[Stable Update] 2023-12-10 - Kernels, Plasma, Phosh, Systemd, Cinnamon, Gnome, libpamac
Hello community,
Another stable branch update with some usual package updates for you.
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Previous News
Notable Package Updates:
  • Most Kernels got updated
    • zfs got updated to 2.2.2 to fix some potential data corruption issues
  • KDE Plasma 5.27.10
  • Phosh 0.34.0
  • tuxclocker is at 1.4.0
  • gamescope-plus got updated to 3.13.16-plus1
  • Systemd is now at 254.7
  • Cinnamon got updated to 6.0
  • GNOME 45.2
  • libpamac fixed the offline updates in 11.6.3
  • issues starting blender 4.0.1 are now fixed
  • Firefox is at 120.0.1 and Thunderbird is at 115.5.1
  • LibreOffice got updated to 7.6.3
  • Maui got renewed to 3.0.2
  • LibreOffice got updated to 7.6.4 and 7.5.9
  • Usual KDE-git, Haskell and Python updates
Additional Info
Info about AUR packages
Our current supported kernels
  • linux419 4.19.301
  • linux54 5.4.263
  • linux510 5.10.203
  • linux515 5.15.142
  • linux61 6.1.66
  • linux65 6.5.13 [EOL]
  • linux66 6.6.5
  • linux67 6.7-rc4
  • linux61-rt 6.1.64_rt17
  • linux65-rt 6.5.2_rt8
  • linux66-rt 6.6.0_rt15
Package Changes (Fri Dec 8 15:26:29 CET 2023)
  • stable core x86_64: 41 new and 41 removed package(s)
  • stable extra x86_64: 2096 new and 2063 removed package(s)
  • stable kde-unstable x86_64: 289 new and 288 removed package(s)
  • stable multilib x86_64: 10 new and 10 removed package(s)
A list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2023-12-10
Broken Wifi with 6.1.66 and 6.6.5 kernels
Some users report broken Wifi driver support with the latest 6.x kernel series, mostly based on Realtek drivers, either from the AUR or provided by the kernels itself. It is also reported that linux515 and linux67 kernel series don’t have those issues. So if you have a potential Wifi driver problem, consider to install those kernels before updating your system. Older kernels can be found here:
Possible issues reported upstream
The Author of the original patch Johannes Berg had reviewed Léo Lam’s patch by now. So everybody who had tested 6.6.5-3 or 6.1.66-2 should reply to the upstream mailing list with a Tested-by tag as described here: [Stable Update] 2023-12-10 - Kernels, Plasma, Phosh, Systemd, Cinnamon, Gnome, libpamac - #95 by philm
2023-12-01
  • IMPORTANT → Linux 6.5 is EOL
    Linux 6.5 is EOL and will be removed from the repo.
    If you use Linux 6.5 and Nvidia or as virtual machine, it is of great importance, that you install Linux 6.6 to avoid driver problems.
    sudo mhwd-kernel -i linux66
2023-11-28
Blender 4.0 may fail on AMD GPUs
The current native ALPM package of Blender provided by our mirrors may fail with AMD GPUs. As an alternative you may want to use Blender-Bin from the AUR, flatpak version, snap version or load it directly from Blender. More infos here: 17:4.0.1-2 Segfault on start (#2) · Issues · Arch Linux / Packaging / Packages / blender · GitLab
2023-11-21
mkinitcpio needs base hook
With the update of mkinitcpio 37 make sure you have the base hook in your /etc/mkinitcpio.conf file, unless you use systemd hook instead. See also wiki for all hook documentation.
2023-11-13
Changes in JDK / JRE 21 packages may require manual intervention
2023-11-02 - Frederik Schwan
We are introducing a change in JDK/JRE packages of our distro. This is triggered from the way a JRE is build in modern versions of Java (>9). We are introducing this change in Java 21.
To sum it up instead of having JDK and JRE packages coexist in the same system we will be making them conflict. The JDK variant package includes the runtime environment to execute Java applications so if one needs compilation and runtime of Java they need only the JDK package in the future. If, on the other hand, they need just runtime of Java then JRE (or jre-headless) will work.
This will (potentially) require a manual user action during upgrade:
  • If you have both JDK and JRE installed you can manually install the JDK with pacman -Sy jdk-openjdk && pacman -Su and this removes the JRE related packages.
  • If you have both JRE and JRE-headless you will need to choose one of them and install it manually since they would conflict each other now.
  • If you only have one of the JDK/JRE/JRE-headless pacman should resolve dependencies normally and no action is needed.
At the moment this is only valid for the upcoming JDK 21 release.
Arch Linux - News: Incoming changes in JDK / JRE 21 packages may require manual intervention
2023-11-06
Powerdevil fails in KDE Plasma
In KDE Plasma, Powerdevil fails and energy settings (Power save v Normal v Performance) are unavailable. See:
Powerdevil fails, Energy settings unavailable
Restarting gnome-shell using Alt+F2 and entering R, causes a crash
FS#79884 : [gnome-shell] Restarting gnome-shell using Alt+F2 and entering R, causes a crash
GNOME Extensions that target older GNOME versions will not work in GNOME 45
It is recommended to remove all third-party extensions before updating, then install the compatible versions after updating and rebooting. All Most extensions in the Manjaro repos are already updated.
kpeoplevcard update requires manual intervention
A “newer” version of kpeoplevcard accidently existed, so to install the current version, either update with sudo pacman -Syu kpeoplevcard or sudo pacman -Syuu.
2023-10-09
glibc-locales update requires manual intervention
If you had the old glibc-locales package from the extra repo installed, the update to the new core package will need manual intervention:
 sudo pacman -Syu glibc-locales --overwrite /usr/lib/locale/\*/\*
2023-10-04
Changes to default password hashing algorithm and umask settings
2023-09-22 - David Runge
With shadow >= 4.14.0, Arch Linux’s default password hashing algorithm changed from SHA512 to yescrypt [1].
Furthermore, the umask [2] settings are now configured in /etc/login.defs instead of /etc/profile.
This should not require any manual intervention.
Reasons for Yescrypt
The password-based key derivation function (KDF) and password hashing scheme yescrypt has been chosen due to its adoption (readily available in libxcrypt, which is used by pam [3]) and its stronger resilience towards password cracking attempts over SHA512.
Although the winner of the Password Hashing Competition [4] has been argon2, this even more resilient algorithm is not yet available in libxcrypt [5][6].
Configuring yescrypt
The YESCRYPT_COST_FACTOR setting in /etc/login.defs is currently without effect, until pam implements reading its value [7]. If a YESCRYPT_COST_FACTOR higher (or lower) than the default (5) is needed, it can be set using the rounds option of the pam_unix [8] module (i.e. in /etc/pam.d/system-auth).
General list of changes
  • yescrypt is used as default password hashing algorithm, instead of SHA512
  • pam honors the chosen ENCRYPT_METHOD in /etc/login.defs and does not override the chosen method anymore
  • changes in the filesystem (>= 2023.09.18) and pambase (>= 20230918) packages ensure, that umask is set centrally in /etc/login.defs instead of /etc/profile
[1] yescrypt - scalable KDF and password hashing scheme
[2] umask(1p) — Arch manual pages
[3] PAM - ArchWiki
[4] https://www.password-hashing.net/
[5] https://github.com/besser82/libxcrypt/pull/113
[6] Add support for Argon2 by maandree · Pull Request #150 · besser82/libxcrypt · GitHub
[7] pam_unix: Support reading YESCRYPT_COST_FACTOR from /etc/login.defs · Issue #607 · linux-pam/linux-pam · GitHub
[8] pam_unix(8) — Arch manual pages
Arch Linux - News: Changes to default password hashing algorithm and umask settings
2023-09-18
filesystem and bashrc-manjaro pacnews
With the filesystem 2023.09.03-1 and bashrc-manjaro 5.1.016-3 updates there may be pacnews for the following files if you have local modifications:
  • /etc/shells
  • /etc/bash.bashrc
This would be a good time to test @Ste74’s new manjaro-pacnew-checker program. See Check and manage pacnew files for more info.
updates for linux515-r8168 and linux61-6168 drivers fail to load r8168 driver
See this post for how to revert to using r8168 driver or install r8168-dkms driver from AUR
Problem with 6.5 kernel and-r8168 module
R8168 driver not loaded on kernel 6.5 after testing update 2023-09-22
All 3 versions of network-r8168 drivers are working again following [Testing Update] 2023-09-27
  • linux65-r8168 8.051.02-7
  • linux61-r8168 8.051.02-5
  • linux515-r8168 8.051.02-4
2023-09-10
LLVM 16 update may break 3rd party MESA drivers
Mesa drivers are affected when there is no matching LLVM version they are complied on. If you use a 3rd party repo like mesanonfree you may want to install llvm15-libs until those get recompiled. See for releases: Releases · mesa-freeworld/mesa-nonfree · GitHub
2023-08-11
Avoid black screen on Ryzen 7 / ThreadRipper / RX7xxx - perhaps others as well
You may be able to avoid black screen if you - prior to rebooting after the update - sync the latest stable kernel - currently - linux64 or linux65 - any of those solves the issue.
sudo mhwd-kernel -i linux65
budgie-desktop >= 10.7.2-6 update requires manual intervention
When upgrading from budgie-desktop 10.7.2-5 to 10.7.2-6, the package mutter43 must be replaced with magpie-wm, which currently depends on mutter. As mutter43 conflicts with mutter, manual intervention is required to complete the upgrade.
First remove mutter43, then immediately perform the upgrade. Do not relog or reboot between these steps.
pacman -Rdd mutter43
pacman -Syu
Manjaro-hello does not start after update
Known issue: "Manjaro Hello" does not start after Update
rm -f ~/.config/autostart/manjaro-hello.desktop
Multiple sink outputs shown in KDE audio controls
Known issue: Bluetooth headset showing multiple entries in KDE after update
2023-07-17
A bug in KDE Frameworks can delete targets of symlinks.
More info here.
Steam cashes on startup with lib32-libgudev installed
The latest lib32-libgudev update does not cooperate with the version of the same package provided by steam, and steam seems to attempt making calls to both leading to the crash.
Details: bug report, arch task, arch forum thread.
  • Workaround #1 (causes steam to avoid making any calls to lib32-libgudev by using a different library altogether)
    • sudo pacman -S lib32-libnm
  • Workaround #2 (forces steam and any other application to always use the new lib32-libgudev)
    • sudo pacman -S lib32-libudev0-shim
  • Workaround #3 (use steam-native-runtime, which doesn’t have the issue)
    • sudo pacman -S steam-native-runtime
2023-07-10
libpamac 11.5.5-1 breaks update function
We are currently working on fixing a reported security vulnerability which gave you root access via pamac-daemon. During that process we broke the update functionality. Hence use sudo pacman -Syu to update to the latest libpamac release (11.5.7-2)
The community repository has been merged into extra and is now empty
The Arch git migration is now complete .
The [community] repository has been merged into [extra] and is now empty.
It may take a bit of time for mirrors to catch up (more details here).
Update your system and handle the pacman
sudo pacman -Syu "pacman>=6.0.2-11"
In order to remove the defunct [community] repo changes must be made to /etc/pacman.conf.
Changes will be provided in a file with the extension .pacnew.
Pacman provides the utility pacdiff to manage these files and will use vim -d for comparison if the environment variable DIFFPROG is not set.
pacdiff -s
If you would like to use a different comparison tool you may prepend the env var:
DIFFPROG=meld pacdiff -s
Then sync with the repositories again:
sudo pacman -Syu
And you can also remove the now unused repository.
sudo pacman -Sc
NOTE: Be aware that this last command will also remove all packages in the pacman cache that are not currently installed: in other words, backup copies of packages that you have uninstalled at some point will no longer be stored on your hard drive.
In most cases, this probably will not cause headaches. To prevent even minor aches and pains, see the Arch Wiki for information on cleaning the cache
Steam fails to launch
A while ago the Steam Runtime developer maintaining the library detection/promotion “greatly encouraged” that the Steam package would (opt)depends on lib32-libnm and friends. The bugs have been opened since alas
In the absence of an updated steam package with updated dependencies,
A workaround is to install lib32-libnm
sudo pacman -Syu lib32-libnm
Steam will not launch - #12 by cscs
FS#79006 : [lib32-libgudev] Recent Update broke steam
Steam crashes at launch with libgudev 238 · Issue #9805 · ValveSoftware/steam-for-linux · GitHub
OpenBLAS >= 0.3.23-2 update requires manual intervention
2023-06-14 - Felix Yan
The openblas package prior to version 0.3.23-2 doesn’t ship optimized LAPACK routine and CBLAS/LAPACKE interfaces for compatibility. This decision has been reverted now, and the ability to choose a different default system BLAS/LAPACK implementation while keeping openblas installed is now provided to allow future co-installation of BLIS, ATLAS, etc.
The default BLAS implementation will be used for most packages like NumPy or R. Please install blas-openblas and blas64-openblas to make OpenBLAS the default BLAS implementation, just like the old behavior.
Unfortunately you will get errors on updating if you currently have OpenBLAS installed as the default BLAS implementation:
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by cblas
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by lapack
Please append your preferred default BLAS implementation to the regular -Syu command line to get around it. For example:
sudo pacman -Syu blas-openblas
or
Arch Linux - News: OpenBLAS >= 0.3.23-2 update requires manual intervention
TeX Live package reorganization
2023-06-18 - Antonio Rojas
Starting from version 2023.66594-9, TeX Live packages have been reorganized to mirror upstream collections. Even though the new texlive-basic replaces the old texlive-core, many of the texlive-core contents (including language specific files) are now split between different packages. To find out which Arch package contains a specific CTAN package, you can use the tlmgr utility, eg.
$ tlmgr info euler | grep collection
collection:  collection-latexrecommended
which means the euler CTAN package is contained in texlive-latexrecommended. You may also use pacman -F to query for specific files.
A new metapackage texlive-meta is available to install all subpackages (except for language specific ones), and the new texlive-doc package provides the full documentation for offline use.
Arch Linux - News: TeX Live package reorganization
Pamac GUI theme does not match system theme
pamac-gtk 11.0.1 uses Gtk 4 that is not supported on Xfce or Cinnamon
user can replace pamac-gtk with pamac-gtk3
sudo pacman -S pamac-gtk3
Black screen after login with SDDM 0.20
Check ~/.profile for any commands that don’t execute properly (but return non-zero exit code instead). May include ~/.bash_profile and .zprofile too. Downgrading to SDDM 0.19 also restores desktop after login.
The issue has been reported upstream.
2023-06-04
DKMS is currently broken as our kernels got compiled against an older gcc
Since the last stable update provided an older toolchain our kernels and binaries got compiled against GCC 12.2.0-1. A similar issue was already posted at Arch years ago: [SOLVED] Kernel 5.5.2 is built with the wrong version of gcc / [testing] Repo Forum / Arch Linux Forums. Therefore users of DKMS have to wait for kernel updates compiled against the new toolchain or downgrade to the older one.
Update (2023-06-05): We pushed a rebuild of all regular kernels against the new toolchain to all branches. Real-Time Kernels we still have to check.
Many applications (firefox, thunderbird, telegram, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
If you have a lot of pip/AUR packages to upgrade to Python 3.11, read this.
If you installed python311 from the AUR, you need to uninstall it before running this update.
i had a strange behaviour. i used the graphical package manager for updating. at finishing the update the update manager became unresponsive as if it was crashed. this took about 2 minutes but the update finished and announced that a reboot is needed.
if anyone else has this behaviour, keep it running even if you think that the update-manager has crashed. strange behaviour but the update ended succesful.
p.s.: (as @Kobold ) demanded. i’m running plasma,x11-session
The issue might be due to the libpamac update. You might have this error message when you do it via the command line:
libpamac 11.6.3 changed dbus api, maybe an old pamac-daemon instance should run after upgrade
possible but hard to say after it is still in the past. if you think that it is better to use the console for this update then please do a notification to other users with a short description how to update (especially for all the new linux-users). that safes a lot of discussions for broken updates… better safe than sorry.
Why @philm, a photo instead of a screenshot or — better yet — copying and pasting the text? You’re worse than the newbies. :stuck_out_tongue_closed_eyes:
:rofl:
I updated with pacman just to be sure, indeed, the demon gets closed in the update proces and has to be restarted or just reboot.
I voted no issue but there was actually something small
installing dotnet-runtime (8.0.0.sdk100-3) breaks dependency 'dotnet-runtime-7.0' required by pinta
So i removed pinta, updated and then reinstalled it. She pulled the now separate package dotnet7, now i have both dotnet8 as orphan and 7 just for pinta.
I just updated with PC/Laptop both on KDE and using the GUI version, no errors in logs while updating and also both had no freezes at all.
So everything was fine there, atleast for me and two of my systems.
You missed the info about the EXT4 data corruption issue.
Hi,
I’ve got a little UI freeze too with a reload of it on GNOME during this last upadte. Only the mouse pointer was responding perfectly. It last only few seconds and end with the UI reload. I ran the update in Terminal with pacman -Syu.
Wish You well
I can not boot linux66 6.6.5. I can boot linux65 6.5.13 [EOL].
It doesn’t even show the boot process, 6.6.5.
I’ll be using a different kernel for a while.
reinstalled.
I tried reinstalling it. The kernel has been fixed. Good.
[2023-12-10T13:13:02+0900] [ALPM] reinstalled linux66-zfs (2.2.2-9)
[2023-12-10T13:13:02+0900] [ALPM] reinstalled linux66-headers (6.6.5-1)
[2023-12-10T13:13:00+0900] [ALPM] reinstalled linux66 (6.6.5-1)
[2023-12-10T12:03:41+0900] [ALPM] upgraded linux66-zfs (2.2.1-9 → 2.2.2-9)
[2023-12-10T12:03:41+0900] [ALPM] upgraded linux66-headers (6.6.3-1 → 6.6.5-1)
[2023-12-10T12:03:39+0900] [ALPM] upgraded linux66 (6.6.3-1 → 6.6.5-1)
plasma, after update octopi notifier show an AUR update but when i select update system it is showing
/bin/bash -c "yay --noeditmenu  -S [33m ;echo 'PAKtC'"
-> '--noeditmenu' is deprecated. Use '--editmenu=false' instead.
-> No AUR package found for [33m
  nothing to do
  PAKtC
if I run yay -Syu I get
-> eddie-ui: the local package (2.23.2-1) is newer than the AUR package (2.21.8-1)
nothing to do
removing noeditmenu show no update and the notifier is back to green
Looks like octopi needs an update as its using deprecated yay flags.
(there has not been any release since the 15 series in september)
Its possible if you use another supported helper as the AUR backend it may not have the same problems.
@Olli If you use Gnome too, then you maybe should edit your first Posting, to make clear this issue is mainly related to Gnome users.
probably it will follow soon (I hope) since it started after today yay update
I have faced the same “problem”. You can do it more easily in one step forcing the installation of the new dependency at the same time you update:
sudo pacman -Syu dotnet-runtime-7.0
I also use eddie-ui (AUR) 2.21.8, really strange that version 2.23.2-1 is shown up for you… because 2.21.8 is the newest stable and 2.23.2 is still Beta and shouldn’t available for you as stable package… i also looked at the official website and double checked that 2.21.8 is still the newest stable, even for AppImage.
Pinta was removed during the update, probably because DotNet framework was updated to version 8, and Pinta uses 7. After update and reboot I reinstalled Pinta without problems. DotNet framework 8 was listed as orphaned, so I could remove it.
wrong mask ?
warning: directory permissions differ on /etc/sudoers.d/
filesystem: 750  package: 755
Ignore this warning. 750 should be fine.
6 posts were split to a new topic: Problem with Wifi driver after updating
