[Stable Update] 2025-07-18 - Kernels, UMU, KDE Frameworks, NetworkManager
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.295
  • linux510 5.10.239
  • linux515 5.15.188
  • linux61 6.1.145
  • linux66 6.6.98
  • linux612 6.12.38
  • linux615 6.15.6
  • linux616 6.16.0-rc5
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.94_rt56
  • linux612-rt 6.12.28_rt10
  • linux615-rt 6.15.0_rt2
Package Changes (Tue Jul 15 09:23:53 CEST 2025)
  • stable core x86_64: 16 new and 16 removed package(s)
  • stable extra x86_64: 1107 new and 1103 removed package(s)
  • stable multilib x86_64: 4 new and 4 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-07-18
2025-07-12
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command in order to downgrade the installed package with the higher version to the version currently in the repository… :point_down:
 sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins.
 sudo pacman -S vlc-plugins-all
linux-firmware-meta replaces linux-fimware
With the linux-firmware-meta package, all of the firmware is now split up into individual packages, which are all installed as dependencies of linux-firmware-meta.
If you wish to uninstall the firmware packages that you don’t need — e.g. linux-firmware-nvidia — including the meta package itself, then be sure to mark the firmware packages you wish to keep as explicitly installed, or else pacman will regard them as orphans, which would be dangerous when cleaning out your real orphans.
 sudo pacman -D --asexplicit <name-of-package(s)>
2025-06-23
Breaking changes to wine and wine-staging
Transition to the new WoW64 wine and wine-staging
2025-06-16
We are transitioning the wine and wine-staging package to a pure wow64 build. This change removes the dependency on the multilib repository for wine and wine-staging.
The main reason for this is to align with upstream Wine development, which simplifies packaging and the dependency chain.
Potential Issues:
  • OpenGL Performance: A known limitation of the new WoW64 mode is reduced performance for 32-bit applications that use OpenGL directly
  • Breaking Changes: Existing 32-bit prefixes needs to be recreated
If you are facing issues with 32 bit prefixes, please recreate these and reinstall the application.
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduces a possible breaking change if you have custom scripts relying on the mirrors data file. If this is the case, then simply create a symlink from the new location under /var/lib back to the old location, i.e. /usr/share.
ln -s /var/lib/pacman-mirrors /usr/share/
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
avahi-discover python script may fail to discover services
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
2025-04-12
Grub gained security fixes. Updating it may be risky
When Manjaro updates the grub package the actual installed binaries in master boot record (MBR) or UEFI won’t get updated. This is however needed to apply recent security fixes added to grub. Therefore we created Install-grub: a new way to keep your EFI/MBR in-sync with grub package to make it easier.
A more manual approach can be found here: [root tip] [How To] Primer on handling a grub package update
We also have it documented in our wiki on how to manually install grub when a disaster happens: GRUB/Restore the GRUB Bootloader - Manjaro. So if you are not experienced with it you can either ignore that extra step or have an install media at hand to recover as needed.
See also on how to create a boot media to install Manjaro fresh: Burn an ISO File - Manjaro. Those who want to get install medias having this update included may look for 25.0 ISOs when released or here: Releases · manjaro/release-review · GitHub
Remember, update-grub only updates the boot menu and install-grub is a script helper to install or reinstall grub on most case automatically via grub-install. All grub installations can be with a risk when not done properly as the user will change low level system parts and can easily break their systems.
Note: most likely grub was initially installed by an installer and therefore the user doesn’t know how grub got installed. So if you are unsure simply skip a reinstallation of grub.
2025-03-24
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
No sound from PulseAudio after PipeWire update
If PulseAudio audio playback is suspended after PipeWire update, unload module-suspend-on-idle
pactl unload-module module-suspend-on-idle
If that works, create a custom default.pa configuration for PulseAudio in home folder
cp /etc/pulse/default.pa ~/.config/pulse/default.pa
and comment out module-suspend-on-idle in custom configuration
sed -i '/load-module module-suspend-on-idle/s/^/#/' ~/.config/pulse/default.pa
2025-03-05
[community] repository removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-05-02
community has been re-created as an empty repository so that systems where package manager configuration /etc/pacman.conf has not been updated can still be used to update packages from other repositories
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
2025-02-04
Kernel 4,19 and 6.11 are EOL, 6.11 and 4.19 got removed from repos
Kernel 6.11 and 4.19 got marked [EOL] on kernel.org
Linux 6.11 and 4.19 have been removed from the repositories.
Please ensure your system use a supported kernel mhwd-kernel -l
PostgreSQL users should consider to prepare the change of major version 16→17
More info here and here
Update libpamac before installing the 2025-02-04 updates
Run sudo pacman -Sy libpamac in a terminal to make sure pamac-manager doesn’t crash during the update.
XFCE 4.20 may blank display after 5 mins idle time regardless of power management settings
Most likely this: Disable screen blanking
Call xfce4-screensaver-preferences and disable the screensaver.
xfce4-screensaver - Usage [Xfce Docs]
Not sure how you guys do it (and hoping I’m not spoiling my luck) but another update without the slightest hickup. Thanks for the awesome work!
It’s because we’re simply the best. :wink:
Wine 10.12 now works on CPUs without AVX
As of this update, kwalletmanager no longer stores any passwords, and has mysteriously also forgotten about the ones that were already stored.
It is also not possible to authorize any applications that may use the wallet. This was already the case since the previous update to kf6, but at least it did still remember the stored passwords then. Right now it’s useless, and I have to manually authenticate every time I start kmail. I even had to manually log into the forum — it’s a good thing I still remembered the password.
Everything went pretty good. Thanks.
Is it possible to avoid “Could not initialise PPT tunable control 0 messages” ?
I thought this message ocurred on AMD systems however i have an intel.
Must i put an extra option in /etc/default/grub ?
Inxi -zv8
  Kernel: 6.12.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=db6584bb-d49d-4eb3-a233-ad26cf9bd9f9 rw rootflags=subvol=@
    kvm.enable_virt_at_load=0 udev.log_priority=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: avail: xfce4-screensaver vt: 7 dm: LightDM
    v: 1.32.0 Distro: Manjaro base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B560-F GAMING WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 1017 date: 07/12/2021
  System RAM: total: 32 GiB available: 31.11 GiB used: 7.3 GiB (23.4%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: no module installed
  Device-2: Controller0-ChannelA-DIMM1 type: DDR4 detail: synchronous
    size: 16 GiB speed: spec: 2133 MT/s actual: 3600 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMK32GX4M2D3600C18 serial: N/A
  Device-3: Controller0-ChannelB-DIMM0 type: no module installed
  Device-4: Controller0-ChannelB-DIMM1 type: DDR4 detail: synchronous
  Info: model: 11th Gen Intel Core i7-11700K bits: 64 type: MT MCP
    arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
    process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
    microcode: 0x64
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 800 min/max: 800/4900:5000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
    bogomips: 115232
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
    fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap smep smx ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.18 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: HDMI-A-1 model: Idek Iiyama PLE2472HD serial: <filter>
    built: 2010 res: 1920x1080 dpi: 92 gamma: 1.2 chroma: red: x: 0.639 y: 0.349
    green: x: 0.333 y: 0.608 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9
    modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1280x960, 1152x864,
    1152x720, 1024x768, 832x624, 800x600, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RKL GT1)
    device-ID: 8086:4c8a memory: 30.38 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
  Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:43c8 class-ID: 0403
  API: ALSA v: k6.12.38-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IP v6: <filter> type: temporary dynamic scope: global
  IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0026
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: N/A rfk-block:
    hardware: no software: no address: see --recommends
  Local Storage: total: 7.28 TiB used: 3.94 TiB (54.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 35.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD60EFAX-68JH4N1 size: 5.46 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A83 scheme: GPT
  ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 7.66 GiB (7.7%)
    fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3 label: N/A
    uuid: db6584bb-d49d-4eb3-a233-ad26cf9bd9f9
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 616 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2 label: N/A
    uuid: 0AE0-B9AA
  ID-3: /data raw-size: 830.51 GiB size: 830.51 GiB (100.00%)
    used: 270.87 GiB (32.6%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:4
    label: N/A uuid: 5bdedbf8-72ed-43b2-8b79-56b6698a5141
  ID-4: /home raw-size: 100 GiB size: 100 GiB (100.00%)
    used: 7.66 GiB (7.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
    label: N/A uuid: db6584bb-d49d-4eb3-a233-ad26cf9bd9f9
  ID-5: /storage raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 508.18 GiB (54.6%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:5
    label: N/A uuid: 86ab2e05-d7fb-4c4d-a76f-85e44feb0dbb
  ID-6: /var/cache raw-size: 100 GiB size: 100 GiB (100.00%)
  ID-7: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
  ID-8: /wd6tb raw-size: 5.46 TiB size: 5.46 TiB (100.00%)
    used: 3.17 TiB (58.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: cc4d8185-6f7c-4009-8574-ef2f3f65aa10
  ID-1: swap-1 type: zram size: 31.11 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 16
    dev: /dev/zram0
  Hub-2: 1-6:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-6.4:4 info: Logitech Mouse type: mouse
    chip-ID: 046d:c077 class-ID: 0301
  Hub-3: 1-9:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 1-9.4:7 info: Metadot Das Keyboard 6 Pro type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 24f0:20a1 class-ID: 0301
  Hub-4: 1-10:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-11:6 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Device-2: 1-14:8 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-5: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-6: 2-5:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  System Temperatures: cpu: 36.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1122 libs: 333 tools: pamac,yay
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    3: https://manjaro.kurdy.org/stable/$repo/$arch
    4: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    5: https://mirror.23m.com/manjaro/stable/$repo/$arch
    6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    8: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 410
  1: cpu: 31.9% command: VirtualBoxVM pid: 1700 mem: 3588.6 MiB (11.2%)
  2: cpu: 5.6% command: VirtualBoxVM pid: 1600 mem: 891.4 MiB (2.7%)
  3: cpu: 5.3% command: VBoxSVC pid: 1550 mem: 35.5 MiB (0.1%)
  4: cpu: 3.4% command: Xorg pid: 930 mem: 124.2 MiB (0.3%)
  5: cpu: 1.4% command: konsole pid: 2502 mem: 107.1 MiB (0.3%)
  Memory top: 5 of 410
  1: mem: 3588.6 MiB (11.2%) command: VirtualBoxVM pid: 1700 cpu: 31.9%
  2: mem: 891.4 MiB (2.7%) command: VirtualBoxVM pid: 1600 cpu: 5.6%
  3: mem: 136.2 MiB (0.4%) command: VirtualBox pid: 1531 cpu: 0.3%
  4: mem: 124.2 MiB (0.3%) command: Xorg pid: 930 cpu: 3.4%
  5: mem: 107.1 MiB (0.3%) command: konsole pid: 2502 cpu: 1.4%
  Processes: 410 Power: uptime: 28m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.43 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: gcc: 15.1.1 Shell: Bash v: 5.3.0 running-in: konsole
    inxi: 3.3.38
I just did the update using pacman, it worked fine, but I got the following message:
The AppArmor profiles of snapd-confine needs to be reloaded.
Run the following command after the update:
systemctl restart apparmor.service
what is that about? should I just copy the last line and run it like this in the terminal, before I restart? Or should i restart first?
Thanks for any advice :slight_smile:
You should always reboot right after a bundled update. Continuing your normal work without rebooting can lead to unexpected situations.
Recommended reading… :point_down:
:+1:
Thank you!
I normally do that (restart immediately after update), but I was not sure, if it could cause problems at the restart if I don’t run this command first, so I wanted to ask, just to be sure.
But I restarted now and everything is running okay so far.
4 posts were merged into an existing topic: Kwalletmanager loses all passwords and does not accept any new ones
A post was split to a new topic: My bluetooth speaker does not work
7 posts were split to a new topic: Troubles with SDDM
Thanks a lot for this update - everything runs fine: PC (Xfce), Laptop (KDE Plasma 6.3.6 Wayland), second Laptop (sway).
After another reboot and subsequent relogin — because there was an update to archlinux-keyring — kwallet seems to work normally. It still did not contain any passwords for kmail, but this time I was able to enter them in the wallet and save them, and kmail and chromium now appear to work normally. So I am going to close the pertinent thread and change my vote in the poll. :wink:
4 posts were split to a new topic: Issue with telegram-desktop
2 posts were split to a new topic: Darktable no longer working
error with sddm (as other ?) since this update :
2 accounts : me as admin and second as simple user
plasma (default x11)
simple user : no issue :thinking: login ok plasma ok
me (x11 and wayland) :grimacing:
after password, i return to sddm (or black screen after first attempt) …
NOT in my xorg log block “modeset” (differ to other ok account):
[    73.655] (II) modeset(0): EDID vendor "GSM", prod id 23658
[    73.655] (II) modeset(0): Using EDID range info for horizontal sync
[    73.655] (II) modeset(0): Using EDID range info for vertical refresh
[    73.655] (II) modeset(0): Printing DDC gathered Modelines:
[    73.655] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    73.655] (II) modeset(0): Modeline "1920x1080"x0.0  174.50  1920 1968 2000 2080  1080 1083 1088 1119 +hsync -vsync (83.9 kHz e)
[    73.655] (II) modeset(0): Modeline "1920x1080"x0.0  228.80  1920 1968 2000 2080  1080 1083 1088 1100 +hsync -vsync (110.0 kHz e)
[    73.655] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
same end in 2 logs
[    52.869] (**) Option "fd" "26"
[    52.869] (II) event3  - Power Button: device removed
[    52.869] (**) Option "fd" "29"
[    52.869] (II) event8  - Video Bus: device removed
[    52.869] (**) Option "fd" "30"
[    52.869] (II) event1  - Power Button: device removed
[    52.869] (**) Option "fd" "31"
[    52.869] (II) event2  - Sleep Button: device removed
[    52.869] (**) Option "fd" "32"
[    52.869] (II) event5  - USB Optical Mouse: device removed
[    52.869] (**) Option "fd" "33"
[    52.869] (II) event7  - CHICONY HP USB Multimedia Keyboard: device removed
[    52.870] (**) Option "fd" "34"
[    52.870] (II) event9  - CHICONY HP USB Multimedia Keyboard System Control: device removed
[    52.870] (**) Option "fd" "35"
[    52.870] (II) event10 - CHICONY HP USB Multimedia Keyboard Consumer Control: device removed
[    52.870] (**) Option "fd" "36"
[    52.870] (II) event4  - AT Translated Set 2 keyboard: device removed
[    52.871] (II) UnloadModule: "libinput"
[    52.871] (II) systemd-logind: releasing fd for 13:68
[    52.872] (II) UnloadModule: "libinput"
[    52.872] (II) systemd-logind: releasing fd for 13:74
[    52.872] (II) systemd-logind: releasing fd for 13:73
[    52.873] (II) UnloadModule: "libinput"
[    52.873] (II) systemd-logind: releasing fd for 13:71
[    52.874] (II) UnloadModule: "libinput"
[    52.874] (II) systemd-logind: releasing fd for 13:69
[    52.874] (II) systemd-logind: releasing fd for 13:66
[    52.875] (II) UnloadModule: "libinput"
[    52.875] (II) systemd-logind: releasing fd for 13:65
[    52.876] (II) UnloadModule: "libinput"
[    52.876] (II) systemd-logind: releasing fd for 13:72
[    52.877] (II) UnloadModule: "libinput"
[    52.877] (II) systemd-logind: releasing fd for 13:67
[    52.927] (II) Server terminated successfully (0). Closing log file.
tests :
  • my home : remove ~/.cache no change
  • tty3 text login is ok
  • sddm wayland or xorg no change
  • boot in no graphic mode, after txt log : startx is OK (plasma ok), but, if i load sddm sudo systemctl start sddm.service, same error
    strange since no sddm in this update.
No time to search this weekend, so my temporary fix is systemctl set-default multi-user.target…
These appear to be related;
