #23 0x00007fd115c3fcf8 n/a (libQt6Core.so.6 + 0x43fcf8)
                                                      #24 0x00007fd11511887d n/a (libglib-2.0.so.0 + 0x5e87d)
                                                      #25 0x00007fd115119cd7 n/a (libglib-2.0.so.0 + 0x5fcd7)
                                                      #26 0x00007fd115119ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                      #27 0x00007fd115c3c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                      #28 0x00007fd1159744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                      #29 0x00007fd11596c7c1 _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x16c7c1)
                                                      #30 0x0000556350d795cc n/a (/usr/bin/kclock + 0xd5cc)
                                                      #31 0x00007fd1152376b5 n/a (libc.so.6 + 0x276b5)
                                                      #32 0x00007fd115237769 __libc_start_main (libc.so.6 + 0x27769)
                                                      #33 0x0000556350d79b25 n/a (/usr/bin/kclock + 0xdb25)
                                                      Stack trace of thread 142670:
                                                      #0  0x00007fd1152ade22 n/a (libc.so.6 + 0x9de22)
                                                      #1  0x00007fd1152a1fda n/a (libc.so.6 + 0x91fda)
                                                      #2  0x00007fd1152a2024 n/a (libc.so.6 + 0x92024)
                                                      #3  0x00007fd11531c05e __poll (libc.so.6 + 0x10c05e)
                                                      #4  0x00007fd1105654a3 n/a (libQt6WaylandClient.so.6 + 0x654a3)
                                                      #5  0x00007fd115b1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #6  0x00007fd1152a57eb n/a (libc.so.6 + 0x957eb)
                                                      #7  0x00007fd11532918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 142669:
                                                      #2  0x00007fd1152a264c n/a (libc.so.6 + 0x9264c)
                                                      #3  0x00007fd1152a4d1e pthread_cond_wait (libc.so.6 + 0x94d1e)
                                                      #4  0x00007fd115b2ddb0 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x32ddb0)
                                                      #5  0x00007fd110565439 n/a (libQt6WaylandClient.so.6 + 0x65439)
                                                      #6  0x00007fd115b1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #7  0x00007fd1152a57eb n/a (libc.so.6 + 0x957eb)
                                                      #8  0x00007fd11532918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 142672:
                                                      #3  0x00007fd11531c5a6 ppoll (libc.so.6 + 0x10c5a6)
                                                      #4  0x00007fd115119e04 n/a (libglib-2.0.so.0 + 0x5fe04)
                                                      #5  0x00007fd115119ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                      #6  0x00007fd115c3c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                      #7  0x00007fd1159744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                      #8  0x00007fd115a8e054 _ZN7QThread3runEv (libQt6Core.so.6 + 0x28e054)
                                                      #9  0x00007fd115b1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #10 0x00007fd1152a57eb n/a (libc.so.6 + 0x957eb)
                                                      #11 0x00007fd11532918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 142678:
                                                      #4  0x00007fd10ccbc188 n/a (libEGL_nvidia.so.0 + 0xbc188)
                                                      #5  0x00007fd10cc8afe1 n/a (libEGL_nvidia.so.0 + 0x8afe1)
                                                      #6  0x00007fd10ccc1bae n/a (libEGL_nvidia.so.0 + 0xc1bae)
                                                      Stack trace of thread 142668:
                                                      #8  0x00007fd115a873c6 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2873c6)
                                                      #9  0x00007fd116f7adae n/a (libQt6DBus.so.6 + 0x37dae)
                                                      #10 0x00007fd115b1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #11 0x00007fd1152a57eb n/a (libc.so.6 + 0x957eb)
                                                      #12 0x00007fd11532918c n/a (libc.so.6 + 0x11918c)
Jul 22 13:47:23 REDACTED systemd-coredump[113035]: Process 112798 (spectacle) of user 1000 dumped core.
