[Testing Update] 2025-09-18 - Kernels, NVIDIA, PipeWire, KDE Gear & Frameworks
Hello community, here we have another set of package updates. This will be mostly the last update to our Zetar release cycle. Please test it thru and let us know if there are any issues left …
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Arch Linux - News: Valkey to replace Redis in the [extra] Repository
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.299
  • linux510 5.10.244
  • linux515 5.15.193
  • linux61 6.1.152
  • linux66 6.6.106
  • linux612 6.12.47
  • linux615 6.15.11 [EOL]
  • linux616 6.16.7
  • linux617 6.17.0-rc6
  • linux61-rt 6.1.151_rt54
  • linux66-rt 6.6.106_rt61
  • linux612-rt 6.12.43_rt12
  • linux615-rt 6.15.0_rt2
  • linux616-rt 6.16.0_rt3
Package Changes (Thu Sep 18 11:29:49 CEST 2025)
  • testing core x86_64: 24 new and 24 removed package(s)
  • testing extra x86_64: 2277 new and 2261 removed package(s)
  • testing multilib x86_64: 35 new and 35 removed package(s)
Overlay Changes
  • testing core x86_64: 40 new and 40 removed package(s)
  • testing extra x86_64: 226 new and 271 removed package(s)
  • testing multilib x86_64: 7 new and 4 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-09-02
  • pacman-mirrors version 5.1
    Deprecation of --geoip in favor of -tz/--timezone.
    This internal change make mirror-list generation use your system’s configured timezone - when applicable - without using an IP location provider.
    More privacy..
2025-08-24
Graphical issues on older hardware (Black screen, Flickering) due to mesa 25.2.x update
It seems on older hardware the mesa 25.2.x update created some regressions which may result in black screens or flickering. Some older Nvidia cards with nouveau driver seem to be affected.
You can try to use the 25.1.x series of Mesa via this repo. Simply place it on top of [extra] in your /etc/pacman.conf file and use sudo pacman -Syuu to downgrade.
[mesa-251]
SigLevel = PackageRequired
Server = https://download.manjaro.org/pkgs/mesa
If you have no graphical session available you can access the bootloader by pressing ESC key during boot and select the bootloader entry. Press CTRL+E for edit and search for the words quiet and splash. Delete those and add 3 to the line. Then execute CTRL+x to start your session. You will land in a text console TTY. Login with your user.
Edit the /etc/pacman.conf with nano: sudo nano /etc/pacman.conf. Perform the downgrade and reboot.
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
Previous testing threads:
After this update my system broke. I was not experiencing any issues before this.
I first noticed that the wireless network was missing and as I started to dig around to see the logs after some (5-10min) everything went downhill.
The system stopped responding where I would wait even 5min for top or dmesg, and even the output of the commands were all messed up.
I could not power-off or reboot my system, it had to be forcibly powered off in every case.
The kworker/1:0-events was working 100% which might be saying something, but I don’t know for sure.
I tested with 2 kernels that I had, it was the same issues:
   * linux615
   * linux616
Sorry I couldn’t provide more details since the system was unusable.
I then proceeded with live usb image (everything worked from the live session), chrooted and switched to stable branch and downgraded.
After switching to stable branch, everything worked like a charm again.
inxi -F output just in case:
  Host: laptop Kernel: 6.16.4-2-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.6 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: ASUS Vivobook S 16 M5606WA_M5606WA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: M5606WA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: M5606WA.314 date: 04/17/2025
  ID-1: BAT1 charge: 70.6 Wh (100%) condition: 70.6/75 Wh (94.2%)
  Info: 12-core model: AMD Ryzen AI 9 HX 370 w/ Radeon 890M bits: 64
    type: MT MCP cache: L2: 12 MiB
  Speed (MHz): avg: 2035 min/max: 605/5158:3289 cores: 1: 2035 2: 2035
    3: 2035 4: 2035 5: 2035 6: 2035 7: 2035 8: 2035 9: 2035 10: 2035 11: 2035
    12: 2035 13: 2035 14: 2035 15: 2035 16: 2035 17: 2035 18: 2035 19: 2035
    20: 2035 21: 2035 22: 2035 23: 2035 24: 2035
  Device-1: Advanced Micro Devices [AMD/ATI] Strix [Radeon 880M / 890M]
    driver: amdgpu v: kernel
  Device-2: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    dri: radeonsi gpu: amdgpu resolution: 3200x2000~120Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.4
    renderer: AMD Radeon 890M Graphics (radeonsi gfx1150 LLVM 20.1.8 DRM 3.64
    6.16.4-2-MANJARO)
  API: Vulkan v: 1.4.321 drivers: radv surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
    driver: snd_acp_pci
  API: ALSA v: k6.16.4-2-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.4.7 status: active
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e
  IF: wlp98s0 state: up mac: 3c:0a:f3:85:4f:db
  IF-ID-1: docker0 state: down mac: 0a:0d:fd:48:3f:b3
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb type: USB
  Local Storage: total: 953.87 GiB used: 76.68 GiB (8.0%)
  ID-1: /dev/nvme0n1 vendor: Micron model: MTFDKBA1T0QFM-1BD1AABGB
  ID-1: / size: 937.53 GiB used: 76.68 GiB (8.2%) fs: ext4 dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 320 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
  System Temperatures: cpu: 42.4 C mobo: 34.0 C gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): cpu: 0 fan-1: 0
  Memory: total: 32 GiB note: est. available: 30.46 GiB used: 6.45 GiB (21.2%)
  Processes: 449 Uptime: 1h 8m Shell: Zsh inxi: 3.3.39
Why are three versions of nVidia all being installed? I haven’t run this update since this just seems wrong. I’ll wait a few days to see what others are seeing.
Can you share the pacman log wiht the lines what is being installed? The packages are probably part of mhwd and not an installation.
Do you mean these 3 lines:
[2025-09-18T20:13:26+1000] [ALPM] upgraded mhwd-nvidia (580.82.07-1 -> 580.82.09-1)
[2025-09-19T04:11:12+1000] [ALPM] installed mhwd-nvidia-570xx (570.190-3)
[2025-09-19T04:11:12+1000] [ALPM] installed mhwd-nvidia-575xx (575.64.05-2)
They are just the module IDs for mhwd (the Manjaro Hardware Detection Library), which is used for installing drivers.
I currently have 5 mhwd-nvidia* packages installed on my AMD system:
pamac search -i mhwd-nvidia
mhwd-nvidia-575xx  575.64.05-2                                extra
    MHWD module-ids for nvidia 575.64.05
mhwd-nvidia-570xx  570.190-3                                  extra
    MHWD module-ids for nvidia 570.190
mhwd-nvidia-470xx  470.256.02-15                              extra
    MHWD module-ids for nvidia 470.256.02
mhwd-nvidia-390xx  390.157-21                                 extra
    MHWD module-ids for nvidia 390.157
mhwd-nvidia  580.82.09-1                                      extra
    MHWD module-ids for nvidia 580.82.09
I think the same would be applicable for all Manjaro users, as they are all required by the MHWD database (mhwd-db):
pamac info mhwd-db
Version               : 20250918-1
Description           : Manjaro Linux Hardware Detection Database
URL                   : https://gitlab.manjaro.org/applications/mhwd-db
Licenses              : GPL-3.0-or-later
Repository            : extra
Installed Size        : 42.8 kB
Groups                : --
Depends On            : libnotify mhwd-amdgpu mhwd-ati mhwd-nvidia>=455 mhwd-nvidia-390xx mhwd-nvidia-470xx
                        mhwd-nvidia-570xx mhwd-nvidia-575xx nvidia-driver-assistant
Optional Dependencies : --
Required By           : mhwd
Optional For          : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Philip Mueller <philm@manjaro.org>
Build Date            : Thu 18 Sep 2025 21:33:53
Install Date          : Fri 19 Sep 2025 04:11:12
Install Reason        : Explicitly installed
Validated By          : Signature
Backup files          : --
I believe the mhwd-nvidia-570xx & mhwd-nvidia-575xx packages were added due to issues some users were having with the most recent mhwd-nvidia version (currently v580). Those users can now install the slightly older v570 or v575 Nvidia drivers.
Manjaro 2025-09-18 Testing Update ($1150) · Snippets · GitLab
                             PACKAGE             20250910             20250918
                         mhwd-nvidia          580.82.07-1          580.82.09-1
                   mhwd-nvidia-570xx                    -            570.190-2
                   mhwd-nvidia-575xx                    -          575.64.05-1
Thanks, that explains things. Installing now.
There is some issue with MEDIATEK MT7922 WiFi chips. The ASUS ALLY also lost its WiFi. Have to see what the issue might be … @zordi
