[Testing Update] 2025-07-03 - Kernels, Linux-Firmware, Systemd, NVIDIA, Firefox, GStreamer
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: See current promotion
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • Some Kernels got updated
    • linux613-rt and linux614-rt got dropped from the repos
    • linux-firmware got split into smaller packages. A meta-package ensures basic firmware installation. For stripping it down you may remove it after you have done the upgrade.
  • Systemd 257.7
  • GNOME 48.3
  • NVIDIA 575.64.03
  • Phosh 0.48.0
  • Firefox 140.0.2
  • GStreamer 1.26.3
  • OpenSearch 3.0
  • PipeWire 1.4.6
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.295
  • linux510 5.10.239
  • linux515 5.15.186
  • linux61 6.1.142
  • linux66 6.6.95
  • linux612 6.12.35
  • linux615 6.15.4
  • linux616 6.16.0-rc4
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.94_rt56
  • linux612-rt 6.12.28_rt10
  • linux615-rt 6.15.0_rt2
Package Changes (Thu Jul 3 09:14:58 CEST 2025)
  • testing core x86_64: 85 new and 81 removed package(s)
  • testing extra x86_64: 1902 new and 2010 removed package(s)
  • testing multilib x86_64: 45 new and 45 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-07-03
2025-06-19
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduce a possible breaking change if you have custom scripts relying on the mirrors data file.
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
2025-06-14
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
2025-03-20
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
2025-03-05
[community] repo removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-05-02
community has been re-created as an empty repository so that systems where package manager configuration /etc/pacman.conf has not been updated can still be used to update packages from other repositories
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
Previous testing threads:
signal-desktop with wayland and Nvidia is only starting with
“signal-desktop --ozone-platform=x11” on my nvidia machine. On an intel notebook it runs without an issue even with native wayland
Spectacle refuses to start.
error while loading shared libraries: libopencv_imgproc.so.411: cannot open shared object file: No such file or directory
OpenCV was updated to 4.12, but 4.11 is expected.
A post was split to a new topic: Keyboard layout switched from German to English after [Testing Update] 2025-07-03
Thanks @dennis.b. If you haven’t done so already, downgrading opencv will solve it :
sudo manjaro-downgrade opencv
Select 4.11 at prompt.
https://wiki.manjaro.org/index.php?title=Downgrading_packages
Thx, might need a rebuild. Next Tuesday 6.3.6 should come out, but I will add a rebuild now.
One tiny glitch. I tried updating via the GUI but the system froze. I retried doing the update via tty and updated with no problem. I also noted the system was running much cooler and with more memory free and with less cpu usage.
I am getting this weird error from dkms
Install DKMS modules        [17/32]
==> dkms install --no-depmod hid-xpadneo/0.9.r222.gcd25680 -k 6.12.35-1-MANJARO
Deprecated feature: CLEAN (/var/lib/dkms/hid-xpadneo/0.9.r222.gcd25680/source/dkms.conf)
==> dkms install --no-depmod it87/287.4bff981 -k 6.12.35-1-MANJARO
Deprecated feature: CLEAN (/var/lib/dkms/it87/287.4bff981/source/dkms.conf)
==> dkms install --no-depmod zenpower3/0.2.0 -k 6.15.4-4-MANJARO
==> dkms install --no-depmod ryzen_smu/0.1.5 -k 6.12.35-1-MANJARO
Deprecated feature: CLEAN (/var/lib/dkms/ryzen_smu/0.1.5/source/dkms.conf)
==> dkms install --no-depmod zenpower3/0.2.0 -k 6.12.35-1-MANJARO
==> dkms install --no-depmod ryzen_smu/0.1.5 -k 6.15.4-4-MANJARO
==> dkms install --no-depmod it87/287.4bff981 -k 6.15.4-4-MANJARO
==> dkms install --no-depmod hid-xpadneo/0.9.r222.gcd25680 -k 6.15.4-4-MANJARO
I have found its nothing to be alarmed but the CLEAN line should be removed somewhere.
https://bugs-devel.debian.org/cgi-bin/bugreport.cgi?bug=1012043
EDIT: This is the root cause deprecate CLEAN by anbe42 · Pull Request #514 · dell/dkms · GitHub
Works, thank you.
On KDE, I noticed that ksystemstats has been removed from the Manjaro repos, but that plasma-systemmonitor and plasma-workspace both depend on ksystemstats :
Output : pamac info ksystemstats
LANG=C pamac info ksystemstats         ✔
Version               : 6.4.0-1
Description           : A plugin based system monitoring daemon
URL                   : https://kde.org/plasma-desktop/
Licenses              : LGPL-2.0-or-later
Repository            : None
Installed Size        : 1.6 MB
Groups                : plasma
Depends On            : gcc-libs glibc kcoreaddons kcrash ki18n kio libksysguard lm_sensors qt6-base solid
Optional Dependencies : libnl: network usage monitor [Installed]
                        networkmanager-qt: network usage monitor [Installed]
                        systemd-libs: GPU monitor [Installed]
Required By           : plasma-systemmonitor plasma-workspace
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Tomaz Canabrava <tcanabrava@archlinux.org>
Build Date            : Wed 18 Jun 2025 21:58:20
Install Date          : Fri 20 Jun 2025 01:27:57
Install Reason        : Installed as a dependency for another package
Validated By          : Signature
Backup files          : --
Also, ksystemstats still appears in the Arch extra repo :
https://archlinux.org/packages/extra/x86_64/ksystemstats/
Could someone please shed some light on the context for the removal ? Is it normal for a package to be removed from a Manjaro repo if other packages still depend on it, and the removed package still exists in an Arch repo ? Thanks.
