Hello community, here we have another set of package updates. Since Iβm still recovering from my move back to Europe from Asia, I might be less responsive on the forum. So lets test these packages thoroughly so we can do another stable branch snap.
Current Promotions
Find out all about our current Gaming Laptop the Hero with Manjaro pre-installed from Spain!
Protect your personal data, keep yourself safe with Surfshark VPN: See current promotion
As of Linux 6.13.12, the 6.13 series is now EOL (End Of Life). Please install 6.14 stable and/or 6.12 LTS (Long Term Support).
2025-04-17 - Andrew Crerar
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Finding information easier about Manjaro always has been a topic that needed to be solved. With our new search we have put all Manjaro data accessible in one place and divided by sections so it makes it easier to digest: News β Manjaro
You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.12.so.
Rebuild them all at once:*
checkrebuild
* Itβs recommended to clean your build cache first with pamac clean --build-files
Info about AUR packages
AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didnβt update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
Update regular repository packages first with
pamac update --no-aur or
sudo pacman -Syu
Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Experienced a couple of random freezes on one of my two displays after installing linux614-nvidia-open. Not sure if its a coincidence, but each freeze occurred on the same display.
Difficult to reproduce and to pinpoint exact sequence of events which lead to freeze, but a freeze never occurred on linux614-nvidia.
Switching the frozen display off and then on again appears to unfreeze the display.
$ journalctl -r --grep=nvidia
May 11 00:18:34 REDACTED systemsettings[41149]: Physical device 0: 'NVIDIA GeForce RTX 3070 Ti' 570.576.0 (api 1.4.303 vendor 0x10DE device 0x2482 type 2)
May 10 19:19:49 REDACTED systemsettings[24763]: Physical device 0: 'NVIDIA GeForce RTX 3070 Ti' 570.576.0 (api 1.4.303 vendor 0x10DE device 0x2482 type 2)
May 10 19:18:27 REDACTED systemsettings[24590]: Physical device 0: 'NVIDIA GeForce RTX 3070 Ti' 570.576.0 (api 1.4.303 vendor 0x10DE device 0x2482 type 2)
May 10 18:34:04 REDACTED kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
May 10 18:34:01 REDACTED kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
May 10 18:33:57 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:57 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:56 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:56 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:55 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:55 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:54 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:54 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:53 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:53 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:52 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:52 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:51 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:51 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:50 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:50 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:49 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:49 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:48 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:48 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:47 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:47 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:46 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:46 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:45 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:45 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:44 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:44 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:43 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:43 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:42 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:42 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:41 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:41 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:40 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:40 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:39 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:39 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:35 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:35 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:33 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:33 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:32 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:32 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:20 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:20 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:18 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:18 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:13 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:13 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:11 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:11 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:10 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:10 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:09 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:09 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:08 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:08 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:04 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:04 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:02 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:02 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:01 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:01 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:33:00 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:33:00 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:59 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:59 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:57 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:57 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:56 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:56 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:55 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:55 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:53 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:53 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:52 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:52 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:51 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:51 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:50 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:50 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:43 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:43 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:42 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:42 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:41 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:41 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:40 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:40 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:39 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:39 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:38 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:38 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:37 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:37 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:36 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:36 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:35 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:35 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:34 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:34 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:33 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:33 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:32 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:32 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:31 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:31 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:30 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:30 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:29 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:29 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:28 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:28 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:27 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:27 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:26 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:26 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:25 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:25 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:24 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:24 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:23 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:23 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:22 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:22 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 18:32:21 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
May 10 18:32:21 REDACTED kwin_wayland[1018]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
May 10 13:29:37 REDACTED kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
May 10 13:29:37 REDACTED kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
May 10 13:29:37 REDACTED kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
May 10 13:29:37 REDACTED kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
May 10 13:29:36 REDACTED kernel: nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
May 10 13:29:36 REDACTED kernel: fbcon: nvidia-drmdrmfb (fb0) is primary device
May 10 13:29:36 REDACTED kernel: nvidia 0000:01:00.0: vgaarb: deactivate vga console
May 10 13:29:36 REDACTED kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
May 10 13:29:36 REDACTED kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
May 10 13:29:36 REDACTED kernel: nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 570.144 Release Build (archlinux-builder@echo archlinux)
May 10 13:29:36 REDACTED kernel: NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 570.144 Release Build (archlinux-builder@echo archlinux)
May 10 13:29:36 REDACTED kernel: nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
May 10 13:29:36 REDACTED kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 240
May 10 13:29:36 REDACTED kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
May 10 13:29:36 REDACTED kernel: nvidia: loading out-of-tree module taints kernel.
