I am experiencing problems with tuxedo-control-center especially its dkms kernel modules with gcc version 13:
DKMS make.log for tuxedo-keyboard-3.2.3 for kernel 5.15.114-1-MANJARO (x86_64)
So 04 Jun 2023 10:13:29 CEST
make -C /lib/modules/5.15.114-1-MANJARO/build M=/var/lib/dkms/tuxedo-keyboard/3.2.3/build modules
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (GCC) 12.2.1 20230201
You are using: gcc (GCC) 13.1.1 20230429
CC [M] /var/lib/dkms/tuxedo-keyboard/3.2.3/build/./src/clevo_wmi.o
CC [M] /var/lib/dkms/tuxedo-keyboard/3.2.3/build/./src/tuxedo_keyboard.o
CC [M] /var/lib/dkms/tuxedo-keyboard/3.2.3/build/./src/clevo_acpi.o
CC [M] /var/lib/dkms/tuxedo-keyboard/3.2.3/build/./src/tuxedo_io/tuxedo_io.o
CC [M] /var/lib/dkms/tuxedo-keyboard/3.2.3/build/./src/uniwill_wmi.o
cc1: error: cannot load plugin ./scripts/gcc-plugins/structleak_plugin.so: ./scripts/gcc-plugins/structleak_plugin.so: undefined symbol: tree_code_type
Maybe this is related to:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=108634
I installed the previous gcc-12 and tried to install the dkms kernel modules again with:
export CC=gcc-12
dkms autoinstall
But it also failed with the same error as before.
Does anybody know how to switch the gcc-version for dkms make?
Telegram-desktop stopped working/launching.
What else, the tray no longer displays charging correctly, the icon is superimposed on the font (in i3wm, I use it by default.)
icon
philm
4 June 2023 08:29
23
Well there is no bug with DKMS nor the kernel. We simply didn’t compile our kernels against the new toolchain, hence dkms is currently broken. Wait for kernel updates.
Gnome. Brave and Badwolf browsers not working properly.
After upgrading to Plasma, at the ejectur konsole, I get this message:
bash: /home/mlpdel/.bashrc: line 139: syntax error: end of file not expected
And my baschrc file has 138 lines.
In addition, the brave browser does not work very well, because the images appear on top of each other and some blink and the text is not visible.
KDE reset the adaptive mouse speed settings, went into settings and returned them to what they were.
Thanks for your quick reply.
A possible workaround might be to somehow configure DKMS to use gcc-12 for compiling kernel modules right?
Anyways, it’s okay for me to wait till the next update.
It’s just the keyboard light and fan-control which is not working at the moment.
Another one with zsh broken, and chsh doesn’t change to zsh again. As I see there are several issues, I restored system state with timeshift to the copy made just before (zsh is back again) and I’ll wait some days to repeat the update.
Hey,
after having this update installed, the entire X server collapsed on me, causing my gnome session to restart. All I could get from the system logs is this
Jun 04 10:55:57 karolyi-desktop gnome-shell[1503]: Received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadMatch (invalid parameter attributes)'.
(Details: serial 33231 error_code 8 request_code 147 (unknown) minor_code 6)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the MUTTER_SYNC environment
variable to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the meta_x_error() function.)
Jun 04 10:55:59 karolyi-desktop systemd-coredump[14208]: [🡕] Process 1503 (gnome-shell) of user 1000 dumped core.
Stack trace of thread 1503:
#0 0x00007fbfcd69f26c n/a (libc.so.6 + 0x8926c)
#1 0x00007fbfcd64fa08 raise (libc.so.6 + 0x39a08)
#2 0x000055d0010fcf19 n/a (gnome-shell + 0x3f19)
#3 0x00007fbfcd64fab0 n/a (libc.so.6 + 0x39ab0)
#4 0x00007fbfcde99408 g_log_structured_array (libglib-2.0.so.0 + 0x5e408)
#5 0x00007fbfcde99703 g_log_default_handler (libglib-2.0.so.0 + 0x5e703)
#6 0x00007fbfcde99975 g_logv (libglib-2.0.so.0 + 0x5e975)
#7 0x00007fbfcde99c64 g_log (libglib-2.0.so.0 + 0x5ec64)
#8 0x00007fbfcd917bc7 n/a (libmutter-12.so.0 + 0x117bc7)
#9 0x00007fbfcd27b3dc _XError (libX11.so.6 + 0x443dc)
#10 0x00007fbfcd27b4e8 n/a (libX11.so.6 + 0x444e8)
#11 0x00007fbfcd27b585 n/a (libX11.so.6 + 0x44585)
#12 0x00007fbfcd27b63a _XEventsQueued (libX11.so.6 + 0x4463a)
#13 0x00007fbfcd269c48 XPending (libX11.so.6 + 0x32c48)
#14 0x00007fbfcde95a0f g_main_context_check (libglib-2.0.so.0 + 0x5aa0f)
#15 0x00007fbfcdef2078 n/a (libglib-2.0.so.0 + 0xb7078)
#16 0x00007fbfcde94c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#17 0x00007fbfcd8cdc5b meta_context_run_main_loop (libmutter-12.so.0 + 0xcdc5b)
#18 0x000055d0010fc526 n/a (gnome-shell + 0x3526)
#19 0x00007fbfcd639850 n/a (libc.so.6 + 0x23850)
#20 0x00007fbfcd63990a __libc_start_main (libc.so.6 + 0x2390a)
#21 0x000055d0010fc835 n/a (gnome-shell + 0x3835)
Stack trace of thread 1508:
#0 0x00007fbfcd713c0f __poll (libc.so.6 + 0xfdc0f)
#1 0x00007fbfcdef217f n/a (libglib-2.0.so.0 + 0xb717f)
#2 0x00007fbfcde94c7f g_main_loop_run (libglib-2.0.so.0 + 0x59c7f)
#3 0x00007fbfce0f5d3c n/a (libgio-2.0.so.0 + 0x10ed3c)
#4 0x00007fbfcdec2315 n/a (libglib-2.0.so.0 + 0x87315)
#5 0x00007fbfcd69d44b n/a (libc.so.6 + 0x8744b)
#6 0x00007fbfcd720e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 1509:
#2 0x00007fbfcde941a2 g_main_context_iteration (libglib-2.0.so.0 + 0x591a2)
#3 0x00007fbfce1f6fde n/a (libdconfsettings.so + 0x5fde)
Stack trace of thread 1505:
#0 0x00007fbfcd7192ed syscall (libc.so.6 + 0x1032ed)
#1 0x00007fbfcdeeb7b5 g_cond_wait (libglib-2.0.so.0 + 0xb07b5)
#2 0x00007fbfcde5ffb4 n/a (libglib-2.0.so.0 + 0x24fb4)
#3 0x00007fbfcdec6f9e n/a (libglib-2.0.so.0 + 0x8bf9e)
Stack trace of thread 1511:
#0 0x00007fbfcd699f0e n/a (libc.so.6 + 0x83f0e)
#1 0x00007fbfcd69c7a0 pthread_cond_wait (libc.so.6 + 0x867a0)
#2 0x00007fbfcc395291 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-102.so + 0x1595291)
#3 0x00007fbfcc395192 n/a (libmozjs-102.so + 0x1595192)
#4 0x00007fbfcc54e4be n/a (libmozjs-102.so + 0x174e4be)
Stack trace of thread 1512:
Stack trace of thread 1513:
Stack trace of thread 1514:
Stack trace of thread 1516:
Stack trace of thread 1517:
Stack trace of thread 1518:
Stack trace of thread 1515:
Stack trace of thread 4714:
#1 0x00007fbfcdeebd03 g_cond_wait_until (libglib-2.0.so.0 + 0xb0d03)
#2 0x00007fbfcde5ff83 n/a (libglib-2.0.so.0 + 0x24f83)
#3 0x00007fbfcdec79fb n/a (libglib-2.0.so.0 + 0x8c9fb)
Stack trace of thread 8202:
#1 0x00007fbfa11ab8c7 n/a (libpulse.so.0 + 0x338c7)
#2 0x00007fbfa119546c pa_mainloop_poll (libpulse.so.0 + 0x1d46c)
#3 0x00007fbfa119f42c pa_mainloop_iterate (libpulse.so.0 + 0x2742c)
#4 0x00007fbfa119f4e1 pa_mainloop_run (libpulse.so.0 + 0x274e1)
#5 0x00007fbfa11afc02 n/a (libpulse.so.0 + 0x37c02)
#6 0x00007fbfa114cc67 n/a (libpulsecommon-16.1.so + 0x5bc67)
#7 0x00007fbfcd69d44b n/a (libc.so.6 + 0x8744b)
#8 0x00007fbfcd720e40 n/a (libc.so.6 + 0x10ae40)
Stack trace of thread 1506:
#3 0x00007fbfcde941f2 n/a (libglib-2.0.so.0 + 0x591f2)
░░ Subject: Process 1503 (gnome-shell) dumped core
It happened when I went on to install the python3.10 package, that started to compile itself. Weird.
Also, I have strange artifacts appearing around my thunderbird window:
Make that all Qt-based applications. (jackd kit, keepassxc, etc).
I had same problem, needed to first apply “adaptive” then “flat” to get it back. Just selecting adaptive then flat did not allow me to apply, as it thought i already had “flat” but in reality it was not.
Not sure, but maybe you can try to add an empty line at the end of your .bashrc?
Hello,
I have the same problem, although only in Gnome.
firefox , thunderbird , libreoffice and maybe some more programs start a bit slow after this update.
No error logs in journalctl
Fixed.
cscs
4 June 2023 10:08
36
@pheiduck
These all sound like the desktop-portal bug
j77h
4 June 2023 10:10
37
Suse says Dolphin 23.04.1-1.1 update broke restore previously open tab at start (May 15th)
This Arch dolphin page says
“23.04.1-2: Fix restoring tabs on startup - Antonio Rojas authored 1 week ago”.
So it looks like 23.04.1-2 has the fix, not 23.04.1-1.1 … ?
philm
4 June 2023 10:13
38
dolphin-23.04.1-1.1 is a rebuild of revision 2
Same here, both different laptops and mouses (by Logitech) and the same issue on both machines. Mouse cursor moves really slow, temporary fix can be made quickly via Mouse app in KDE, increasing movement speed and checking Adaptive acceleration profile.
Also, my zsh does not work anymore. But I have always been a fan of bash, so…
philm
4 June 2023 10:30
40
Here are some ISOs built against this update for testing: Release 202306040845 · manjaro/release-review · GitHub . Simply download the split-archives and extract them as usual. Then use Etcher to flash it on your USB-Stick.
@cscs Which desktop-portal bug?
