Session is randomly resetting
Hi there. I have a fresh install of Manjaro on my MSI Bravo 15 B7ED and my XFCE session is randomly resetting itself causing me to lose a lot of time.
The screen just frozes, gets black, then the login screen reappears.
Why is this happening and how to avoid?
I do have the most recent BIOS for this laptop.
[mi@noneofurbusiness Desktop]$ journalctl --boot=-2 --priority=3 --catalog --no-pager
Σεπ 19 02:38:49 noneofurbusiness kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SBRG.EC0], AE_NOT_FOUND (20240322/dswload2-162)
Σεπ 19 02:38:49 noneofurbusiness kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240322/psobject-220)
Σεπ 19 02:38:49 noneofurbusiness kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP5.RTL8], AE_ALREADY_EXISTS (20240322/dswload2-326)
Σεπ 19 02:38:49 noneofurbusiness kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240322/psobject-220)
Σεπ 19 02:38:49 noneofurbusiness kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.PCIC], AE_ALREADY_EXISTS (20240322/dswload2-326)
Σεπ 19 02:38:49 noneofurbusiness kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.DVID], AE_ALREADY_EXISTS (20240322/dsfield-637)
Σεπ 19 02:38:49 noneofurbusiness kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN.DDID], AE_ALREADY_EXISTS (20240322/dsfield-637)
Σεπ 19 02:38:49 noneofurbusiness kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Σεπ 19 02:38:49 noneofurbusiness kernel: usbhid 3-2:1.3: can't add hid device: -71
Σεπ 19 02:38:49 noneofurbusiness kernel: usbhid 3-2:1.3: probe with driver usbhid failed with error -71
Σεπ 19 02:38:50 noneofurbusiness kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 92016610
Σεπ 19 02:38:50 noneofurbusiness kernel: ext4_test_bit(bit=4065, block=368050192) = 0
Σεπ 19 02:38:50 noneofurbusiness kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 92016622
Σεπ 19 02:38:50 noneofurbusiness kernel: ext4_test_bit(bit=4077, block=368050192) = 0
Σεπ 19 02:38:50 noneofurbusiness kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 91364782
Σεπ 19 02:38:50 noneofurbusiness kernel: ext4_test_bit(bit=7597, block=365428752) = 0
Σεπ 19 02:38:50 noneofurbusiness kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 91366150
Σεπ 19 02:38:50 noneofurbusiness kernel: ext4_test_bit(bit=773, block=365428753) = 0
Σεπ 19 02:38:50 noneofurbusiness kernel: EXT4-fs error (device nvme0n1p3): ext4_orphan_get:1420: comm mount: bad orphan inode 91357215
Σεπ 19 02:38:50 noneofurbusiness kernel: ext4_test_bit(bit=30, block=365428752) = 0
Σεπ 19 02:38:57 noneofurbusiness dbus-broker-launch[1026]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
░░ Subject: Invalid service file
░░ Defined-By: dbus-broker
░░ Support: https://groups.google.com/forum/#!forum/bus1-devel
░░ A service file is a ini-type configuration file.
░░ It has one required section
░░ named [D-BUS Service]. The section contains the required key 'Name', which
░░ must be a valid D-Bus name that is unique across all service files. It also
░░ contains at least one of the two optional keys 'SystemdService' and 'Exec',
░░ as well as optionally the key 'User'. Exec must be a valid shell command and
░░ User must be a valid user on the system.
░░ A service file should be named after the D-Bus name it configures. That is
░░ a file containing Name=org.foo.bar1 should be named org.foo.bar1.service.
░░ For backwards compatibility, we only warn when files do not follow this
░░ convention when run as a user bus. The system bus considers this an error
░░ and ignores the service file.
Σεπ 19 02:39:03 noneofurbusiness lightdm[1057]: gkr-pam: unable to locate daemon control file
Σεπ 19 02:39:03 noneofurbusiness dbus-broker-launch[1095]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
Σεπ 19 06:54:36 noneofurbusiness wireplumber[1087]: spa.alsa: Failed to enable UCM device HDMI2: no UCM verb set
Σεπ 19 06:55:52 noneofurbusiness wireplumber[1087]: spa.alsa: Failed to enable UCM device HDMI2: no UCM verb set
Σεπ 19 09:00:56 noneofurbusiness wireplumber[1087]: spa.alsa: Failed to enable UCM device HDMI2: no UCM verb set
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:1 pasid:32773)
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:  in process Xorg pid 952 thread Xorg:cs0 pid 972
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a23000 from client 0x1b (UTCL2)
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00101031
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          Faulty UTCL2 client ID: TCP (0x8)
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          MORE_FAULTS: 0x1
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          WALKER_ERROR: 0x0
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          PERMISSION_FAULTS: 0x3
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          MAPPING_ERROR: 0x0
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          RW: 0x0
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a25000 from client 0x1b (UTCL2)
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          Faulty UTCL2 client ID: CB/DB (0x0)
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          MORE_FAULTS: 0x0
Σεπ 19 09:05:30 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          PERMISSION_FAULTS: 0x0
Σεπ 19 09:05:40 noneofurbusiness kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, but soft recovered
Σεπ 19 09:05:41 noneofurbusiness systemd-coredump[11897]: [🡕] Process 952 (Xorg) of user 0 dumped core.
                                                 Stack trace of thread 972:
                                                 #0  0x0000788f358df3f4 n/a (libc.so.6 + 0x963f4)
                                                 #1  0x0000788f35886120 raise (libc.so.6 + 0x3d120)
                                                 #2  0x0000788f3586d4c3 abort (libc.so.6 + 0x244c3)
                                                 #3  0x00005eb794c2212e OsAbort (Xorg + 0x14b12e)
                                                 #4  0x00005eb794c235e7 FatalError (Xorg + 0x14c5e7)
                                                 #5  0x00005eb794c2a268 n/a (Xorg + 0x153268)
                                                 #6  0x0000788f358861d0 n/a (libc.so.6 + 0x3d1d0)
                                                 #7  0x0000788f358df3f4 n/a (libc.so.6 + 0x963f4)
                                                 #8  0x0000788f35886120 raise (libc.so.6 + 0x3d120)
                                                 #9  0x0000788f3586d4c3 abort (libc.so.6 + 0x244c3)
                                                 #10 0x0000788f33152a03 n/a (radeonsi_dri.so + 0x952a03)
                                                 #11 0x0000788f33155dac n/a (radeonsi_dri.so + 0x955dac)
                                                 #12 0x0000788f32880fa4 n/a (radeonsi_dri.so + 0x80fa4)
                                                 #13 0x0000788f328a3e1d n/a (radeonsi_dri.so + 0xa3e1d)
                                                 #14 0x0000788f358dd39d n/a (libc.so.6 + 0x9439d)
                                                 #15 0x0000788f3596249c n/a (libc.so.6 + 0x11949c)
                                                 Stack trace of thread 965:
                                                 #0  0x0000788f358d9a19 n/a (libc.so.6 + 0x90a19)
                                                 #1  0x0000788f358dc479 pthread_cond_wait (libc.so.6 + 0x93479)
                                                 #2  0x0000788f328a3eee n/a (radeonsi_dri.so + 0xa3eee)
                                                 #3  0x0000788f32880ecc n/a (radeonsi_dri.so + 0x80ecc)
                                                 #4  0x0000788f328a3e1d n/a (radeonsi_dri.so + 0xa3e1d)
                                                 #5  0x0000788f358dd39d n/a (libc.so.6 + 0x9439d)
                                                 #6  0x0000788f3596249c n/a (libc.so.6 + 0x11949c)
                                                 Stack trace of thread 964:
                                                 Stack trace of thread 976:
                                                 Stack trace of thread 975:
                                                 Stack trace of thread 952:
                                                 #0  0x0000788f359601fd syscall (libc.so.6 + 0x1171fd)
                                                 #1  0x0000788f3287809b n/a (radeonsi_dri.so + 0x7809b)
                                                 #2  0x0000788f32880b61 n/a (radeonsi_dri.so + 0x80b61)
                                                 #3  0x0000788f33139cf3 n/a (radeonsi_dri.so + 0x939cf3)
                                                 #4  0x0000788f32e78691 n/a (radeonsi_dri.so + 0x678691)
                                                 #5  0x0000788f328f9879 n/a (radeonsi_dri.so + 0xf9879)
                                                 #6  0x0000788f350d6e3a n/a (amdgpu_drv.so + 0xae3a)
                                                 #7  0x0000788f350d6fa0 n/a (amdgpu_drv.so + 0xafa0)
                                                 #8  0x0000788f350ddd47 n/a (amdgpu_drv.so + 0x11d47)
                                                 #9  0x00005eb794b45bfd BlockHandler (Xorg + 0x6ebfd)
                                                 #10 0x00005eb794c1d13e WaitForSomething (Xorg + 0x14613e)
                                                 #11 0x00005eb794b06667 n/a (Xorg + 0x2f667)
                                                 #12 0x0000788f3586ee08 n/a (libc.so.6 + 0x25e08)
                                                 #13 0x0000788f3586eecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                 #14 0x00005eb794b077c5 _start (Xorg + 0x307c5)
                                                 Stack trace of thread 963:
                                                 Stack trace of thread 974:
                                                 Stack trace of thread 981:
                                                 Stack trace of thread 966:
                                                 Stack trace of thread 973:
                                                 Stack trace of thread 980:
                                                 Stack trace of thread 967:
                                                 Stack trace of thread 970:
                                                 Stack trace of thread 971:
                                                 Stack trace of thread 1070:
                                                 Stack trace of thread 997:
                                                 #0  0x0000788f358d9c70 n/a (libc.so.6 + 0x90c70)
                                                 #1  0x0000788f358e0b68 pthread_mutex_lock (libc.so.6 + 0x97b68)
                                                 #2  0x00005eb794c204a7 n/a (Xorg + 0x1494a7)
                                                 #3  0x00005eb794c21d8a n/a (Xorg + 0x14ad8a)
                                                 #4  0x00005eb794c25449 n/a (Xorg + 0x14e449)
                                                 Stack trace of thread 978:
                                                 Stack trace of thread 982:
                                                 Stack trace of thread 969:
                                                 Stack trace of thread 968:
                                                 Stack trace of thread 979:
                                                 Stack trace of thread 977:
░░ Subject: Process 952 (Xorg) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 952 (Xorg) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Σεπ 19 09:05:41 noneofurbusiness systemd-coredump[11918]: [🡕] Process 11909 (xfsettingsd) of user 1000 dumped core.
                                                 Stack trace of thread 11909:
                                                 #0  0x00007aa81720e54b g_log_writer_default (libglib-2.0.so.0 + 0x6a54b)
                                                 #1  0x00007aa817205a68 g_log_structured_array (libglib-2.0.so.0 + 0x61a68)
                                                 #2  0x00007aa817205cdf g_log_structured_standard (libglib-2.0.so.0 + 0x61cdf)
                                                 #3  0x00005f9ed216c366 n/a (xfsettingsd + 0x6366)
                                                 #4  0x00007aa816fd8e08 n/a (libc.so.6 + 0x25e08)
                                                 #5  0x00007aa816fd8ecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                 #6  0x00005f9ed216c7b5 n/a (xfsettingsd + 0x67b5)
░░ Subject: Process 11909 (xfsettingsd) dumped core
░░ Process 11909 (xfsettingsd) crashed and dumped core.
Σεπ 19 09:05:43 noneofurbusiness wireplumber[1087]: spa.alsa: Failed to enable UCM device HDMI2: no UCM verb set
Σεπ 19 09:05:45 noneofurbusiness dbus-broker-launch[12001]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
Σεπ 19 09:05:48 noneofurbusiness lightdm[12033]: gkr-pam: unable to locate daemon control file
Σεπ 19 09:05:49 noneofurbusiness wireplumber[1087]: spa.alsa: Failed to enable UCM device HDMI2: no UCM verb set
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:2 pasid:32773)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:  in process Xorg pid 11946 thread Xorg:cs0 pid 11956
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a64000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00201031
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          Faulty UTCL2 client ID: TCP (0x8)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          MORE_FAULTS: 0x1
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          WALKER_ERROR: 0x0
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          PERMISSION_FAULTS: 0x3
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          MAPPING_ERROR: 0x0
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          RW: 0x0
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a66000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a69000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a6b000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00000000
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          Faulty UTCL2 client ID: CB/DB (0x0)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          MORE_FAULTS: 0x0
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:          PERMISSION_FAULTS: 0x0
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a6e000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a70000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a73000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a75000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a50000 from client 0x1b (UTCL2)
Σεπ 19 09:13:01 noneofurbusiness kernel: amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x0000800108a55000 from client 0x1b (UTCL2)
Σεπ 19 09:13:11 noneofurbusiness kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_0.0.0 timeout, but soft recovered
Σεπ 19 09:13:11 noneofurbusiness systemd-coredump[13719]: [🡕] Process 11946 (Xorg) of user 0 dumped core.
                                                 Stack trace of thread 11956:
                                                 #0  0x00007a5c2fb7f3f4 n/a (libc.so.6 + 0x963f4)
                                                 #1  0x00007a5c2fb26120 raise (libc.so.6 + 0x3d120)
                                                 #2  0x00007a5c2fb0d4c3 abort (libc.so.6 + 0x244c3)
                                                 #3  0x000062252835f12e OsAbort (Xorg + 0x14b12e)
                                                 #4  0x00006225283605e7 FatalError (Xorg + 0x14c5e7)
                                                 #5  0x0000622528367268 n/a (Xorg + 0x153268)
                                                 #6  0x00007a5c2fb261d0 n/a (libc.so.6 + 0x3d1d0)
                                                 #7  0x00007a5c2fb7f3f4 n/a (libc.so.6 + 0x963f4)
                                                 #8  0x00007a5c2fb26120 raise (libc.so.6 + 0x3d120)
                                                 #9  0x00007a5c2fb0d4c3 abort (libc.so.6 + 0x244c3)
                                                 #10 0x00007a5c2d352a03 n/a (radeonsi_dri.so + 0x952a03)
                                                 #11 0x00007a5c2d355dac n/a (radeonsi_dri.so + 0x955dac)
                                                 #12 0x00007a5c2ca80fa4 n/a (radeonsi_dri.so + 0x80fa4)
                                                 #13 0x00007a5c2caa3e1d n/a (radeonsi_dri.so + 0xa3e1d)
                                                 #14 0x00007a5c2fb7d39d n/a (libc.so.6 + 0x9439d)
                                                 #15 0x00007a5c2fc0249c n/a (libc.so.6 + 0x11949c)
                                                 Stack trace of thread 11951:
                                                 #0  0x00007a5c2fb79a19 n/a (libc.so.6 + 0x90a19)
                                                 #1  0x00007a5c2fb7c479 pthread_cond_wait (libc.so.6 + 0x93479)
                                                 #2  0x00007a5c2caa3eee n/a (radeonsi_dri.so + 0xa3eee)
                                                 #3  0x00007a5c2ca80ecc n/a (radeonsi_dri.so + 0x80ecc)
                                                 #4  0x00007a5c2caa3e1d n/a (radeonsi_dri.so + 0xa3e1d)
                                                 #5  0x00007a5c2fb7d39d n/a (libc.so.6 + 0x9439d)
                                                 #6  0x00007a5c2fc0249c n/a (libc.so.6 + 0x11949c)
                                                 Stack trace of thread 11957:
                                                 Stack trace of thread 11947:
                                                 Stack trace of thread 11960:
                                                 Stack trace of thread 11961:
                                                 Stack trace of thread 11954:
                                                 Stack trace of thread 11955:
                                                 Stack trace of thread 11946:
                                                 #0  0x00007a5c2fc001fd syscall (libc.so.6 + 0x1171fd)
                                                 #1  0x00007a5c2ca7809b n/a (radeonsi_dri.so + 0x7809b)
                                                 #2  0x00007a5c2ca80b61 n/a (radeonsi_dri.so + 0x80b61)
                                                 #3  0x00007a5c2d339cf3 n/a (radeonsi_dri.so + 0x939cf3)
                                                 #4  0x00007a5c2d078691 n/a (radeonsi_dri.so + 0x678691)
                                                 #5  0x00007a5c2caf9879 n/a (radeonsi_dri.so + 0xf9879)
                                                 #6  0x00007a5c2f376e3a n/a (amdgpu_drv.so + 0xae3a)
                                                 #7  0x00007a5c2f376fa0 n/a (amdgpu_drv.so + 0xafa0)
                                                 #8  0x00007a5c2f37dd47 n/a (amdgpu_drv.so + 0x11d47)
                                                 #9  0x0000622528282bfd BlockHandler (Xorg + 0x6ebfd)
                                                 #10 0x000062252835a13e WaitForSomething (Xorg + 0x14613e)
                                                 #11 0x0000622528243667 n/a (Xorg + 0x2f667)
                                                 #12 0x00007a5c2fb0ee08 n/a (libc.so.6 + 0x25e08)
                                                 #13 0x00007a5c2fb0eecc __libc_start_main (libc.so.6 + 0x25ecc)
                                                 #14 0x00006225282447c5 _start (Xorg + 0x307c5)
                                                 Stack trace of thread 11953:
                                                 Stack trace of thread 11952:
                                                 Stack trace of thread 11948:
                                                 Stack trace of thread 11959:
                                                 Stack trace of thread 11950:
                                                 Stack trace of thread 11958:
                                                 Stack trace of thread 11949:
                                                 Stack trace of thread 11970:
                                                 #0  0x00007a5c2fc028b2 epoll_wait (libc.so.6 + 0x1198b2)
                                                 #1  0x000062252835ed40 n/a (Xorg + 0x14ad40)
                                                 #2  0x0000622528362449 n/a (Xorg + 0x14e449)
                                                 #3  0x00007a5c2fb7d39d n/a (libc.so.6 + 0x9439d)
                                                 #4  0x00007a5c2fc0249c n/a (libc.so.6 + 0x11949c)
                                                 Stack trace of thread 13670:
                                                 Stack trace of thread 12036:
                                                 Stack trace of thread 12104:
                                                 Stack trace of thread 11966:
                                                 Stack trace of thread 11965:
                                                 Stack trace of thread 11964:
                                                 Stack trace of thread 11962:
                                                 Stack trace of thread 11963:
                                                 Stack trace of thread 11967:
░░ Subject: Process 11946 (Xorg) dumped core
░░ Process 11946 (Xorg) crashed and dumped core.
Σεπ 19 09:13:13 noneofurbusiness wireplumber[1087]: spa.alsa: Failed to enable UCM device HDMI2: no UCM verb set
Σεπ 19 09:13:15 noneofurbusiness dbus-broker-launch[13806]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
Σεπ 19 09:13:20 noneofurbusiness lightdm[13838]: gkr-pam: unable to locate daemon control file
Σεπ 19 09:13:21 noneofurbusiness wireplumber[1087]: spa.alsa: Failed to enable UCM device HDMI2: no UCM verb set
Σεπ 19 09:21:07 noneofurbusiness dbus-broker-launch[805]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Σεπ 19 09:21:07 noneofurbusiness nm-openvpn[2299]: event_wait : Interrupted system call (fd=-1,code=4)
Hi @overcat,
We wouldn’t know now, would we? I see this is not your first time here, so I shouldn’t have to tell you this, but:
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
And to get more specific information:
Finding errors for specific boot
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
how do I block you?
For everybody else reading this, I am not new to linux, just came around from Slackware to test and my other PC burned out so now I am stuck with Manjaro till my new one arrives.
It would be a help if somebody told me where to find the logs regarding session errors or hardware errors (I suppose this will be either a session error or some service is not starting properly) but the logs are not in the same place I am used to be finding those in Slackware or are very different.
I am new to the systemd thing.
On my profile.
And I find it HILLARIOUS that you’re asking ME how to block MYSELF because you can’t find out how to do it yourself…
But just a tip: with that kind of attitude towards someone trying to help, you won’t get far.
you didn’t try to help.
You copypasted a wall of text.
Also if you would care to watch I posted ONE post here previously in 2022 without getting an answer. Didn’t find a block function, so muted.
Have a nice day.
EDIT - I hope to find my answers here
I did:
didn’t you read?
Then your session restarted.
Could be OOM killer - but that is a guess
Ensure you have the necessary swap
thanks mate. Found the error but no idea what to do with it yet.
Plenty of SWAP here…
Here’s my inxi -Fxx
  Host: miah Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 14.2.1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 dm: LightDM
  Type: Laptop System: Micro-Star product: Bravo 15 B7ED v: REV:1.0
  Mobo: Micro-Star model: MS-158P v: REV:1.0 serial: <superuser required>
    part-nu: 158P.1 UEFI: American Megatrends LLC. v: E158PAMS.10A
    date: 07/08/2024
  ID-1: BAT1 charge: 44.3 Wh (97.4%) condition: 45.5/52.0 Wh (87.4%)
    volts: 12.9 min: 11.4 model: MSI BIF0_9 serial: N/A status: not charging
  Info: 8-core model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3+ rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
  Speed (MHz): avg: 2140 min/max: 400/4829 cores: 1: 2140 2: 2140 3: 2140
    4: 2140 5: 2140 6: 2140 7: 2140 8: 2140 9: 2140 10: 2140 11: 2140 12: 2140
    13: 2140 14: 2140 15: 2140 16: 2140 bogomips: 102270
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 24 [Radeon RX 6400/6500
    XT/6500M] vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2
    pcie: speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DP-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:743f
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 pcie:
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-2, DP-3, DP-4,
    DP-5, DP-6, DP-7, DP-8, DP-9, Writeback-2 bus-ID: 07:00.0
    chip-ID: 1002:1681 temp: 44.0 C
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 5-1:2 chip-ID: 30c9:0042
  Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: xfwm4 v: 4.18.0 driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 4480x1080
  Monitor-1: HDMI-A-1 mapped: HDMI-A-1-0 pos: left
    model: LG (GoldStar) ULTRAWIDE res: 2560x1080 dpi: 81 diag: 869mm (34.2")
  Monitor-2: eDP-1 mapped: eDP pos: primary,right
    model: ChiMei InnoLux 0x1521 res: 1920x1080 dpi: 142 diag: 394mm (15.5")
  API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: radeonsi
    device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
    LLVM 18.1.8 DRM 3.57 6.9.12-3-MANJARO) device-ID: 1002:1681
  API: Vulkan v: 1.3.279 surfaces: xcb,xlib device: 0 type: discrete-gpu
    driver: mesa radv device-ID: 1002:743f device: 1 type: integrated-gpu
    driver: mesa radv device-ID: 1002:1681
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab28
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:1640
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Micro-Star MSI driver: snd_pci_acp6x v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
  IF: eno1 state: down mac: d8:43:ae:2f:88:9d
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
  IF: wlp6s0 state: up mac: a8:3b:76:d2:0a:51
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 bus-ID: 1-3:2 chip-ID: 0e8d:0608
  Local Storage: total: 1.82 TiB used: 472.43 GiB (25.4%)
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT2000P5PSSD8 size: 1.82 TiB
    speed: 63.2 Gb/s lanes: 4 serial: 2207357B6E83 temp: 33.9 C
  ID-1: / size: 191.19 GiB used: 17.07 GiB (8.9%) fs: ext4 dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 1.51 TiB used: 455.37 GiB (29.5%) fs: ext4
    dev: /dev/nvme0n1p3
  ID-1: swap-1 type: partition size: 97.66 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p4
  System Temperatures: cpu: 53.6 C mobo: 32.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 48.0 C mem: 66.0 C fan: 0 device: amdgpu
    temp: 44.0 C
  Memory: total: 64 GiB note: est. available: 62.01 GiB used: 3.56 GiB (5.7%)
  Processes: 359 Power: uptime: 29m wakeups: 0 Init: systemd v: 256
    default: graphical
  Packages: pm: pacman pkgs: 1496 Compilers: N/A Shell: Bash v: 5.2.32
    running-in: xfce4-terminal inxi: 3.3.36
This happens totally randomly, but I noticed that more often than not, the session resets when uploading edited files to server.
I mostly use chrome, filezilla, kate, thunderbird, a VPN connection & have some music on…
Funnily it never happens when I game.
A person’s skill level (with the forum, or generally) is seldom obvious, and members will often provide helpful links and other information to assist another member to navigate.
This is never intended as an insult, although with potentially so many language difficulties and comprehension levels in play, sometimes communication suffers.
While using the Manjaro forum, we simply ask that you remember the human factor; treat others with respect; try not to take offense when none might have actually been given.
Humility.
The following is copy/pasted in the hope that it will be beneficial.
As an infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
Last, but not least, the Update Announcements, which you should check frequently for important update related information.
An issue may be directly related to a particular update; these announcements should generally be checked before posting a request for support.
Filesystem errors may have unexplainable sideeffects and may be caused by forced shutdowns or fautly memory.
To ignore or mute other users - https://forum.manjaro.org/u/overcat/preferences/users
Why? :man_shrugging:
(but your link wasn’t the direction )
It is easy to find the option.
Upon reading along, even I was inclined to block OP for their excessive reaction.
But then I decided that I would make a mental mark
and just would not care about any of their current or future troubles …
Thank you a lot, this actually helped to shed some light onto my problem.
…not
I have not come here to socialize, but to seek a solution.
I haven’t found any similar thread so I perhaps thought that somebody else might have encountered this behaviour.
It seems you have adopted the stackoverflow culture of reposting walls of text and feeling important by getting likes or whatever, instead of really wanting to help somebody with their problem.
Well, OK.
For simply asking how do I block somebody here I get a flag and my post is hidden. Gonna spend my night reinstalling my laptop on another distro, I don’t wanna be a part of this unhelpful, toxic community.
Be my guest, go flag this too.
Yes, the PC has been resetting the session a lot today, but I don’t get restarts and the SSD was brand new. I have formatted the disk running the official Manjaro install USB.
I still don’t understand why this is happening.
Are there other logs I can read to see where exactly this session reset happens?
The link would only work for OP
Other users are re-directed to https://forum.manjaro.org/u/overcat/activity
To use your own username to access your blocklist settings - https://forum.manjaro.org/u/nachlese/preferences/users
o.k.
I know how it works - have decided against it every time I was initially inclined to do it.
Will keep that mental note - confirmed to me by the recent responses of OP.
I could say something potentially helpful - but I won’t. :man_shrugging:
lovely
Wie Du in den Wald hineinrufst so schallt es heraus.
Passt scho. Könnts da ohne mich weitermachen.
Mindestens host ma ka Wall of Text hingschmissn.
Schönen Abend.
ja, pfiat di
Ich bin zwar Sachse, verstehe bayrisch aber trotzdem
Hab auch bisher nur nette Menschen von da kennengelernt.
Ich dachte ja Du hättest eine Frage oder ein Problem gehabt
welches Du allein nicht lösen konntest.
I thought you had a problem or a question which you could not resolve by yourself.
not anymore, it seems
