[Testing Update] 2025-07-06 - Kernels, KDE Gear, Mesa
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: See current promotion
Recent News
2025-04-17 - Andrew Crerar
Arch Linux - News: Valkey to replace Redis in the [extra] Repository
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.295
  • linux510 5.10.239
  • linux515 5.15.186
  • linux61 6.1.143
  • linux66 6.6.96
  • linux612 6.12.36
  • linux615 6.15.5
  • linux616 6.16.0-rc4
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.94_rt56
  • linux612-rt 6.12.28_rt10
  • linux615-rt 6.15.0_rt2
Package Changes (Sun Jul 6 15:06:47 CEST 2025)
  • testing core x86_64: 4 new and 4 removed package(s)
  • testing extra x86_64: 510 new and 509 removed package(s)
  • testing multilib x86_64: 11 new and 11 removed package(s)
Overlay Changes
  • testing core x86_64: 9 new and 9 removed package(s)
  • testing extra x86_64: 71 new and 74 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-07-06
2025-06-19
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduce a possible breaking change if you have custom scripts relying on the mirrors data file.
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
2025-06-14
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
2025-03-20
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
2025-03-05
[community] repo removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-05-02
community has been re-created as an empty repository so that systems where package manager configuration /etc/pacman.conf has not been updated can still be used to update packages from other repositories
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
Previous testing threads:
Just a minor issue. When using latest accent color change. I’m not allowed to choose “maia”. 10 is not accepted as a valid input.
This program will overwrite any existing gtk.css configuration files located in ~/.config/gtk-3.0/gtk.css and ~/.config/gtk-4.0/gtk.css, but it will create backups of these files. Are you sure you want to proceed?
Proceed? (y/n)
y
Continuing...
1. blue
2. teal
3. green
4. yellow
5. orange
6. red
7. pink
8. purple
9. slate
10. maia
Choose a color (1-9):
Thunderbird 140
one of the fixes: Spellcheck no longer highlighted misspelled words in the compose window
(repaired)
Whoops. :grimacing: Fixed with accent-color-change r156.46ce088-3 coming along shortly.
I’m still missing KDE Plasma 6.4 in testing, or did I overlook something? I’ve now switched to unstable. It’s running fine.
I will release Plasma 6.3.6 soon on testing, which then marks the 25.0.5 OS update of Zetar …
6 posts were split to a new topic: GNOME Terminal is missing the New Tab option
Sorry, had to snip your latest reply after splitting out off-topic things into it’s own thread.
On-topic restoration:
Got the update to 6.3.6 now, but no announcement.
The post, accidentally deleted?, is referenced right above your post
A new ISO is available to test Plasma 6.3.6 and upcoming 25.0.5 release of Manjaro: Release 202507090628 · manjaro/release-review · GitHub
Any chance this ISO supports manjaro-chroot -a for BTRFS?
I haven’t tested this with the 25.0.4 ISO yet, but normally it should already have been implemented on that one.
Edit: No, judging by the GitLab page, it would appear that my patch has not been merged yet. :frowning:
