[root tip] [How To] Kernel - Headers - DKMS
What you will learn
You will learn why AUR packages tend to create issues when they depend on DKMS and thus specific kernel headers.
You will also learn what DKMS is and how to mitigate build issues with DKMS package and other packages depending on the kernel headers.
Finally you will learn why the kernel headers is not present by default.
What is DKMS
DKMS is an acronym for Dynamic Kernel Module Service and is a set of scripts which can update your custom build drivers upon updating your kernel.
The common usecase is using AUR to build drivers for various wireless cards which lacks the kernel module to work and edge cases like using you phone as webcam.
A sure sign of a buildscript depending on DKMS is the -dkms phrase in the name of the buildscript.
DKMS requires the kernel headers packge to be installed on your system - but not any package - it must be the package matching your current running kernel and any other kernel you have installed - that is of course - it can be omitted if you don’t intend to use the specific script on other kernels.
AUR build scripts
AUR packages are created for Arch Linux - it should be obvious from the name.
AUR scripts are very useful - suffice you understand how to use them - but remember this
:warning: AUR is unsupported (read the disclaimer on AUR and Manjaro) so you must have the required knowledge or wish to learn how to use AUR scripts.
Kernel headers
Manjaro supports running multiple kernels - Arch always runs on the latest mainline kernel linux.
This means Manjaro has multiple headers packages and they use a different name schema - yet providing the required dependency to dkms linux-headers and remember this name is Arch naming because AUR is Arch.
On Manjaro this kernel dependency must be resolved manually - and you need to know which kernel you are using - otherwise pacman defaults to the first header package listed linux414-headers which of course won’t work unless you actually are using 4.14 as the primary kernel.
Manjaro builds upon Arch where the philosophy is K.I.S.S and therefore kernel and kernel headers are split packages.
Only a subset of users wil ever require the linuxXYY-headers package and therefore it is not installed by default and those needed the headers are required to know why and for which kernel.
Adding the linuxXYY-headers package to the default ISO will usually trigger the word bloat with the majority user base and add another item to the FUD machine targeting Manjaro.
Installing headers
Before you build any AUR script you should verify the build script - best practise and all - to verify if it depends on linux-headers or dkms.
If you find this to be true - list your installed kernels with mhwd
mhwd-kernel -li
Depending on you system you will get a response like
 $ mhwd-kernel -li
Currently running: 6.7.5-1-MANJARO (linux67)
   * linux66
   * linux67
If you have more than one - consider removing unused kernels - usually you only need headers for currently active kernel.
Using the above example - we use pacman to install the headers - don’t ever just install the headers - always run a full system sync
sudo pacman -Syu linux67-headers
Now you are ready to run makepkg or pamac build or yay -S
If the package is a repo package depending on the kernel headers - pacman will display a numbered list of packages supplying the headers and you will have to tell pacman which one you need.
Be warned that the default selection is always number 1 and this is most likely not the package you want. Carefully examine the list and identify which header package contains the version of your running kernel.
Using the example from above you would look for the number identifying (x) linux515-headers - then feed that number to pacman.
Conclusion
The Manjaro slogan Enjoy the simplicity is not referring to package maintenance but how you get a fully functional system by using a Manjaro ISO to install your system.
Running a Linux system as a padawan - close to bleeding edge - requires persistence and willingness to learn. Issues and problems are important tutors in that regard.
DKMS packages are invaluable helpers - but remember - the usage is your responsibility and yours alone.
Feel free to ask - but don’t complain …
Can't use wifi adapter
Broadcom-wl-dkms | newbie question
Dkms dependency issue
Installation of kernel headers
Wifi dongle not detected Ref : ACI200M (new user in Linux)
[root tip] Topic Collection List View
RTL8192EU being broken after every kernel upgrade
Support for R8125 Realtek 2.5 gbe Ethernet Adapter
Wifi Slows to 0kbps periodically
OpenRazer on Manjaro KDE not working
RTX4070Ti SUPER with current driver
Macbook Broadcom4322 wifi
Driver USB Adapter WiFi Comfast Realtek 8851BU
Can't install Manjaro XFCE on new laptop - no network device drives
Is there any plan to provide the new Nvidia open kernel module?
Wifi driver not properly making package
Can not compile kernel modules for RocketRaid 640L
Tp link T2E archer wifi card not working
Iriunwebcam - missing v4l2loopback kernel module
Rtw89 stopped working after kernel upgrade/switch to 5.15
Dkms, need help installing acpi_call
Power and voltage monitoring via ryzen-smu - module not loading
[HowTo] Manually build a Manjaro kernel module
Tuxedo InfinityBook Pro 14 Gen 8 Intel Iris Xe + NVIDIA GeForce RTX 3050
System boot into black screen after installing hyprdots
Macbook air 2015-16, camera doesn't work
Matrox driver installation
Network connection oscillating on/off regularly
Cannot find working driver for Archer T3U Nano Usb adapter (could not solve)
What is this dkms problem?
No wifi and confused about mhwd and Arch
Issue with RTL8125 Ethernet driver on Manjaro Linux
Can not load graphical installer with proprietary drivers
IPU6 Camera not recognized (Dell Precision 5490)
Cant find or install kernel-devel
I can't connect to wifi because of a problem in the Network driver
Ich suche eine Virtuelle Maschine die unter einen neueren Lts Kernel läuft
Lenovo Ideapad Flex 5i -- No Key to turn on Wifi
Getting DisplayLink to work with StarTech adapter on Wayland
Yet another iwlwifi problem
Wi-Fi not working on my Acer laptop (MediaTek)
Virtualbox: cannot create new VMs nor add existing VMs
Device Not Ready - Wi-Fi Network
Network drivers MHWDCONFIG is invalid and empty
Can't open anbox
Problems installing moc-pulse AUR package
==> ERROR: Missing 5.17.9-1-MANJARO kernel headers for module v4l2loopback/0.12.5
Installation of Manjaro alongside Windows
Broadcom 4321 [14e4:4328] rev03
I have to reinstall rtl8192eu after every kernel update
notes and extras
I think this is a very handy command to have ready when dealing with kernel headers:
pamac install $(pamac list --installed --quiet | grep "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
This will install the headers for all currently, still supported installed kernels.
