Session is randomly resetting
The only one being rude, unhelpful and “toxic” is you.
It’s not necessarily an easy problem to pin down, none of us are psychic, if you want help (I know not any more), people have to have enough information. They were simply requesting more information by providing information on how to do that.
You didn’t have to read it or reply…you didn’t have to be rude and “toxic” either.
No I asked for where do I find the logs on my session to analyse the problem because I am new to a systemd system.
I have posted my logs and all I got was a wall of (unhelpful) text, a flag for asking how to block/mute here.
As I see it I was not rude at all.
Yes, I am now pretty pissed for all of this AND not being able to use my laptop properly.
I don’t have time for this drama, so the logical step is to reinstall with a distro without systemd, where the community actually is nice, down to earth and straightforward, and I can read the logs and solve my own problems, which is, as it seems, my only option, even if it means I’l be 2-3 days late with my work.
As you said, you are not willing to help me with my problem, so I’ll live with that.
Best regards from Vienna.
I’m willing.
but:
your displayed attitude puts me off.
The initial response from @Mirdarthos surely was intended to be helpful - not to mock you.
Wien - der Akzent ist für mich zwar klar zu unterscheiden.
Bayrisch war nur eine Annahme basierend auf den paar Worten von Dir.
… andere würden fragen:
WTF is wrong with you?
You are the one asking for assistance. …
It certainly felt like he was mocking me.
Where is Brahma when one needs him…
I don’t think I have the same problem as here tho…
you started with the german and austrian and bayerisch are indeed similar
ad/… andere würden fragen:
Well, this doesn’t happen to me on the other forum with the other distro, as said I was only testing Manjaro on my backup laptop and now I am stuck with it and perhaps thought I might give it a go… So yeah, it was a neat experience here. Thank you for having me.
You where welcome.
… only speaking for me …
… and I don’t even use Manjaro myself - I just like to help people who do
Much appreciated.
EDIT
I got to a solution with the help of chatGPT and reddit like
1/
https://www.reddit.com/r/MSILaptops/comments/1c8t1gl/comment/l47m1go/
It’s very simple to solve. It’s something related to the bios. Get into the bios, disconnect the laptop from the power source, press the power on button for 30 secs until it flashes Three times. If you did it well, the machine won’t turn on again until you connect the charger again. Start it up, and problem solved. The issue started when the machine run low charge while disconnect doesn’t it? I and many people had the same, but it’s not the big deal.
which really helped with all the ACPI BIOS errors.
I can monitor my logs with
journalctl -xe or journalctl -f
and check for duplicate sessions with
pgrep -fl xfsettingsd
pkill xfsettingsd
xfsettingsd --replace &
and session errors with
cat ~/.xsession-errors
I also deleted the duplicate d-bus thing.
org.freedesktop.Notifications is the standard D-Bus service name used for notifications across different Linux desktop environments. Keeping this one ensures compatibility with applications that rely on the standard notifications interface.
On the other hand, org.xfce.Notifyd is likely a legacy or XFCE-specific name that might no longer be necessary. It’s safe to remove or rename this file.
