Not sure where to post this. Feel free to move this to an appropriate location
The title is the error that I see every time I boot my laptop.
I used this iso at installation: manjaro-kde-24.0-240513-linux69.iso
Is this something that I can ignore or is it something that could eventually bite me?
An attempt to give some relevant system info. Let me know if I should provide more.
inxi -C -D ✔
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
cache: L2: 5 MiB
Speed (MHz): avg: 693 min/max: 400/4200 cores: 1: 400 2: 400 3: 1143
4: 400 5: 400 6: 1119 7: 789 8: 898
Local Storage: total: 931.51 GiB used: 99.81 GiB (10.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
lsblk ✔
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 931.5G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
├─nvme0n1p2 259:2 0 922.4G 0 part /
└─nvme0n1p3 259:3 0 8.8G 0 part [SWAP]
Perhaps logs might reveal something;
journalctl --boot=-1 --priority=3 --catalog --no-pager
I vaguely recall seeing a similar error mentioned in forums a few years ago, but I’m uncertain of the significance. It might be something similar to when a wrong memory range is accessed; but this is only a guess, at best.
Did you check it for errors after download?
I suspect you have chosen to use xfs filesystem - did you?
@linux-aarhus Yes I chose XFS, because I was running away from BTRFS.
EXT4 might be a better choice, do yo think?
I cannot say - I only discovered myself that Calamares and xfs appears to have issues - the swap partition will be misaligned - it should not have any impact when in use - not that I have seen - except for the annoying message.
If one were to dive further into the matter the Calamares dependency of kde partition manager is the likely culprit.
That said I am still not sure where the blame is rooted.
@soundofthunder `
journalctl --boot=-1 --priority=3 --catalog --no-pager ✔
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\CTDP], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._CRT.S1CT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._HOT.S1HT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._PSV.S1PT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN1._AC0.S1AT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._AC0 due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._CRT.S2CT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._HOT.S2HT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._PSV.S2PT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN2._AC0.S2AT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._AC0 due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._CRT.S3CT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._HOT.S3HT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN3._PSV.S3PT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN3._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._CRT.S4CT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._CRT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._HOT.S4HT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._HOT due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._PSV.S4PT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._PSV due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SEN4._AC0.S4AT], AE_NOT_FOUND (20230628/psargs-330)
Jun 03 21:25:27 henry-vivobookasuslaptopx515eax515ea kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN4._AC0 due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Jun 03 21:25:28 henry-vivobookasuslaptopx515eax515ea kernel: iwlwifi 0000:02:00.0: WRT: Invalid buffer destination
Jun 03 21:25:29 henry-vivobookasuslaptopx515eax515ea kernel: Bluetooth: hci0: No support for _PRR ACPI method
Jun 03 21:25:29 henry-vivobookasuslaptopx515eax515ea kernel: iwlwifi 0000:02:00.0: WRT: Invalid buffer destination
Jun 03 21:25:33 henry-vivobookasuslaptopx515eax515ea systemd[1095]: basic.target: Job paths.target/start deleted to break ordering cycle starting with basic.target/start
Jun 03 21:25:42 henry-vivobookasuslaptopx515eax515ea systemd[1162]: basic.target: Job paths.target/start deleted to break ordering cycle starting with basic.target/start
Jun 03 21:25:47 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: ENABLED CHANGEDD: true
Jun 03 21:25:47 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: MODE CHANGED: 1
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.kickoff
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.icontasks
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.systemmonitor.cpucore
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.systemmonitor.net
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.trash
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.marginsseparator
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.weatherWidget-3
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.showdesktop
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.systemtray
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: org.kde.plasma.digitalclock
Jun 03 21:25:49 henry-vivobookasuslaptopx515eax515ea plasmashell[1375]: qml: luisbocanegra.panel.colorizer
Jun 03 21:56:52 henry-vivobookasuslaptopx515eax515ea konsole[3465]: kf.newstuff.core: Could not determine type of archive file "/tmp/iBoPZn-Commonality.colorscheme"
Jun 04 09:13:55 henry-vivobookasuslaptopx515eax515ea kernel: iwlwifi 0000:02:00.0: WRT: Invalid buffer destination
Jun 04 09:13:55 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event6 - Asus WMI hotkeys: client bug: event processing lagging behind by 460ms, your system is too slow
Jun 04 09:13:55 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event0 - Lid Switch: client bug: event processing lagging behind by 319ms, your system is too slow
Jun 04 09:13:55 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event1 - Power Button: client bug: event processing lagging behind by 283ms, your system is too slow
Jun 04 09:13:55 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event2 - Power Button: client bug: event processing lagging behind by 283ms, your system is too slow
Jun 04 11:09:32 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event8 - ELAN1200:00 04F3:309F Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.25.0/touchpad-jumping-cursors.html for details
Jun 04 16:30:05 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event8 - ELAN1200:00 04F3:309F Touchpad: kernel bug: Touch jump detected and discarded.
Jun 04 16:40:00 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event8 - ELAN1200:00 04F3:309F Touchpad: kernel bug: Touch jump detected and discarded.
Jun 04 16:58:24 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event8 - ELAN1200:00 04F3:309F Touchpad: kernel bug: Touch jump detected and discarded.
Jun 04 17:00:34 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event8 - ELAN1200:00 04F3:309F Touchpad: kernel bug: Touch jump detected and discarded.
