System won’t launch
Hello there, I was using my system this evening, when I connected another HDMI to my main screen (from a second PC, I do this for work). From this moment, my principal PC wouldn’t have 2 screen at the same time.
Setup is a desktop, connected to a principal 27" screen in DP, and a secondary 23" in HDMI. And only one screen would be active at a time, the HDMI. If I unpluged it, the DP screen will be active, then, as soon as I connect the HDMI back, the DP turn off and the HDMI become the main. The DP screen is still visible in display, but even if I make him active, nothing change.
Then, I tried to reboot, with only one screen pluged, and the session won’t load anymore. After the UEFI screen, I have a black screen with the following:
/dev/sda3: recovering journal
/dev/sda3: clean, 316886/9601024 files, 5381290/30400000 blocks.
I get that this is a pretty standard message and no the problem, it’s just to situate where the boot process ends.
And then the system froze. Seems to be a graphical card issue? I did update a lot of package via Pamac today.
I just booted with the live CD, both screens works fine, but I can’t go to my system to troubleshoot the screen stuff or get info of the system… I can get info from the LiveCD, if that could help? Could this be a nVidia driver issue?
If I manjaro-chroot -a to get the system info, I can show you this:
12CPU quad core Intel Core i7-4770 (-MT MCP-) 12speed/min/max 3304/800/3900 MHz
12Kernel 5.15.60-1-MANJARO x86_64 12Up 41m 12Mem 2502.6/15874.8 MiB (15.8%) 12Storage 3.42 TiB (2.3% used)
12Procs 254 12Client Unknown Client: systemd 12inxi 3.3.23
Thanks you for reading this, hope you have some insights on this.
If you have access to TTY, you can try logging in and look for errors.
A common case is a partially updated system…
sudo pacman-mirrors -f5 && sudo pacman -Syyu
… or an unsupported kernel.
Good day to you and thank for the reply. Unfortunately, I wasn’t able to access TTY. I did reinstall my /, and I boot again, but still with only one screen…
Drivers output:
      video-nvidia            2021.11.04               false            PCI
       video-linux            2018.05.04                true            PCI
video-nvidia-470xx            2021.11.04               false            PCI
video-nvidia-390xx            2021.11.26               false            PCI
0000:00:02.0 (0380:8086:0412) Display controller Intel Corporation:
And Kernel:
Currently running: 6.1.0-1-MANJARO (linux61)
  • linux515
  • linux61
  • linux60-rt
I did a sudo pacman-mirrors -f5 && sudo pacman -Syyu, the system says there is nothing new and nothing to update.
Here is a screenshot of the configuration and main screen I had. If I press apply, both screens turn black and after a few seconds, it revert to only the HDMI one.
Do you also have the issue when booting with the 5.15 kernel?
Please provide your system information, formatted, as detailed in the guides linked above.
Yes, I had the same problem with the kernel 5.15 (it was from the live image).
Here is the complet system information, sorry about the first try.
  Kernel: 6.1.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=47876846-116b-4cc4-8606-d468435cc25c rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: MSI model: Z87 MPOWER MAX (MS-7815) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.1
    date: 04/26/2013
  RAM: total: 15.5 GiB used: 5.32 GiB (34.3%)
  Info: model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1066 high: 1678 min/max: 800/3900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1236 2: 872 3: 1363
    4: 800 5: 802 6: 980 7: 1678 8: 800 bogomips: 54416
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
    vendor: Micro-Star MSI driver: i915 v: kernel arch: Gen-5.75
    process: Intel 45nm built: 2010 ports: active: none
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0412
    class-ID: 0380
  Device-2: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: Gigabyte driver: nvidia
    v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
    status: current (as of 2022-10) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:17c8 class-ID: 0300
  Device-3: Logitech HD Pro Webcam C920 type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 3-3.2:7 chip-ID: 046d:082d
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: N/A
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 110 s-size: 444x249mm (17.48x9.80")
    s-diag: 509mm (20.04")
  Monitor-1: DP-2 size-res: N/A modes: N/A
  Monitor-2: HDMI-0 pos: primary res: 1920x1080 hz: 60 dpi: 96
    size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX 980
    Ti/PCIe/SSE2 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    driver: snd_hda_intel v: kernel bus-ID: 3-3.2:7 chip-ID: 046d:082d
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  Device-3: NVIDIA GM200 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:0fb0 class-ID: 0403
  Device-4: Logitech HD Pro Webcam C920 type: USB
  Sound API: ALSA v: k6.1.0-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0887
    class-ID: 0280
  Device-2: Intel 82574L Gigabit Network driver: e1000e v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0 chip-ID: 8086:10d3
    class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
    driver: btusb v: 0.8 bus-ID: 3-4:3 chip-ID: 8087:07da class-ID: e001
  Local Storage: total: 3.42 TiB used: 76.62 GiB (2.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1ER164
    type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 830 Series
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 3B1Q scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM003-9YN162
    type: HDD rpm: 7200 serial: <filter> rev: CC4B scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS70 rev: EX00
    dev-links: cdrom
  ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%) used: 13.53 GiB (9.5%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 47876846-116b-4cc4-8606-d468435cc25c
  ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
    used: 312 KiB (0.0%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 45FD-1779
  ID-3: /home raw-size: 300.72 GiB size: 294.93 GiB (98.08%)
    used: 63.09 GiB (21.4%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 2d689f0d-0b4f-4661-b487-01c7c60cfa2e
  ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 5ed028aa-ef1f-4241-8da5-7f0092442931
  ID-1: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ext4 label: home2
    uuid: b8e27ec3-fa1c-4c5e-9ee4-8a0ee758a8ac
  ID-2: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: ntfs
    label: R\xc3\xa9serv\xc3\xa9 au syst\xc3\xa8me uuid: E7F3E7794B69D7AA
  ID-3: /dev/sdc2 maj-min: 8:34 size: 238.38 GiB fs: ntfs
    label: Syst\xc3\xa8me uuid: F671D6381748C0F7
  ID-4: /dev/sdd1 maj-min: 8:49 size: 931.51 GiB fs: ntfs label: Disque 1
    uuid: 06D023B5D023A9BF
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
  Hub-6: 3-3:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-3.1:4 info: SteelSeries ApS Sensei Raw Gaming Mouse
    type: HID,Mouse,Keyboard driver: hid-generic,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 200mA chip-ID: 1038:1369 class-ID: 0300
  Device-2: 3-3.2:7 info: Logitech HD Pro Webcam C920 type: Video,Audio
    power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Device-3: 3-3.4:6 info: Megawin Truly Ergonomic Keyboard type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
    chip-ID: 0e6a:030c class-ID: 0300
  Device-4: 3-4:3 info: Intel Centrino Bluetooth Wireless Transceiver
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Hub-7: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-8: 4-3:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
  Hub-9: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 6-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 58 C
  Processes: 258 Uptime: 1h 28m wakeups: 0 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1344 libs: 410 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Hello,
The issue sounds a lot like this one
And i would probably go the same route as i mentioned there.
Wow, as soon as I renamed the file, and plugged the second screen, the system worked again correctly!
It didn’t saved the widget of the screen, but that no big deal. Should I keep that kscreen_BCK from now on along the newly created kscreen?
You can delete the _BCK one, but i wonder, does all still works with the new folder/files created after a reboot and disconnect/reconnect of the second Monitor?
Yes, I tried a few reboots, the system works fine now, with “both” kscreen folder.
I will mark this as solved.
Thank you both for your time and answers!
