[Testing Updates] 2025-06-05 - Kernels, VirtualBox, Bluez, PipeWire, Qt6, Mesa, Thunderbird
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: See current promotion
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.295
  • linux510 5.10.237
  • linux515 5.15.185
  • linux61 6.1.141
  • linux66 6.6.93
  • linux612 6.12.32
  • linux614 6.14.10
  • linux615 6.15.1
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.87_rt54
  • linux612-rt 6.12.28_rt10
  • linux613-rt 6.13_rt5
  • linux614-rt 6.14.0_rt3
  • linux615-rt 6.15.0_rt2
Package Changes (Thu Jun 5 09:10:59 CEST 2025)
  • testing core x86_64: 26 new and 24 removed package(s)
  • testing extra x86_64: 697 new and 746 removed package(s)
  • testing multilib x86_64: 19 new and 19 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-06-05
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Change the ownership of the folder /usr/lib/avahi including files
sudo chown root:avahi /usr/lib/avahi -R
sudo chmod g+w /usr/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
2025-03-20
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
2025-03-05
[community] repo removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-05-02
community has been re-created as an empty repository so that systems where package manager configuration /etc/pacman.conf has not been updated can still be used to update packages from other repositories
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
Previous testing threads:
So, I’ve just upgraded my install and it seems like some Applications stopped displaying anything, I’m fairly certain It’s related to the new mesa upgrade. The two that i could find were pamac itself, which was just displaying two flickering rectangles instead of the GUI and the Appimage version of azahar, which displays no video, the game logic seems to be running fine though. Also would note that the flatpak version of azahar seems to be working fine. Would it be possible for me to recieve a list of all mesa packages i should downgrade so i can downgrade them to test it manually? Thanks.
edit: Yep, I managed to revert my mesa packages to the previous version (1:25.1.1-2) and they both started working normally again. Guess I’ll have to wait for the mesa folks fix it.
I have an i5-3470 just with It’s integrated graphics (Intel hd 2500). Probably should’ve added this earlier, sorry.
Hi all,
Obsidian is not working under wayland, no issues with X11.
Gnome, Nvidia, 6.12 (same with 6.15)
The icon appears in the dock, but the window does not appear on the screen
solved by starting with
"obsidian --ozone-platform-hint=X11 "
 ~  obsidian                                                               ✔
2025-06-06 04:54:56 Loading main app package /usr/lib/obsidian/obsidian.asar
Ignored: Error: ENOENT: no such file or directory, open '/home/joerg/.config/obsidian/obsidian.json'
2025-06-06 04:54:56 Checking for update using Github
[3815:0606/065457.109018:ERROR:angle_platform_impl.cc(44)] ImageEGL.cpp:112 (operator()): eglCreateImage failed with 0x00003009
ERR: ImageEGL.cpp:112 (operator()): eglCreateImage failed with 0x00003009
[3815:0606/065457.109261:ERROR:scoped_egl_image.cc(23)] Failed to create EGLImage: EGL_SUCCESS
[3815:0606/065457.109369:ERROR:native_pixmap_egl_binding.cc(117)] Unable to initialize binding from pixmap
[3815:0606/065457.109492:ERROR:ozone_image_backing.cc(307)] OzoneImageBacking::ProduceSkiaGanesh failed to create GL representation
[3815:0606/065457.109578:ERROR:shared_image_manager.cc(256)] SharedImageManager::ProduceSkia: Trying to produce a Skia representation from an incompatible backing: OzoneImageBacking
[3815:0606/065457.109764:ERROR:gpu_service_impl.cc(1162)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
[3682:0606/065457.121761:ERROR:gpu_process_host.cc(981)] GPU process exited unexpectedly: exit_code=8704
2025-06-06 04:54:57 Success.
2025-06-06 04:54:57 Latest version is 1.8.10
2025-06-06 04:54:57 App is up to date.
[3855:0606/065457.685479:ERROR:angle_platform_impl.cc(44)] ImageEGL.cpp:112 (operator()): eglCreateImage failed with 0x00003009
[3855:0606/065457.685732:ERROR:scoped_egl_image.cc(23)] Failed to create EGLImage: EGL_SUCCESS
[3855:0606/065457.685934:ERROR:native_pixmap_egl_binding.cc(117)] Unable to initialize binding from pixmap
[3855:0606/065457.686091:ERROR:ozone_image_backing.cc(307)] OzoneImageBacking::ProduceSkiaGanesh failed to create GL representation
[3855:0606/065457.686190:ERROR:shared_image_manager.cc(256)] SharedImageManager::ProduceSkia: Trying to produce a Skia representation from an incompatible backing: OzoneImageBacking
[3855:0606/065457.686374:ERROR:gpu_service_impl.cc(1162)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
[3682:0606/065457.699164:ERROR:gpu_process_host.cc(981)] GPU process exited unexpectedly: exit_code=8704
[3878:0606/065458.286619:ERROR:angle_platform_impl.cc(44)] ImageEGL.cpp:112 (operator()): eglCreateImage failed with 0x00003009
[3878:0606/065458.286842:ERROR:scoped_egl_image.cc(23)] Failed to create EGLImage: EGL_SUCCESS
[3878:0606/065458.287034:ERROR:native_pixmap_egl_binding.cc(117)] Unable to initialize binding from pixmap
[3878:0606/065458.287236:ERROR:ozone_image_backing.cc(307)] OzoneImageBacking::ProduceSkiaGanesh failed to create GL representation
[3878:0606/065458.287432:ERROR:shared_image_manager.cc(256)] SharedImageManager::ProduceSkia: Trying to produce a Skia representation from an incompatible backing: OzoneImageBacking
[3878:0606/065458.287699:ERROR:gpu_service_impl.cc(1162)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
[3682:0606/065458.300010:ERROR:gpu_process_host.cc(981)] GPU process exited unexpectedly: exit_code=8704
With mesa 25.1 it’s necessary to remove ENABLE_HDR_WSI=1 from whereever you might have used it, to get HDR to work before mesa 25.1. Without removing it, mpv had washed out colours for me; after removing it, HDR was back. (also you can uninstall now obsolete vk-hdr-layer-kwin6-git (AUR))
Post-update, one of my bluetooth 5.3 devices (Philips TAT1108 wireless earbuds) could no longer retain a bluetooth connection : device would connect and immediately disconnect.
Attempted unsuccessfully to remove and to repair the device on both kernel 6.15.1 and on kernel 6.12.32 with no luck : the device still could not retain a connection.
Fixed by downgrading bluez to 5.82 and repairing device. Bluetooth connection between host and device is now stable again.
Addendum - the connection problem appears related to host wireless hardware. The problem exists for a host with an Intel AX211 wireless module, but not for hosts with either a Realtek RTL8822BE module or an Intel AC8265 module.
With kernel 6.15.1, the Wi-Fi disappears on my Intel Arrow Lake-H. iwlwifi won’t load, and the Wi-Fi remains missing. Bluetooth is unaffected. I reverted to kernel 6.14.10. Wi-Fi and Bluetooth work.
vi2a3
:stuck_out_tongue:
Why not use 6.12? It is after all an LTS kernel, and it’s supported with bug fixes and security patches up until at least December 2026.
:+1: Yes, my AI says I can downgrade to kernel 6.12, but I also think the current kernel is a step forward in supporting the relatively new Arrow Lake CPUs. The Wi-Fi loss isn’t a major issue for me right now, and will surely be fixed in the 6.15.x releases. :sunglasses:
With kernel 6.15.2 the problem is solved!
