Manjaro maintenance
Hi, are there any maintenance hacks for Manjaro? To repair or check the system for errors or other system problems?
For instance; by pure chance (luck) I just stumbled upon this post to rebuild some packages and it solved a couple of errors on my machine and now I wonder if I missed more of these kind of hacks?
Additional Info
:information_source: You will need to rebuild any AUR Python packages after the system update, that install files to site-packages or link to libpython3.10.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.10/ :
pacman -Qoq /usr/lib/python3.10/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.10)
  • Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
in this post:
At the end of the article is some more reading material.
Personally I use this: [Checklist] after you install your system
Each and every user and use case is different - there is no one-size-fits-all.
That said you should take a look at the Tutorials section - there is a wealth of documentation written by members …
To mention a few …
The Manjaro wiki
The Arch mother wiki