Jun 04 17:00:34 henry-vivobookasuslaptopx515eax515ea kwin_wayland[1205]: kwin_libinput: Libinput: event8 - ELAN1200:00 04F3:309F Touchpad: WARNING: log rate limit exceeded (5 msgs per 24h). Discarding future messages.
Jun 04 20:16:50 henry-vivobookasuslaptopx515eax515ea kernel: iwlwifi 0000:02:00.0: WRT: Invalid buffer destination
Jun 05 10:04:53 henry-vivobookasuslaptopx515eax515ea kernel: iwlwifi 0000:02:00.0: WRT: Invalid buffer destination
Jun 05 10:05:22 henry-vivobookasuslaptopx515eax515ea dbus-broker-launch[584]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jun 05 10:05:22 henry-vivobookasuslaptopx515eax515ea dbus-broker-launch[1191]: Activation request for 'org.kde.ksystemstats1' failed.
Jun 05 10:05:22 henry-vivobookasuslaptopx515eax515ea dbus-broker-launch[584]: Activation request for 'org.freedesktop.hostname1' failed.
Jun 05 10:05:23 henry-vivobookasuslaptopx515eax515ea kernel: iwlwifi 0000:02:00.0: WRT: Invalid buffer destination
Jun 05 10:05:23 henry-vivobookasuslaptopx515eax515ea dbus-broker-launch[584]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jun 05 10:05:23 henry-vivobookasuslaptopx515eax515ea kernel: watchdog: watchdog0: watchdog did not stop!
Jfrost:
Yes I chose XFS
You might benefit from a BIOS update and/or a different kernel. Whether or not that will change anything remains to be seen.
Could you also post the full command output of:
inxi --admin --verbosity=8 --filter --no-host --width
Here it is:
inxi --admin --verbosity=8 --filter --no-host --width ✔
Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=b1db5da2-9fe0-4f5a-b9f5-af77434d9dfa rw quiet splash
resume=UUID=6f075f41-82dd-429a-a1ed-ef4f52a8a608 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515EA_X515EA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X515EA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: X515EA.309
date: 05/16/2022
ID-1: BAT0 charge: 28.4 Wh (79.8%) condition: 35.6/37.1 Wh (96.0%) volts: 7.8
min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 35
System RAM: total: 16 GiB available: 15.32 GiB used: 3.15 GiB (20.5%)
Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A1G44AB0-CWE
serial: N/A
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Crucial Technology
part-no: CT8G4SFS832A.M8FR serial: <filter>
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 850 high: 1287 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 688 3: 1149 4: 1210
5: 400 6: 400 7: 1287 8: 1266 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 322e:2103
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1670x939 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.8-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.96 GiB unified: yes display-ID: :1.0
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel bus-ID: 0000:02:00.0 chip-ID: 8086:2725 class-ID: 0280
IP v4: <filter> type: dynamic scope: global broadcast: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0032
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 99.61 GiB (10.7%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 921.97 GiB (99.95%)
used: 99.61 GiB (10.8%) fs: xfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: b1db5da2-9fe0-4f5a-b9f5-af77434d9dfa
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1293-6A98
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 6f075f41-82dd-429a-a1ed-ef4f52a8a608
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Sonix USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 322e:2103 class-ID: 0e02
Device-2: 1-10:3 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
System Temperatures: cpu: 42.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2400
Packages: pm: pacman pkgs: 1415 libs: 303 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
2: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
5: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://muug.ca/mirror/manjaro/stable/$repo/$arch
8: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 270
1: cpu: 26.7% command: firefox pid: 2330 mem: 422.4 MiB (2.6%)
2: cpu: 15.4% command: firefox pid: 2657 mem: 307.4 MiB (1.9%)
3: cpu: 7.3% command: firefox pid: 2524 mem: 231.6 MiB (1.4%)
4: cpu: 7.0% command: konsole pid: 3002 mem: 119.1 MiB (0.7%)
5: cpu: 5.7% command: plasmashell pid: 1396 mem: 366.3 MiB (2.3%)
Memory top: 5 of 270
1: mem: 422.4 MiB (2.6%) command: firefox pid: 2330 cpu: 26.7%
2: mem: 366.3 MiB (2.3%) command: plasmashell pid: 1396 cpu: 5.7%
3: mem: 307.4 MiB (1.9%) command: firefox pid: 2657 cpu: 15.4%
4: mem: 235.5 MiB (1.5%) command: kwin_wayland pid: 1233 cpu: 3.2%
5: mem: 231.6 MiB (1.4%) command: firefox pid: 2524 cpu: 7.3%
Processes: 270 Power: uptime: 15m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.12 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
Maybe when a new iso is released, I can try Ext4.
It’s also possible that your machine is just too new and Linux (generally) hasn’t caught up yet; though, that’s only a guess. You have the latest kernel, so that’s good. Otherwise, nothing really jumps out screaming that there’s any problem with the system; apart from the repeating ACPI BIOS Error
which I don’t know specifically how to diagnose.
EXT4 is generally a safe choice; it’s the most widely supported filesystem.
I tend to think that also. When I was shopping for a new laptop, I originally had selected a 12th gen intel machine, got this 11th gen laptop at a discount because where I bought it, they couldn’t locate the box it came with, and it was the only one in the store. After I bought it, I began to read how people were experiencing difficulties with intel’s 12th gen machines.
I am somewhat ambivalent about Ext4 because I have experienced bitrot with ext4. So finally, I’ll stay with Xfs and keep fingers, toes and feet crossed.
Looking at the error, it tells me that the attempt to read or write outside of a partition was detected and stopped. Will that continue to be stopped in the future? Time will tell.
