[Stable Update] 2025-07-20 - Kernels, Mesa, Thunderbird, LibreOffice, Perl, Vulkan
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.296
  • linux510 5.10.240
  • linux515 5.15.189
  • linux61 6.1.146
  • linux66 6.6.99
  • linux612 6.12.39
  • linux615 6.15.7
  • linux616 6.16.0-rc6
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.94_rt56
  • linux612-rt 6.12.28_rt10
  • linux615-rt 6.15.0_rt2
Package Changes (Sat Jul 19 08:50:01 CEST 2025)
  • stable core x86_64: 30 new and 31 removed package(s)
  • stable extra x86_64: 1878 new and 1874 removed package(s)
  • stable multilib x86_64: 22 new and 22 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-07-20
2025-07-12
SDDM may crash with Nvidia drivers
In some case Nvidia drivers need the following workaround in /etc/environment to launch SDDM properly:
MESA_LOADER_DRIVER_OVERRIDE=zink
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command in order to downgrade the installed package with the higher version to the version currently in the repository… :point_down:
 sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins.
 sudo pacman -S vlc-plugins-all
linux-firmware-meta replaces linux-fimware
With the linux-firmware-meta package, all of the firmware is now split up into individual packages, which are all installed as dependencies of linux-firmware-meta.
If you wish to uninstall the firmware packages that you don’t need — e.g. linux-firmware-nvidia — including the meta package itself, then be sure to mark the firmware packages you wish to keep as explicitly installed, or else pacman will regard them as orphans, which would be dangerous when cleaning out your real orphans.
 sudo pacman -D --asexplicit <name-of-package(s)>
2025-06-23
Breaking changes to wine and wine-staging
Transition to the new WoW64 wine and wine-staging
2025-06-16
We are transitioning the wine and wine-staging package to a pure wow64 build. This change removes the dependency on the multilib repository for wine and wine-staging.
The main reason for this is to align with upstream Wine development, which simplifies packaging and the dependency chain.
Potential Issues:
  • OpenGL Performance: A known limitation of the new WoW64 mode is reduced performance for 32-bit applications that use OpenGL directly
  • Breaking Changes: Existing 32-bit prefixes needs to be recreated
If you are facing issues with 32 bit prefixes, please recreate these and reinstall the application.
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduces a possible breaking change if you have custom scripts relying on the mirrors data file. If this is the case, then simply create a symlink from the new location under /var/lib back to the old location, i.e. /usr/share.
ln -s /var/lib/pacman-mirrors /usr/share/
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
avahi-discover python script may fail to discover services
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
2025-04-12
Grub gained security fixes. Updating it may be risky
When Manjaro updates the grub package the actual installed binaries in master boot record (MBR) or UEFI won’t get updated. This is however needed to apply recent security fixes added to grub. Therefore we created Install-grub: a new way to keep your EFI/MBR in-sync with grub package to make it easier.
A more manual approach can be found here: [root tip] [How To] Primer on handling a grub package update
We also have it documented in our wiki on how to manually install grub when a disaster happens: GRUB/Restore the GRUB Bootloader - Manjaro. So if you are not experienced with it you can either ignore that extra step or have an install media at hand to recover as needed.
See also on how to create a boot media to install Manjaro fresh: Burn an ISO File - Manjaro. Those who want to get install medias having this update included may look for 25.0 ISOs when released or here: Releases · manjaro/release-review · GitHub
Remember, update-grub only updates the boot menu and install-grub is a script helper to install or reinstall grub on most case automatically via grub-install. All grub installations can be with a risk when not done properly as the user will change low level system parts and can easily break their systems.
Note: most likely grub was initially installed by an installer and therefore the user doesn’t know how grub got installed. So if you are unsure simply skip a reinstallation of grub.
2025-03-24
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
No sound from PulseAudio after PipeWire update
If PulseAudio audio playback is suspended after PipeWire update, unload module-suspend-on-idle
pactl unload-module module-suspend-on-idle
If that works, create a custom default.pa configuration for PulseAudio in home folder
cp /etc/pulse/default.pa ~/.config/pulse/default.pa
and comment out module-suspend-on-idle in custom configuration
sed -i '/load-module module-suspend-on-idle/s/^/#/' ~/.config/pulse/default.pa
2025-03-05
[community] repository removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-05-02
community has been re-created as an empty repository so that systems where package manager configuration /etc/pacman.conf has not been updated can still be used to update packages from other repositories
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
2025-02-04
Kernel 4,19 and 6.11 are EOL, 6.11 and 4.19 got removed from repos
Kernel 6.11 and 4.19 got marked [EOL] on kernel.org
Linux 6.11 and 4.19 have been removed from the repositories.
Please ensure your system use a supported kernel mhwd-kernel -l
PostgreSQL users should consider to prepare the change of major version 16→17
More info here and here
Update libpamac before installing the 2025-02-04 updates
Run sudo pacman -Sy libpamac in a terminal to make sure pamac-manager doesn’t crash during the update.
XFCE 4.20 may blank display after 5 mins idle time regardless of power management settings
Most likely this: Disable screen blanking
Call xfce4-screensaver-preferences and disable the screensaver.
xfce4-screensaver - Usage [Xfce Docs]
Link is now fixed …
Getting 3 stable updates in a span of 8 days? Is it Christmas already? Update went smoothly as usual
ahah being lazy I prefer monthly updates :sweat_smile:
I updated via pamac and it crashed during the install but oddly was still running in the background (checked htop and also try rerunning pamac threw a Waiting for another package manager to quit). I waited a bit and re-ran pamac and it showed that there was no pending installation. Current shows Manjaro Zetar 25.0.6 is running.
Recurring Regression on Thinkpad T60, Intel Graphics 945GM/ i915
No text in SDDM and KRunner, No Graphics in KSystemMonitor.
sddm-greeter-qt6	Failed to link shader program: error: Exceeded max nr indirect texture lookups (5/4)
sddm-greeter-qt6	Failed to build graphics pipeline state
ksplashqml	Failed to link shader program: error: Exceeded max nr indirect texture lookups (5/4)
ksplashqml	Failed to build graphics pipeline state
kinfocenter	Failed to link shader program: error: Exceeded max ALU instructions (152/64)
kinfocenter	Failed to build graphics pipeline state
plasma-systemmonitor	Failed to link shader program: error: Too many fragment shader default uniform block components
error: Too many fragment shader uniform components
plasma-systemmonitor	Failed to build graphics pipeline state
plasma-systemmonitor	Failed to link shader program: error: Exceeded max ALU instructions (96/64)
ACPI	        \_SB_.PCI0.LPC_.EC__.HKEY: BCSG: evaluate failed
thinkpad_acpi	acpi_evalf(BCSG, dd, ...) failed: AE_NOT_FOUND
inxi -zv8
  Kernel: 6.12.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    clocksource: hpet avail: acpi_pm
    root=UUID=e1dde0ee-4c15-4d8c-a030-ca6fcbe770c3 rw quiet splash
    resume=UUID=cb0b30f7-da3e-478f-b887-28a5d39632e1 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 1952VA4 v: ThinkPad T60
  Mobo: LENOVO model: 1952VA4 serial: <superuser required>
    uuid: <superuser required> BIOS: LENOVO v: 79ETE6WW (2.26 ) date: 04/01/2010
  ID-1: BAT0 charge: 35.7 Wh (82.3%) condition: 43.4/47.5 Wh (91.3%)
    volts: 12.0 min: 10.8 model: SANYO COMPATIBLE type: Li-ion serial: <filter>
    status: not charging
  System RAM: total: 2 GiB available: 1.91 GiB used: 1.51 GiB (79.2%)
  Array-1: capacity: 2 GiB slots: 2 modules: 2 EC: None
    max-module-size: 1024 MiB note: est.
  Device-1: DIMM 1 type: DDR2 detail: synchronous size: 1024 MiB speed: N/A
    volts: N/A width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A
    serial: N/A
  Device-2: DIMM 2 type: DDR2 detail: synchronous size: 1024 MiB speed: N/A
    serial: N/A
  Info: model: Intel Core2 T5500 bits: 64 type: MCP arch: Core2 Merom
    level: v1 built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15)
    stepping: 6 microcode: 0xD1
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: <unsupported> cache:
    L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 2 MiB desc: 1x2 MiB
  Speed (MHz): avg: 998 min/max: 1000/1667 scaling: driver: acpi-cpufreq
    governor: schedutil cores: 1: 998 2: 998 bogomips: 6653
  Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
    cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca
    mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36
    pti rep_good sep sse sse2 ssse3 syscall tm tm2 tsc vme xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT disabled
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Device-1: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics
    vendor: Lenovo ThinkPad R60/T60/X60 series driver: i915 v: kernel
    arch: Gen-3.5 process: Intel 90nm built: 2005-06 ports: active: LVDS-1
    empty: DVI-D-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:27a2 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
    alternate: fbdev,vesa dri: i915 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
    s-diag: 338mm (13.3") monitors: <missing: xrandr>
  Monitor-1: LVDS-1 model: Lenovo 0x4020 built: 2007 res: 1024x768 dpi: 91
    gamma: 1.2 chroma: red: x: 0.612 y: 0.329 green: x: 0.298 y: 0.529 blue:
    x: 0.149 y: 0.129 white: x: 0.314 y: 0.329 size: 287x215mm (11.3x8.46")
    diag: 359mm (14.1") ratio: 4:3 modes: 1024x768
  API: EGL v: 1.5 hw: drv: intel i915 platforms: device: 0 egl: 1.4
    drv: i915 device: 1 drv: swrast gbm: egl: 1.4 drv: i915 surfaceless:
    egl: 1.4 drv: i915 x11: egl: 1.4 drv: i915 inactive: wayland
  API: OpenGL v: 4.5 compat-v: 2.1 vendor: mesa v: 25.1.6-arch1.1 glx-v: 1.4
    direct-render: yes renderer: i915 (: 945GM) device-ID: 8086:27a2
    memory: 187.5 MiB unified: yes
  Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Lenovo
    ThinkPad R60/T60/X60 series driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:27d8 class-ID: 0403
  Device-2: Texas Instruments PCM2900B Audio CODEC
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 08bb:29b0 class-ID: 0300
  API: ALSA v: k6.12.39-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
  Device-1: Intel 82573L Gigabit Ethernet vendor: Lenovo ThinkPad T60
    driver: e1000e v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 02:00.0 chip-ID: 8086:109a class-ID: 0200
  IF: ens2 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR5212 802.11abg NIC vendor: IBM ThinkPad
    11a/b/g Wireless LAN Mini Express driver: ath5k v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:1014 class-ID: 0200
  IF: wls3 state: up mac: <filter>
  Local Storage: total: 232.89 GiB used: 57.29 GiB (24.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM UJ-822S rev: 1.61
    dev-links: cdrom
  ID-1: / raw-size: 68.36 GiB size: 66.74 GiB (97.62%) used: 23.33 GiB (35.0%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: SYSTEM
    uuid: e1dde0ee-4c15-4d8c-a030-ca6fcbe770c3
  ID-2: /home raw-size: 136.72 GiB size: 133.51 GiB (97.66%)
    used: 32.8 GiB (24.6%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: DATA
    uuid: a9b78d9b-3f94-454d-a8b9-3f2e849b9484
  ID-1: swap-1 type: partition size: 11.72 GiB used: 1.16 GiB (9.9%)
    priority: -2 dev: /dev/sda4 maj-min: 8:4 label: SWAP
    uuid: cb0b30f7-da3e-478f-b887-28a5d39632e1
  ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: <superuser required> label: N/A
    uuid: N/A
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Device-1: 3-1:2 info: Texas Instruments PCM2900B Audio CODEC
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-5: 5-0:1 info: full speed or root hub ports: 8 rev: 2.0
  System Temperatures: cpu: 55.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 2963 fan-2: 2963
  Packages: pm: pacman pkgs: 1299 libs: 335 tools: pamac
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 179
  1: cpu: 28.5% command: ps pid: 2204 mem: 3.80 MiB (0.1%)
  2: cpu: 14.6% command: firefox pid: 788 mem: 326.2 MiB (16.6%)
  3: cpu: 9.4% command: konsole pid: 2142 mem: 122.1 MiB (6.2%)
  4: cpu: 6.9% command: firefox pid: 1863 mem: 226.6 MiB (11.5%)
  5: cpu: 5.9% command: zsh pid: 2150 mem: 8.22 MiB (0.4%)
  Memory top: 5 of 179
  1: mem: 326.2 MiB (16.6%) command: firefox pid: 788 cpu: 14.6%
  2: mem: 246.7 MiB (12.5%) command: firefox pid: 1051 cpu: 5.3%
  3: mem: 226.6 MiB (11.5%) command: firefox pid: 1863 cpu: 6.9%
  4: mem: 223.9 MiB (11.4%) command: firefox pid: 1708 cpu: 2.1%
  5: mem: 216.4 MiB (11.0%) command: firefox pid: 1123 cpu: 3.2%
  Processes: 179 Power: uptime: 26m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 767.4 MiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.0 running-in: konsole inxi: 3.3.38
Currently unable to update because of
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.23m.com : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.23m.com : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.23m.com : The requested URL returned error: 404
warning: too many errors from mirror.23m.com, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.23m.com : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from ftp.rz.tu-bs.de : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from ftp.rz.tu-bs.de : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from ftp.rz.tu-bs.de : The requested URL returned error: 404
warning: too many errors from ftp.rz.tu-bs.de, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from ftp.rz.tu-bs.de : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from ftp.belnet.be : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from ftp.belnet.be : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from ftp.belnet.be : The requested URL returned error: 404
warning: too many errors from ftp.belnet.be, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from ftp.belnet.be : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.futureweb.be : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.futureweb.be : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.futureweb.be : The requested URL returned error: 404
warning: too many errors from mirror.futureweb.be, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.futureweb.be : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.init7.net : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.init7.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.init7.net : The requested URL returned error: 404
warning: too many errors from mirror.init7.net, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.init7.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.alwyzon.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.alwyzon.net : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.alwyzon.net : The requested URL returned error: 404
warning: too many errors from mirror.alwyzon.net, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.alwyzon.net : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.alpix.eu : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.alpix.eu : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.alpix.eu : The requested URL returned error: 404
warning: too many errors from mirror.alpix.eu, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.alpix.eu : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.easyname.at : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.easyname.at : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.easyname.at : The requested URL returned error: 404
warning: too many errors from mirror.easyname.at, skipping for the remainder of this transaction
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.easyname.at : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from ftp.lysator.liu.se : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from ftp.lysator.liu.se : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from ftp.lysator.liu.se : The requested URL returned error: 404
warning: too many errors from ftp.lysator.liu.se, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from ftp.lysator.liu.se : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from ftp.gwdg.de : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from ftp.gwdg.de : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from ftp.gwdg.de : The requested URL returned error: 404
warning: too many errors from ftp.gwdg.de, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from ftp.gwdg.de : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.mirrors.lavatech.top : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.mirrors.lavatech.top : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from manjaro.mirrors.lavatech.top : The requested URL returned error: 404
warning: too many errors from manjaro.mirrors.lavatech.top, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from manjaro.mirrors.lavatech.top : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from ask4.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from ask4.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from ask4.mm.fcix.net : The requested URL returned error: 404
warning: too many errors from ask4.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from ask4.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.ipacct.com : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.ipacct.com : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from manjaro.ipacct.com : The requested URL returned error: 404
warning: too many errors from manjaro.ipacct.com, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from manjaro.ipacct.com : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.mirrors.uk2.net : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from manjaro.mirrors.uk2.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from manjaro.mirrors.uk2.net : The requested URL returned error: 404
warning: too many errors from manjaro.mirrors.uk2.net, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.mirrors.uk2.net : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from ipng.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from ipng.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from ipng.mm.fcix.net : The requested URL returned error: 404
warning: too many errors from ipng.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from ipng.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from manjaro.ynh.ovh : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from manjaro.ynh.ovh : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.ynh.ovh : The requested URL returned error: 404
warning: too many errors from manjaro.ynh.ovh, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from manjaro.ynh.ovh : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.raiolanetworks.com : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.raiolanetworks.com : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.raiolanetworks.com : The requested URL returned error: 404
warning: too many errors from mirror.raiolanetworks.com, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.raiolanetworks.com : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirrors.up.pt : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirrors.up.pt : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirrors.up.pt : The requested URL returned error: 404
warning: too many errors from mirrors.up.pt, skipping for the remainder of this transaction
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirrors.up.pt : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst' from mirror.hostiko.network : The requested URL returned error: 404
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst' from mirror.hostiko.network : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst' from mirror.hostiko.network : The requested URL returned error: 404
warning: too many errors from mirror.hostiko.network, skipping for the remainder of this transaction
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst' from mirror.hostiko.network : The requested URL returned error: 404
error: failed retrieving file 'linux612-headers-6.12.38-1-x86_64.pkg.tar.zst.sig' from manjaro.kurdy.org : The requested URL returned error: 404
error: failed retrieving file 'github-cli-2.75.1-1-x86_64.pkg.tar.zst.sig' from manjaro.kurdy.org : The requested URL returned error: 404
error: failed retrieving file 'linux612-nvidia-575.64.03-4-x86_64.pkg.tar.zst.sig' from manjaro.kurdy.org : The requested URL returned error: 404
warning: too many errors from manjaro.kurdy.org, skipping for the remainder of this transaction
error: failed retrieving file 'linux612-6.12.38-1-x86_64.pkg.tar.zst.sig' from manjaro.kurdy.org : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
mirrors are already updated
Please execute (have patience - it will take some time)
sudo pacman-mirrors -c all && sudo pacman -Syu
Managed to solve the problem before your reply, i restarted, logged out, stopped gdm and did pacman -Syyu (I know not recommended but wanted to try it if for some reason it helps) and update went smoothly after that. Thanks for your help.
Another pretty smooth update; thanks team.
I had to rebuild a few Perl modules to fit in with the new version, but that was hardly onerous.
Another nice, smooth update (this thing of not owning a “good” graphic card has its advantages :joy:).
Just a curiosity: the update-grub thing works ok, no problem on reboot, but each time it says:
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Does anybody know why?
I’m glad to report that kernel 6.15.7-1 seems to have the computer not staying turned off issue sorted out.
Flawless update for me, however I received a warning on a laptop with an encrypted drive. I set up the full encryption with the manjaro installer a couple of years ago and never touched it. From pacman.log
[ALPM-SCRIPTLET] → Running build hook: [openswap]
[ALPM-SCRIPTLET] ==> WARNING: you are using potentially dangerous unlock_method keyfile, please make sure you know what you are doing
[ALPM-SCRIPTLET] ==> WARNING: Swap suspend — The Linux Kernel documentation
[ALPM-SCRIPTLET] ==> WARNING: dm-crypt/Swap encryption - ArchWiki
[ALPM-SCRIPTLET] ==> WARNING: keyfile_device_mount_options variable is not set and unlock_method is set to keyfile
In the pacnew file for openswap there is now the option “keyfile_device_mount_options variable” included, so I set it in the existing openswap.conf to the recommended “ro,noload”, which makes sense for something that should not change. But just to make sure I wanted to ask if there is any other trap to be aware of? From the link provided in the warning I could just understand that loading a key from a mounted filesystem after suspend is a problem?
I have an issue with my system freezing under heavy GPU load that started when I updated. I made a support page here: System freezes under heavy GPU load after today's update. AMDGPU RDNA3
My Digital Camera no longer recognise and mount option no longer shown in gtk filebrowser program’s… I don’t know whats going on, but it looks like a regression too me.
This time I was in a hurry while updating so I did not merge openswap.conf.pacnew.
I never touched this config and now I am not sure what to do with it :thinking:
I’ve had the same issue for a long time :frowning: unsure what causes it. I have tried closing the gui/taskbar package manager first, but it doesn’t change anything.
You may want to create a topic about this crash, mention it here and paste the backtrace (shown in journaltcl) in it.
Ideally, we would have debug symbols so that the backtrace would be much more useful.
One of these 2 Kernel versions did fix my shutdown problem.
  • linux615 6.15.6
  • linux615 6.15.7
Now shutdown now does not reboot my system anymore.
