[root tip] [How To] Basic Samba Setup and Troubleshooting
Difficulty: ★★☆☆☆
What is SAMBA
Samba is the standard Windows interoperability suite of programs for Linux and Unix.
What can you learn from this?
This document from my notepad is intended as a help to setup simple client connection to home NAS and simple file sharing from your Manjaro desktop to other computers in your home network. If you are looking for domain specific setup and integration to Microsoft AD you must refer to the official samba documentation [1].
Occasional sharing
Python http.server
If you only occasionally need to serve files - you can do so using the default Python installation.
Copy the files to you want to share to ~/Public then open a terminal in the folder and run two commands.
The first displays your IP address using an utility script. Example
~/Public $ check-network
192.168.1.20
The second run the http service exposing the content of your ~/Public folder
~/Public $ python -m http.server -d ~/Public  8080
Serving HTTP on 0.0.0.0 port 8080 (http://0.0.0.0:8080/) ...
Then share the IP and port. The person(s) can fetch the file(s) using their browser and navigating to - the slash at the end is important (otherwise the browser runs a search using the configured search engine)
http://$IPADDRESS:8080/
When you are finished sharing, close the terminal or press Ctrlc to stop sharing.
Simple http servers
Packages such as darkhttpd and caddy provides webservers to service static files and can be installed from the repo.
The caddy package also provides a SSL/TLS enabled server.
Samba Client
For simple client connection to shares provided by a NAS or maybe your router only a few packages are needed. The package smbclient provides the tools necessary for accessing samba fileshares.
There is several packages which builds upon the client and makes it easier to connect and automount a share from a file manager. Packages such as gvfs-smb and smb4k extends the file manager with seamless mount of Samba shares.
Ensure the packages are up-to-date by running below command in a terminal
sudo pacman -Syu smbclient gvfs gvfs-smb --needed
smbclient
Before attempting a connection either reboot your system or manually load the kernel module
sudo modprobe cifs
Also a configuration file /etc/samba/smb.conf must be present. The client doesn’t require any content - just the presence and can thus be created by the touch utility.
sudo mkdir /etc/samba
sudo touch /etc/samba/smb.conf
GVFS
Open your file manager and enter the server name or IP address in location bar.
If the location bar is not visible it is often activated using the hot key-combo CtrlL. Input the server name and share using the protocol format
smb://server-name/share
Some file managers (e.g. dolphin) can better deduct if credentials are required if the username is supplied like this
smb://username@server-name/share
When you are challenged for credentials input those to access the content. Do not save your credentials just yet. Later on you will return here to store the credentials in your keyring.
This method is using gvfs which creates the mountpoint in the /run tree and therefore the mount will not persist across reboot.
You can inspect the file structure by opening the folder matching the uid for your user. If you have a mounted share you can run ls on the gvfs folder - it will yield an output similar to below example
$ ls /run/user/$UID/gvfs
'smb-share:server=nas.net.nix.dk,share=data'
System Automount
systemd units
When mounting one or more network shares on boot one need to take into account when the network is up and connected - otherwise the system will hang for 90s for each share.
This can be done using fstab or using systemd units [ How to use systemd mount unit ] [ sample mount units ].
User Mount
As demonstrated, a file manager can utilize gvfs to create a user mounted samba share, and this knowledge can used in creating some automation.
As shown the gio mountpoint takes the following form where $UID, $HOST and $SHARE represents the variable factors
/run/user/$UID/gvfs/'smb-share:server=$HOST,share=$SHARE'
We will use the gio smb mount script to mount the share. Use the template provided in the topic to create your own script. When you have the script in place and working come back here.
The script asks for username, workgroup and password (unless configured otherwise) when you run it and that is fine for the occasional mount but you will likely want to automount the share when you log onto your system.
User Automount
The script can be executed at login in a number of ways - but remember - the script’s success depends on the credentials being available in your keyring.
  • Adding the script to your environment’s autostart configuration
  • Manually creating a desktop launcher in ~/.config/autorun
This topic will propose a somewhat different method by means of a systemd user service which will be used to execute our script upon login.
:spiral_notepad: To be able to automount the share you can
Either
  • Stored the credentials in your keyring when challenged by the file manager.
    Or
  • Store the credentials in the mount script mentioned above
The user service
Create the folder ~/.config/systemd/user and create a service file named e.g. gio-smb-share-name.service - use the same name as the script you are calling - thus making the dependency obvious and simplify future maintenance.
mkdir -p ~/.config/systemd/user
touch ~/.config/systemd/user/gio-smb-share-name.service
Open the file in your favorite editor and paste below content.
[Unit]
Description=GIO mount smb share-name
[Service]
Type=oneshot
ExecStart=/home/%u/.local/bin/gio-smb-share-name.sh
ExecStop=/home/%u/.local/bin/gio-smb-share-name.sh -u
RemainAfterExit=true
[Install]
WantedBy=default.target
Watch your SMBLinks folder and start the service
systemctl --user start gio-smb-share-name.service
Note the symlink is created. Stop the service to watch the symlink disappear
systemctl --user stop gio-smb-share-name.service
When everything works - start and enable the user service
systemctl --user enable --now gio-smb-share-name.service
Manjaro Samba Server
:information_source: Starting from Windows 10 1709, guest access in SMB2 and SMB3 may be disabled by default. This means that guest access from Windows 10 to a Samba share may not work, for more information, see here.
https://wiki.samba.org/index.php/Setting_up_Samba_as_a_Standalone_Server
:warning:
  1. Sharing data will open ports to the network.
    • This is not unsafe if properly secured and protected.
  2. Only run a Samba file service on a trusted secure network or zone.
  3. Ensure firewalld is set up to only allow share traffic when connected to a trusted and secure network or zone.
  4. Never run a samba file server on a public network.
  5. Avoid NT1 aka SMB1 - it is unsafe and exploited by numerous ransomware projets.
Secure your service
if you are using another firewall service (e.g. ufw) either setup that service to allow samba and skip this step or stop and disable the service before continuing.
Install the package firewalld then enable and start the service.
sudo pacman -Syu firewalld
sudo systemctl enable --now firewalld
firewalld has some predefined zones which we will use for this purpose to define trusted and untrusted network. If a network is not defined in any zones it is treated as public which means visible on the network and no open ports
  • home
  • public
When you are connected to what you deem a trusted and secure network run the following command
nmcli device show | grep IP4.ROUTE
IP4.ROUTE[1]:             dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 100
IP4.ROUTE[2]:             dst = 0.0.0.0/0, nh = 192.168.1.1, mt = 100
In this example note the first destination network; 192.168.1.0/24. This it a common network used by many home routers. Your result may be different - adjust accordingly.
Before you begin - list the default services permanently enabled for the zones
sudo firewall-cmd --permanent --zone="home" --list-services
sudo firewall-cmd --permanent --zone="public" --list-services
Next step is to to tell the firewall this network is trusted - replace the variable with your network (note it is possible to have more than one trusted network - eg. home and work)
sudo firewall-cmd --permanent --zone="home" --add-source="$NETWORK"
Using the example using above (remember - your network may not be the same)
sudo firewall-cmd --permanent --zone="home" --add-source="192.168.1.0/24"
Next we define the policy for the samba service
sudo firewall-cmd --permanent --zone="home" --add-service="samba"
With the security in place proceed to installing and configuring Samba
Install samba package
Install the samba package and ensure your system is fully updated in the process.
sudo pacman -Syu samba
Basic Server configuration
Create the configuration file /etc/samba/smb.conf - the folder may need to be created beforehand.
sudo mkdir -p /etc/samba
Edit the file - using superuser privilige - insert below content and save the file (need superuser). If you are connecting an existing network of servers change the WORKGROUP to match the existing network.
[global]
   workgroup = MANJARO
   server string = Manjaro Samba Server
   server role = standalone server
   log file = /var/log/samba/log.%m
   max log size = 50
   guest account = nobody
   map to guest = Bad Password
   min protocol = SMB2
   max protocol = SMB3
[public]
   path = /srv/samba/share-name
   public = yes
   writable = yes
   printable = no
Test your config
sudo testparm /etc/samba/smb.conf
Create share and set permissions
To share e.g. removable devices you need to mount the devices.
This is best done using using systemd mount and if removable create both mount and automount unit.
[root tip] [How To] Use systemd to mount ANY device
Create the shared folder
sudo mkdir -p /srv/samba/share-name
Set permissions to any and all
sudo chmod -R ugo+rw /srv/samba/share-name
Start the services
sudo systemctl enable --now smb nmb
Enable Usershares
This section is an almost word-to-word replication from the ArchWiki
Note: This is an optional feature. Skip this section if you do not need it.
Usershares is a feature that gives non-root users the capability to add, modify, and delete their own share definitions. See smb.conf(5)
Samba - ArchWiki
Before enabling usershares you must create the folder, group, set correct permissions and add a section to your smb.conf. Any local user allowed to share own data must be added to the group created.
Steps
  1. Create the folder
    sudo mkdir -p /var/lib/samba/usershares
  2. Create a system user group
    sudo groupadd -r sambashare
  3. Set folder owner
    sudo chown root:sambashare /var/lib/samba/usershares
  4. Set correct permissions (you won’t allow users to delete shares created by other users)
    sudo chmod 1770 /var/lib/samba/usershares
  5. Add configuration to smb.conf
    [global]
      usershare path = /var/lib/samba/usershares
      usershare max shares = 100
      usershare allow guests = yes
      usershare owner only = yes
    Test your configuration
  6. Add your user (you may add other local users if desired) - replace $USER
    sudo gpasswd sambashare -a $USER
  7. Restart your services
    sudo systemctl restart smb nmb
  8. Log out and log back in - to activate your group membership
Service Visibility
To make server visible on the network you need the avahi package synced and services enabled and running. Network Manager depends on Avahi so on Manjaro it is installed but not enabled.
Enable the service on the server using command (provide password when challenged) or use sudo
sudo systemctl enable avahi-daemon.service avahi-daemon.socket
Troubleshooting
Did you remember to add users to the service?
Samba users must exist as a system user before using smbpasswd
sudo smbpasswd -a $USERNAME
Samba documentation on https://www.samba.org/samba/docs/current/man-html/smbpasswd.8.html
Filemanagers
Some file managers implement a GoNetwork option.
Screenshot using PCManFM
To make this option usable you need the avahi package synced and services enabled and running. Network Manager depends on Avahi so on Manjaro it is installed but not enabled.
Enable the service on the client using command (provide password when challenged) or use sudo
sudo systemctl enable avahi-daemon.service avahi-daemon.socket avahi-dnsconfd.
Access Control Lists aka ACL
Missing r/w access due to permissions. In essence, it was similar to this issue. Simple solution is to remove your share and create it again. And no need to change tdbsam to smbpasswd. – Credit @openminded
AppArmor when serving samba shares
Some editions of Manjaro comes with AppArmor enabled (snap support) which may lead to issues when samba is updated.
In such case you can use the following quick fix
sudo aa-complain /etc/apparmor.d/usr.sbin.smbd
Now proceed to reading documentation on AppArmor especially the section on editing AppArmor profiles for a better and more long-term solution. – Credit @openminded
On 2022-09-02T22:00:00Z @0xbeaf contributed this comment on another topic and has been added here to complement this section.
Click to unfold the complete quote
  • Changes to how samba does rpc seems to be the main culprit. Since it is using multiple new executable files to delegate its jobs, new profiles and overrides for apparmor needs to be added.
  • I had to add override rules for usr.sbin.smbd, samba-dcerpcd, samba-rpcd and samba-rpcd-classic.
  • To get rid of all DENIED error messages in apparmor log, I had to add one more entity to profile rules. E.g. to whitelist the path /tank/anbaar, I added the following to all above-mentioned profiles in /etc/apparmor.d/local:
/tank/anbaar lrwk,
/tank/anbaar/ lrwk,
/tank/anbaar/** lrwk,
  • Additionally, /usr/share/samba and /var/cache/samba had to be whitelisted for samba-rpcd so avahi service could properly work with a macOS machine so that it could automatically find and mount the TimeMachine share-points!!!
Helpful links:
  1. https://ubuntu.com/server/docs/security-apparmor
  2. https://gitlab.com/apparmor/apparmor/-/wikis/AppArmor_Core_Policy_Reference
  3. FS#74614 : [apparmor] new profiles needed for samba-4.16
  4. profiles/apparmor.d: Add new profiles needed for samba-4.16 (!871) · Merge requests · AppArmor / apparmor · GitLab
On 2022-10-05T22:00:00Z it is suggested to apply the following configuration to apparmor - credit @jrichard326
sudo aa-complain /usr/bin/smbd
sudo aa-complain samba-dcerpcd samba-bgqd samba-rpcd samba-rpcd-classic samba-rpcd-spoolss
Client
Samba client requires the file /etc/samba/smb.conf even if it is empty.
Browse available shares
It may not be possible to browse shares by using the service name
SMB1 has been removed for security reasons. This also removed the possibliity to browse a server for avaliable shares.
The removal enhances the resistance against ransomware and other malware propagating over the network.
 $ smbclient -L {host|ip} -U%
        Sharename       Type      Comment
        public          Disk
        IPC$            IPC       IPC Service (Manjaro Samba Server)
SMB1 disabled -- no workgroup available
Netbios requests has been disabled due to the vulnerabilities thus highly improving resistance against ransomware abusing the service to spread itself.
Always connect to the share directly
smbclient //{host|ip}/public
Using a file manager you may need to add username to the request e.g. smb://username@service/sharename and provide the password. Only then you will be able to see what other shares the service provides.
Initial share lookup
If you find browsing the network from your file manager is not possible issues it may be helpful to add the following content - replace the WORKGROUP with your computer name or another identifying name
[global]
    workgroup = WORKGROUP
You may get messages like
Failed to retrieve share list from server: No such file or directory
The specified location is not mounted
Samba protocol version
Upstream Samba disabled SMB1 due to a vulnerability exploited by a widespread ransomware. Yet many ISP provided routers has not been upgraded and you may have difficulties connecting the router’s samba service using a default samba client.
To gain access to such share you need to add a samba configuration which sole purpose is to enable the deprecated samba version. Add the following line in the [global] section of the configuration file
[global]
    client min protocol = NT1
Arch Wiki
The options uid and gid corresponds to the local (e.g. client) user/user group to have read/write access on the given path.
Note:
  • If the uid and gid being used does not match the user of the server, the forceuid and forcegid options may be helpful. However note permissions assigned to a file when forceuid or forcegid are in effect may not reflect the the real (server) permissions. See the File And Directory Ownership And Permissions section in mount.cifs(8) § FILE AND DIRECTORY OWNERSHIP AND PERMISSIONS for more information.
  • To mount a Windows share without authentication, use "username=*".
Warning: Using uid and/or gid as mount options may cause I/O errors, it is recommended to set/check correct File permissions and attributes instead.
– Arch Wiki
More reading
Setting up Samba share manjaro kde
Permission issues mounting SMB share
Thunar: How do I access folders shared on Windows computers?
Dolphin: The file or folder smb://sharename does not exist
Connecting to Router attached drive (5.15LTS Plasma)
Upgrade to Samba 4.17 broke file sharing
Warum ist Samba nicht von Ubuntu nach Manjaro übertragbar
Smb client problem
Samba failed to start, fresh install manjaro
NAS mounten nach Kernel-Wechsel funktioniert nicht
Cifs: "mount error(20): Not a directory" while mounting
Sharing problem
DIY a Manjaro Desktop to function as a router - possible?
Why can't I share from immediate subdirectories of "/"?
[root tip] [How To] Troubleshoot samba share write protection when accessed from Windows
Basic network setup
Can't Connect to Samba share but I can SSH and I can connect to other shares
Samba asennus rikki vai onko?
Samba out-of-the-box
Accessing a shared Windows folder over LAN via Dolphin filemanager?
Kde drive (folder) sharing error
Help with file sharing
Samba not working unable to start the samba service
How do I completely re-install PAM security?
Dolphin File Manager to access Synology Database
Mount SMB share via CLI gives no write permission
After installation I can only see one partition and its a read only
Netzwerkzugriff auf anderen Manjaro Rechner einrichten
How to hide Manjaro in the local network
Cifs/smb mount with hidden credentials
Feedback from a relatively new user to Manjaro
Manjaro GNOME, setting menu for File-Sharing options disappeared
FreeFileSync: Als Ziel smb Pfad eintragen
CIFS Shares used to work, now won't mount at all
Basic file sharing using nemo
[root tip] [How To] Step By Step - File Share Using Samba
Connect Manjaro & Windows 11 via Ethernet for File Sharing
Can see samba host in network view of Windows but can't open. "Windows Cannot Access"
Cannot mount CIFS share
Trouble getting Samba shares started
Fstab NAS mount fails after update
Network share from windows to manjaro
When I open a folder using vscode in KDE, I cannot find the remote location
I don't see network places - nautilus
Access Windows 11 Shared Folder From Manjaro KDE Linux?
Systemd conditionals possible
Can't access samba shares like local storage
Can't access my Manjaro samba server with a "permission denied" error
Trying to Mount UNRAID on Local System Over SMB | CIFS?
How to put a login form on shared folder from Linux to win10
Gnome Files, typing "smb://" in "Connect to Server" becomes red
Viewing files on a network drive
Snap cannot communicate with server
How to transfer music to an iOS (iPhone)?
Cant share a folder
Reboot fails when cifs network share is mounted
Mate: When transfering to USB3 SSD plugged into router
Samba AppArmor permissions
Samba WERR_ACCESS_DENIED
Samba error code 22
How to open and write Libreoffice Writer files to a NAS using Samba
Samba shares not auto populating in KDE dolphin
How do I stop the amnesia occuring when reconnecting to my NAS?
SMB: can't connect to server from mac os finder
Simple File Sharing in Manjaro
Browse Network Locations Within an Application
I forgot how I set up SMB 2 years ago
Dolphin can't login to samba server
Dolphin cannot access win10 PC per "smb://"
Cannot access synology drives by dolphin
Samba: Unable to login with Dolphin - part II
SAMBA & SMB Services Problem Starting
Dolphin - Problems with mounting netwrork shares and reseting it's credentials
Samba isn't working anymore
Windows Shared Folders Keep Prompting for Credentials
Samba cannot share folders after recent update
Auto Mounts No Longer Working After Updates
Smb file transfer stuck since Stable Update 2024-11-30
Not able to connecto to Samba server
"Folder empty" on Samba-accessed NAS after a file operation
Samba Unable to create new folder in accessed share
Samba share names not working
SMB share does not works
System not mounting network drive on boot
Samba-Shares nach Update nur noch lesend. Kein schreiben mehr möglich
Samba error code 22
Hi Frede,
I think it would be of help if I share a couple of quick tips as a follow-up of Samba: no r/w access to shared files and other problems I had with Samba recently. Feel free to add them to your root tip, if you like.
First, my problem with r/w access to my own share was caused by ACL. In essence, it was similar to this issue. Plain dumb solution is to remove your share and create it again. And no need to change tdbsam to smbpasswd, you were absolutely right.
