[Testing Updates] 2025-06-11 - Kernels, Mesa, KDE Gear, LibreOffice, AMD ROCm
Current Promotions
  • Protect your personal data, keep yourself safe with Surfshark VPN: See current promotion
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.295
  • linux510 5.10.237
  • linux515 5.15.185
  • linux61 6.1.141
  • linux66 6.6.93
  • linux612 6.12.33
  • linux614 6.14.11 [EOL]
  • linux615 6.15.2
  • linux616 6.16.0-rc1
  • linux61-rt 6.1.134_rt51
  • linux66-rt 6.6.87_rt54
  • linux612-rt 6.12.28_rt10
  • linux613-rt 6.13_rt5
  • linux614-rt 6.14.0_rt3
  • linux615-rt 6.15.0_rt2
Package Changes (Tue Jun 10 18:34:17 CEST 2025)
  • testing core x86_64: 23 new and 23 removed package(s)
  • testing extra x86_64: 1171 new and 1144 removed package(s)
  • testing multilib x86_64: 18 new and 28 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-06-11
2025-06-01
2025-06-01 - avahi-discover python script
avahi-discover fails when attempting to write the discovered services to a sqlite database in /usr/lib/avahi due to lack of permissions.
The issue can be reproduced using a pristine Arch LInux system - it appears from the issues at GitHub - avahi/avahi: Avahi - Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour the issue is known - but not fixed.
→ Use of dbm causes problems with Python 3.13 · Issue #670 · avahi/avahi · GitHub
→ Fix issue with dbm.sqlite3 on readonly directories by mickael9 · Pull Request #698 · avahi/avahi · GitHub
Even though the issue has been known to upstream since december 2024, the behaviour on unstable branch has changed fairly recently - perhaps 4 weeks.
Temporary workaround
The workaround it is not optimal - but if you rely on avahi discover service - it will work
Move /usr/lib/avahi to /var/lib and symlink it back to /usr
sudo mv /usr/lib/avahi /var/lib/ && sudo ln -s /var/lib/avahi /usr/lib/
Change the ownership of the folder /var/lib/avahi including files
sudo chown root:avahi /var/lib/avahi -R
sudo chmod g+w /var/lib/avahi -R
sudo gpasswd -a $USER avahi
Topic in German section
2025-03-20
System may hang during splash screen when Nvidia 570 drivers are used
A lot of users with older Nvidia cards report system hanging on Plymouth splash screen after installing Nvidia 570 drivers. In the past we had issues with plymouth in general combined with Nvidia drivers. Therefore we didn’t update plymouth in our stable and testing branch.
As a workaround splash could be removed from /etc/default/grub file followed by a update-grub cmd to remove plymouth from starting. Another alternative is to test the newer plymouth and give feedback if that solves the issue:
sudo pacman -U https://mirrors.manjaro.org/repo/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
2025-03-05
[community] repo removed from servers
Similar to Arch we removed our [community] repos from our mirrors and servers. You may want to check your pacnew files or manually remove [community] and [kde-unstable] when used in your /etc/pacman.conf file.
2025-05-02
community has been re-created as an empty repository so that systems where package manager configuration /etc/pacman.conf has not been updated can still be used to update packages from other repositories
2025-02-16
Update only regular repository packages first, no AUR
Follow the best practice of first updating only regular repository packages, followed separately by AUR packages.
  1. Update regular repository packages first with
    • pamac update --no-aur
      or
    • sudo pacman -Syu
  2. Then, if needed, update AUR packages.
Failure to follow this practice may result in the installation of packages that you may not need, and may cause problems. For further details, see:
Keyboard layout issues / Update issues with fcitx5
If a system had sdl2 installed and AUR updates enabled, fcitx5 might be installed as a make dependency
It is recommended to remove fcitx5 and any other orphan packages following the update
pamac remove --orphans
Previous testing threads:
The application was obviously badly designed, because /usr is a read-only filesystem hierarchy, and nothing should be expecting to be able to write to anything under /usr.
A better workaround would therefore be to move the database to /var/lib and create a symlink to it under /usr/lib.
Video wallpapers have a cool new cyberpunk aesthetic(it flickers too):
Example
Now to be fair, it’s been a while since I updated the video wallpapers engine, so should probably do that, but figured it’s worth reporting here anyways.
Edit: updating the Wallpaper engine didn’t fix it, and it’s very likely a codec issue not a GPU driver issue(though never say never) and the GPU(rx 6600 xt) itself works fine - it’s just the video wallpaper. The driver update might have exposed a pre-existing issue in a codec perhaps, but that’s just a guess on my part.
@Aragorn It is a wiki post. When tested you can update the latest as needed before it gets posted in our stable branch announcement.
I have edited the wiki post. But that still doesn’t negate the fact that the application was ill-designed if it attempts to write to /usr.
You suggested to move the database to /var/lib and create a symlink to it under /usr/lib. That needs testing … @Aragorn
No need. The symlink under /usr/lib will forward every access to the actual location under /var/lib, and I’ve adapted the rest of the commands in the wiki post to directly address the directory under /var/lib.
Remember, symlinks are transparent to the application, because they are constructs in the filesystem layer itself. The application doesn’t know the difference between a symlink and an actual file or directory.
double check if today’s announcement also has your changes included …
Good point. It didn’t, so I edited it there too. :wink:
