Manjaro-settings-manager has light theme instead of dark
on XFCE: I use Matcha-dark-sea but manjaro-settings-manager has light theme instead of dark
grafik
After recent update, system is not applying configuration settings in ~/.profile including: export QT_QPA_PLATFORMTHEME="qt5ct" for QT theme
If there is no response to this command
echo $QT_QPA_PLATFORMTHEME
Forum users have posted 3 different ways to resolve this:
  1. Copy configuration in ~/.profile to ~/.bash_profile
OR
  1. Configure ~/.bash_profile to read ~/.profile
    tee -a ~/.bash_profile <<< "[[ -f ~/.profile ]] && . ~/.profile"
OR
  1. create a symlink for ~/.profile to ~/.xprofile
    cd $HOME; ln -s .profile .xprofile
Xfce theming theming issues with some applications green others blue
[Stable update]-2024-03-06 - post #31
It seems my /.profile is not being used anymore
I use ZShell
didn`t solve my issue here
Also this does not:
$ GTK2_RC_FILES=/usr/share/themes/Matcha-dark-sea/gtk-2.0/gtkrc manjaro-settings-manager
well it is qt app, so it only makes sense
QT_QPA_PLATFORMTHEME=qt5ct manjaro-settings-manager
as already mentioned above.
yep, but it is still light instead of dark so its not sourcing the kvantum theme or xfce4 one.
$ sudo pacman -S kvantum-qt5
solved it but highlight color is blue instead of green
Seems like unannounced change in the kvantum system und packaging in the unstable branch, hopefully we will get more info when it hits stable.
solved all issues now, I removed xfce-panel-workaround from startup items was a bad idea.
kvantum-qt5 is a new package to support QT5 themes, split from kvantum 1.0.10-3 that supports QT6 only
upgpkg: 1.0.10-3: Build tools with Qt6, split Qt5 style to a separate package (a624b468) · Commits · Arch Linux / Packaging / Packages / kvantum · GitLab
I need it for audacious until it is rebuild up on qt6.
