There are some recent bugs in LibreOffice apparently fixed by the 24.2.4 release.
I’m noting this here in case it’s relevant. Cheers.
Every time i wish i had more bang for buck and fancy new stuff with plasma and wayland i read something like this and i am glad i am on the ancient dull xfce, where my office just works.
Wait 'till XFCE has a major step update ![]()
Yeah, I was using it when we went version 3 to 4 - good times! ![]()
I am afraid i will not live that long ![]()
EDIT, solved.
Since the update, i am dealing with some issues when coming back from standby. All open windows are closed, seems like the system wakes up in a new graphical session.
The issue is with the manjaro and wayland surface.
On another computer, using manjaro and X11, there are no issues.
Since the last 2 stable updates with KDE6 update, I have been experiencing inconsistent behavior of Display and Brightness settings for my monitor, where it does not dim nor sleeps after the set timers.
Manually restarting plasma-powerdevil.service temporarily fixes it
This mostly/only happens after resuming from sleep. On a cold or reboot Energy Saving works fine.
Anyone know if this a known issue in KDE6?
Journalctl to me does not show anything out of the ordinary that sticks out regarding powerdevil:
journalctl
jun 05 14:13:21 Infinity systemd[1]: Started dbus-:1.1-org.kde.powerdevil.discretegpuhelper@6.service.
jun 05 14:13:21 Infinity systemd[1]: Started dbus-:1.1-org.kde.powerdevil.chargethresholdhelper@8.service.
jun 05 14:13:21 Infinity systemd[1]: Started dbus-:1.1-org.kde.powerdevil.backlighthelper@6.service.
jun 05 14:13:21 Infinity backlighthelper[207391]: org.kde.powerdevil: no kernel backlight interface found
jun 05 14:13:21 Infinity org_kde_powerdevil[207355]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
jun 05 14:13:21 Infinity org_kde_powerdevil[207355]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
jun 05 14:13:21 Infinity org_kde_powerdevil[207355]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
jun 05 14:13:21 Infinity org_kde_powerdevil[207355]: Options passed from client:
jun 05 14:13:21 Infinity org_kde_powerdevil[207355]: Applying combined options:
jun 05 14:13:22 Infinity org_kde_powerdevil[207355]: Library initialization complete.
jun 05 14:13:23 Infinity org_kde_powerdevil[207355]: org.kde.powerdevil: Handle button events action could not check for screen configuration
jun 05 14:13:23 Infinity org_kde_powerdevil[207355]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
jun 05 14:13:31 Infinity systemd[1]: dbus-:1.1-org.kde.powerdevil.discretegpuhelper@6.service: Deactivated successfully.
jun 05 14:13:31 Infinity systemd[1]: dbus-:1.1-org.kde.powerdevil.backlighthelper@6.service: Deactivated successfully.
jun 05 14:13:32 Infinity systemd[1]: dbus-:1.1-org.kde.powerdevil.chargethresholdhelper@8.service: Deactivated successfully.
jun 05 14:14:30 Infinity systemd[1]: Started dbus-:1.1-org.kde.powerdevil.chargethresholdhelper@9.service.
jun 05 14:14:30 Infinity systemsettings[206312]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed: "Charge thresholds are not supported by the kernel for this hardware"
jun 05 14:14:39 Infinity systemd[1]: dbus-:1.1-org.kde.powerdevil.chargethresholdhelper@9.service: Deactivated successfully.
jun 05 14:16:13 Infinity systemd[1]: Started dbus-:1.1-org.kde.powerdevil.chargethresholdhelper@10.service.
jun 05 14:16:13 Infinity systemsettings[207624]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed: "Charge thresholds are not supported by the kernel for this hardware"
jun 05 14:16:23 Infinity systemd[1]: dbus-:1.1-org.kde.powerdevil.chargethresholdhelper@10.service: Deactivated successfully.
plasma-powerdevil.service:
Summary
plasma-powerdevil.service - Powerdevil
Loaded: loaded (/usr/lib/systemd/user/plasma-powerdevil.service; static)
Active: active (running) since Wed 2024-06-05 14:13:22 CEST; 18min ago
Main PID: 207355 (org_kde_powerde)
Tasks: 13 (limit: 38374)
Memory: 14.3M (peak: 16.6M)
CPU: 893ms
CGroup: /user.slice/user-1000.slice/user@1000.service/background.slice/plasma-powerdevil.service
└─207355 /usr/lib/org_kde_powerdevil
jun 05 14:13:21 Infinity systemd[924]: Starting Powerdevil...
jun 05 14:13:21 Infinity org_kde_powerdevil[207355]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are no>
jun 05 14:13:22 Infinity systemd[924]: Started Powerdevil.
jun 05 14:13:23 Infinity org_kde_powerdevil[207355]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are no>
Sys info:
inxi -v7azy
inxi -v7azy
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f rw quiet splash
udev.log_priority=3 amd_pstate=passive amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 3.D0
date: 04/01/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 4.7 GiB (15.0%)
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 624 high: 1273 min/max: 550/4822 boost: enabled scaling:
driver: amd-pstate governor: conservative cores: 1: 550 2: 550 3: 550 4: 550
5: 1273 6: 550 7: 550 8: 550 9: 550 10: 550 11: 550 12: 550 13: 550
14: 1012 15: 550 16: 550 bogomips: 108847
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 28:00.0
chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.6.8-2-MANJARO) device-ID: 1002:73df memory: 11.72 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5.05 TiB used: 1.41 TiB (27.9%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Lexar model: SSD NM620 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.23 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Reletech model: M.2 SSD 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM32.1 temp: 26.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 022 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 0104 scheme: MBR
ID-1: / raw-size: 857.7 GiB size: 843.16 GiB (98.31%) used: 393.9 GiB (46.7%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: 4A19-EA19
ID-3: /mnt/data raw-size: 858.48 GiB size: 843.93 GiB (98.31%)
used: 225.62 GiB (26.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:4
label: DATA uuid: 74423f52-a944-4f61-9500-f4bc683c2cef
ID-4: /mnt/data2 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 215.62 GiB (13.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: DATA2
uuid: 4de3dfe5-98c9-438d-9fef-7bd41d5bf67f
ID-5: /mnt/storage raw-size: 755.73 GiB size: 755.73 GiB (100.00%)
used: 608.55 GiB (80.5%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: STORAGE
uuid: B0A0696BA069394C
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 529 MiB fs: ntfs label: Recovery
uuid: AC98EB3A98EB01A6
ID-2: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
uuid: A8EF-469B
ID-3: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb4 maj-min: 8:20 size: 79.88 GiB fs: ntfs label: MAIN_SSD
uuid: 5C828893828872F6
ID-5: /dev/sdb5 maj-min: 8:21 size: 331.05 GiB fs: ntfs label: DATA_GAMES
uuid: FC8038908038537E
ID-6: /dev/sdc2 maj-min: 8:34 size: 175.78 GiB fs: ext4 label: BACKUP
uuid: b2548556-eb55-44c4-bc73-91b7499dee60
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-8:3 info: SONiX USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 320f:500c class-ID: 0301
Device-2: 1-9:4 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 09da:9090 class-ID: 0301
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 2-1:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Texas Instruments PCM2902 Audio Codec type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-1:2 info: JMS578 based SATA bridge type: mass storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 8mA chip-ID: 0080:a001 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 27.0 C mobo: 25.0 C gpu: amdgpu temp: 31.0 C
mem: 38.0 C
Fan Speeds (rpm): fan-1: 631 fan-2: 497 fan-3: 0 fan-4: 812 fan-5: 0
fan-6: 0 gpu: amdgpu fan: 0
Processes: 365 Uptime: 27m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1529 libs: 465 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.2.21
running-in: konsole inxi: 3.3.31
I had installed Openai Whisper manually with Python, but since this update it doesn’t work anymore. In the end I gave up and removed it.
Also another application (Darkradiant → build from source, which uses Python for script functions) suddenly stopped working.
Edit: this might have been because of a previous update instead. Not sure. Sorry.
Both available from the AUR. Both reliant on Python. Did you rebuild/reinstall them after the update?
I didn’t install them via aur.
Openai whisper I installed via info here:
GitHub - openai/whisper: Robust Speech Recognition via Large-Scale Weak Supervision (I think, it’s a long time ago)
Darkradiant I’ve build from source:
https://wiki.thedarkmod.com/index.php?title=DarkRadiant_-_Compiling_in_Linux
I will probably try rebuilding DarkRadiant at least.
