[Testing Update] 2025-11-10 - Kernels, Systemd, Mkinitcpio, KDE Gear, Plasma
Hello community, here we have another set of package updates. Welcome to our new development cycle of Manjaro 25.1.0, code-named ‘Anh-Linh’.We will focus on Plasma 6.5 series and will introduce GNOME 49, maybe Cosmic 1.0 (Beta).
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.301
  • linux510 5.10.246
  • linux515 5.15.196
  • linux61 6.1.158
  • linux66 6.6.116
  • linux612 6.12.57
  • linux617 6.17.7
  • linux618 6.18.0-rc5
  • linux61-rt 6.1.156_rt56
  • linux66-rt 6.6.116_rt66
  • linux612-rt 6.12.49_rt13
  • linux616-rt 6.16.0_rt3
  • linux617-rt 6.17.5_rt7
Package Changes (11/10/25 08:39 CET)
  • testing core x86_64: 26 new and 26 removed package(s)
  • testing extra x86_64: 897 new and 919 removed package(s)
  • testing multilib x86_64: 15 new and 15 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-11-10
mkinitcpio v40 disabled fallback image creation for new installs
mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
This is only affects new installs as we can’t change the hook files on existing installs.
To disable fallback image creation on older installed systems
  • Change PRESETS=('default' 'fallback') line to PRESETS=('default') in the respective .preset files in /etc/mkinitcpio.d/.
  • Regenerate initramfs
  • Update your boot loader configuration.
Warning
Disabling all fallback initramfs generation will deprive you of another option to boot into the system in case a default initramfs fails. Before proceeding, make sure you have a bootable installation medium for rescue purposes on hand.
2025-09-28
2025-9-27
Heads up: Gnome 49 is here and wayland is the default.
2025-08-24
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
It seems on older hardware the mesa 25.2.x update created some regressions which may result in black screens or flickering. Some older Nvidia cards with nouveau driver seem to be affected.
You can try to use the 25.1.x series of Mesa via this repo. Simply place it on top of [extra] in your /etc/pacman.conf file and use sudo pacman -Syuu to downgrade.
[mesa-251]
SigLevel = PackageRequired
Server = https://download.manjaro.org/pkgs/mesa
If you have no graphical session available you can access the bootloader by pressing ESC key during boot and select the bootloader entry. Press CTRL+E for edit and search for the words quiet and splash. Delete those and add 3 to the line. Then execute CTRL+x to start your session. You will land in a text console TTY. Login with your user.
Edit the /etc/pacman.conf with nano: sudo nano /etc/pacman.conf. Perform the downgrade and reboot.
Previous testing threads:
By default, mkinitcpio 40 no longer produces the fallback initcpio.
mkinitcpio needs an update..
Please update ffmpeg as well.
ffmpeg is a package we import from Arch verbatim, and the version of ffmpeg in the Manjaro Unstable and Testing repositories is 2:8.0-3, which is the same as in Arch.
So it will be in the next release release, cool
Right, that’s by design:
Disabled fallback image creation for new installs.
Generally they are not super useful and people that need them can enable them if
they would like too. This is only affects new installs as we can’t change the
– mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
Fallback images are for wussies.
/me hides under the table :stuck_out_tongue:
Fallback images are like suspenders. If you’re wearing a belt, you (almost) never need them.
But when it comes to computers, software, and my data, I always wear a belt and suspenders, and sometimes a safety pin too. (In real life, a belt is enough for me.)
:footprints:
3 kernel, fallback, btrfs-raid (2 different SSDs), snapshots(@,@home,@…), backups(external) & live-USB
I was so happy when pacdiff’s merge feature got fixed in Manjaro after being broken for a few months. (Last year was it?)
I’ve never done it any other way! Update every system easily with ssh, and much quicker than meld for me.
Now it’s doing something really wonky.
Even though I should not get this, for one pacnew I got:
==> pacnew file found for /etc/default/grub-btrfs/config
:: (V)iew, (M)erge, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/m/s/r/o/q] m
  -> Unable to find an older package to base merge on.
I skipped that file, and moved on to one of the other 8 I think I had. I was 3 or 4 in when I realised the merge view was off.
The remaining ones, (V)iew and (M)erge are completely different diffs, (V)iew being correct.
For now, I have to rollback, I saved botched pacnews. :slightly_frowning_face:
Did you remove grub-btrfs 4.13-2 from your cache?
Always leave at least one older version. I usually leave three and use sudo paccache -rvk3 occasionally.
I suppose you could downgrade temporarily to that version with sudo manjaro-downgrade grub-btrfs, then update and deal with the pacnew. Not tested, however in theory I imagine that should work.
What to do for existing installs?
Copy the hook.preset to a configurable location and uncomment the fallback bits:
sudo cp /usr/share/mkinitcpio/hook.preset /etc/mkinitcpio.conf.d/
It’s not about the package, it’s the (M)erge feature of pacdiff.
The other ones that didn’t error like that one, weren’t handling pacnew files correctly either.
Edit:
I forgot I undid a whole slew of pacnew files from the last massive update. (Then forgot to move them back.)
User error.
I’m still scarred from the months of mergeless pacdiff for everyone! I can now sleep again.
interesting change. Frankly, as a sdboot user, this saves a lot of space efi partitions, as fallback images are huge. With just one kernel it is usually enough, but I had run into problems with two kernels present (i.e. four initram images).
ArchWiki - mkinicpio - Disabling fallback intramfs generation
The generation of fallback images can be disabled:
  • Remove the fallback initramfs images in /boot/.
Warning
Can gajim 2.4 and the required deps be snuck into this round of updates? :crossed_fingers:
It already is.
Switched from stable to testing. Going well for now. Thanks for the work.
