[HowTo] Work around gpg verification issue on left behind systems
Difficulty: ★☆☆☆☆
This script is the result of people here in the forum having problems with Manjaro installations that haven’t been updated for more than 2 months or booting an old ISO plus installing it which is older than 2 months. I was a bit tired of explaining how to solve that issue and created a script, which does the job.
Methods
Method 1 - Basic
  1. Remove lock files of pamac and pacman
  2. Refresh Package Database
  3. Populate local keyrings to the GnuPG Database of pacman
  4. Refresh GnuPG Database of pacman from the Internet [optional]
  5. Performing a full upgrade with pacman [optional]
Method 2 - Moderate
  2. Remove Pacman’s GnuPG Database
  3. Initilize Pacman’s GnuPG Database
  4. Populate local keyrings to Pacman’s GnuPG Database
  5. Refresh GnuPG Database of pacman from the Internet [optional]
  6. Remove cached software packages [optional]
  7. Performing a full upgrade with pacman [optional]
Method 3 - Aggressive
  2. Switch to global mirror (Manjaro’s CDN)
  3. Remove Pacman’s GnuPG Database
  4. Initilize Pacman’s GnuPG Database
  5. Remove cached software packages
  6. Create a temporary folder in /tmp
  7. Copy /etc/pacman.conf to TMPDIR/pacman.conf and disable temporarily gpg verification.
  8. Download the newest packages which contains the gpg keyrings in TMPDIR
  9. Install temporarily downloaded keyring packages
  10. Remove temporary directory TMPDIR
  11. Switch to a local mirror by Geolocation
  12. Refresh GnuPG Database of pacman from the Internet [optional]
  13. Performing a full upgrade with pacman [optional]
Addition: Fix GPGme Errors
  1. Remove all Signatures at /var/lib/pacman/sync/
  2. Remove all Signatures at /var/cache/pacman/pkg/
  3. Remove lock files of pamac and pacman
  4. Refresh Package Database
The third one is just the original old script. Method 1 and 2 are inspired by [HowTo] Solve Keyring Related Issues in Manjaro
Added an automated fix for gpgme errors like here described: [root tip] [How To] Mitigate and prevent GPGME error when syncing your system
In a nutshell:
curl requests a *.sig file and the server responds with 200 [OK], but has sent an HTML file with the message 404 [NOT FOUND], although it should respond with the status code 404 [NOT FOUND].
So an incorrectly configured server.
Now there are signature files that have HTML content. This leads to problems with pacman, as pacman cannot do anything with them, but wants to check the databases with the “signatures” that have the wrong content. This means that no update can be carried out here. You should delete the corresponding signature files with incorrect content.
Script
###START###
#!/usr/bin/env bash
set -o errexit  #>Exit when a command fails (returns non-zero)
set -o pipefail #>Exit when a command within a pipeline fail (returns non-zero)
set -o nounset  #>Forbid to use unset
# Reset language to default
export LANG=C
export LC_ALL=C
# Switch to root account
RunasRoot () { sudo --login --user=root "$@"; }
# Colors for messages
PrintInfo () { printf '\e[32m[INFO]\e[0m \e[33m%s\e[0m\n' "$1"; }
PrintError () { printf '\e[31m[ERROR]\e[0m \e[33m%s\e[0m\n' "$1"; }
PrintQuestion () { printf '\e[35m[QUESTION]\e[0m \e[33m%s\e[0m\n' "$1"; }
RmLockFiles ()
   PrintInfo "Remove lock files of pamac and pacman"
   ##Seems to be obsolete
   #RunasRoot find /var/tmp/pamac/ -type f -iname "*db.lck" -exec rm --force --verbose "{}" \;
   RunasRoot find /var/lib/pacman/ -type f -iname "*db.lck" -exec rm --force --verbose "{}" \;
AskForUpgrade ()
   PrintInfo "Performing a full upgrade with pacman"
   while true; do
      PrintQuestion "Do you want to continue? [Yy/Nn] (Be aware that a full upgrade needs enough ram on a live session)"
      read -p "> [Yy/Nn] " yn
      case $yn in
      [Yy]*)
         RunasRoot pacman --sync --refresh --refresh --sysupgrade --sysupgrade --noconfirm
         PrintInfo "Done. Note that you need to refresh the database for pamac also."
         break
      [Nn]*)
         break
         break
      esac
   done
AskForRefreshKeys ()
   PrintInfo "Refresh GnuPG Database of pacman from the Internet"
   while true; do
      PrintQuestion "Do you want to continue? [Yy/Nn] (Note that this can take a while.)"
      case $yn in
      [Yy]*)
         RunasRoot pacman-key --refresh-keys
         break
      [Nn]*)
         break
         break
      esac
   done
AskForRemoveCache ()
   PrintInfo "Remove cached software packages [optional]"
   while true; do
      PrintQuestion "Delete them? [Yy/Nn]"
      read -p "[Yy/Nn] > " yn
      case $yn in
      [Yy]*)
         PrintInfo "Removing package cache"
         RunasRoot pacman --sync --clean --clean --noconfirm
         if [[ $(ls /var/cache/pacman/pkg/ | wc -l) != 0 ]]; then
            RunasRoot find /var/cache/pacman/pkg/ -type f -exec rm --force --verbose "{}" \;
         fi
      [Nn]*)
         break
         fi
      esac
   done
BasicMethod ()
   RmLockFiles
   PrintInfo "Refresh Package Database"
   PrintInfo "Populate local keyrings to the GnuPG Database of pacman"
   RunasRoot pacman-key --populate archlinux manjaro
   AskForRefreshKeys
   AskForUpgrade
ModerateMethod ()
   RmLockFiles
   PrintInfo "Remove Pacman's GnuPG Database"
   RunasRoot find /etc/pacman.d/gnupg/ -exec rm --recursive --force --verbose "{}" \;
   PrintInfo "Initilize Pacman's GnuPG Database"
   RunasRoot pacman-key --init
   PrintInfo "Populate local keyrings to Pacman's GnuPG Database"
   AskForRefreshKeys
   AskForRemoveCache
   AskForUpgrade
AggressiveMethod ()
   RmLockFiles
   PrintInfo "Switch to global mirror (Manjaro's CDN)"
   RunasRoot pacman-mirrors --country Global
   RunasRoot pacman-mirrors --fasttrack 5
   fi
   PrintInfo "Create a temporary folder in /tmp"
   TMPDIR="$(mktemp -d)"
   RunasRoot chmod -R 755 "${TMPDIR}"
   RunasRoot chown -R root:root "${TMPDIR}"
   PrintInfo "${TMPDIR}"
   PrintInfo "Copy /etc/pacman.conf to ${TMPDIR}/pacman.conf and disable temporarily gpg verification."
   RunasRoot cp "/etc/pacman.conf" "${TMPDIR}/pacman.conf"
   RunasRoot sed --in-place --regexp-extended 's/^(SigLevel).+$/\1 = Never/g' "${TMPDIR}/pacman.conf"
   PrintInfo "Download the newest packages which contains the gpg keyrings in ${TMPDIR}"
   RunasRoot pacman --sync --refresh --downloadonly --noconfirm --cachedir "${TMPDIR}" --config "${TMPDIR}/pacman.conf" archlinux-keyring manjaro-keyring gnupg --overwrite "*"
   PrintInfo "Install temporarily downloaded keyring packages"
   RunasRoot pacman --upgrade --noconfirm --config "${TMPDIR}/pacman.conf" --overwrite "*" $(find ${TMPDIR} -type f -name "*.tar.*")
   PrintInfo "Remove temporary directory: ${TMPDIR}"
   RunasRoot find "${TMPDIR}" -type f -exec rm --recursive --force --verbose "{}" \;
   RunasRoot rmdir --verbose "${TMPDIR}"
   PrintInfo "Switch to a local mirror by Geolocation/Timezone"
   RunasRoot pacman-mirrors --timezone
   AskForRefreshKeys
   AskForUpgrade
FixGPGmeERROR ()
  PrintInfo "Remove all Signatures at /var/lib/pacman/sync/"
  RunasRoot find /var/lib/pacman/sync/ -type f -name "*.sig" -exec rm --force --verbose "{}" \;
  PrintInfo "Remove all Signatures at /var/cache/pacman/pkg/"
  RunasRoot find /var/cache/pacman/pkg/ -type f -name "*.sig" -exec rm --force --verbose "{}" \;
  RmLockFiles
  AskForUpgrade
HelpPage ()
   printf "\n\t%s\n" "Method 1 - Basic"
   printf "\t%s\n" "1. Remove lock files of pamac and pacman"
   printf "\t%s\n" "2. Refresh Package Database"
   printf "\t%s\n" "3. Populate local keyrings to the GnuPG Database of pacman"
   printf "\t%s\n" "4. Refresh GnuPG Database of pacman from the Internet [optional]"
   printf "\t%s\n" "5. Performing a full upgrade with pacman [optional]"
   printf "\n\t%s\n" "Method 2 - Moderate"
   printf "\t%s\n" "2. Remove Pacman's GnuPG Database"
   printf "\t%s\n" "3. Initilize Pacman's GnuPG Database"
   printf "\t%s\n" "4. Populate local keyrings to Pacman's GnuPG Database"
   printf "\t%s\n" "5. Refresh GnuPG Database of pacman from the Internet [optional]"
   printf "\t%s\n" "6. Remove cached software packages [optional]"
   printf "\t%s\n" "7. Performing a full upgrade with pacman [optional]"
   printf "\n\t%s\n" "Method 3 - Aggressive"
   printf "\t%s\n" "2. Switch to global mirror (Manjaro's CDN)"
   printf "\t%s\n" "3. Remove Pacman's GnuPG Database"
   printf "\t%s\n" "4. Initilize Pacman's GnuPG Database"
   printf "\t%s\n" "5. Remove cached software packages"
   printf "\t%s\n" "6. Create a temporary folder in /tmp"
   printf "\t%s\n" "7. Copy /etc/pacman.conf to TMPDIR/pacman.conf and disable temporarily gpg verification."
   printf "\t%s\n" "8. Download the newest packages which contains the gpg keyrings in TMPDIR"
   printf "\t%s\n" "9. Install temporarily downloaded keyring packages"
   printf "\t%s\n" "10. Remove temporary directory TMPDIR"
   printf "\t%s\n" "11. Switch to a local mirror by Geolocation"
   printf "\t%s\n" "12. Refresh GnuPG Database of pacman from the Internet [optional]"
   printf "\t%s\n" "13. Performing a full upgrade with pacman [optional]"
   printf "\n\t%s\n" "Addition: Fix GPGme Errors"
   printf "\t%s\n" "1. Remove all Signatures at /var/lib/pacman/sync/"
   printf "\t%s\n" "2. Remove all Signatures at /var/cache/pacman/pkg/"
   printf "\t%s\n" "3. Remove lock files of pamac and pacman"
   printf "\t%s\n" "4. Refresh Package Database"
   printf "\t%s\n" "5. Performing a full upgrade with pacman"
   printf "\n\t%s\n\n" "Note: That tool is not designed to fix gpg issues with your local user GnuPG Database, which is commonly used for AUR Packages as an example."
HelpUsage () { printf '\e[32m%s\e[0m\n' "$0 [--usage|--help|--basic|--moderate|--aggressive|--fixgpgme|--ask] (default: [--basic])"; }
Menu ()
   clear
   while true; do
      printf '\e[33m%s\e[0m\n' "1. Basic"
      printf '\e[33m%s\e[0m\n' "2. Moderate"
      printf '\e[33m%s\e[0m\n' "3. Aggressive"
      printf '\e[33m%s\e[0m\n' "4. Addition: Fix GPGme Errors"
      printf '\e[33m%s\e[0m\n' "5. Explanations of the methods"
      printf '\n\e[33m%s\e[0m\n\n' "Type [q] to quit."
      PrintQuestion "Choose a Method by typing the number and press ENTER on your keyboard."
      read -p "[1,2,3,4,q]>  " choice
      case $choice in
         1)
            BasicMethod && exit
         2)
            ModerateMethod && exit
         3)
            AggressiveMethod && exit
         4)
            FixGPGmeERROR && exit
         5)
            HelpPage && continue
         q)
            exit
            clear && PrintError "No valid answer. Continue." && continue ;;
      esac
   done
[[ -z $@ ]] && Menu && exit
case $1 in
   --basic)
      BasicMethod && exit
   --moderate)
   --aggressive)
   --fixgpgme)
   --help)
      HelpUsage && HelpPage && exit
   --usage)
      HelpUsage && exit
   --ask)
      Menu && exit
      PrintError "\"$1\" is not a valid parameter. See \"$0 --usage\""
esac
###END###
You could run it like that:
# No argument/parameter will default to "--ask"
export FILE=$(curl -s "https://forum.manjaro.org/raw/125822" | sed -n -r '/^###START###$/,/^###END###$/p')
bash <(<<<"$FILE")
bash <(<<<"$FILE") --help
bash <(<<<"$FILE") --usage
bash <(<<<"$FILE") --ask
bash <(<<<"$FILE") --basic
bash <(<<<"$FILE") --moderate
bash <(<<<"$FILE") --aggressive
bash <(<<<"$FILE") --fixgpgme
This is a wiki article and you are invited to make the script better or add more explanations or anything else.
Pacman package *corrupted
Error when updating manjaro
Pacman/Pamac - Invalid or corrupted database
Can not open Electron based applications
Pgp error beim Versuch testdiskim liveusb system zu installieren
Error when installing hydra
"untrusted keys" and "corrupted"
Package is corrupted (invalid or corrupted package (PGP signature))
Dropbox: package missing required signature
Invalid or corrupted database (pgp signature) error
Kernel update failed + new kernel is not installing
Trouble upgrading kernel from 511 to 515
Pacman macht Probleme
Getting invalid or corrupted package (PGP signature) error when updating
Cant Update Manjaro
Pacman fails because of missing keys
Brave can't share screen
Python application doesn't find tkinter but it's installed
I can't update anything, i dont know what to do
Probleme bei der Systemaktualisierung
Update Issue on PGP signature
Error manjaro-keyring
Failed to build gcc11
Invalid or corrupted database when updating
Pamac gui software center - reset to "factory defaults"
Pacman-key --refresh-keys always hangs on the same key
Can’t import keys (Stable Update 2023-07-10)
Fehler mit glibc und glibc-locales nach Installation und Systemupdate
No logro actulizar el error sigue
Can't install manjaro-keyring, arch-keyring : package missing required signature
Tensorflow-opt-cuda signature error
PGP errors when trying to update. Can't update fresh install
Manjaro looks strange after last stable update
Package kde-applications-meta not installing
Unable to update. Signatures not trust
[Testing Update] 2024-08-16/18 - Kernels, KDE Frameworks, Mesa, Cosmic, GNOME, Phosh
Can't install gPodder
Update Error PGP Signature
Pacman is not updating : invalid or corrupted database (PGP signature)
Unable to use pacman-mirrors
Error firma PGP
Error: firefox: signature from "Jan Alexander Steffens (heftig) <heftig@archlinux.org>" is unknown trust
Invalid or Corrupted packages (PGP signatures)
PGP signature error with 2024-07-01 update
Error: archlinux-keyring: signature from is unknown trust
Signature errors
Error on system update
I can't update manjaro kde
My system demanjaroed itself
Beschädigte Datenbank (PGP-Signatur)
Update Fehler, bzw. Probleme
Invalid or corrupted database (PGP signature) - 2025-03-05 Stable Update
Keine Updates für manjaro gnome seit April
Archlinux keyring fails to update
Getting "invalid or corrupted package (PGP signature)" error
Marginal Trust invalid or corrupt package Error while updating manjaro
Invalid or corrupted database (PGP signature), Need Help
Having trouble updating with pacman - corrupted signatures
Pacman gone now after update and now can't enter the OS?
Error: manjaro-keyring: signature is unknown trust
Invalid or corrupted package (PGP signature) --- Why
Manjaro: failed to commit transaction (invalid or corrupted package (PGP signature))
I can't install any software through Add/Remove software
thank you so much I tried fixing the signatures using commands, and by fixing them manually, but it didn’t work then I used 1,2,and 3. I almost lost hope, but 3 fixed it. you’re the best