My guess is that the Plasma 6.4.0 version was prematurely rolled out to Testing (& Stable) branches, and subsequently removed from Testing, but the version for Plasma 6.3.5 hasn’t been returned to the repo:
mbn info ksystemstats -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 6.4.2-1
Build Date     : Wed 02 Jul 2025 16:43:01
Branch         : unstable
Version        : 6.4.2-1
Branch         : stable
Version        : 6.4.0-1
Build Date     : Wed 18 Jun 2025 19:58:20
mbn can be found in the manjaro-check-repos package
Here’s my installation/update history for it:
Output of paclog --grep=ksystemstats
[2023-11-09T08:41:03+1100] [ALPM] upgraded ksystemstats (5.27.8-2 -> 5.27.9-1)
[2023-12-10T11:49:52+1100] [ALPM] upgraded ksystemstats (5.27.9-1 -> 5.27.10-1)
[2024-03-13T12:45:03+1100] [ALPM] upgraded ksystemstats (5.27.10-1 -> 5.27.11-1)
[2024-05-08T17:57:01+1000] [ALPM] upgraded ksystemstats (5.27.11-1 -> 6.0.4-1)
[2024-05-23T11:58:48+1000] [ALPM] upgraded ksystemstats (6.0.4-1 -> 6.0.5-0)
[2024-05-27T19:25:48+1000] [ALPM] upgraded ksystemstats (6.0.5-0 -> 6.0.5-1)
[2024-09-08T11:20:02+1000] [ALPM] upgraded ksystemstats (6.0.5-1 -> 6.1.4-1)
[2024-09-13T17:43:41+1000] [ALPM] upgraded ksystemstats (6.1.4-1 -> 6.1.5-1)
[2024-10-11T09:01:14+1100] [ALPM] upgraded ksystemstats (6.1.5-1 -> 6.2.0-1)
[2024-10-17T10:31:13+1100] [ALPM] upgraded ksystemstats (6.2.0-1 -> 6.2.1-1)
[2024-10-24T13:56:32+1100] [ALPM] upgraded ksystemstats (6.2.1-1 -> 6.2.2-1)
[2024-11-06T17:15:23+1100] [ALPM] upgraded ksystemstats (6.2.2-1 -> 6.2.3-1)
[2024-11-27T22:48:05+1100] [ALPM] upgraded ksystemstats (6.2.3-1 -> 6.2.4-0)
[2024-11-28T14:31:13+1100] [ALPM] upgraded ksystemstats (6.2.4-0 -> 6.2.4-1)
[2025-01-04T21:42:34+1100] [ALPM] upgraded ksystemstats (6.2.4-1 -> 6.2.5-1)
[2025-02-17T19:21:13+1100] [ALPM] upgraded ksystemstats (6.2.5-1 -> 6.3.0-1)
[2025-02-19T16:43:45+1100] [ALPM] upgraded ksystemstats (6.3.0-1 -> 6.3.1-1)
[2025-03-01T14:48:18+1100] [ALPM] upgraded ksystemstats (6.3.1-1 -> 6.3.2-1)
[2025-03-13T09:51:23+1100] [ALPM] upgraded ksystemstats (6.3.2-1 -> 6.3.3-1)
[2025-04-05T20:12:14+1100] [ALPM] upgraded ksystemstats (6.3.3-1 -> 6.3.4-1)
[2025-05-10T10:16:15+1000] [ALPM] upgraded ksystemstats (6.3.4-1 -> 6.3.5-1)
[2025-06-19T19:30:24+1000] [ALPM] upgraded ksystemstats (6.3.5-1 -> 6.4.0-1)
Should been fixed by now. Seems during some sync a 6.4.0 version was somehow added by Arch … [manjaro-packages] [BoxIt] Memo (x64)
Thanks @philm . The 6.4.0 → 6.3.5 version downgrade has been successfully installed from the Global mirrors:
sudo pacman -Syuu
[sudo] password for scotty:
 core is up to date
 extra                                               8.5 MiB  4.81 MiB/s 00:02 [--------------------------------------------] 100%
warning: ksystemstats: downgrading from version 6.4.0-1 to version 6.3.5-1
resolving dependencies...
Packages (1) ksystemstats-6.3.5-1
Total Installed Size:   1.49 MiB
Net Upgrade Size:      -0.04 MiB
:: Proceed with installation? [Y/n] y
