[Testing Update] 2025-08-10 - Linux-Firmware, Gstreamer, KDE Framework
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.296
  • linux510 5.10.240
  • linux515 5.15.189
  • linux61 6.1.147
  • linux66 6.6.101
  • linux612 6.12.41
  • linux615 6.15.9
  • linux616 6.16.0
  • linux617 6.17.0-rc0
  • linux61-rt 6.1.146_rt53
  • linux66-rt 6.6.99_rt58
  • linux612-rt 6.12.39_rt11
  • linux615-rt 6.15.0_rt2
Package Changes (Thu Aug 7 19:55:16 CEST 2025)
  • testing core x86_64: 5 new and 5 removed package(s)
  • testing extra x86_64: 1412 new and 1409 removed package(s)
  • testing multilib x86_64: 4 new and 4 removed package(s)
Overlay Changes
  • testing core x86_64: 13 new and 13 removed package(s)
  • testing extra x86_64: 44 new and 46 removed package(s)
  • testing multilib x86_64: 1 new and 1 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-08-10
2025-07-24
grub update - watch out
Before you reboot - ensure to run install-grub script to sync the efi-stubs and recreate the grub config.
[Testing Update] 2025-07-19 - Kernels, Mesa, Thunderbird, Grub, Perl, Vulkan - #19 by linux-aarhus
2025-07-10
Warning: ksystemstats: local (6.4.0-1) is newer than extra
If you get this warning, run the following command… :point_down:
sudo pacman -Syuu
VLC does not play (certain) videos
For this update, the VLC packages were split up, and not all codecs may be installed on your system. You can install the additional codecs individually, or install the vlc-plugins-all meta-package, which will pull in all available plugins. :point_down:
 sudo pacman -S vlc-plugins-all
2025-06-19
Possible breaking changes to pacman-mirrors
:warning: With pacman-mirrors 5.0-1, the global mirrors.json data file has been moved from /usr/share/pacman-mirrors to /var/lib/pacman-mirrors.
:warning: This move introduce a possible breaking change if you have custom scripts relying on the mirrors data file.
:information_source: The moving of the file is the only change and has been made to make it possible for users to have their /usr-tree on a separate read-only partition or btrfs subvolume.
2025-06-14
xkeyboard-config 2.45 issue with symlinks
You may fail to upgrade from 2.44 to 2.45 due to some changes to symlinks. A discussion about it can be found here: Cannot update xkeyboard-config to 2.45 / Pacman & Package Upgrade Issues / Arch Linux Forums
The solution is to update the AUR packages depending on xkeyboard-config or move the files to the new folder /usr/share/xkeyboard-config-2.
More information about it here: xkeyboard-config 2.45 issue with symlinks (#1) · Issues · Arch Linux / Packaging / Packages / xkeyboard-config · GitLab
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
Previous testing threads:
Slimbook MANJARO III
CPU: AMD Ryzen 7 8845HS
Graphics: Nvidia RTX 4070 8GB
Display: 15.3" WQHD 2560*1600p 120 Hz
Keyboard: RGB
Material: aluminum
Ports: 3x USB 3.2, 1x USB-C 3.2, HDMI 2.1, MiniDP
Connectivity: RJ45, Wifi 6, Bluetooth 5.2
RAM memory: up to 96GB DDR5
Storage: 2x SSD NVMe PCIe 4.0 M.2 up to 8TB
Keyboard: multiple languages
Operating System: Manjaro Gaming Plasma 6
Flash Drive: available with your Linux distro
Get it now
A post was split to a new topic: VLAN aware bridge in systemd-networkd doesn’t work anymore
