[Testing Update] 2025-09-27 - Kernels, Plasma 6.4.5, GNOME 49.0, Cosmic 1.0b1
Hello community, here we have another set of package updates. Welcome to our new development cycle of Manjaro 25.1.0, code-named ‘Anh-Linh’. It is not sure yet if we will focus on Plasma 6.4 series or adopt 6.5 series early on. For sure we will introduce GNOME 49 and maybe Cosmic 1.0 (Beta).
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Arch Linux - News: Valkey to replace Redis in the [extra] Repository
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.299
  • linux510 5.10.244
  • linux515 5.15.193
  • linux61 6.1.154
  • linux66 6.6.108
  • linux612 6.12.49
  • linux616 6.16.9
  • linux617 6.17.0-rc7
  • linux61-rt 6.1.151_rt54
  • linux66-rt 6.6.106_rt61
  • linux612-rt 6.12.43_rt12
  • linux615-rt 6.15.0_rt2
  • linux616-rt 6.16.0_rt3
Package Changes (Sat Sep 27 09:30:09 CEST 2025)
  • testing core x86_64: 26 new and 28 removed package(s)
  • testing extra x86_64: 2234 new and 2301 removed package(s)
  • testing multilib x86_64: 13 new and 13 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-09-02
  • pacman-mirrors version 5.1
    Deprecation of --geoip in favor of -tz/--timezone.
    This internal change make mirror-list generation use your system’s configured timezone - when applicable - without using an IP location provider.
    More privacy..
2025-08-24
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
It seems on older hardware the mesa 25.2.x update created some regressions which may result in black screens or flickering. Some older Nvidia cards with nouveau driver seem to be affected.
You can try to use the 25.1.x series of Mesa via this repo. Simply place it on top of [extra] in your /etc/pacman.conf file and use sudo pacman -Syuu to downgrade.
[mesa-251]
SigLevel = PackageRequired
Server = https://download.manjaro.org/pkgs/mesa
If you have no graphical session available you can access the bootloader by pressing ESC key during boot and select the bootloader entry. Press CTRL+E for edit and search for the words quiet and splash. Delete those and add 3 to the line. Then execute CTRL+x to start your session. You will land in a text console TTY. Login with your user.
Edit the /etc/pacman.conf with nano: sudo nano /etc/pacman.conf. Perform the downgrade and reboot.
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
Previous testing threads:
Heavy Gnome difficulties.
I did a timeshift back, due to a lot of extension issues. Need to figure it out as even “dash to panel” is not working in my setup. It Crashes even though it’s updated.
Will try to install the update / Gnome 49 with all extensions disabled and enabling them step by step.
But later tomorrow or so.
Got a big update this morning, resulting in an unbootable system. Black screen only. Thankfully I am on a dual boot and windows still works.
@momo51 the Black Screen issue sounds really universal. You may want to check the content of /var/log/pacman.log to understand what got updated. This guide might bring you some insights on how to check via chroot: GRUB/Restore the GRUB Bootloader - Manjaro Current install medias with yesterday’s update can be found here: Help testing 25.0.9 Release
Hello Philm,
to be more precise, the system boot up fine up to a login screen (sddm) but after entering the password, I end up on a black screen. I was able to restore an earlier partition image (macrium) and re-instate the boot loader which got me back in manjaro (kde) again. I have put the updates on hold for now until someone confirm as well. I don’t want to do all the work again.
  • since some components are old now (firefox, thunderbird) and cannot be update because of others dependancies, I am going back to window.
second try on one of my Gnome systems.
This time I disabled all extensions upfront, followed by disabling extensions at all, followed by logout and install via tty the Gnome 49 update.
A lot of extensions are not working, incl. relevant ones as “dash to panel”, so I will timeshift back again.
I assume you use X11 still. You may want to install additionally kwin-x11 and plasma-x11-session. Else switch in SDDM to Wayland, which is the new default.
GNOME is normally not used with extensions. Anyhow, lets see if the extension developers will catch up … Releases · home-sweet-gnome/dash-to-panel · GitHub
no i was on wayland. I was using a theme with an sddm which was working fine so I am wondering if it is a problem ?
*** Well look like you system will not allow more comments from me …
Mod note:- Consecutive posts are disallowed. You will find that posting after another member’s comment works as expected. Instead of waiting for someone to comment, simply edit your existing comment to add additional information. Note:- you may need to click the ellipsis button (the three dots) to reveal the edit button (pencil). :eyes:
No that doesn’t work. I cannot answer back to Philm
GNOME or Plasma don’t like user customization. When a major release gets out it is best to start with a fresh user in default settings. Especially themes or plugins or extensions may create issues. Depending what got changed or additional installed, it can be easy or more complex to find out.
sddm is particularly sensitive to the configured theme - so if you are using a custom theme - please test by reverting to the default breeze or breath theme and verify if the issue persist.
Is it possible that @momo51 might be suffering from a variation of Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update?
After the update GNOME does not start. I recently switched to testing, so I can provide this boot log. Please let me know what else I can do to support you.
Sep 27 14:35:28 thymos systemd-coredump[1263]: Process 1225 (gdm) of user 0 terminated abnormally with signal 5/TRAP, processing...
Sep 27 14:35:28 thymos systemd[1247]: Startup finished in 89ms.
Sep 27 14:35:28 thymos systemd[1]: Created slice Slice /system/systemd-coredump.
Sep 27 14:35:28 thymos systemd[1]: Started Process Core Dump (PID 1263/UID 0).
Sep 27 14:35:28 thymos systemd-coredump[1264]: Process 1225 (gdm) of user 0 dumped core.
                                               Stack trace of thread 1225:
                                               #0  0x00007f648238764b g_logv (libglib-2.0.so.0 + 0x6564b)
                                               #1  0x00007f6482387904 g_log (libglib-2.0.so.0 + 0x65904)
                                               #2  0x00005592183b9ddc n/a (/usr/bin/gdm + 0x33ddc)
                                               #3  0x00005592183c0b65 n/a (/usr/bin/gdm + 0x3ab65)
                                               #4  0x00007f648206eac6 n/a (libffi.so.8 + 0x7ac6)
                                               #5  0x00007f648206b76b n/a (libffi.so.8 + 0x476b)
                                               #6  0x00007f648206e06e ffi_call (libffi.so.8 + 0x706e)
                                               #7  0x00007f6482492818 g_cclosure_marshal_generic_va (libgobject-2.0.so.0 + 0x18818)
                                               #8  0x00007f64824acc77 n/a (libgobject-2.0.so.0 + 0x32c77)
                                               #9  0x00007f64824acd89 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32d89)
                                               #10 0x00007f64824ace44 g_signal_emit (libgobject-2.0.so.0 + 0x32e44)
                                               #11 0x00005592183be1f2 n/a (/usr/bin/gdm + 0x381f2)
                                               #12 0x00007f64821f89cc n/a (libgio-2.0.so.0 + 0xa89cc)
                                               #13 0x00007f64821fe472 n/a (libgio-2.0.so.0 + 0xae472)
                                               #14 0x00007f64822729ce n/a (libgio-2.0.so.0 + 0x1229ce)
                                               #15 0x00007f64821f89cc n/a (libgio-2.0.so.0 + 0xa89cc)
                                               #16 0x00007f64821fe472 n/a (libgio-2.0.so.0 + 0xae472)
                                               #17 0x00007f64822688b3 n/a (libgio-2.0.so.0 + 0x1188b3)
                                               #18 0x00007f64821f89cc n/a (libgio-2.0.so.0 + 0xa89cc)
                                               #19 0x00007f64821f8a15 n/a (libgio-2.0.so.0 + 0xa8a15)
                                               #20 0x00007f6482380f4d n/a (libglib-2.0.so.0 + 0x5ef4d)
                                               #21 0x00007f6482382617 n/a (libglib-2.0.so.0 + 0x60617)
                                               #22 0x00007f64823829d7 g_main_loop_run (libglib-2.0.so.0 + 0x609d7)
                                               #23 0x000055921839322f n/a (/usr/bin/gdm + 0xd22f)
                                               #24 0x00007f6481e27675 n/a (libc.so.6 + 0x27675)
                                               #25 0x00007f6481e27729 __libc_start_main (libc.so.6 + 0x27729)
                                               #26 0x0000559218393595 n/a (/usr/bin/gdm + 0xd595)
                                               Stack trace of thread 1227:
                                               #0  0x00007f6481f1876d syscall (libc.so.6 + 0x11876d)
                                               #1  0x00007f64823b17ee g_cond_wait (libglib-2.0.so.0 + 0x8f7ee)
                                               #2  0x00007f64823481cd n/a (libglib-2.0.so.0 + 0x261cd)
                                               #3  0x00007f64823ba447 n/a (libglib-2.0.so.0 + 0x98447)
                                               #4  0x00007f64823b987c n/a (libglib-2.0.so.0 + 0x9787c)
                                               #5  0x00007f6481e969cb n/a (libc.so.6 + 0x969cb)
                                               #6  0x00007f6481f1aa0c n/a (libc.so.6 + 0x11aa0c)
                                               Stack trace of thread 1230:
                                               #0  0x00007f6481e9f042 n/a (libc.so.6 + 0x9f042)
                                               #1  0x00007f6481e931ac n/a (libc.so.6 + 0x931ac)
                                               #2  0x00007f6481e931f4 n/a (libc.so.6 + 0x931f4)
                                               #3  0x00007f6481f1acf5 epoll_wait (libc.so.6 + 0x11acf5)
                                               #4  0x00007f648251cc98 sd_event_wait (libsystemd.so.0 + 0x43c98)
                                               #5  0x00007f648251e164 sd_event_run (libsystemd.so.0 + 0x45164)
                                               #6  0x00007f648251e2b0 sd_event_loop (libsystemd.so.0 + 0x452b0)
                                               #7  0x00005592183a3000 n/a (/usr/bin/gdm + 0x1d000)
                                               #8  0x00007f64823b987c n/a (libglib-2.0.so.0 + 0x9787c)
                                               #9  0x00007f6481e969cb n/a (libc.so.6 + 0x969cb)
                                               #10 0x00007f6481f1aa0c n/a (libc.so.6 + 0x11aa0c)
                                               Stack trace of thread 1242:
                                               #1  0x00007f64823b277e g_cond_wait_until (libglib-2.0.so.0 + 0x9077e)
                                               #2  0x00007f6482348197 n/a (libglib-2.0.so.0 + 0x26197)
                                               #3  0x00007f64823bb29b n/a (libglib-2.0.so.0 + 0x9929b)
                                               Stack trace of thread 1229:
                                               #3  0x00007f6481f0da36 ppoll (libc.so.6 + 0x10da36)
                                               #4  0x00007f6482382744 n/a (libglib-2.0.so.0 + 0x60744)
                                               #5  0x00007f64823829d7 g_main_loop_run (libglib-2.0.so.0 + 0x609d7)
                                               #6  0x00007f648226a264 n/a (libgio-2.0.so.0 + 0x11a264)
                                               #7  0x00007f64823b987c n/a (libglib-2.0.so.0 + 0x9787c)
                                               #8  0x00007f6481e969cb n/a (libc.so.6 + 0x969cb)
                                               #9  0x00007f6481f1aa0c n/a (libc.so.6 + 0x11aa0c)
                                               Stack trace of thread 1228:
                                               #5  0x00007f6482382825 g_main_context_iteration (libglib-2.0.so.0 + 0x60825)
                                               #6  0x00007f6482382872 n/a (libglib-2.0.so.0 + 0x60872)
Sep 27 14:35:28 thymos systemd[1]: gdm.service: Main process exited, code=dumped, status=5/TRAP
Sep 27 14:35:28 thymos systemd[1]: gdm.service: Failed with result 'core-dump'.
Sep 27 14:35:28 thymos systemd[1]: gdm.service: Triggering OnFailure= dependencies.
Sep 27 14:35:28 thymos systemd[1]: systemd-coredump@0-1263-0.service: Deactivated successfully.
Sep 27 14:35:28 thymos systemd[1]: Starting Terminate Plymouth Boot Screen...
Sep 27 14:35:28 thymos systemd[1]: Finished Hold until boot process finishes up.
Sep 27 14:35:28 thymos systemd[1]: Finished Terminate Plymouth Boot Screen.
Sep 27 14:35:28 thymos systemd[1]: gdm.service: Scheduled restart job, restart counter is at 1.
Sep 27 14:35:28 thymos systemd[1]: plymouth-quit.service: Deactivated successfully.
Sep 27 14:35:28 thymos systemd[1]: Stopped Terminate Plymouth Boot Screen.
Sep 27 14:35:28 thymos systemd[1]: Reached target Multi-User System.
Sep 27 14:35:28 thymos systemd[1]: Starting GNOME Display Manager...
Sep 27 14:35:28 thymos systemd[1]: Started GNOME Display Manager.
Sep 27 14:35:28 thymos systemd[1]: Reached target Graphical Interface.
Sep 27 14:35:28 thymos systemd[1]: Startup finished in 15.368s (firmware) + 7.303s (loader) + 6.915s (kernel) + 5.782s (userspace) = 35.371s.
Sep 27 14:35:28 thymos systemd-logind[910]: New session 3 of user gdm-greeter.
Sep 27 14:35:28 thymos systemd[1]: Started Session 3 of User gdm-greeter.
Sep 27 14:35:28 thymos gdm[1278]: Gdm: GdmSession: no session desktop files installed, aborting...
Sep 27 14:35:28 thymos kernel: traps: gdm[1278] trap int3 ip:7fbb5c39664b sp:7ffcd617cec0 error:0 in libglib-2.0.so.0.8600.0[6564b,7fbb5c34f000+a7000]
Sep 27 14:35:28 thymos systemd-coredump[1289]: Process 1278 (gdm) of user 0 terminated abnormally with signal 5/TRAP, processing...
Sep 27 14:35:28 thymos systemd[1]: Started Process Core Dump (PID 1289/UID 0).
Sep 27 14:35:28 thymos systemd-coredump[1290]: Process 1278 (gdm) of user 0 dumped core.
                                               Stack trace of thread 1278:
                                               #0  0x00007fbb5c39664b g_logv (libglib-2.0.so.0 + 0x6564b)
                                               #1  0x00007fbb5c396904 g_log (libglib-2.0.so.0 + 0x65904)
                                               #2  0x00005598a7832ddc n/a (/usr/bin/gdm + 0x33ddc)
                                               #3  0x00005598a7839b65 n/a (/usr/bin/gdm + 0x3ab65)
                                               #4  0x00007fbb5c07dac6 n/a (libffi.so.8 + 0x7ac6)
                                               #5  0x00007fbb5c07a76b n/a (libffi.so.8 + 0x476b)
                                               #6  0x00007fbb5c07d06e ffi_call (libffi.so.8 + 0x706e)
                                               #7  0x00007fbb5c4a1818 g_cclosure_marshal_generic_va (libgobject-2.0.so.0 + 0x18818)
                                               #8  0x00007fbb5c4bbc77 n/a (libgobject-2.0.so.0 + 0x32c77)
                                               #9  0x00007fbb5c4bbd89 g_signal_emit_valist (libgobject-2.0.so.0 + 0x32d89)
                                               #10 0x00007fbb5c4bbe44 g_signal_emit (libgobject-2.0.so.0 + 0x32e44)
                                               #11 0x00005598a78371f2 n/a (/usr/bin/gdm + 0x381f2)
                                               #12 0x00007fbb5c2079cc n/a (libgio-2.0.so.0 + 0xa89cc)
                                               #13 0x00007fbb5c20d472 n/a (libgio-2.0.so.0 + 0xae472)
                                               #14 0x00007fbb5c2819ce n/a (libgio-2.0.so.0 + 0x1229ce)
                                               #15 0x00007fbb5c2079cc n/a (libgio-2.0.so.0 + 0xa89cc)
                                               #16 0x00007fbb5c20d472 n/a (libgio-2.0.so.0 + 0xae472)
                                               #17 0x00007fbb5c2778b3 n/a (libgio-2.0.so.0 + 0x1188b3)
                                               #18 0x00007fbb5c2079cc n/a (libgio-2.0.so.0 + 0xa89cc)
                                               #19 0x00007fbb5c207a15 n/a (libgio-2.0.so.0 + 0xa8a15)
                                               #20 0x00007fbb5c38ff4d n/a (libglib-2.0.so.0 + 0x5ef4d)
                                               #21 0x00007fbb5c391617 n/a (libglib-2.0.so.0 + 0x60617)
                                               #22 0x00007fbb5c3919d7 g_main_loop_run (libglib-2.0.so.0 + 0x609d7)
                                               #23 0x00005598a780c22f n/a (/usr/bin/gdm + 0xd22f)
                                               #24 0x00007fbb5be27675 n/a (libc.so.6 + 0x27675)
                                               #25 0x00007fbb5be27729 __libc_start_main (libc.so.6 + 0x27729)
                                               #26 0x00005598a780c595 n/a (/usr/bin/gdm + 0xd595)
                                               Stack trace of thread 1279:
                                               #0  0x00007fbb5bf1876d syscall (libc.so.6 + 0x11876d)
                                               #1  0x00007fbb5c3c07ee g_cond_wait (libglib-2.0.so.0 + 0x8f7ee)
                                               #2  0x00007fbb5c3571cd n/a (libglib-2.0.so.0 + 0x261cd)
                                               #3  0x00007fbb5c3c9447 n/a (libglib-2.0.so.0 + 0x98447)
                                               #4  0x00007fbb5c3c887c n/a (libglib-2.0.so.0 + 0x9787c)
                                               #5  0x00007fbb5be969cb n/a (libc.so.6 + 0x969cb)
                                               #6  0x00007fbb5bf1aa0c n/a (libc.so.6 + 0x11aa0c)
                                               Stack trace of thread 1282:
                                               #0  0x00007fbb5be9f042 n/a (libc.so.6 + 0x9f042)
                                               #1  0x00007fbb5be931ac n/a (libc.so.6 + 0x931ac)
                                               #2  0x00007fbb5be931f4 n/a (libc.so.6 + 0x931f4)
                                               #3  0x00007fbb5bf1acf5 epoll_wait (libc.so.6 + 0x11acf5)
                                               #4  0x00007fbb5c52bc98 sd_event_wait (libsystemd.so.0 + 0x43c98)
                                               #5  0x00007fbb5c52d164 sd_event_run (libsystemd.so.0 + 0x45164)
                                               #6  0x00007fbb5c52d2b0 sd_event_loop (libsystemd.so.0 + 0x452b0)
                                               #7  0x00005598a781c000 n/a (/usr/bin/gdm + 0x1d000)
                                               #8  0x00007fbb5c3c887c n/a (libglib-2.0.so.0 + 0x9787c)
                                               #9  0x00007fbb5be969cb n/a (libc.so.6 + 0x969cb)
                                               #10 0x00007fbb5bf1aa0c n/a (libc.so.6 + 0x11aa0c)
                                               Stack trace of thread 1280:
                                               #3  0x00007fbb5bf0da36 ppoll (libc.so.6 + 0x10da36)
                                               #4  0x00007fbb5c391744 n/a (libglib-2.0.so.0 + 0x60744)
                                               #5  0x00007fbb5c391825 g_main_context_iteration (libglib-2.0.so.0 + 0x60825)
                                               #6  0x00007fbb5c391872 n/a (libglib-2.0.so.0 + 0x60872)
                                               #7  0x00007fbb5c3c887c n/a (libglib-2.0.so.0 + 0x9787c)
                                               #8  0x00007fbb5be969cb n/a (libc.so.6 + 0x969cb)
                                               #9  0x00007fbb5bf1aa0c n/a (libc.so.6 + 0x11aa0c)
                                               Stack trace of thread 1287:
                                               #1  0x00007fbb5c3c177e g_cond_wait_until (libglib-2.0.so.0 + 0x9077e)
                                               #2  0x00007fbb5c357197 n/a (libglib-2.0.so.0 + 0x26197)
                                               #3  0x00007fbb5c3ca29b n/a (libglib-2.0.so.0 + 0x9929b)
                                               Stack trace of thread 1281:
                                               #5  0x00007fbb5c3919d7 g_main_loop_run (libglib-2.0.so.0 + 0x609d7)
                                               #6  0x00007fbb5c279264 n/a (libgio-2.0.so.0 + 0x11a264)
Sep 27 14:35:28 thymos systemd[1]: systemd-coredump@1-1289-0.service: Deactiva
Ok I can answer now … my system is very recent (AMD Ryzen 5 5600x, Radeon RX6600.)
I have another machine also with a theme. I will reset the theme to a standard one to see if the update will go through…
**** Nope, after resetting to a breeze theme and doing the update, the system still black out on boot. I lost it ???
I am still getting a black screen after the update, just after the login screen. That is not because of theming. I had countless hours of installations. I am afraid of loosing everything. Is there a way to see what is wrong?
No issue so far with Plasma with either x11 or Wayland. For x11, i have installed kwin-x11 and plasma-x11-session. No configuration required at all. :beers:
By the way, do we have to do something as there is a new Grub version ?
Do i have to run grub-install ?
Either installing the install-grub script or restoring the boot loader brings you the update to your EFI system partition. (In case of BIOS boot it will take care on boot.img and core.img.)
Yay! Finally!
No issues.
Thank you for your hard work (which appears to be ongoing with this).
Dash to Panel added GNOME 49 support with v70. It’s working fine here. Please create a new Support > GNOME topic for further troubleshooting.
GNOME has dropped Xorg (X11) support and no longer ships session files in /usr/share/xsessions/. Make sure your /etc/gdm/custom.conf looks like this:
# GDM configuration storage
[daemon]
AutomaticLoginEnable=False
# Uncomment the line below to force the login screen to use Xorg
#WaylandEnable=false
[security]
[xdmcp]
[chooser]
[debug]
# Uncomment the line below to turn on debugging
#Enable=true
Not only were there no issues, the main vertical panel placed centrally dividing two screens now correctly auto hides. .
Thanks @Yochanan , based on this I deleted the Dash2Panel Config in the dconf database, after this it is starting again and I just need to re-configure to my wishes.
Edit:
it seems to be that the Dash2Panel functionality “automatic hide” is causing the trouble … on two of my Manjaro Gnome 49 Systems Dash2Panel works without this feature - but only without … switching on makes Dash2Panel crash
