[Testing Update] 2023-03-11 - Kernels, Mesa 22.3.7, Phosh, LibreOffice 7.4.6
thank team manjaro for responding so quickly
May be linked to the problem I had with a previous unstable version. (did not test on this one)
Intel i915 hangs when booting kernel 5.15.99. I found that the bug has already been reported:
I’ll be using 5.15.98 for now (tried 5.15.100 on unstable - no fix there).
Just pushed the new kernel point releases:
  • linux419 4.19.276
  • linux54 5.4.235
  • linux510 5.10.173
  • linux515 5.15.100
  • linux61 6.1.18
  • linux62 6.2.5
Question: if our issue was resolved by a fast-tracked package update (like was done today), should we change our answer to the poll? Since it was an issue with the update, but is no longer.
I noticed a new warning:
WARNING: consolefont: no font found in configuration
Is that expected or something out of ordinary?
Hello!
Doesn’t work for me as My Broadcom wifi adaptor is not working with these new releases.
I’m using Linux510-LTS kernel (Can’t upgrade because of old legacy NVidia driver 340.108)
Same with Linux54-LTS
Found this on Arch Forum:
https://bbs.archlinux.org/viewtopic.php?id=153982
How to understand a patch works
Most likely the developers doing the kernel work won’t get the info at all. Lets take a look at the patch header:
author	John Harrison <John.C.Harrison@Intel.com>	2023-02-15 17:11:01 -0800
committer	Greg Kroah-Hartman <gregkh@linuxfoundation.org>	2023-03-10 09:40:14 +0100
commit	4eb6789f9177a5fdb90e1b7cdd4b069d1fb9ce45 (patch)
tree	7f0259b02632bf92193b3b5aa5c45d6f0fa3ebdd
parent	64bcaffa2d5c88ddfe12d6019ad58986bd0e314c (diff)
download	linux-4eb6789f9177a5fdb90e1b7cdd4b069d1fb9ce45.tar.gz
drm/i915: Don't use BAR mappings for ring buffers with LLC
commit 85636167e3206c3fbd52254fc432991cc4e90194 upstream.
Direction from hardware is that ring buffers should never be mapped
via the BAR on systems with LLC. There are too many caching pitfalls
due to the way BAR accesses are routed. So it is safest to just not
use it.
Signed-off-by: John Harrison <John.C.Harrison@Intel.com>
Fixes: 9d80841ea4c9 ("drm/i915: Allow ringbuffers to be bound anywhere")
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Tvrtko Ursulin <tvrtko.ursulin@linux.intel.com>
Cc: intel-gfx@lists.freedesktop.org
Cc: <stable@vger.kernel.org> # v4.9+
We know that there was an author by Intel John Harrison doing the patch. If we look at the last CC we see that patch should be added to all kernels starting with 4.9 kernel. So most likely you might have similar issues with higher and lower kernel series than your used 5.15 series if the same patch gets applied there also. You can check that here @stasadev: Making sure you're not a bot!. More or less higher than 6.2.2 might also not work on your end: Making sure you're not a bot!. So test that by checking which kernels we provide.
So check other kernel series if they also don’t boot as you still have 5.15.98 as your fallback one.
If it is true, simply check if other kernel series are affected too by this.
How to report properly
The first thing you can do is to add a confirm report similar as you have found already here Making sure you're not a bot! by adding your own details of hardware and maybe the dmesg log of the 5.15.99 and 5.15.98 of your own system additionally to the already reported one.
Next step is simply to summarize the issue in an email and sent that to upstream. Which emails? Well you have all what you need in the patch itself. Simply send them to the email addresses exactly as given. Also include the stable@vger.kernel.org and intel-gfx@lists.freedesktop.org mailing lists, as some developers still work on email.
What I think personally
Well, most likely it also can be a missing patch within the 5.15 kernel series. For example I see this in all the other kernel series when the patch is applied, except 5.15, even it is tacked to be included: Making sure you're not a bot! So test as recommended other kernel series and see if they work for you.
What Manjaro can do
We might revert the patch as of now and follow up with upstream.
[Testing Update] 2023-03-15 - Plasma 5.27.3, KDE Frameworks 5.104.0, Kodi 20.1, Firefox 111.0
Wifi gui disappeared after updating & removing orphans
[Testing Update] 2023-03-28 - Mesa
[Testing Update] 2023-03-25 - Kernels, Firefox, Deepin, GNOME, NVIDIA, Wine
[Stable Update] 2023-09-10 - Kernels, Systemd, Firefox, Thunderbird, LLVM
[Testing Update] 2023-08-04 - Kernels, Nextcloud, Plasma 5.27.7, Mesa 23.1.5, Firefox, Thunderbird
[Stable Update] 2023-03-31 - Kernels, Plasma 5.27 LTS, Pamac, Phosh, Mesa, LibreOffice
[Stable Update] 2023-04-06 - Kernels, Systemd, Nextcloud 26, Linux-Firmware, LibreOffice 7.5.2
[Stable Update] 2023-05-07 - Kernels, KDE Gear 23.04.0, KDE Frameworks 5.105.0, Qt5, Firefox, Thunderbird
[Testing Update] 2023-04-08 - Kernels, Plasma 5.27.4, Phosh, Pipewire, KDE-git
[Unstable Update] 2023-05-03 - Python 3.11, GCC 13
[Stable Update] 2023-04-11 - Kernels, Plasma 5.27.4, Phosh, Pipewire 0.3.68, KDE-git
[Testing Update] 2023-04-14 - Kernels, Deepin, Qt5/6, KDE Framworks 5.105.0
[Unstable Update] 2023-04-14 - Kernels, Deepin, Qt5/6, KDE Frameworks 5.105.0,
[Testing Update] 2023-05-11 - Python 3.11, GCC 13, GNOME 44.1, KDE Plasma 5.27.5
[Testing Update] 2023-06-15 - Kernel, Systemd, Mesa, GNOME 44.2, NVIDIA, ZFS, LibreOffice, PipeWire
[Testing Update] 2023-07-25 - Kernels (zenbleed), Firmware, Pipewire, KDE-git, Python
[Unstable Update] 2023-05-15 - Kernels, KDE Frameworks 5.106.0, KiCAD 7.0.3, Python, Haskell
[Testing Update] 2023-05-20 - KDE Frameworks, Python, Haskell, Wine
[Unstable Update] 2023-05-21 - Repository changes
[Testing Update] 2023-06-27 - Kernels, Linux-Firmware, Mesa, Wine, Nvidia, KDE-git
[Testing Update] 2023-06-29 - Kernels, ICU, Gaming, KDE-git, Python, Haskell
[Testing Update] 2023-07-01 - Kernels, Pipewire, Bluez, Evolution, KDE-Git
[Stable Update] 2023-07-10 - Kernels, Plasma, Gnome, LibreOffice, Pipewire, Mozilla, Wine
[Stable Update] 2023-07-27 - Kernels, Nvidia, Virtualbox, Thunderbird, LibreOffice, Pipewire
[Testing Update] 2023-07-31 - Kernels, Pipewire, Gamescope-Plus, Squashfuse
[Testing Update] 2023-07-15 - Kernels, Pipewire, KDE Frameworks, Systemd, Firefox, Wine, Cinnamon
[Testing Update] 2023-08-08 - Kernels, Firmwares, Plasma, Pamac, Firefox, Pipewire
[Stable Update] 2023-08-11 - Kernels, Plasma, Nvidia, Firefox, Thunderbird, Pamac, Pipewire, Mesa
[Testing Update] 2023-08-19 - Kernels, GlibC, Mesa 23.1.6, Deepin, Firefox, Thunderbird
[Stable Update] 2023-09-18 - Kernels, Mesa, Pipewire, Systemd, LibreOffice, KDE, Thunderbird
[Stable Update] 2023-08-29 - Kernels, Mesa, Deepin, Firefox, KDE Gear & Frameworks, Nvidia, Budgie
[Testing Update] 2023-05-13 - Kernels, Firefox, LibreOffice Still, KDE-git, Python
[Unstable Update] 2023-04-07 - Kernels, Systemd, Phosh, PipeWire, Plasma, Arch Spring Cleanup
[Testing Update] 2023-08-09 - Kernels, Gamescope-Plus, NVIDIA, KDE-git, Haskell, Perl, Python
[Stable Update] 2023-07-17 - Kernels, Pipewire, KDE Frameworks, Systemd, Firefox, Wine
[Testing Update] 2023-03-18 - Kernels, Thunderbird, Cinnamon, KDE-git, Python, Haskell
[Stable Update] 2023-06-04 - Kernels, Gnome 44.1, Plasma 5.27.5, Python 3.11, Toolchain, Firefox
[Testing Update] 2023-04-01 - Kernels, Nextcloud Hub 4, Linux Firmware, LibreOffice 7.5.2
[Testing Update] 2023-07-24 - Kernels, Pipewire, Thunderbird 115, Grub 2.12-rc1, LibreOffice 7.5.5, Mesa 23.1.4
[Testing Update] 2023-06-24 - Kernels, Plasma, Linux-Firmware, Pamac GTK4, Firefox, KDE-git
[Testing Update] 2023-04-25 - Kernels, Virtualbox, LxQt 1.3.0, Systemd 253.3, KDE Gear 23.04, Firefox, Pipewire
[Unstable Update] 2023-05-06 - GNOME 44.1
[Testing Update] 2023-04-27 - Kernels, GNOME 43.6, Firefox, QEMU 8.0, KDE-git
[Testing Update] 2027-07-28 - Kernels, Gamescope-Plus, Mesa 23.1.4, Firefox, Wine
Thanks. However, I’m not sure if I understand it. I don’t see any depreciated hooks in my case. And oh, this is a topic from 2012… so I’m not sure how relevant it is.
Here is mine grub file in/etc/default/ :
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash loglevel=3 udev.log_priority=3 vt.global_cursor_default=0 resume=/dev/sda4 resume_offset=1363968"
GRUB_CMDLINE_LINUX="rhgb quiet mitigations=off"
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_BACKGROUND="/root/alien-background.png"
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
sudo vim /etc/vconsole.conf
KEYMAP=us
FONT=lat9w-16
sudo cp -p /etc/mkinitcpio.conf /etc/mkinitcpio_edit_consolefont.conf;sudo vim /etc/mkinitcpio.conf
remove consolefont from hooks line
sudo mkinitcpio -P;sudo grub-mkconfig -o /boot/grub/grub.cfg
v6.2.5 fixed the wifi issue :slight_smile:
I have now a minor silly issue. Whenever I update the nvidia driver I get this (harmless) error:
(4/5) reinstalling linux62-nvidia
cat: /usr/lib/modules/extramodules-6.1-MANJARO/version: No such file or directory
depmod: ERROR: Bad version passed
error: command failed to execute correctly
I checked in /usr/share/libalpm and the post-transaction hooks seem correct to me. I also don’t have any trace left of kernel v6.1 - as far as I can see, at least.
Where else shall I look for left-overs?
@chainofflowers Can be related to this: [pkg-upd] 34-1.1 (a2fb55ca) Ā· Commits Ā· Packages / Core / mkinitcpio Ā· GitLab. Check if the preset is still given and see what mkinitcpio hook does …
Thanks. There was no font defined in the /etc/vconsole.conf`, Since I have no idea what is the default, I added what you have.
From what I see the consolefont hook is not depreciated, so I’m leaving it for now.
But not the 5.10.173 :frowning:
@michaldybczak
should be enough, I don’t have it on my hooks line as well.
There is no trace of 6.1 in /etc/mkinitcpio/*, and mkinicpio -P behaves correctly…
Moreover I just tried with another computer with a Broacom Wifi with kernel 6.2.5 but on Mageia and I got the same pblm: Wifi not available :frowning:
So the pblm is not specific to Manjaro
Question: Is it possible to downgrade the kernel?
