Pamac is broken
Dear people,
i cant use pamac anymore, meaning i cant do any updates manually and i cant install any programs. I had the problem before that something was wrong an i searched it up and found a few things here on the manjaro forum that i tried, but somehow it got worse. When i try to install something i get this message: Process could not be prepared successfully, destination not found: …
As for updates i get: My database is corrupted or something.
I hope you can help me.
Best regards
Please note that pamac is only one of the options for updating and installing. The native package manager for Arch-based distributions is pacman — which is a command-line-only tool — and yay for AUR stuff. In addition to that, if you want a graphical package manager front-end, then you can also use octopi, although that doesn’t come installed by default anymore.
The above all in mind, you can update your system with… :point_down:
sudo pacman-mirrors -f && sudo pacman -Syyu && yay -Su
That all said, even though pamac is a bit of a problem child, we can only help you debug the problems you’re having with it if you give us the exact and correct information of why you cannot use it anymore. This means that we need to see the error messages verbatim.
Please take a minute to read these two posts… :point_down:
… and perhaps also this one… :point_down:
Hi @zuluugugulumugu, and welcome!
Seeing as my, and I expect many people here’s crystal ball is malfunctioning, we need more information from you. More specifically error messages. So please provide the error message exactly as it’s shown to you. And seeing as you’re new here:
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
I see, so i already provided you with the error messages. Please tell me what you need exactly.
What does the crystal ball mean? Is it amateurish behavior or sth?
i did this command, nothing really changed
Please don’t use made-up abbreviations. See:
This: :point_down:
Is not an error message.
It means your topic is assuming we can read your mind - which we cannot - and we don’t understand what you are saying.
Please elaborate - and don’t even think of using images.
Please see
Oh right, i thought you can. Sorry.
Well, that’s why we need the error messages as described previously.
So the exact error message is:
invalid or corrupted database.
Its not in the terminal.
Sorry, i understand you guys now.
Meanwhile, im trying to find the thread i tried the commands from or is there something better i can help you with?
Its by the way only the flatpak, aur and snap packages i install manually that arent working right now.
Search results for 'invalid or corrupted database' - Manjaro Linux Forum.
Selfcontained apps in snap and flatpak format is only supported by whoever created it.
Custom packages from AUR should only be used with Manjaro unstable branch
Please provide the output to the following:
pamac checkupdates --force-refresh
And please, run it from a terminal so you can copy-and-paste the output.
found the thread, this is what i did
i did it because the thing with the updates was there before so when i tried to update manually i didnt work and i got the error message i mentioned before. It worked for a few days, but now like i said i cant install things.
The best way to get your system corrupted is by installing packages without updating your system first.
What is the output of… :point_down:
inxi -Fazy
Please see reread these commants #15 and #8
Its long, im sorry, but can you tell me what output you need exactly.
I think this thread goes really wrong here. We should go back to basics and understand what the problem here is. Pamac is a graphical program, but also can be used as a terminal program to update your system and also install additional software thru flatpak and snaps plus the AUR.
The best thing is to turn all those 3rd party options in settings off and try to do a system update. @zuluugugulumugu you can simply open a terminal window and issue pamac update and post the result. Also checking your /var/log/pacman.log file will give you a clue which updates were done on the OS side of things. Snaps and Flatpaks are separate systems of how you can install software. The AUR may interfere with regular OS updates.
Posting the output of inxi -Fazy will give a general idea of your system.
Article to read: https://www.makeuseof.com/how-to-open-terminal-in-linux/