Edit: I got Whisper working again using an AUR package.
There has been a recent Python version bump. That, coupled with other recent changes, will probably mean some things need to be rebuilt no matter where they came from.
See Python 3.12 info in this same thread.
I am having issues with the Wynsdey update that I haven’t seen posted elsewhere.
- One of my two GPUs (AMD RV730 GL FirePro V3750) no longer drives video output even though it is detected by the OS.
- If I drop to a tty, then the monitors attached to the non-working GPU start working, and the other monitors attached to the other GPU freeze
- I’m also getting corrupted display issues. Like this is my cursor:
The update seems to have broken support for one of my GPUs and is causing corrupt graphics on my other GPU. I appreciate any guidance!
`$ inxi -bz`
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 46.2 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/27/2022
Info: 12-core AMD Ryzen 9 5900X [MT MCP] speed (MHz): avg: 2565
min/max: 2200/4950
Device-1: AMD RV730 GL [FirePro V3750] driver: radeon v: kernel
Device-2: AMD Cape Verde XT [Radeon HD 7770/8760 / R7 250X] driver: radeon
v: kernel
Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
Display: wayland server: X.Org v: 24.1 with: Xwayland v: 24.1.0
compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
dri: radeonsi,r600 gpu: radeon resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
driver: r8169
Local Storage: total: 51.87 TiB used: 10.23 TiB (19.7%)
Memory: total: 64 GiB note: est. available: 62.7 GiB used: 8.43 GiB (13.4%)
Processes: 606 Uptime: 2h 24m Shell: Zsh inxi: 3.3.34
sudo mhwd -l
> 0000:0b:00.0 (0300:1002:683d) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:07:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
> 0000:05:00.0 (0300:1002:949f) Display controller ATI Technologies Inc:
Edit: I’ve discovered some relevant log entries in journalctl:
gnome-shell:6746: GLib-CRICITAL **: g_close(fd:0) failed with EBADF. The tracking of file descriptors got messed up
grome-shell:6746: libmutterWARNING **: Failed to open gpu '/dev/dri/card0': No suitable mode setting backend found
/dev/dri/card1 works perfectly fine, that is the GPU that is working. Why is the other one failing? I still don’t know how to go about fixing this.
Hmm… I just got around to applying the stable updates from 2024-05-13 onwards, and having spent a good while following the guide to dealing with the latest system Python updgrade.
I’m not 100% sure, but I think it’s this latest (2024-05-29) update which includes Pipewire that has caused my problem. My laptop speakers work fine, but my wired headphones do not work at all. I’m using wireplumber as a session manager.
I think someone else had a similar problem with the first big update ([Stable Update] 2024-05-13 - Kernels, Plasma 6, Gnome 46, LxQT 2.0, Nvidia, Pacman - #259 by DrRevert) but the fix (involving ~/.config/wireplumber) is not relevant to me.
Since this update, after typing in my LUKS password at the initial prompt but before the diagnostic messages appear, I get this:
Keyfile could not be opened. Reverting to passphrase.
A password is required to access the luks-<id> volume:
Enter passphrase for /dev/nvme0n1p2:
I can then enter my LUKS password again and it continues booting. I suspect there’s something wrong with my mkinitcpio.conf. I’ve merged the .pacnew provided by this update, the resulting file is (sans comments):
MODULES=()
BINARIES=()
FILES=()
HOOKS=(base udev keyboard keymap autodetect modconf kms block consolefont encrypt openswap resume filesystems fsck)
(I tinkered with HOOKS a lot previously following some posts here in an attempt to get USB keyboards to work at the initial LUKS prompt, with no luck, hence the weird order).
OK, I think I fixed it: I went to pavucontrol and saw that the Built-in Audio profile was Analog Surround 4.0 Output + Analog Stereo Input (unavailable).
I changed that to Analog Stereo Output, which restored audio in my headphones
I also found Analog Stereo Duplex profile worked as well – indeed these were the only two profiles which weren’t marked (unavailable) in the drop-down menu.
Hope this helps someone else. I think this happened to me once before after an update as well, but I had trouble remembering this fix. I wish I could properly understand how audio on Linux works so that I don’t have to keep blindly playing around with the ornaments in order to fix a problem with a straightforward solution. One day maybe.
Hi I just updated my system from before the 2024-05-13 update where KDE updated to 6. I can’t comment on that thread anymore as it’s closed but it went somewhat okay, still trying to see what changed and what’s not working anymore.
I’m missing the kernel app. Before the update there was an app to check available kernels and install them. Where is that now? Also I think the drivers section is missing, where I could choose which driver I wanted to use (open source, vs proprietary) for my hardware.
Also the KDE plasma report that is pre-installed in the system tray produces the following error and not working:
file:///usr/share/plasma/plasmoids/org.kde.plasma.weather/contents/ui/main.qml:452:25: Type FullRepresentation unavailable
file:///usr/share/plasma/plasmoids/org.kde.plasma.weather/contents/ui/FullRepresentation.qml:38:24: Cannot assign object of type "QQC2.Action" to property of type "Action_QMLTYPE_93*" as the former is neither the same as the latter nor a sub-class of it.
EDIT: I found the kernel app, it’s no longer a standalone app that I can search and find in the launcher. Instead I had to go to the system tray >Manjaro settings manager and right click that to find the kernels. However the hardware/drivers app is still missing
Hello everyone, this is my first post here, please don’t through a lot of tomatoes. So, since the previous update I’m getting troubles with frozen screen, when nothing is active and only power button can help. It happens occasionally on different loads, sometimes during just laptop idling. The interesting part is that Caps Lock led starts blinking once the system got frozen. Please let me know what information is required to troubleshoot this issue.
Generated on 2024-06-06 13:07:1717664835
#################### inxi -Fxzc0 ########################
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required> UEFI: LENOVO v: GSCN33WW
date: 07/04/2022
ID-1: BAT0 charge: 71.9 Wh (100.0%) condition: 71.9/75.0 Wh (95.9%) volts: 17.1 min: 15.4
model: Celxpert L20C4PE1 status: full
Info: 8-core model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 516 high: 2256 min/max: 400/4680 cores: 1: 400 2: 400 3: 400 4: 400 5: 400
6: 400 7: 2256 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 105453
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo driver: nvidia v: 550.78
arch: Ampere bus-ID: 01:00.0
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu
v: kernel arch: GCN-5 bus-ID: 05:00.0 temp: 43.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB bus-ID: 3-4:5
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 compositor: kwin_wayland
driver: X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau dri: radeonsi gpu: nvidia,amdgpu
resolution: 1: 1920x1080 2: 2560x1600
API: EGL v: 1.5 drivers: kms_swrast,nvidia,radeonsi,swrast platforms:
active: gbm,wayland,x11,surfaceless,device inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.8-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir LLVM 17.0.6 DRM 3.54
6.6.32-1-MANJARO)
API: Vulkan v: 1.3.279 drivers: nvidia,radv surfaces: xcb,xlib,wayland devices: 2
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.7 status: off
Server-3: PulseAudio v: 17.0 status: active
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter vendor: Lenovo
driver: mt7921e v: kernel bus-ID: 03:00.0
IF: wlo1 state: down mac: <filter>
Device-2: ASIX AX88772B Fast Ethernet Controller driver: asix type: USB bus-ID: 1-2:2
IF: enp5s0f3u2 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-239fb1dc4855 state: down mac: <filter>
IF-ID-2: br-a736bda00cfd state: down mac: <filter>
IF-ID-3: br-b7a2e7bd3bab state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8 type: USB
bus-ID: 3-3:3
Local Storage: total: 476.94 GiB used: 341.6 GiB (71.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB temp: 36.9 C
ID-1: / size: 459.43 GiB used: 341.6 GiB (74.4%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
System Temperatures: cpu: 58.1 C mobo: 42.0 C gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): N/A
Memory: total: 28 GiB available: 27.26 GiB used: 6.05 GiB (22.2%)
Processes: 379 Uptime: 7m Init: systemd
Packages: 2086 Compilers: clang: 17.0.6 gcc: 14.1.1 Client: Unknown Client: krunner
inxi: 3.3.34
Hi @almond.cake, and welcome!
Please start a new thread and provide the necessary information so that we, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
These may only be coincidental; but, both within the last few days seems like it might be worth attracting some attention:
