[Stable Update] 2023-06-04 - Kernels, Gnome 44.1, Plasma 5.27.5, Python 3.11, Toolchain, Firefox
Hello community,
Another stable branch update with some usual package updates for you.
It took us almost a month to complete these updates for you. There are a lot of changes: toolchain, systemd, latest updates to KDE and Gnome and many more are included in this one. Hence we also decided to bump our release version to 23.0 and used Ultima Thule as our code name. Well it is still a Star Trek planet but it also might have some vibes form Zelda.
The install media will come later, therefore the package version has still a preview in it …
You may check out our merch and support the project …
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
  • As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Previous News
Notable Package Updates:
  • Kernels got updated
  • Systemd is now at 253 series
  • Python 3.11
  • GCC 13
  • GNOME 44 / 44.1
  • KDE Plasma 5.27.5
  • KDE Gear got renewed to 23.04.1
  • KDE Frameworks got updated to 5.106.0
  • Firefox is at 113.0.1
  • Thunderbird 102.11.0
  • Still branch of LibreOffice got updated to 7.4.7 which is the last version of that series
  • Wine is at 8.8
  • Usual KDE-git, Python and Haskell updates
Additional Info
:information_source: You will need to rebuild any AUR Python packages after the system update, that install files to site-packages or link to libpython3.10.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.10/ :
pacman -Qoq /usr/lib/python3.10/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.10)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Get our latest daily developer images now from Github: Plasma, GNOME, XFCE. You can get the latest stable releases of Manjaro from CDN77. Review images with this update included can be found here: Release 202306040845 · manjaro/release-review · GitHub
Our current supported kernels
  • linux419 4.19.284
  • linux54 5.4.244
  • linux510 5.10.181
  • linux515 5.15.114
  • linux61 6.1.31
  • linux62 6.2.16 [EOL]
  • linux63 6.3.5
  • linux64 6.4-rc2
  • linux62-rt 6.2.0_rt3
  • linux63-rt 6.3.1_rt13
Package Changes (Fri May 19 08:26:21 CEST 2023)
  • stable community x86_64: 4106 new and 4037 removed package(s)
  • stable core x86_64: 83 new and 79 removed package(s)
  • stable extra x86_64: 1332 new and 1496 removed package(s)
  • stable kde-unstable x86_64: 400 new and 400 removed package(s)
  • stable multilib x86_64: 46 new and 45 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2023-06-04
DKMS is currently broken as our kernels got compiled against an older gcc
Since the last stable update provided an older toolchain our kernels and binaries got compiled against GCC 12.2.0-1. A similar issue was already posted at Arch years ago: [SOLVED] Kernel 5.5.2 is built with the wrong version of gcc / [testing] Repo Forum / Arch Linux Forums. Therefore users of DKMS have to wait for kernel updates compiled against the new toolchain or downgrade to the older one.
Update (2023-06-05): We pushed a rebuild of all regular kernels against the new toolchain to all branches. Real-Time Kernels we still have to check.
Many applications (firefox, thunderbird, telegram, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
If you have a lot of pip/AUR packages to upgrade to Python 3.11, read this.
If you installed python311 from the AUR, you need to uninstall it before running this update.
2023-05-07
All initramfs builds fail with ERROR: Hook ‘zfs’ cannot be found
There was an issue with zfs-utils 2.1.11-1 package having the initcipio files wrongly installed. Please update to zfs-utils 2.1.11-1.1 and re-run mkinitcpio -P. If you have an already unbootable system, you may recover by using an install media and chroot into it to complete the update.
2023-04-11
xf86-input-libinput 1.3.0 DPI and mouse acceleration issue on KDE Plasma X11
A bug report was opened on https://bugs.kde.org/show_bug.cgi?id=468217#c3 and a temporary fis is also mentioned on Mouse acceleration - ArchWiki
Widgets on Plasma desktop are lost after update
2023-03-31
GRUB, LUKS and full disk encryption: 'no such cryptodisk found'
Following grub’s update, new configuration may be needed to be manually applied:
  • Based on the manual, unlike filesystem UUIDs, UUIDs for encrypted devices must be specified without dash separators. So check /boot/grub/grub.cfg for entries like cryptomount -u 3722dfb2-3b32-414b-bd59-4329fa92b6a9 and try to remove the dash separators. You have to redo that whenever you update a kernel or call update-grub on your own. You can read more about it here
  • A message “no such cryptodisk found” may appear on the following reboot, but should not prevent you from continuing by typing any key. This happens if you forgot to remove the dashes in /boot/grub/grub.cfg after update-grub got called.
We may add a alpm-hook to grub package to do that monkey job for you automatically. As an alternative you may reinstall grub, as the newer version can handle both cases, including the dashes.
For more details:
Info about recent NVIDIA packaging changes
[Testing Update] 2023-03-25 - Kernels, Firefox, Deepin, GNOME, NVIDIA, Wine - #42 by philm
Possible kernel fs block code regression in 6.2.3 umounting usb drives
With kernel 6.2.3 when you simply plug in a usb external drive, mount it and umount it, then the journal has a kernel Oops. A bug report, that includes the journal output was submitted at. Making sure you're not a bot! Discussion can be found here: https://www.spinics.net/lists/stable/msg637035.html
kernel 5.15.99+ Black/empty screen during boot with i915 Intel gfx. No ways to do anything
Seems there is a regression introduced with 5.15.99 kernel update: Making sure you're not a bot!. My thoughts here: [Testing Update] 2023-03-11 - Kernels, Mesa 22.3.7, Phosh, LibreOffice 7.4.6 - #31 by philm
NVIDIA 530.41.03-1 high refresh rate problems
FS#77975 - [nvidia] 530.41.03-1 high refresh rate problems
2023-02-12
Switch to the base-devel meta package requires manual intervention
2023-02-12 - Robin Candau
On February 2nd, the base-devel package group has been replaced by a meta package of the same name.
If you installed the base-devel package group prior to this date, explicitly re-install it to get the new base-devel package installed on the system:
pacman -Syu base-devel
– Arch Linux - News: Switch to the base-devel meta package requires manual intervention
2023-02-03
vlc player crashes while playing videos
A solution, regarding to rob215x, is:
VLC would crash immediately when trying to play any video. I opened VLC directly, and changed Preferences > Video > Output from “Automatic” to “VDPAU” and it works now. I found that solution on another thread but I still don’t understand the problem and why VDPAU works.
2023-01-24
PHP 8.2 update and introduction of legacy branch
2023-01-13 - Pierre Schmitz
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php and php-legacy can be installed at the same time as the latter uses a -legacy suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap extension will no longer be provided as it relies on the c-client library which has been abandoned for many years.
– Arch Linux - News: PHP 8.2 update and introduction of legacy branch
GTK apps are loading very slowly after the last update
Firefox very slow to start after recent update
Slow opening applications after update
Doesn't boot after update: nvidia version magic 5.15.114-1-MANJARO should be 5.15.114-2-MANJARO
Very slow to open emails and browser
Very slow startup on some apps after update
Xfce, Firefox und LibreOffice starten sehr langsam seit neuem Kernel Update
Calibre: "Open containing folder" doesn't work
2023-06-05 update broke gnome-shell
Lag when starting a program
Applications slow to start after system upgrade (Manjaro XFCE)
Starting any program became very slow
Incredibly slow application load times after updates
Problemas con xdg
Firefox does not give me a window when launched
Brave not working proper after today's Update
Is Manjaro MATE Dying?
Chrome based browsers no longer load dark pages since 04.06 update
Slow run firefox
Recent updates greatly slows launching apps
Issue with xapp-gtk3-module
Problems with dbus and xdg-desktop-portal
Libre Office is very slow now...why?
Netzwerkverbindung dauert nach Booten sehr lange bis aktiv
Lenovo AMD - no keyboard
Steam crash, Flatpak & xdg-desktop-portal-(gnome)
LibreOffice takes forever to load or open a file
Firefox starting slow
After last full upgrade apps loading very slow
Firefox starts only after long delay
Manjaro crash and dont start
Recovering after interrupted Update fails: chroot: failed to run command '/bin/bash': Input/output error
Screen lagginess or temp app/screen freeze
What is the clean Manjaro-XFCE stock set of packages forming graphical environment and to be present in distribution?
