[Testing Update] 2025-10-13 - Kernels, Qt 6.10, KDE Frameworks & Gear
Hello community, here we have another set of package updates. Welcome to our new development cycle of Manjaro 25.1.0, code-named ‘Anh-Linh’. It is not sure yet if we will focus on Plasma 6.4 series or adopt 6.5 series early on. For sure we will introduce GNOME 49 and maybe Cosmic 1.0 (Beta).
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • Some Kernels got updated
    • kernel 6.16 series is now marked EOL
    • including new firmware
  • Qt 6.10
  • KDE Frameworks 6.19.0
  • KDE Gear 25.08.2
  • New update to grub to fix installations on older UEFI systems
  • amdvlk got removed
  • LiberOffice 25.8.2
  • Pipewire 1.4.9
  • ROCm 6.4.4
  • Vulkan SDK 1.4.328.1
  • Haskell and Python updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.300
  • linux510 5.10.245
  • linux515 5.15.194
  • linux61 6.1.155
  • linux66 6.6.111
  • linux612 6.12.52
  • linux616 6.16.12 [EOL]
  • linux617 6.17.2
  • linux618 6.18.0-rc1
  • linux61-rt 6.1.151_rt54
  • linux66-rt 6.6.106_rt61
  • linux612-rt 6.12.49_rt13
  • linux615-rt 6.15.0_rt2
  • linux616-rt 6.16.0_rt3
Package Changes (10/13/25 11:28 CEST)
  • testing core x86_64: 37 new and 37 removed package(s)
  • testing extra x86_64: 2489 new and 2518 removed package(s)
  • testing multilib x86_64: 25 new and 28 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-09-28
2025-9-27
Heads up: Gnome 49 is here and wayland is the default.
2025-08-24
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
It seems on older hardware the mesa 25.2.x update created some regressions which may result in black screens or flickering. Some older Nvidia cards with nouveau driver seem to be affected.
You can try to use the 25.1.x series of Mesa via this repo. Simply place it on top of [extra] in your /etc/pacman.conf file and use sudo pacman -Syuu to downgrade.
[mesa-251]
SigLevel = PackageRequired
Server = https://download.manjaro.org/pkgs/mesa
If you have no graphical session available you can access the bootloader by pressing ESC key during boot and select the bootloader entry. Press CTRL+E for edit and search for the words quiet and splash. Delete those and add 3 to the line. Then execute CTRL+x to start your session. You will land in a text console TTY. Login with your user.
Edit the /etc/pacman.conf with nano: sudo nano /etc/pacman.conf. Perform the downgrade and reboot.
Previous testing threads:
Post update, libinstpatch and qt6-wayland are identified as orphans. I don’t recall installing these myself. To confirm, is it safe to remove both these packages ? Thanks.
pamac remove -o
Préparation...
Vérification des dépendances...
A désinstaller (2):
  libinstpatch 1.1.7-2      extra
  qt6-wayland  6.10.0-1     extra
Taille totale libérée : 6.1 Mo
Appliquer la transaction ? [o/N]
EDIT : found this in the October Unstable Update announcement thread for qt6-wayland
I’ll use your own words to answer your question…
Why? Because…
After upgrading you may now have packages that are no longer needed or that are no longer in the official repositories.
– System maintenance - ArchWiki
Ayuh.1
1 Say it with a Maine accent :wink:
Hi, I’ve noticed that 6.17.3 introduced some regression patches. May I suggest another one?
AMD made a regression right between 6.17-rc7 and 6.17 release. Some laptops experience full brightness after suspend.
They already submitted a revert patch, but it has not been merged yet.
There is a regression in after chromium based browsers update (checked brave, chrome, chrome beta, chrome canary and chrome dev - only chrome canary was unaffected, although chrome canary has lower version than chrome dev, so I suspect that regressing commit has not made its way to canary yet)
On wayland HDR displays chromium based browser is waaaay to dark (not that this issue is different than washed colors that were reported some time ago)
EDIT: Probably caused by: 78295f48c220860f587ce266227e0011d9a3ec41 - chromium/src - Git at Google
