I used to use this driver GitHub - tomaspinho/rtl8821ce for my wireless chip, with this latest update I had to go back to rtw8821-ce (installed by default in the kernel, and which often gave me problems) because right after rebooting at the end of the update the pc would tell me that it couldn’t connect to wifi then it wouldn’t respond to any command(even via tty), I had to delete the rtl8821 driver and remove rtw8821 from the blacklist. Does anyone have any idea how this is possible and if there is a solution?
You could just have tried rebuilding the package before rebooting. (Well, I say could, but you should’ve done so anyway since it’s good practise to rebuild all AUR packages after an upgrade.)
I am experiencing the same issue (aur wifi driver not working and freezing the desktop to an ugly grey) on a desktop pc with kernel 6.1.66. dkms loads this driver GitHub - RinCat/RTL88x2BU-Linux-Driver: Realtek RTL88x2BU WiFi USB Driver for Linux Updating this / re-installing did not solve anything.
BTW On Arch the same update caused the same problems.
I have rolled back the update with timeshift and not sure what to do next.