Dolphin
we have a bug with this last version 23.04.1-1 : dolphin does not remember open tabs
fixed with 23.04.1-2 in unstable
[TIPS] With this new systemd 253 :
A new LogFilterPatterns= option has been added for units. It may be used to specify accept/deny regular expressions for log messages generated by the unit, that shall be enforced by systemd-journald.
Rejected messages are neither stored in the journal nor forwarded. This option may be used to suppress noisy or uninteresting messages from units.
If the first character of the pattern is “~”, log entries matching the pattern should be discarded. This option takes a single pattern as an argument but can be used multiple times to create a list of allowed and denied patterns.
For example:
# /etc/systemd/system/user@.service.d/30-journalfilter.conf
[Service]
# no save messages with :
LogFilterPatterns=~QML
LogFilterPatterns=~org\.kde\.plasma
LogFilterPatterns=~QObject:
LogFilterPatterns=~QFont::
After applying update, my shell was BASH.
To get back with ZSH:
type -a zsh ## find path to zsh
chsh -s /usr/bin/zsh ## change bash to zsh
See https://www.cyberciti.biz/faq/change-my-default-shell-in-linux-using-chsh/.
Note that default font color is not green anymore but white.
Just switch to “Breath” profile in Konsole and set it by default to get your colors back.
Update went smoothly. I had some Python 3.10 packages that needed rebuilding. A couple of notes:
  • rebuild-detector was not installed: I have a many years old install, so I installed it
  • the python-pep517 package that was installed was not found anymore, so I uninstalled it as it had no dependencies… I’ll see if anything breaks
Problems
Starting Firefox and LibreWolf suddenly takes a very long time. Like 30 seconds to 1 minute. Used to be a couple of seconds. Chromium starts pretty much instantly as before.
Edit: Okay, so I probably really needed the coffee. The workaround mentioned above under the known issues and solutions (replacing xdg-desktop-portal-gnome with xdg-desktop-portal-gtk) worked for my Cinnamon gtk-based desktop. Thanks @philm for reminding me to read the troubleshooting post.
Previous detailed problem report
Once started Firefox and LibreWolf work normally, no slowdowns. Also, when already running, new windows/tabs are normal speed. It’s just starting the application when it is not yet running that is very slow after the update.
Update: confirmed with a second updated Manjaro install (laptop) that launching Firefox is now very slow.
Firefox gives no output when starting from the terminal, LibreWolf says:
Crash Annotation GraphicsCriticalError: |[0][GFX1-]: glxtest: VA-API test failed: no supported VAAPI profile found. (t=25.3851) [GFX1-]: glxtest: VA-API test failed: no supported VAAPI profile found.
ATTENTION: default value of option mesa_glthread overridden by environment.
[ERROR glean_core] Error setting metrics feature config: Json(Error("EOF while parsing a value", line: 1, column: 0))
[Child 27338, Main Thread] WARNING: JSWindowActorChild::SendRawMessage (Conduits, ConduitClosed) not sent: !CanSend() || !mManager || !mManager->CanSend(): file /root/.local/share/bsys6/work/librewolf-113.0.2-1/dom/ipc/jsactor/JSWindowActorChild.cpp:57
No idea if that is related.
My inxi output
  Host: bliep Kernel: 6.3.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.1 Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 vt: 7 dm: LightDM
    v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Dell product: Inspiron 660 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Dell model: 0XR1GT v: A00 serial: <superuser required> UEFI: Dell
    v: A13 date: 05/22/2018
  Info: quad core model: Intel Core i5-2320 bits: 64 type: MCP
    smt: <unsupported> arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB
    L3: 6 MiB
  Speed (MHz): avg: 1597 min/max: 1600/3300 cores: 1: 1597 2: 1597 3: 1597
    4: 1597 bogomips: 23965
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Dell driver: i915 v: kernel arch: Gen-6 ports: active: none
    empty: DP-3,HDMI-A-3,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0102
    class-ID: 0380
  Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 pcie: speed: 5 GT/s
    lanes: 16 ports: active: DP-2,HDMI-A-2 empty: DP-1,DVI-D-1,HDMI-A-1
    bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 51.0 C
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu,modesetting
    alternate: fbdev,vesa dri: radeonsi,crocus gpu: amdgpu display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
    s-diag: 1064mm (41.9")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: right model: Dell E248WFP
    serial: G274H87O20CS res: 1920x1200 hz: 60 dpi: 94
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") modes: max: 1920x1200
    min: 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary,left
    model: Samsung SMS24A450 serial: H4MC801052 res: 1920x1200 hz: 60 dpi: 94
    min: 720x400
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 580 Series
    (polaris10 LLVM 15.0.7 DRM 3.52 6.3.5-1-MANJARO) direct-render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: speed: 5 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  API: ALSA v: k6.3.5-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: sndiod v: N/A status: off
  Server-2: JACK v: 1.9.22 status: off
  Server-3: PipeWire v: 0.3.70 status: off
  Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module
  Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Dell
    driver: ath9k v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 168c:0032 class-ID: 0280
  IF: wlp3s0 state: down mac: a6:6a:b9:04:60:85
    vendor: Dell driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: d4:be:d9:df:1c:f4
  Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 2-1.1:3
    chip-ID: 0b05:17cb class-ID: fe01 serial: 5CF370A3C2BF
  Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: 5C:F3:70:A3:C2:BF
  Local Storage: total: 763.85 GiB used: 609.57 GiB (79.8%)
  ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
    speed: 6.0 Gb/s tech: SSD serial: S3Z2NB1K357906P fw-rev: 1B6Q scheme: GPT
  ID-2: /dev/sdb vendor: Western Digital model: WD3200AAJS-56M0A0
    size: 298.09 GiB speed: 3.0 Gb/s tech: N/A serial: WD-WCAV2W546492
    fw-rev: 3E01 scheme: MBR
  ID-1: / size: 456.88 GiB used: 347.65 GiB (76.1%) fs: ext4 dev: /dev/dm-0
    mapped: cryptroot
  ID-2: /boot size: 511 MiB used: 250.8 MiB (49.1%) fs: vfat dev: /dev/sda1
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
  Fan Speeds (RPM): cpu: 492 mobo: 1016 gpu: amdgpu fan: 1151
  Processes: 255 Uptime: 17m wakeups: 0 Memory: available: 15.49 GiB
  used: 3.15 GiB (20.4%) Init: systemd v: 253 default: graphical Compilers:
  gcc: 13.1.1 clang: 15.0.7 Packages: 1747 pm: pacman pkgs: 1737 pm: flatpak
  pkgs: 10 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
Thanks @philm , but where is that new release 23.0 Ultima Thule? It doesn’t appear in download section?
and by the way the news in telegram channel is very poor!
Thanks again
is in testing (xdg-desktop-portal-gnome bug) but not here ?
Update went smoothly but now my Logitech mouse is moving reaaaaly slow in plasma desktop :confused:
What is the point of a stable branch if bugs successfully reach it? :thinking: :thinking: :thinking:
zsh is broken
Since the profile has changed, have to switch to the old one
that python guide is ridiculously complex, what are my chances if i just run the update, and re-install all packages i use?
we can easily bypass it ! we can change a package for another :wink:
for zsh is in post #4 (edit: or ok for use old profil)
Yes, there might be slow starts of applications when a certain package got installed as dependency. See troubleshoots for help.
It’s useful if you have too many (AUR and pip) packages to remember.
No problem.
If you have so few python (AUR and pip) packages you can remember them all, that’s the easy way.
EDIT: added “(AUR and pip)”
Will be a fix for zsh, or will stay as it is??
I dont see speed issues so far
It doesn’t fix Dolphin
I changed the text a little to hopefully make it clear that the guide is for 3rd party packages like from the AUR. With the system update regular packages provided by use have been updated against python 3.11 already.
@philm Any chance that dolphin 23.04.1-2 will be brought in soon?
@papajoke Thanks for the warning.
I keep about 24 Dolphin windows open, across 6 desktops,
with about 10 tabs in each, and they re-open automatically when I log on.
It’s how I easily find the various things I’m working on,
coz I couldn’t figure out how to use KDE tools that say they do this kind of thing. :wink:
That is why we have the testing branch and rely on community feedback. Some issues only get detected in the stable branch as more people use it. The dolphin issue should been fixed with dolphin-23.04.1-1.1. Regarding ZSH we are still working on a proper fix.
But these are noticeable, albeit minor, bugs in popular applications :melting_face:
