[Testing Update] 2025-09-29 - Kernel 6.17, Deepin, Yoshimi, Haskell, Python
Hello community, here we have another set of package updates. Welcome to our new development cycle of Manjaro 25.1.0, code-named ‘Anh-Linh’. It is not sure yet if we will focus on Plasma 6.4 series or adopt 6.5 series early on. For sure we will introduce GNOME 49 and maybe Cosmic 1.0 (Beta).
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • Some Kernels got updated
  • Updates to Deepin
  • Yoshimi 2.3.5
  • Haskell and Python updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.299
  • linux510 5.10.244
  • linux515 5.15.193
  • linux61 6.1.154
  • linux66 6.6.108
  • linux612 6.12.49
  • linux616 6.16.9
  • linux617 6.17.0
  • linux61-rt 6.1.151_rt54
  • linux66-rt 6.6.106_rt61
  • linux612-rt 6.12.49_rt13
  • linux615-rt 6.15.0_rt2
  • linux616-rt 6.16.0_rt3
Package Changes (Mon Sep 29 07:42:36 CEST 2025)
  • testing core x86_64: 6 new and 6 removed package(s)
  • testing extra x86_64: 1175 new and 1173 removed package(s)
  • testing multilib x86_64: 6 new and 6 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-09-28
2025-08-24
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
It seems on older hardware the mesa 25.2.x update created some regressions which may result in black screens or flickering. Some older Nvidia cards with nouveau driver seem to be affected.
You can try to use the 25.1.x series of Mesa via this repo. Simply place it on top of [extra] in your /etc/pacman.conf file and use sudo pacman -Syuu to downgrade.
[mesa-251]
SigLevel = PackageRequired
Server = https://download.manjaro.org/pkgs/mesa
If you have no graphical session available you can access the bootloader by pressing ESC key during boot and select the bootloader entry. Press CTRL+E for edit and search for the words quiet and splash. Delete those and add 3 to the line. Then execute CTRL+x to start your session. You will land in a text console TTY. Login with your user.
Edit the /etc/pacman.conf with nano: sudo nano /etc/pacman.conf. Perform the downgrade and reboot.
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
Previous testing threads:
Fresh ISOs including this update can be found here: Release 202509291348 · manjaro/release-review · GitHub
Hi, I am experiencing this issue with akonadi IMAP agents after the update. It’s an old issue (5 years ago!) but it’s exactly the same.
And - as in that the bug report: on my laptop, with the very same packages installed, everything works fine indeed.
I also tried with ufw disable: no change.
Anyone else experiencing this weird issue?
UPDATE:
Got it.
In /usr/lib/NetworkManager/conf.d/20-connectivity.conf I have:
[connectivity]
uri=http://ping.manjaro.org/check_network_status.txt
but it seems not to be responding to my wget calls, therefore - I assume - NetworkManager thinks I have “limited connectivity” and akonadi (can’t figure out why) stays offline.
I think it is this old bug:
https://www.reddit.com/r/kde/comments/uulpcv/i_get_limited_connectivity_even_though_my/
I solved by creating a NetworkManager config file that disables that check:
/etc/NetworkManager/conf.d/disable-connectivity-check.conf
[connectivity]
enabled=false
and then restarted NetworkManager.
I had the same problem.
However, the error disappeared when I used my cell phone hotspot (5G), and my cell phone couldn’t access the page via Wi-Fi either.
Pinging the address worked, but http/https connect timed out.
It’s working again now, though. It seemed to me to be an internet provider or hosting problem. The error is now gone.
Lenovo L14, AMD CPU und GPU, Manjaro Gnome, Testing.
Following the 29/09/2025 update, suspend did not work anymore, neither on 6.12 nor on 6.16/6.17.
Root cause was that systemd-rfkill service was enabled. By whom and why? I have no clue.
TLP and suspend did work before the update, but not after the install anymore. So during this updated something changed with regards to this service.
Why is this an issue? As this blocks TLP to work, leading in suspend issues.
Solved by
sudo systemctl mask systemd-rfkill.service
sudo systemctl mask systemd-rfkill.socket
reboot
and suspend works again.
But why / what did change during the update?
@Zauberer-Merlin Is it possible that the issue is specific to your hardware and config ?
I have a Manjaro KDE Lenovo ThinkPad X1 Carbon Gen 8 (Intel CPU) and a Manjaro Gnome HP X360 13 (AMD CPU). Both machines have integrated graphics and suspend works on both.
That said, I do not have tlp installed : tlp does not appear to be a default package on new installations of Zetar 25.0. Also, default power management seems fine without it on 6.16.
Is anyone running docker and having issues with kernel 6.17?
I’m getting
$ systemctl status docker.s*
× docker.socket - Docker Socket for the API
     Loaded: loaded (/usr/lib/systemd/system/docker.socket; disabled; preset: disabled)
     Active: failed (Result: service-start-limit-hit) since Wed 2025-10-01 13:44:14 CEST; 2s ago
   Duration: 8.506s
 Invocation: b4cab8acdc6e44e791e9704dff26ad7a
   Triggers: ● docker.service
     Listen: /run/docker.sock (Stream)
   Mem peak: 512K
        CPU: 1ms
Okt 01 13:44:06 einstein systemd[1]: Starting Docker Socket for the API...
Okt 01 13:44:06 einstein systemd[1]: Listening on Docker Socket for the API.
Okt 01 13:44:14 einstein systemd[1]: docker.socket: Failed with result 'service-start-limit-hit'.
× docker.service - Docker Application Container Engine
     Loaded: loaded (/usr/lib/systemd/system/docker.service; enabled; preset: disabled)
     Active: failed (Result: exit-code) since Wed 2025-10-01 13:43:37 CEST; 39s ago
 Invocation: bade8d6dbb844b9496a558f1cf5203dd
TriggeredBy: × docker.socket
       Docs: https://docs.docker.com
    Process: 11627 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
   Main PID: 11627 (code=exited, status=1/FAILURE)
Okt 01 13:43:37 einstein systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Okt 01 13:43:37 einstein systemd[1]: docker.service: Start request repeated too quickly.
Okt 01 13:43:37 einstein systemd[1]: docker.service: Failed with result 'exit-code'.
Okt 01 13:43:37 einstein systemd[1]: Failed to start Docker Application Container Engine.
Okt 01 13:44:14 einstein systemd[1]: docker.service: Start request repeated too quickly.
Okt 01 13:44:14 einstein systemd[1]: docker.service: Failed with result 'exit-code'.
Okt 01 13:44:14 einstein systemd[1]: Failed to start Docker Application Container Engine.
and
$ sudo dockerd --debug
INFO[2025-10-01T13:47:22.777878753+02:00] Starting up
DEBU[2025-10-01T13:47:22.778272689+02:00] Listener created for HTTP on unix (/var/run/docker.sock)
INFO[2025-10-01T13:47:22.778368727+02:00] OTEL tracing is not configured, using no-op tracer provider
INFO[2025-10-01T13:47:22.778426222+02:00] CDI directory does not exist, skipping: failed to monitor for changes: no such file or directory  dir=/etc/cdi
INFO[2025-10-01T13:47:22.778435962+02:00] CDI directory does not exist, skipping: failed to monitor for changes: no such file or directory  dir=/var/run/cdi
DEBU[2025-10-01T13:47:22.784805013+02:00] Golang's threads limit set to 112500
INFO[2025-10-01T13:47:22.785131368+02:00] Creating a containerd client                  address=/run/containerd/containerd.sock timeout=1m0s
DEBU[2025-10-01T13:47:22.785220316+02:00] metrics API listening on /var/run/docker/metrics.sock
DEBU[2025-10-01T13:47:22.785582841+02:00] Using default logging driver json-file
DEBU[2025-10-01T13:47:22.785673169+02:00] No quota support for local volumes in /var/lib/docker/volumes: Filesystem does not support, or has not enabled quotas
DEBU[2025-10-01T13:47:22.786015003+02:00] processing event stream                       module=libcontainerd namespace=plugins.moby
DEBU[2025-10-01T13:47:22.794689606+02:00] [graphdriver] priority list: [overlay2 fuse-overlayfs btrfs zfs vfs]
DEBU[2025-10-01T13:47:22.807186090+02:00] successfully detected metacopy status         storage-driver=overlay2 usingMetacopy=true
DEBU[2025-10-01T13:47:22.812350442+02:00] backingFs=extfs, projectQuotaSupported=false, usingMetacopy=true, indexOff="index=off,", userxattr=""  storage-driver=overlay2
INFO[2025-10-01T13:47:22.812370515+02:00] [graphdriver] using prior storage driver: overlay2
DEBU[2025-10-01T13:47:22.812380190+02:00] Initialized graph driver overlay2
DEBU[2025-10-01T13:47:22.822738755+02:00] Max Concurrent Uploads: 5
DEBU[2025-10-01T13:47:22.822744423+02:00] Max Download Attempts: 5
INFO[2025-10-01T13:47:22.822762225+02:00] Loading containers: start.
DEBU[2025-10-01T13:47:22.824713483+02:00] processing event stream                       module=libcontainerd namespace=moby
DEBU[2025-10-01T13:47:22.825243819+02:00] loaded container                              container=01eea8bf83895f1eef7b12e7f00e3c88060e53274b56731d4571a5b17a5662f2 paused=false running=false
DEBU[2025-10-01T13:47:22.825244550+02:00] loaded container                              container=d0e3c4d35712e13d25c4bc57c9f23f3f20343f70428956cae6e7b119dc1872be paused=false running=false
DEBU[2025-10-01T13:47:22.825246942+02:00] loaded container                              container=d0fa11f412a8adc0c192acf28ba36574e1e4e748c93a6625eefd79ac0803c487 paused=false running=false
DEBU[2025-10-01T13:47:22.853149271+02:00] restoring container                           container=01eea8bf83895f1eef7b12e7f00e3c88060e53274b56731d4571a5b17a5662f2 paused=false restarting=false running=false
DEBU[2025-10-01T13:47:22.853180751+02:00] restoring container                           container=d0fa11f412a8adc0c192acf28ba36574e1e4e748c93a6625eefd79ac0803c487 paused=false restarting=false running=false
DEBU[2025-10-01T13:47:22.853266795+02:00] restoring container                           container=d0e3c4d35712e13d25c4bc57c9f23f3f20343f70428956cae6e7b119dc1872be paused=false restarting=false running=false
DEBU[2025-10-01T13:47:22.853790014+02:00] done restoring container                      container=d0fa11f412a8adc0c192acf28ba36574e1e4e748c93a6625eefd79ac0803c487 paused=false restarting=false running=false
DEBU[2025-10-01T13:47:22.853846687+02:00] done restoring container                      container=d0e3c4d35712e13d25c4bc57c9f23f3f20343f70428956cae6e7b119dc1872be paused=false restarting=false running=false
DEBU[2025-10-01T13:47:22.853919170+02:00] done restoring container                      container=01eea8bf83895f1eef7b12e7f00e3c88060e53274b56731d4571a5b17a5662f2 paused=false restarting=false running=false
DEBU[2025-10-01T13:47:22.854009820+02:00] Option DefaultDriver: bridge
DEBU[2025-10-01T13:47:22.854026473+02:00] Option DefaultNetwork: bridge
DEBU[2025-10-01T13:47:22.854032845+02:00] Network Control Plane MTU: 1500
DEBU[2025-10-01T13:47:22.854284450+02:00] Modules already loaded                        modules="[nf_conntrack nf_conntrack_netlink]"
DEBU[2025-10-01T13:47:22.856105575+02:00] /usr/bin/iptables, [--wait -t filter -C FORWARD -j DOCKER-ISOLATION]
DEBU[2025-10-01T13:47:22.857591550+02:00] /usr/bin/iptables, [--wait -t nat -D PREROUTING -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2025-10-01T13:47:22.863868812+02:00] /usr/bin/iptables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL ! --dst 127.0.0.0/8 -j DOCKER]
DEBU[2025-10-01T13:47:22.871315446+02:00] /usr/bin/iptables, [--wait -t nat -D OUTPUT -m addrtype --dst-type LOCAL -j DOCKER]
DEBU[2025-10-01T13:47:22.881407585+02:00] /usr/bin/iptables, [--wait -t nat -D PREROUTING]
DEBU[2025-10-01T13:47:22.894076689+02:00] /usr/bin/iptables, [--wait -t nat -D OUTPUT]
DEBU[2025-10-01T13:47:22.908067088+02:00] /usr/bin/iptables, [--wait -t nat -F DOCKER]
DEBU[2025-10-01T13:47:22.921376446+02:00] /usr/bin/iptables, [--wait -t nat -X DOCKER]
DEBU[2025-10-01T13:47:22.934914564+02:00] /usr/bin/iptables, [--wait -t filter -F DOCKER]
DEBU[2025-10-01T13:47:22.938129957+02:00] /usr/bin/iptables, [--wait -t filter -X DOCKER]
DEBU[2025-10-01T13:47:22.941256102+02:00] /usr/bin/iptables, [--wait -t filter -F DOCKER-FORWARD]
DEBU[2025-10-01T13:47:22.944325139+02:00] /usr/bin/iptables, [--wait -t filter -X DOCKER-FORWARD]
DEBU[2025-10-01T13:47:22.947254630+02:00] /usr/bin/iptables, [--wait -t filter -F DOCKER-BRIDGE]
DEBU[2025-10-01T13:47:22.950193877+02:00] /usr/bin/iptables, [--wait -t filter -X DOCKER-BRIDGE]
DEBU[2025-10-01T13:47:22.953452494+02:00] /usr/bin/iptables, [--wait -t filter -F DOCKER-CT]
DEBU[2025-10-01T13:47:22.956605203+02:00] /usr/bin/iptables, [--wait -t filter -X DOCKER-CT]
DEBU[2025-10-01T13:47:22.959748494+02:00] /usr/bin/iptables, [--wait -t filter -F DOCKER-ISOLATION-STAGE-1]
DEBU[2025-10-01T13:47:22.962706834+02:00] /usr/bin/iptables, [--wait -t filter -X DOCKER-ISOLATION-STAGE-1]
DEBU[2025-10-01T13:47:22.965870659+02:00] /usr/bin/iptables, [--wait -t filter -F DOCKER-ISOLATION-STAGE-2]
DEBU[2025-10-01T13:47:22.968916592+02:00] /usr/bin/iptables, [--wait -t filter -X DOCKER-ISOLATION-STAGE-2]
DEBU[2025-10-01T13:47:22.972180213+02:00] /usr/bin/iptables, [--wait -t filter -F DOCKER-ISOLATION]
DEBU[2025-10-01T13:47:22.975335761+02:00] /usr/bin/iptables, [--wait -t filter -X DOCKER-ISOLATION]
DEBU[2025-10-01T13:47:22.978694587+02:00] /usr/bin/iptables, [--wait -t nat -n -L DOCKER]
DEBU[2025-10-01T13:47:22.992025980+02:00] /usr/bin/iptables, [--wait -t nat -N DOCKER]
DEBU[2025-10-01T13:47:23.005499053+02:00] daemon configured with a 15 seconds minimum shutdown timeout
DEBU[2025-10-01T13:47:23.005553124+02:00] start clean shutdown of all containers with a 15 seconds timeout...
INFO[2025-10-01T13:47:23.008179075+02:00] stopping event stream following graceful shutdown  error="<nil>" module=libcontainerd namespace=moby
DEBU[2025-10-01T13:47:23.008221171+02:00] Cleaning up old mountid : start.
DEBU[2025-10-01T13:47:23.008726548+02:00] Cleaning up old mountid : done.
failed to start daemon: Error initializing network controller: error obtaining controller instance: failed to register "bridge" driver: failed to create NAT chain DOCKER: iptables failed: iptables --wait -t nat -N DOCKER: iptables v1.8.11 (legacy): can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
 (exit status 3)
INFO[2025-10-01T13:47:23.009220657+02:00] stopping event stream following graceful shutdown  error="context canceled" module=libcontainerd namespace=plugins.moby
with
$ modinfo ip_tables
filename:       /lib/modules/6.17.0-0-MANJARO/kernel/net/ipv4/netfilter/ip_tables.ko.zst
description:    IPv4 packet filter
author:         Netfilter Core Team <coreteam@netfilter.org>
license:        GPL
srcversion:     E76A147B434207E5FEF1739
depends:        x_tables
intree:         Y
retpoline:      Y
vermagic:       6.17.0-0-MANJARO SMP preempt mod_unload
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        69:51:BF:7E:9D:06:07:EA:22:2F:EC:21:52:17:75:92:BF:73:EE:FA
sig_hashalgo:   sha512
signature:      30:66:02:31:00:C8:9A:26:7B:02:49:48:FC:4F:65:5F:6E:2F:08:D1:
		8E:C6:C6:0A:2F:60:54:16:2F:9B:86:4C:C7:78:F8:5D:8F:68:C1:F2:
		89:8D:2E:49:F4:6D:9C:70:6B:C2:C5:A2:DE:02:31:00:98:1B:9B:56:
		31:88:38:BE:80:90:F8:3B:81:05:6A:7A:59:89:A9:B2:9A:D6:B7:60:
		EC:75:13:EB:6F:02:D0:2F:1C:F8:FA:0F:C3:DD:FF:EB:19:0E:C2:43:
		97:24:FB:7D
EDIT: This seems to be fixed by GitHub · Where software is built
Maybe this should be addressed somehow.
EDIT: Though it might just be a workaround.
EDIT: Doesn’t fix it :frowning:
Our build should normally support IPTABLES_LEGACY in 6.17: legacy iptables broken [LWN.net]
Somehow seems to not be the case. Any idea how to debug/fix that?
Maybe I missed some. Try to rebuild the kernel with these config updates: [prepare] try to enable ip-tables legacy support for docker (7a4b29ad) · Commits · Packages / core / linux617 · GitLab and let me know if they change anything …
What solved it was replacing iptables with iptables-nft. Was there ever an announcement for this transition? I can not recall seeing one in any announcement.
I have this system running since 2020-07-26 and never touched iptables myself.
it was changed during the 6.17-rc development cycle: netfilter: Exclude LEGACY TABLES on PREEMPT_RT.
See also here:
Wait but if it was fixed a month ago via update config (8f16121c) · Commits · Packages / core / linux617 · GitLab how could it happen that I still got hit?
