[Testing Update] 2025-11-14 - Kernels, GStreamer, Firefox, Mesa, LibreOffice, Vivaldi
Hello community, here we have another set of package updates. Welcome to our new development cycle of Manjaro 25.1.0, code-named ‘Anh-Linh’.We will focus on Plasma 6.5 series and will introduce GNOME 49, maybe Cosmic 1.0 (Beta).
Current Promotions
Recent News
2025-04-17 - Andrew Crerar
Previous News
Notable Package Updates
  • Kernels got updated/rebuilt
    • including firmware and binutils updates/rebuilds
  • GStreamer 1.26.8
  • Firefox 145.0
  • Mesa 25.2.7
  • LibreOffice 25.8.3
  • Vivaldi 7.7
Additional Info
Python 3.13 info
Rebuild them all at once:*
 checkrebuild
Info about AUR packages
Our current supported kernels
  • linux54 5.4.301
  • linux510 5.10.246
  • linux515 5.15.196
  • linux61 6.1.158
  • linux66 6.6.116
  • linux612 6.12.58
  • linux617 6.17.8
  • linux618 6.18.0-rc5
  • linux61-rt 6.1.158_rt58
  • linux66-rt 6.6.116_rt66
  • linux612-rt 6.12.57_rt14
  • linux616-rt 6.16.0_rt3
  • linux617-rt 6.17.5_rt7
Package Changes (11/14/25 14:37 CET)
  • testing core x86_64: 75 new and 75 removed package(s)
  • testing extra x86_64: 1078 new and 1188 removed package(s)
  • testing multilib x86_64: 28 new and 28 removed package(s)
A list of all changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2025-11-10
mkinitcpio v40 disabled fallback image creation for new installs
mkinitcpio v40, packaging changes and kernel-install - Arch-dev-public - lists.archlinux.org
This is only affects new installs as we can’t change the hook files on existing installs.
To disable fallback image creation on older installed systems
  • Change PRESETS=('default' 'fallback') line to PRESETS=('default') in the respective .preset files in /etc/mkinitcpio.d/.
  • Regenerate initramfs
  • Update your boot loader configuration.
Warning
Disabling all fallback initramfs generation will deprive you of another option to boot into the system in case a default initramfs fails. Before proceeding, make sure you have a bootable installation medium for rescue purposes on hand.
2025-09-28
2025-9-27
Heads up: Gnome 49 is here and wayland is the default.
Previous testing threads:
A post was split to a new topic: System locking up after logging in
Might be a dumb question, but what exactly am I meant to execute when it says: “Update your boot loader configuration.”? Am I missing something or are they (in case of GRUB) talking about
sudo grub-mkconfig -o /boot/grub/grub.cfg
:white_question_mark:
sudo update-grub updates the Grub configuration.
update-grub is basically a script to simplify longer commands such as the example you gave:
So, updating your boot loader configuration (if Grub) can be achieved with:
sudo mkinitcpio -P
sudo update-grub
usually followed by a reboot.