                                                      Stack trace of thread 112798:
                                                      #0  0x00007fc3b64a774c n/a (libc.so.6 + 0x9774c)
                                                      #1  0x00007fc3b644ddc0 raise (libc.so.6 + 0x3ddc0)
                                                      #2  0x00007fc3b643557a abort (libc.so.6 + 0x2557a)
                                                      #3  0x00007fc3b6a91217 n/a (libQt6Core.so.6 + 0x91217)
                                                      #4  0x00007fc3b6a920ec _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x920ec)
                                                      #5  0x00007fc3b72aebaa n/a (libQt6Qml.so.6 + 0xaebaa)
                                                      #6  0x00007fc3b6bbf57f _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bf57f)
                                                      #7  0x00007fc3aeb7f6c6 n/a (libQt6QuickTemplates2.so.6 + 0x17f6c6)
                                                      #8  0x00007fc3b6bb8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #9  0x00007fc3b6bbfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #10 0x00007fc3381463e6 n/a (libQt6QuickLayouts.so.6 + 0x2d3e6)
                                                      #11 0x00007fc3b6bb8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #12 0x00007fc3b6bbfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #13 0x00007fc3381463e6 n/a (libQt6QuickLayouts.so.6 + 0x2d3e6)
                                                      #14 0x00007fc3b6bb8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #15 0x00007fc3b6bbfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #16 0x00007fc3b9666923 n/a (libQt6Quick.so.6 + 0x466923)
                                                      #17 0x00007fc3b6bb8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #18 0x00007fc3b6bbfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #19 0x00007fc3aeb80d52 n/a (libQt6QuickTemplates2.so.6 + 0x180d52)
                                                      #20 0x00007fc3b6bb8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #21 0x00007fc3b6bbfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #22 0x00007fc3b9666923 n/a (libQt6Quick.so.6 + 0x466923)
                                                      #23 0x00007fc3b6bb8fe2 _ZN14QObjectPrivate14deleteChildrenEv (libQt6Core.so.6 + 0x1b8fe2)
                                                      #24 0x00007fc3b6bbfc19 _ZN7QObjectD2Ev (libQt6Core.so.6 + 0x1bfc19)
                                                      #25 0x00007fc3aeb80d52 n/a (libQt6QuickTemplates2.so.6 + 0x180d52)
                                                      #26 0x00007fc3b9470b5d _ZN10QQuickViewD2Ev (libQt6Quick.so.6 + 0x270b5d)
                                                      #27 0x000055cb3186b512 n/a (/usr/bin/spectacle + 0xaf512)
                                                      #28 0x00007fc3b6bc0d3c _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1c0d3c)
                                                      #29 0x00007fc3b9b01c70 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x101c70)
                                                      #30 0x00007fc3b6b68118 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x168118)
                                                      #31 0x00007fc3b6b684fb _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x1684fb)
                                                      #32 0x00007fc3b6e3fcf8 n/a (libQt6Core.so.6 + 0x43fcf8)
                                                      #33 0x00007fc3b2d2387d n/a (libglib-2.0.so.0 + 0x5e87d)
                                                      #34 0x00007fc3b2d24cd7 n/a (libglib-2.0.so.0 + 0x5fcd7)
                                                      #35 0x00007fc3b2d24ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                      #36 0x00007fc3b6e3c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                      #37 0x00007fc3b6b744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                      #38 0x00007fc3b9194a7c _ZN4KJob4execEv (libKF6CoreAddons.so.6 + 0x7da7c)
                                                      #39 0x000055cb318429fa n/a (/usr/bin/spectacle + 0x869fa)
                                                      #40 0x000055cb31851065 n/a (/usr/bin/spectacle + 0x95065)
                                                      #41 0x00007fc3b6bd37ef n/a (libQt6Core.so.6 + 0x1d37ef)
                                                      #42 0x000055cb318acdf8 n/a (/usr/bin/spectacle + 0xf0df8)
                                                      #43 0x00007fc3b6bd38b1 n/a (libQt6Core.so.6 + 0x1d38b1)
                                                      #44 0x00007fc3bc577a07 _ZN25PipeWireBaseEncodedStream9setActiveEb (libKPipeWireRecord.so.6 + 0x10a07)
                                                      #45 0x000055cb318a7d64 n/a (/usr/bin/spectacle + 0xebd64)
                                                      #46 0x000055cb31854f77 n/a (/usr/bin/spectacle + 0x98f77)
                                                      #47 0x00007fc3b7555363 n/a (libQt6Qml.so.6 + 0x355363)
                                                      #48 0x00007fc3b740a7f7 _ZN3QV413QObjectMethod11callPreciseERK18QQmlObjectOrGadgetRK16QQmlPropertyDataPNS_15ExecutionEngineEPNS_8CallDataEN11QMetaObject4CallE (libQt6Qml.so.6 + 0x20a7f7)
                                                      #49 0x00007fc3b740e385 _ZNK3QV413QObjectMethod12callInternalEPKNS_5ValueES3_i (libQt6Qml.so.6 + 0x20e385)
                                                      #50 0x00007fc3b74690fe n/a (libQt6Qml.so.6 + 0x2690fe)
                                                      #51 0x00007fc3b746cc14 n/a (libQt6Qml.so.6 + 0x26cc14)
                                                      #52 0x00007fc3b73b4c70 n/a (libQt6Qml.so.6 + 0x1b4c70)
                                                      #53 0x00007fc3b73bbfd9 _ZN3QV48Function4callEP7QObjectPPvPK9QMetaTypeiPNS_16ExecutionContextE (libQt6Qml.so.6 + 0x1bbfd9)
                                                      #54 0x00007fc3b7511400 _ZN24QQmlJavaScriptExpression8evaluateEPPvPK9QMetaTypei (libQt6Qml.so.6 + 0x311400)
                                                      #55 0x00007fc3b74a9e2b _ZN25QQmlBoundSignalExpression8evaluateEPPv (libQt6Qml.so.6 + 0x2a9e2b)
                                                      #56 0x00007fc3b74af0fd n/a (libQt6Qml.so.6 + 0x2af0fd)
                                                      #57 0x00007fc3b753b460 _ZN12QQmlNotifier10emitNotifyEP20QQmlNotifierEndpointPPv (libQt6Qml.so.6 + 0x33b460)
                                                      #58 0x00007fc3b6bd3462 n/a (libQt6Core.so.6 + 0x1d3462)
                                                      #59 0x00007fc3aeab7e22 _ZN27QQuickAbstractButtonPrivate13handleReleaseERK7QPointFm (libQt6QuickTemplates2.so.6 + 0xb7e22)
                                                      #60 0x00007fc3aead3990 _ZN13QQuickControl17mouseReleaseEventEP11QMouseEvent (libQt6QuickTemplates2.so.6 + 0xd3990)
                                                      #61 0x00007fc3b93acfc7 _ZN17QQuickItemPrivate19deliverPointerEventEP6QEvent (libQt6Quick.so.6 + 0x1acfc7)
                                                      #62 0x00007fc3b93b6453 _ZN10QQuickItem5eventEP6QEvent (libQt6Quick.so.6 + 0x1b6453)
                                                      #63 0x00007fc3b9b01c70 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x101c70)
                                                      Stack trace of thread 112811:
                                                      #0  0x00007fc3b64ade22 n/a (libc.so.6 + 0x9de22)
                                                      #1  0x00007fc3b64a1fda n/a (libc.so.6 + 0x91fda)
                                                      #2  0x00007fc3b64a264c n/a (libc.so.6 + 0x9264c)
                                                      #3  0x00007fc3b64a4f28 pthread_cond_timedwait (libc.so.6 + 0x94f28)
                                                      #4  0x00007fc3b6d2dd25 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x32dd25)
                                                      #5  0x00007fc3b6d27c40 n/a (libQt6Core.so.6 + 0x327c40)
                                                      #6  0x00007fc3b6d1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #7  0x00007fc3b64a57eb n/a (libc.so.6 + 0x957eb)
                                                      #8  0x00007fc3b652918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 112809:
                                                      Stack trace of thread 112800:
                                                      #3  0x00007fc3b64a4d1e pthread_cond_wait (libc.so.6 + 0x94d1e)
                                                      #4  0x00007fc3b6d2ddb0 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x32ddb0)
                                                      #5  0x00007fc3ba30e439 n/a (libQt6WaylandClient.so.6 + 0x65439)
                                                      Stack trace of thread 112822:
                                                      #2  0x00007fc3b64a2024 n/a (libc.so.6 + 0x92024)
                                                      #3  0x00007fc3b651c05e __poll (libc.so.6 + 0x10c05e)
                                                      #4  0x00007fc2e575f0a7 n/a (libcuda.so.1 + 0x35f0a7)
                                                      #5  0x00007fc2e58442ea n/a (libcuda.so.1 + 0x4442ea)
                                                      #6  0x00007fc2e574f0d3 n/a (libcuda.so.1 + 0x34f0d3)
                                                      Stack trace of thread 112863:
                                                      #3  0x00007fc3b64add28 n/a (libc.so.6 + 0x9dd28)
                                                      #4  0x00007fc31a2d654a _ZN13IlmThread_3_39Semaphore4waitEv (libIlmThread-3_3.so.32 + 0x554a)
                                                      #5  0x00007fc31a2d7daa n/a (libIlmThread-3_3.so.32 + 0x6daa)
                                                      #6  0x00007fc31a2d5a0d n/a (libIlmThread-3_3.so.32 + 0x4a0d)
                                                      #7  0x00007fc3b66e51a4 execute_native_thread_routine (libstdc++.so.6 + 0xe51a4)
                                                      #8  0x00007fc3b64a57eb n/a (libc.so.6 + 0x957eb)
                                                      #9  0x00007fc3b652918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 112907:
                                                      #4  0x00007fc338e17447 n/a (libnvidia-eglcore.so.575.64.03 + 0xa17447)
                                                      #5  0x00007fc338e159ea n/a (libnvidia-eglcore.so.575.64.03 + 0xa159ea)
                                                      #6  0x00007fc3b64a57eb n/a (libc.so.6 + 0x957eb)
                                                      #7  0x00007fc3b652918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 112868:
                                                      #3  0x00007fc3b651c5a6 ppoll (libc.so.6 + 0x10c5a6)
                                                      #4  0x00007fc3b6d15473 _Z12qt_safe_pollP6pollfdm14QDeadlineTimer (libQt6Core.so.6 + 0x315473)
                                                      #5  0x00007fc3b63790c3 n/a (libQt6Network.so.6 + 0x1440c3)
                                                      #6  0x00007fc3b62f6611 n/a (libQt6Network.so.6 + 0xc1611)
                                                      #7  0x00007fc3b62ec4df _ZN15QAbstractSocket16waitForReadyReadEi (libQt6Network.so.6 + 0xb74df)
                                                      #8  0x00007fc3ba8bc2b8 n/a (libKF6KIOCore.so.6 + 0x422b8)
                                                      #9  0x00007fc3ba8ff609 n/a (libKF6KIOCore.so.6 + 0x85609)
                                                      #10 0x00007fc3ba99d147 n/a (libKF6KIOCore.so.6 + 0x123147)
                                                      #11 0x00007fc3b6d1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #12 0x00007fc3b64a57eb n/a (libc.so.6 + 0x957eb)
                                                      #13 0x00007fc3b652918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 113030:
                                                      #4  0x00007fc33a6bc188 n/a (libEGL_nvidia.so.0 + 0xbc188)
                                                      #5  0x00007fc33a68afe1 n/a (libEGL_nvidia.so.0 + 0x8afe1)
                                                      #6  0x00007fc33a6c1bae n/a (libEGL_nvidia.so.0 + 0xc1bae)
                                                      Stack trace of thread 112916:
                                                      Stack trace of thread 112812:
                                                      Stack trace of thread 112862:
                                                      Stack trace of thread 112867:
                                                      Stack trace of thread 112813:
                                                      #4  0x00007fc3b2d24e04 n/a (libglib-2.0.so.0 + 0x5fe04)
                                                      #5  0x00007fc3b2d24ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                      #6  0x00007fc3b6e3c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                      #7  0x00007fc3b6b744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                      #8  0x00007fc3b6c8e054 _ZN7QThread3runEv (libQt6Core.so.6 + 0x28e054)
                                                      #9  0x00007fc3b6d1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #10 0x00007fc3b64a57eb n/a (libc.so.6 + 0x957eb)
                                                      #11 0x00007fc3b652918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 112801:
                                                      #4  0x00007fc3ba30e4a3 n/a (libQt6WaylandClient.so.6 + 0x654a3)
                                                      #5  0x00007fc3b6d1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      Stack trace of thread 112810:
                                                      Stack trace of thread 112807:
                                                      Stack trace of thread 112865:
                                                      Stack trace of thread 112815:
                                                      Stack trace of thread 112915:
                                                      #4  0x00007fc2e56bb30a n/a (libcuda.so.1 + 0x2bb30a)
                                                      #5  0x00007fc2e574f0d3 n/a (libcuda.so.1 + 0x34f0d3)
                                                      Stack trace of thread 112808:
                                                      Stack trace of thread 113031:
                                                      Stack trace of thread 112799:
                                                      #8  0x00007fc3b6c873c6 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2873c6)
                                                      #9  0x00007fc3b877adae n/a (libQt6DBus.so.6 + 0x37dae)
                                                      #10 0x00007fc3b6d1ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                      #11 0x00007fc3b64a57eb n/a (libc.so.6 + 0x957eb)
                                                      #12 0x00007fc3b652918c n/a (libc.so.6 + 0x11918c)
                                                      Stack trace of thread 112866:
                                                      Stack trace of thread 112864:
Jul 21 20:55:49 REDACTED systemd-coredump[71446]: Process 70498 (spectacle) of user 1000 dumped core.
                                                     Stack trace of thread 71370:
                                                     #0  0x00007f1fc66a5732 n/a (libavfilter.so.10 + 0x2a5732)
                                                     #1  0x00007f1fc66a6aa8 n/a (libavfilter.so.10 + 0x2a6aa8)
                                                     #2  0x00007f1fc66a743f n/a (libavfilter.so.10 + 0x2a743f)
                                                     #3  0x00007f1fc6516112 n/a (libavfilter.so.10 + 0x116112)
                                                     #4  0x00007f1fc64ecd1f n/a (libavfilter.so.10 + 0xecd1f)
                                                     #5  0x00007f1fc64ed277 n/a (libavfilter.so.10 + 0xed277)
                                                     #6  0x00007f1fcfb2e631 n/a (libKPipeWireRecord.so.6 + 0x12631)
                                                     #7  0x00007f1fcfb28ed3 n/a (libKPipeWireRecord.so.6 + 0xced3)
                                                     #8  0x00007f1fc9ae51a4 execute_native_thread_routine (libstdc++.so.6 + 0xe51a4)
                                                     #9  0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #10 0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 70500:
                                                     #0  0x00007f1fc98ade22 n/a (libc.so.6 + 0x9de22)
                                                     #1  0x00007f1fc98a1fda n/a (libc.so.6 + 0x91fda)
                                                     #2  0x00007f1fc98a2024 n/a (libc.so.6 + 0x92024)
                                                     #3  0x00007f1fc991c05e __poll (libc.so.6 + 0x10c05e)
                                                     #4  0x00007f1fcdb584a3 n/a (libQt6WaylandClient.so.6 + 0x654a3)
                                                     #5  0x00007f1fca11ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                     #6  0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #7  0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 70498:
                                                     #3  0x00007f1fc991c5a6 ppoll (libc.so.6 + 0x10c5a6)
                                                     #4  0x00007f1fc62b8e04 n/a (libglib-2.0.so.0 + 0x5fe04)
                                                     #5  0x00007f1fc62b8ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                     #6  0x00007f1fca23c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                     #7  0x00007f1fc9f744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                     #8  0x00007f1fc9f6c7c1 _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x16c7c1)
                                                     #9  0x0000559bc28087ae n/a (/usr/bin/spectacle + 0x4c7ae)
                                                     #10 0x00007f1fc98376b5 n/a (libc.so.6 + 0x276b5)
                                                     #11 0x00007f1fc9837769 __libc_start_main (libc.so.6 + 0x27769)
                                                     #12 0x0000559bc280be65 n/a (/usr/bin/spectacle + 0x4fe65)
                                                     Stack trace of thread 70499:
                                                     #8  0x00007f1fca0873c6 _ZN7QThread4execEv (libQt6Core.so.6 + 0x2873c6)
                                                     #9  0x00007f1fcc57adae n/a (libQt6DBus.so.6 + 0x37dae)
                                                     #10 0x00007f1fca11ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                     #11 0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #12 0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 70501:
                                                     Stack trace of thread 70513:
                                                     #8  0x00007f1fca08e054 _ZN7QThread3runEv (libQt6Core.so.6 + 0x28e054)
                                                     #9  0x00007f1fca11ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                     #10 0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #11 0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 70519:
                                                     #4  0x00007f1ef695f0a7 n/a (libcuda.so.1 + 0x35f0a7)
                                                     #5  0x00007f1ef6a442ea n/a (libcuda.so.1 + 0x4442ea)
                                                     #6  0x00007f1ef694f0d3 n/a (libcuda.so.1 + 0x34f0d3)
                                                     #7  0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #8  0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 71341:
                                                     #0  0x00007f1f3e937fea n/a (libnvidia-eglcore.so.575.64.03 + 0xb37fea)
                                                     #1  0x00007f1f3e91e297 n/a (libnvidia-eglcore.so.575.64.03 + 0xb1e297)
                                                     #2  0x00007f1f3e91fdb6 n/a (libnvidia-eglcore.so.575.64.03 + 0xb1fdb6)
                                                     #3  0x00007f1f3e937751 n/a (libnvidia-eglcore.so.575.64.03 + 0xb37751)
                                                     #4  0x00007f1f3e801a13 n/a (libnvidia-eglcore.so.575.64.03 + 0xa01a13)
                                                     #5  0x00007f1f3e90034e n/a (libnvidia-eglcore.so.575.64.03 + 0xb0034e)
                                                     #6  0x00007f1f3e8b1aeb n/a (libnvidia-eglcore.so.575.64.03 + 0xab1aeb)
                                                     #7  0x00007f1f3e8b205f n/a (libnvidia-eglcore.so.575.64.03 + 0xab205f)
                                                     #8  0x00007f1f3e4dddda n/a (libnvidia-eglcore.so.575.64.03 + 0x6dddda)
                                                     #9  0x00007f1f3e4de662 n/a (libnvidia-eglcore.so.575.64.03 + 0x6de662)
                                                     #10 0x00007f1fcda742a0 _ZN13DmaBufHandler13downloadFrameER6QImageRK13PipeWireFrame (libKPipeWireDmaBuf.so.6 + 0x32a0)
                                                     #11 0x00007f1fcfb308d9 n/a (libKPipeWireRecord.so.6 + 0x148d9)
                                                     #12 0x00007f1fcfb2df7f n/a (libKPipeWireRecord.so.6 + 0x11f7f)
                                                     #13 0x00007f1fcfb2e546 n/a (libKPipeWireRecord.so.6 + 0x12546)
                                                     #14 0x00007f1fc9fd37ef n/a (libQt6Core.so.6 + 0x1d37ef)
                                                     #15 0x00007f1fcbaf7bd3 _ZN20PipeWireSourceStream13frameReceivedERK13PipeWireFrame (libKPipeWire.so.6 + 0x18bd3)
                                                     #16 0x00007f1fcbafea14 _ZN20PipeWireSourceStream11handleFrameEP9pw_buffer (libKPipeWire.so.6 + 0x1fa14)
                                                     #17 0x00007f1fcbaff770 _ZN20PipeWireSourceStream7processEv (libKPipeWire.so.6 + 0x20770)
                                                     #18 0x00007f1fc2fba22d n/a (libpipewire-0.3.so.0 + 0x7b22d)
                                                     #19 0x00007f1fc2f94c07 n/a (libpipewire-0.3.so.0 + 0x55c07)
                                                     #20 0x00007f1fc2f95096 n/a (libpipewire-0.3.so.0 + 0x56096)
                                                     #21 0x00007f1f4da00d46 n/a (libspa-support.so + 0x6d46)
                                                     #22 0x00007f1fcbaebeb9 n/a (libKPipeWire.so.6 + 0xceb9)
                                                     #23 0x00007f1fc9fd37ef n/a (libQt6Core.so.6 + 0x1d37ef)
                                                     #24 0x00007f1fc9fddb40 _ZN15QSocketNotifier5eventEP6QEvent (libQt6Core.so.6 + 0x1ddb40)
                                                     #25 0x00007f1fccf01c70 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0x101c70)
                                                     #26 0x00007f1fc9f68118 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x168118)
                                                     #27 0x00007f1fca23f9f2 n/a (libQt6Core.so.6 + 0x43f9f2)
                                                     #28 0x00007f1fc62b787d n/a (libglib-2.0.so.0 + 0x5e87d)
                                                     #29 0x00007f1fc62b8cd7 n/a (libglib-2.0.so.0 + 0x5fcd7)
                                                     #30 0x00007f1fc62b8ee5 g_main_context_iteration (libglib-2.0.so.0 + 0x5fee5)
                                                     #31 0x00007f1fca23c5e2 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x43c5e2)
                                                     #32 0x00007f1fc9f744b6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x1744b6)
                                                     #33 0x00007f1fca08e054 _ZN7QThread3runEv (libQt6Core.so.6 + 0x28e054)
                                                     #34 0x00007f1fca11ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                     #35 0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #36 0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 70514:
                                                     #2  0x00007f1fc98a264c n/a (libc.so.6 + 0x9264c)
                                                     #3  0x00007f1fc98a4d1e pthread_cond_wait (libc.so.6 + 0x94d1e)
                                                     #4  0x00007f1f4dcbc188 n/a (libEGL_nvidia.so.0 + 0xbc188)
                                                     #5  0x00007f1f4dc8afe1 n/a (libEGL_nvidia.so.0 + 0x8afe1)
                                                     #6  0x00007f1f4dcc1bae n/a (libEGL_nvidia.so.0 + 0xc1bae)
                                                     Stack trace of thread 70566:
                                                     #3  0x00007f1fc98add28 n/a (libc.so.6 + 0x9dd28)
                                                     #4  0x00007f1f2c25954a _ZN13IlmThread_3_39Semaphore4waitEv (libIlmThread-3_3.so.32 + 0x554a)
                                                     #5  0x00007f1f2c25adaa n/a (libIlmThread-3_3.so.32 + 0x6daa)
                                                     #6  0x00007f1f2c258a0d n/a (libIlmThread-3_3.so.32 + 0x4a0d)
                                                     #7  0x00007f1fc9ae51a4 execute_native_thread_routine (libstdc++.so.6 + 0xe51a4)
                                                     #8  0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #9  0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 71439:
                                                     #4  0x00007f1fc6e6b6cf n/a (libavutil.so.59 + 0x6b6cf)
                                                     #5  0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #6  0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 70565:
                                                     Stack trace of thread 70567:
                                                     Stack trace of thread 70564:
                                                     Stack trace of thread 70559:
                                                     #4  0x00007f1fca115473 _Z12qt_safe_pollP6pollfdm14QDeadlineTimer (libQt6Core.so.6 + 0x315473)
                                                     #5  0x00007f1fc97790c3 n/a (libQt6Network.so.6 + 0x1440c3)
                                                     #6  0x00007f1fc96f6611 n/a (libQt6Network.so.6 + 0xc1611)
                                                     #7  0x00007f1fc96ec4df _ZN15QAbstractSocket16waitForReadyReadEi (libQt6Network.so.6 + 0xb74df)
                                                     #8  0x00007f1fcde462b8 n/a (libKF6KIOCore.so.6 + 0x422b8)
                                                     #9  0x00007f1fcde89609 n/a (libKF6KIOCore.so.6 + 0x85609)
                                                     #10 0x00007f1fcdf27147 n/a (libKF6KIOCore.so.6 + 0x123147)
                                                     #11 0x00007f1fca11ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                     #12 0x00007f1fc98a57eb n/a (libc.so.6 + 0x957eb)
                                                     #13 0x00007f1fc992918c n/a (libc.so.6 + 0x11918c)
                                                     Stack trace of thread 71440:
                                                     Stack trace of thread 71338:
                                                     #3  0x00007f1fc98a4f28 pthread_cond_timedwait (libc.so.6 + 0x94f28)
                                                     #4  0x00007f1fca12dd25 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x32dd25)
                                                     #5  0x00007f1fca127c40 n/a (libQt6Core.so.6 + 0x327c40)
                                                     #6  0x00007f1fca11ee69 n/a (libQt6Core.so.6 + 0x31ee69)
                                                     Stack trace of thread 71337:
                                                     Stack trace of thread 70705:
                                                     #4  0x00007f1f3e817447 n/a (libnvidia-eglcore.so.575.64.03 + 0xa17447)
                                                     #5  0x00007f1f3e8159ea n/a (libnvidia-eglcore.so.575.64.03 + 0xa159ea)
                                                     Stack trace of thread 71374:
                                                     #4  0x00007f1fc1ac13f5 n/a (libvpx.so.9 + 0xc13f5)
                                                     Stack trace of thread 71441:
                                                     Stack trace of thread 71375:
                                                     Stack trace of thread 71351:
                                                     Stack trace of thread 71339:
                                                     Stack trace of thread 71371:
                                                     #4  0x00007f1fc9adaaa1 _Z19__gthread_cond_waitP14pthread_cond_tP15pthread_mutex_t (libstdc++.so.6 + 0xdaaa1)
                                                     #5  0x00007f1fcfb28d1d n/a (libKPipeWireRecord.so.6 + 0xcd1d)
                                                     #6  0x00007f1fc9ae51a4 execute_native_thread_routine (libstdc++.so.6 + 0xe51a4)
                                                     Stack trace of thread 71437:
                                                     Stack trace of thread 71442:
                                                     Stack trace of thread 71352:
                                                     Stack trace of thread 71344:
                                                     Stack trace of thread 71443:
                                                     Stack trace of thread 71353:
                                                     Stack trace of thread 71444:
                                                     Stack trace of thread 71349:
                                                     Stack trace of thread 71346:
                                                     Stack trace of thread 71342:
                                                     #3  0x00007f1fc9929475 epoll_wait (libc.so.6 + 0x119475)
                                                     #4  0x00007f1f4da13a2a n/a (libspa-support.so + 0x19a2a)
                                                     #5  0x00007f1f4da00c7f n/a (libspa-support.so + 0x6c7f)
                                                     #6  0x00007f1fc2fc1c84 n/a (libpipewire-0.3.so.0 + 0x82c84)
                                                     Stack trace of thread 71354:
                                                     Stack trace of thread 71433:
                                                     Stack trace of thread 70568:
                                                     Stack trace of thread 71435:
                                                     Stack trace of thread 71434:
                                                     Stack trace of thread 71436:
                                                     Stack trace of thread 70563:
                                                     Stack trace of thread 71438:
                                                     Stack trace of thread 71343:
                                                     Stack trace of thread 71345:
                                                     Stack trace of thread 71347:
                                                     Stack trace of thread 71348:
                                                     Stack trace of thread 71350:
                                                     Stack trace of thread 71373:
