[HowTo] Updating Manjaro as safely as possible
The golden rule — which nobody follows, of course — when using a rolling-release distribution…:
  • Always apply the bundled updates by way of the command line in a tty while completely logged out of your graphical environment, so that no shared libraries will be in use that will be overwritten by the update process. The safest way even would be to cleanly reboot your system first before applying any updates, and to then switch to a tty and run the update process from there without logging into your graphical interface at all.
Then, there are two additional golden rules specific to all Arch-based distributions…:
  • Always update the packages from the official repositories first, and update the AUR stuff, the Snaps, the FlatPaks and the AppImages afterwards.
  • Never interrupt the update process. You can interrupt the download of the packages — for instance if your mirror is too slow and you want to run pacman-mirrors first in order to switch to a faster mirror — but once the actual updating has begun and the downloaded packages have begun replacing the installed ones, you have to let it finish, or else you will render your system unbootable.
And lastly, the golden rule that applies to all distributions…:
  • Thou shalt make backups on another storage medium than the one thine system is installed on. (Note: timeshift snapshots on btrfs are not backups! If your drive fails, then you still lose everything.)
Gollum_Backupses
Updating Manjaro as safely as possible / logging out?
I just Timeshiftereded back becauseafter update restart no internet
I updated my system and it broke it
I cannot update my apps
"The Screen locker is broken..." After last updates (13/10/2023)
Software Updates
Plasma Application Launcher Empty (Unstable)
Can't boot after update, can't boot live USB either
"Remote Peer Disconnected" error when trying to open Add/Remove Software
[Stable Update] 2024-10-01 - Kernels, Plasma 6.1.5, KDE Gear 24.08.1, LibreOffice, Virtualbox 7.1
[Stable Update] 2025-05-04 - Kernels, GNOME 48.1, NVIDIA, KDE Gear, KDE Frameworks, LXQt
[Stable Update] 2024-05-13 - Kernels, Plasma 6, Gnome 46, LxQT 2.0, Nvidia, Pacman
[Stable Update] 2025-05-14 - Kernels, Firefox, Thunderbird, Mesa, Plasma, LibreOffice, QEMU
CheckAURVCSUpdates
Error en cambio de sesión y ejecución de programas
Can I remove all partitions?
Apps are closing
Confusion about manjaro-pacnew-checker
Blue Screen Of Death on freshly-installed system
What's the best resource for being up to date with infrastructural Manjaro changes?
Konsole and Kate crashes when typing
Blackscreen after update all packages and install pulseaudio
OBS Studio Black Screen at recording games with obs-vkcapture
Manjaro looks strange after last stable update
Firefox crashes during each upgrade
Manjaro 23.02 on Orange Pi 800 won't boot after update
Plasma 6 looks awful
No desktop fresh install
Suggestion: make it harder to do a full system update using the GUI
Improving pamac
732 available updates cannot update system
[Stable Update] 2025-07-18 - Kernels, UMU, KDE Frameworks, NetworkManager
I would like to install version LibreOffice 24.2.4
For me manjaro became unuseble
File conflict errors related to Python 3.12
Problems installing moc-pulse AUR package
Crash - help me isolate the issue with journalctl
Problem updating repository and packages
I can't connect to wifi because of a problem in the Network driver
Ich suche eine Virtuelle Maschine die unter einen neueren Lts Kernel läuft
Sleep function missing
Don't seem to be able to update anymore?
General Question About Updates
Display returning irregular (or not at all) after screen turns off
[Stable Update] 2025-04-12 - Kernels, Plasma, Systemd, Mesa, Grub, Wine
Another Failed Update
Dysfunctional Pamac
New linux user : manjaro doesn't recognize my partitions for installing
Update 2025-06-23 Breaks the Display of my Laptop's GUI when Invoked from Pamac, Works with Pacman
Add/remove software closes during every update now
System not starting: You need to load the kernel first
Make initramfs fallback safe from automatic deletion?
New to Manjaro: Questions about updating the system
[INFO] Stable branch - BIG update BEST practice
[Stable Update] 2026-02-01 - Kernels, COSMIC, Plasma, GNOME, Mesa
System not booting after running out of space during update
Pamac CLI terminated during update... update continued in backend
Need guidance about update and problems after. (picom, polkit, replace kernel?)
Update resulted in kwin-wayland loads CPU, baloo loads ram
System froze during kernel update, now not booting
Cannot update due to dependency issues
[Stable Update] 2025-07-12 - Kernels, Systemd, GNOME, NVIDIA, Plasma, Firefox, VLC splits
How long can we delay this update, before the next stable release update will show the light?
Gthumb crash after update
