[Testing Update] 2025-08-04 - Kernels, Toolchain, Blender, Mesa, Ollama
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • Some Kernels got updated
    • this includes an initial preview of 6.17 kernel series
    • toolchain updates with gcc security fixes and glibc 2.42
  • Some Updates to GNOME
  • Blender 4.5.1
  • Mesa 25.1.7
  • Inputplumber 0.61.0
  • Ollama 0.10.1
  • Updates to Python and Haskell
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.296
  • linux510 5.10.240
  • linux515 5.15.189
  • linux61 6.1.147
  • linux66 6.6.101
  • linux612 6.12.41
  • linux615 6.15.9
  • linux616 6.16.0
  • linux617 6.17.0-rc0
  • linux61-rt 6.1.146_rt53
  • linux66-rt 6.6.99_rt58
  • linux612-rt 6.12.39_rt11
  • linux615-rt 6.15.0_rt2
Package Changes (Mon Aug 4 08:50:41 CEST 2025)
  • testing core x86_64: 25 new and 25 removed package(s)
  • testing extra x86_64: 1449 new and 1446 removed package(s)
  • testing multilib x86_64: 17 new and 17 removed package(s)
Overlay Changes
  • testing core x86_64: 27 new and 25 removed package(s)
  • testing extra x86_64: 185 new and 178 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-08-04
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
2025-06-19
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduce a possible breaking change if you have custom scripts relying on the mirrors data file.
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
2025-06-14
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
Previous testing threads:
orphaned knewstuff5, if I run pacman -R knewstuff5 it will remove 17 related packages
safe to proceed?
You can check if you have any of these apps installed, it was a dependency of: Arch Linux - knewstuff5 5.116.0-3 (x86_64) There is also our tool called dependency-checker
OK, thanks.
edit:
pacman or octopi are not finding dependency-checker or manjaro-dependency-checker nor is in manjaro-tools…
I’ve not any apps that require knestuff5 as shown in the right side of arch link
sudo pacman -Rns knewstuff5
21 to remove:
attica5 kbookmarks5 kcompletion5 kcrash5 kdbusaddons5 kdeclarative5 kded5 kglobalaccel5 kio5 kitemviews5 kjobwidgets5  kpackage5 kservice5  ktextwidgets5  kwallet5  kxmlgui5 qca-qt5 solid5 sonnet5 syndication5 knewstuff5
removed all since they have the 6 counterpart
$ pacman -F /usr/bin/dependency-checker
usr/bin/dependency-checker is owned by extra/libpamac 11.7.3-5
ah… I don’t have pamac installed…
Then you must have removed it yourself, because pamac is one of the packages that come preinstalled with every Manjaro ISO, whether minimal or full, and whether it’s the Plasma Edition, the Xfce Edition or the GNOME Edition.
pamac is one of Manjaro’s halo components, and it was specifically developed for and by Manjaro. Which doesn’t mean that it’s without flaws, of course — quite the contrary, actually — but again, if you don’t have it, then you must have removed it yourself.
Can one use Manjaro without pamac? Yes, one can, provided that one would use pacman for repo packages and yay or another AUR helper for the AUR stuff. I have no experience with Snaps or FlatPaks, but as I gather, they come with their own tools for installation, removal and management.
So if you wish to use all of those individual tools instead of pamac, then it’s perfectly possible to keep maintaining your Manjaro system without it. But pamac has a (gtk-based) GUI, and some people here absolutely prefer that.
Alternatively, octopi is a qt-based front-end to pacman and (if configured to do so) to an AUR helper, so people preferring a GUI for package management can use that instead — and especially so the people using Plasma, because of the tighter visual integration — but people using Xfce or GNOME might object to a qt-based GUI, and for them, pamac-gtk or pamac-gtk3 would be preferable.
Ironic, isn’t it, that I of all people would be recommending pamac? :grin:
exactly
I use pacman, yay and octopi
Zero problems with update. No install-grub script execution required on my single boot UEFI system (never installed it). Just restored the boot loader as usual when grub was updated to enable all new features.
As grub wasn’t one of the updated packages, would install-grub have been necessary? As grub is a bootloader [AFAIK], did you reinstall grub another way? My apologies for not understanding.
Seems whenever there is a grub update the new script install-grub is a topic again: Install-grub: a new way to keep your EFI/MBR in-sync with grub package
@2old4gaming normally you don’t need it. It is designed to work with the default install of Manjaro when auto-partitioning without luks was chosen. Most users might have chosen that option in Calamares. Everything else might be an “advanced” install of Manjaro.
If you need to recover a grub install, most people will link you to this wiki page: GRUB/Restore the GRUB Bootloader - Manjaro
So the TDLR in short:
  • whenever pacman or pamac is updating the grub package you won’t touch your UEFI/MBR install.
  • therefore you might need to use grub-install or the new install-grub which provides an alpm-hook to mostly automate it.
  • security fixes or changes of grub may ship as binaries but won’t secure your PC unless you have synced the binaries also to your UEFI/MBR
  • last time Arch Linux told users to update grub on UEFI/MBR as well was this case: Arch Linux - News: Grub bootloader upgrade and configuration incompatibilities
Hope this might help a little on why that script actually exists …
PPS: update-grub is only updating the menu.cfg file and has nothing to do with updating a package …
install-grub is great tool for me, installed since it was announced
The update went fine. But when I run the checkrebuild command I get this output flagging xnviewmp. I use this application everyday without problems. Should I be concerned? Do need to do anything?
checkrebuild -v         INT ✘
foreign xnviewmp
ldd /opt/xnviewmp/XnView
        liblibraw.so.1 => not found
        libmdk.so.0 => not found
        libc++.so.1 => not found
ldd /opt/xnviewmp/lib/styles/libqgtk2style.so
        libgtk-x11-2.0.so.0 => not found
        libgdk-x11-2.0.so.0 => not found
ldd /opt/xnviewmp/lib/platformthemes/libqgtk2.so
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Oh, I don’t know, how about — wait for it — simply rebuilding it, eh? :grin:
pamac build xnviewmp
forehead smack. I was a version behind. LOL!
