Hello Manjaro Members, I’m a new user of Manjaro Plasma Desktop and got stuck on an error. I allocated 307.6 GB disk partition to Manjora OS (I’m using Windows on the other side). After a few days of setup, Instead of allocating 307 GB combined for both root and home partition, I thought of giving 128 GB to root and the remaining part to home partition. I did the partition using konsole,
cfdisk /dev/nvme0n1
After writing the partition to the disk, suddenly the screen became black. Then I rebooted my laptop. The screen shows,
Enter passphrase for hd1,gpt6 (6c5cdc30-9889-40ef-8ce7-c36f352131be):
In the beginning of installation of Manjaro, I set up a encrypt password for this os. And the above asked passphrase is usual. If I enter the passphrase correctly, it’ll decrypt the master key and shows the lock screen. But now it shows this error:
Attempting to decrypt the master key…
Slot 0 opened
error: attempt to read or write outside of disk ‘cryptouuid/6c5cdc30988940ef8ce7c36f352131be’.
Entering rescue mode…
grub rescue> _
To resolve this error, I referred some articles and videos. Then I tried this,
grub rescue> Is
(crypto0) (proc) (hd0) (hd0, gpt1) (hd1) (hd1, gpt7) (hd1, gpt6) (hd1, gpt5) (hd1, gpt4) (hd1, gpt3) (hd1, gpt2) (hd1, gpt1)
grub rescue> Is (crypto0)
(crypto0): Filesystem is ext2.
grub rescue> set boot-(crypto0)
grub rescue> set prefix=(crypto0) /boot/grub
grub rescue> insmod normal
error: file /x86_64-efi/normal. mod’ not found.
If I type “insmod normal” there, I get
““error: file ‘x86_64-efi/normal.mod’ not found.””
I don’t know if I successfully wrote the partition, it suddenly became black and I rebooted then. I backed up all my data before partitioning the disk. What to do now? Someone kindly help me to overcome this error on startup. Thanks in advance .
