Is this step necessary?
❯ sudo chmod -R ugo+rw /mnt/storage
[sudo] password for user:
~ 2h 23m 4s
~ 2h 23m 4s
Maybe this helps:
https://www.cyberciti.biz/tips/how-do-i-set-permissions-to-samba-shares.html
Or this:
It is generally a bad idea to use /mnt as base for permanent mountpoints.
In the context of a mountpoint for a samba share
Use a separate structure - e.g. /data/storage - this is the only way to ensure correct permissions.
Read up on Linux ACL Access Control Lists - ArchWiki
