After a system hang and reboot, manjaro does not load further /dev/sda1 clean files blocks. I tried different solutions on the forums, but I realized that each solution is different and I can’t find a clear answer. Live system on a flash drive and Windows on the second disk are loaded, ctrl+alt+f2 works too but Manjaro is not. I installed the system not long ago and since then it has worked stably. Please write what information to provide you because I am a noob.
My laptop Acer Aspire V Nitro (VN7-571G-573Q) i5-5200U GeForce GTX 950M
Output from journalctl --boot=-1 --priority=3
Oct 31 13:38:23 maksimo systemd-modules-load[235]: Failed to find module 'vmmon'
Oct 31 13:38:25 maksimo kernel: nouveau 0000:04:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ PRIVRING ]
Oct 31 13:38:26 maksimo sddm[360]: Failed to read display number from pipe
Oct 31 13:38:28 maksimo sddm[360]: Failed to read display number from pipe
Oct 31 13:38:30 maksimo sddm[360]: Failed to read display number from pipe
Oct 31 13:38:30 maksimo sddm[360]: Could not start Display server on vt 1
Oct 31 14:14:11 maksimo login[694]: pam_systemd(login:session): Failed to release session: Interrupted system call
Oct 31 14:14:13 maksimo kernel: watchdog: watchdog0: watchdog did not stop!
Output from journalctl --boot=-3 --priority=4
Oct 30 23:38:37 maksimo kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org
/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 30 23:38:37 maksimo kernel: #3
Oct 30 23:38:37 maksimo kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 30 23:38:37 maksimo kernel: pci 0000:00:14.0: can't derive routing for PCI INT A
Oct 30 23:38:37 maksimo kernel: pci 0000:00:14.0: PCI INT A: no GSI
Oct 30 23:38:37 maksimo kernel: ata2.00: ATA Identify Device Log not supported
Oct 30 23:38:37 maksimo kernel: xhci_hcd 0000:00:14.0: can't derive routing for PCI INT A
Oct 30 23:38:37 maksimo kernel: xhci_hcd 0000:00:14.0: PCI INT A: no GSI
Oct 30 23:38:37 maksimo kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect pleas
e boot with i8042.nopnp
Oct 30 23:38:37 maksimo systemd-modules-load[226]: Failed to find module 'vmmon'
Oct 30 23:38:38 maksimo kernel: wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
Oct 30 23:38:38 maksimo kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (firs
t instance was on PNP0C14:00)
Oct 30 23:38:38 maksimo kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
Oct 30 23:38:39 maksimo kernel: ACPI Warning: \_SB.PCI0.RP05.PXSX._DSM: Argument #4 type mismatch - Found [Buf
fer], ACPI requires [Package] (20210730/nsarguments-61)
Oct 30 23:38:39 maksimo kernel: at24 1-0050: supply vcc not found, using dummy regulator
Oct 30 23:38:39 maksimo kernel: iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
Oct 30 23:38:39 maksimo systemd[418]: ConfigurationDirectory 'bluetooth' already exists but the mode is differ
ent. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 30 23:38:39 maksimo kernel: nouveau 0000:04:00.0: bus: MMIO read of 00000000 FAULT at 022554 [ PRIVRING ]
Oct 30 23:38:39 maksimo kernel: thermal thermal_zone3: failed to read out thermal zone (-61)
Oct 30 23:38:40 maksimo kernel: kauditd_printk_skb: 20 callbacks suppressed
Oct 30 23:38:40 maksimo sddm[350]: Failed to read display number from pipe
Oct 30 23:38:40 maksimo sddm[350]: Attempt 1 starting the Display server on vt 1 failed
Oct 30 23:38:42 maksimo sddm[350]: Failed to read display number from pipe
Oct 30 23:38:42 maksimo sddm[350]: Attempt 2 starting the Display server on vt 1 failed
Oct 30 23:38:44 maksimo sddm[350]: Failed to read display number from pipe
Oct 30 23:38:44 maksimo sddm[350]: Attempt 3 starting the Display server on vt 1 failed
Oct 30 23:38:44 maksimo sddm[350]: Could not start Display server on vt 1
Oct 30 23:38:53 maksimo sddm[350]: Signal received: SIGTERM
Oct 30 23:38:53 maksimo kernel: kauditd_printk_skb: 15 callbacks suppressed
My system:
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2137 quiet systemd.show_status=1
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire VN7-571G v: V1.14
serial: <superuser required>
Mobo: Acer model: Aspire VN7-571G v: V1.14 serial: <superuser required>
UEFI-[Legacy]: Insyde v: 1.14 date: 01/08/2015
ID-1: BAT0 charge: 37.8 Wh (100.0%) condition: 37.8/52.5 Wh (72.0%)
volts: 12.5 min: 11.4 model: LGC AC14A8L type: Li-ion serial: <filter>
status: not charging
RAM: total: 7.68 GiB used: 2.2 GiB (28.6%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1142 high: 1397 min/max: 500/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1397 2: 798 3: 1037
4: 1339 bogomips: 17566
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: Acer Incorporated ALI
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-07)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 04:00.0 chip-ID: 10de:139a class-ID: 0302
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-1.7:4
chip-ID: 04f2:b469 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x046f built: 2014 res: 1920x1080
hz: 60 dpi: 141 gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Acer
Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2725
class-ID: 0280
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.5:6 chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 941.99 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 66C5 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000LPVX-22V0TT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Transcend
model: JetFlash 32GB size: 29.1 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 447.13 GiB fs: ext4 label: N/A
uuid: 49e86a43-cef9-4855-a4df-c69354930c10
ID-2: /dev/sdb1 maj-min: 8:17 size: 50 MiB fs: ntfs
label: System-reserviert uuid: F62A6FC72A6F8389
ID-3: /dev/sdb2 maj-min: 8:18 size: 465.71 GiB fs: ntfs label: N/A
uuid: 10B870D9B870BEB2
ID-4: /dev/sdc1 maj-min: 8:33 size: 3.32 GiB fs: iso9660
ID-5: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Device-1: 1-1.5:6 info: Intel AX210 Bluetooth type: Bluetooth
Device-2: 1-1.7:4 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b469
class-ID: 0e02
Device-3: 1-1.8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-1:2 info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical
mouse [More&Better] type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 2-2:3 info: Transcend Information JetFlash type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 8564:1000 class-ID: 0806 serial: <filter>
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C pch: 41.5 C mobo: N/A gpu: nouveau
temp: 38.0 C
Processes: 199 Uptime: 4m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1209
lib: 318 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