Next, another weird (at first glance) problem a user could face recently is inability to even view server’s shares at all with a not-so-easy-to-understand error message (“broken pipe” or something). Oh, my hair got grey while trying to figure the cause of this issue. It was simple though, and the culprit was AppArmor update. Some users might have it enabled as well, and chances are they might face a similar problem too, so what a person need to do it such situation is sudo aa-complain /etc/apparmor.d/usr.sbin.smbd for a quick fix and proceed to reading documentation on editing AppArmor profiles for a better and more long-term solution.
And the last but not least let me comment on your warning " Never run a samba file server on a laptop (it’s portable and smb service is easy to forget)"
I’m not sure if my suggestion is good from a Linux admin’s perspective, but I think for a casual home user it would suffice: create a Network Manager dispatcher script that will run or stop smb.service when your laptop connects and disconnects to/from your home networks, e.g.:
/etc/NetworkManager/dispatcher.d/20-smb_server.sh
#!/bin/bash
# Find the connection UUID with "nmcli con show" in terminal.
# All NetworkManager connection types are supported: wireless, VPN, wired...
if [[ "$CONNECTION_UUID" == "%UUID_1%" ]] || [[ "$CONNECTION_UUID" == "%UUID_2%" ]] || [[ "$CONNECTION_UUID" == "%UUID_3%" ]]; then
    # Script parameter $1: NetworkManager connection name, not used
    # Script parameter $2: dispatched event
    case "$2" in
        "up")
            systemctl start smb.service
        "down");&
        "pre-down");&
        "vpn-pre-down")
            systemctl stop smb.service
    esac
fi
Write your connection UUIDs (nmcli con show) and make this file executable, of course.
Yes samba can be troublesome - I appreciate your thoughts.
Paritcularly the ones on AppArmor. I know it exist - I even remember fiddling with issues surrounding it many years - perhaps 20 - ago but I have no recent knowledge on that subject.
The issue with creating the broken pipe message is - for my experience - when trying to browse network from a file manager caused by not having the smb.conf containing a workgroup = WORKGROUP. I have had this message without AppArmor.
While I certainly - from a business security perspective - see the benefits of such hardening - many such features are created for company environments with an incentive to ensure stability and protect business enviroments and processes and as such a large need for homogeneus systems and at the same time protecting their environment against rogue processes initiated by users ignorance.
I am not arguing against using AppArmor but AppArmor comes as a requirement of the Ubuntu snap circus which then makes it a necessary part of Manjaro - since the initial support of snaps.
The idea of stopping the service using a dispatcher script is good but it is easier accomplished by setting up firewalld to only expose smb on a trusted zone.
We could add an Advanced section at the end or a separate topic: Advanced Samba Troubleshooting
followup
Added firewalld security config for running samba on trusted network.
IMO this is a huge issue and I’m surprised we don’t have a fix for it yet.
Samba is a popular service and an update breaking it is very disappointing.
I have enabled more logs options, and following message is spammed in log.samba-dcerpcd file (whose file size is now about 40 MB!) whenever I try to access my shares.
../../source3/rpc_server/rpc_host.c:2940(main)
  main: messaging_init() failed
I have tried all suggested workarounds to no availability!
It is impossible to suggest a one-size-fits-all as each and every use case is different.
If samba doesn’t share as expected or stops working it is likely a local issue - it is very rare an upstream issue causes it - but that happens e.g. when SMB1 was disabled and renamed to NT1.
If samba stops working - check your setup
  • find out if something changed upstream
  • do you have apparmor running?
  • do you have selinux running?
  • did you change firewall?
If you cannot get up and running
  • check your smb.conf
    • do not plaster the config with defaults
    • only add what differs from default
    • do not use every suggestion you find on the internet
    • they are usually only valid for the issue you read about
  • check filesystem permissions
  • check your shares
  • check your privileges
  • check your local permissions
  • check server permissions
  • if you are using a router
    • check the service on the router
    • did the firmware autoupdate
    • try rebooting the router
Thanks for your reply & suggestions. I’d however argue that this is related to the recent update and changes made in how samba does rpc calls and its interaction with apparmor.
My system was properly configured and working. This is a server providing samba services to multiple clients and no error related to shares/priviliges/permissions was ever reported.
My guess is that the update from 4.16.3-1 → 4.16.4-1 (around end of July / early August) is the culprit.
As I mentioned I have tried the apparmor solutions suggested here and they didn’t help. I will go through the list of links you shared, hoping I can get my systems up and running.
Thanks again.
Samba is extremely sensitive to upstream changes - checking your config may prove the most fruitful option - especially if you weed out everything which is not default - then revisit the remaining options according to the latest release.
In danish we have a saying ‘liden tue vælter stort læs’ roughly translated it is - the tiniest obstacle can tilt a truckload to the side.
sudo aa-complain samba-rpcd
Can you check if these command fix the issue ?
Can a manjaro dev check this :
audit[26626]: AVC apparmor="DENIED" operation="file_lock" profile="samba-dcerpcd" name="/var/cache/samba/names.tdb" pid=26626 comm="samba-dcerpcd" requested_mask="k" denied_mask="k" fsuid=0 ouid=0
audit[26711]: AVC apparmor="DENIED" operation="open" profile="samba-rpcd" name="/var/cache/samba/names.tdb" pid=26711 comm="rpcd_lsad" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0
Looking at output of dmesg, I am seeing a lot of outputs similar to following:
apparmor="DENIED" operation="open" profile="samba-rpcd-classic" name="/var/cache/samba/names.tdb" pid=8481 comm="rpcd_classic" requested_mask="wrc" denied_mask="wrc" fsuid=0 ouid=0
SYSCALL arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7ffc6d491380 a2=80042 a3=1b0 items=0 ppid=67644 pid=67654 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="rpcd_classic" exe="/usr/lib/samba/samba/rpcd_classic" subj==samba-rpcd-classic (enforce) key=(null)
apparmor="ALLOWED" operation="file_lock" profile="samba-dcerpcd" name="/var/cache/samba/gencache.tdb" pid=8261 comm="samba-dcerpcd" requested_mask="wk" denied_mask="wk" fsuid=0 ouid=0
Is there any other method to inspect the logs of aa-complain?
I was finally able to solve my issue:
  • To get rid of all DENIED error messages in apparmor log, I had to add one more entity to profile rules. For example, to whitelist /tank/anbaar, I added the following to all above-mentioned profiles in /etc/apparmor.d/local:
/tank/anbaar lrwk,
/tank/anbaar/ lrwk,
Helpful links:
  1. Security - AppArmor | Ubuntu
  2. AppArmor_Core_Policy_Reference · Wiki · AppArmor / apparmor · GitLab
So essentially - this is not really a samba issue - which will explain why Samba never fails me.
Since I don’t use snap and don’t use AppArmor or SELinux I have never been able to reproduce the issues.
I commend you for how you troubleshooted this and shared the result :+1:
As you have found - this is not something that can be solved by Manjaro as a the distribution but has to be solved by the user running the system(s).
@openminded commented on the subject back when I wrote the basic troubleshooting guide for Samba and I have added your last comment to the guide.
Thanks for maintaining the troubleshooting guide.
I have to disagree about distributions role when such non-trivial changes are introduced to a popular service such as samba.
I think at minimum a warning/notification during the package upgrade should have been issued for users. Or ideally have done what Debian or openSUSE do where a script (update-apparmor-samba-profile) automatically whitlelists shares that are not the default users’ home folders.
Thing is, Manjaro is not targeted at corporate users like SUSE or Ubuntu. Moreover, by default it provides neither AppArmor nor Samba, hence all collisions between those two are out of focus of Manjaro team.
Then, if I have understood correctly, when an user doesn’t use snap packages its safe to disable apparmor. Is this correct?
Yes that is correct
Thank you very much!! :clap: :clap: :clap:
Best regards!! :grinning: :grinning:
A post was split to a new topic: Permission on mountpoint for samba share
