[Testing Update] 2025-09-02 - Kernels, Wine, Haskell, Python
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • Some Kernels got rebuilt
  • Wine 10.14
  • Haskell and Python updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.297
  • linux510 5.10.241
  • linux515 5.15.190
  • linux61 6.1.149
  • linux66 6.6.103
  • linux612 6.12.44
  • linux615 6.15.11 [EOL]
  • linux616 6.16.4
  • linux617 6.17.0-rc4
  • linux61-rt 6.1.146_rt53
  • linux66-rt 6.6.101_rt59
  • linux612-rt 6.12.43_rt12
  • linux615-rt 6.15.0_rt2
  • linux616-rt 6.16.0_rt3
Package Changes (Tue Sep 2 06:46:14 CEST 2025)
  • testing core x86_64: 1 new and 1 removed package(s)
  • testing extra x86_64: 1284 new and 1290 removed package(s)
  • testing multilib x86_64: 4 new and 4 removed package(s)
Overlay Changes
  • testing core x86_64: 30 new and 30 removed package(s)
  • testing extra x86_64: 54 new and 56 removed package(s)
  • testing multilib x86_64: 1 new and 1 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-09-02
  • pacman-mirrors version 5.1
    Deprecation of --geoip in favor of -tz/--timezone.
    This internal change make mirror-list generation use your system’s configured timezone - when applicable - without using an IP location provider.
    More privacy..
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
Previous testing threads:
